Posted: Sat Apr 26, 2008 8:20 am Post subject: The accident versus ready to fly aircraft |
Hi guys,
Yesterday, my over zealous “spam-protection” ate a dozen emails that
were sent me on this issue, so I’m going to try a blanket answer with a
“do not archive” that only reflects my view. If there was a specific
technical question on an item, please do not hesitate to resend your
email. Thanks again, Larry McFarland
Professionally, I’ve only “studied” fatigue testing and failure on
mechanical and structural elements, so I’m not qualified to make any
statements that could prove anything. That experience did provide
valuable insight on a few of the things seen in the images. After
reading the NTSB sequence of events, I put the images on my computer to
take an only slightly closer look via Photoshop, and did come to some
conclusions on the damage characteristics. NTSB may offer a general
statement, but the specific cause may never be answered in their report
unless they take time to thoroughly investigate manufacture process,
assembly errors and variant materials in the plane.
The observed leveling and low altitude suggests the pilot was aware of a
progressive structural failure.
Complete failure of the center section front spar between and below the
end points is telling. Bending stresses causing the center spar web and
caps to crack and separate along lines nearly parallel to it, given the
flight path, was progressive. Impact would not likely push or pull a
long fractured line in the same direction as the design stress, but the
length of center spar fracture and break up was so complete that it
suggests that the shock that permitted folding wing(s) began here.
The loss of a rear spar attachment and flap could very well create
excessive stress on the front spar, break the bottom caps, and initiate
collapse of the wing(s).
The clean sheared rivet lines on the bottom spar cap versus the material
that was last to tear from the top cap suggests that the web to cap line
was torn from between the spar caps before being separated from the
fuselage. Extensive separation of the center spar from top and bottom
components far exceeds the damage seen in the wing, still attached. The
fractures are not peeled and are parallel with the line of stress and
are seen in the straight portions of still connected web and upper cap
image 27. Broken out bolt holes are clean and likely impact related. The
origin of failure is nearer the front lower spar cap and web than within
the wing.
. The original still flying XL demo plane is representative of all the
XLs flying today and it strongly argues the case for a defective
material or construction process by the actual foreign manufacturer of
the quick-build or ready to fly aircraft. It’s not the result of a
defective design material or process call out in the Zenith plans.
Example: If pre-punched holes for the spar web didn’t match the caps,
would the manufacturer just drill open the holes and continue to rivet?
Very possible for people paid on product-volume, but I doubt a kit
builder or scratch builder would ever tolerate such practice.
I believe the plans to be “golden” and safe for both the kit and the
scratch builder. The 601XL is a fine aircraft that will be around for a
long time, so stay the course and keep on building.
<http://www.macsmachine.com/> Do not archive
cookwithgas
Posted: Sat Apr 26, 2008 9:57 am Post subject: Re: The accident versus ready to fly aircraft |
Thanks Larry for your thoughtful input.
This morning I put just over an hour on my 601XL and felt very good about it. It flies like a dream and I have to pinch myself because I can't believe I built it and that it flies that well.
I did a more thorough than usual pre-flight and found everything to be solid and tight. The design is good and all the hard work has paid off with a very nice aircraft.
For those still building, don't be discouraged. Do quality work and you will have a well-built, safe aircraft.
Scott Laughlin
601XL/Corvair
Finished & Flying as much as possible.
amyvega2005(at)earthlink. Guest
Posted: Sat Apr 26, 2008 1:01 pm Post subject: The accident versus ready to fly aircraft |
Righ ON! I just came back from flying and I as well am inspecting the plane throughout. Scott please send more pics of your flying, I love those vids! Sorry I missed you at the BBQ!
Juan
wjones(at)brazoriainet.co Guest
Posted: Sat Apr 26, 2008 1:42 pm Post subject: The accident versus ready to fly aircraft |
Hello all you newly licensed 601XL pilots . Did you use DARs or FAA ,if so
was any special inspection requirements imposed since 3/1/08 . My local DAR
said that he received information from the FAA that he must check to see if
any additional inspection requirements apply to the 601XL .
Wade Jones South Texas
601XL plans building
Cont. 0200
Posted: Sat Apr 26, 2008 2:27 pm Post subject: The accident versus ready to fly aircraft |
Wade,
we went to a DAR, and my thoughts on your DAR's comment, Go to another DAR.
JUan
cookwithgas
Posted: Sat Apr 26, 2008 3:31 pm Post subject: Re: The accident versus ready to fly aircraft |
I used the FAA. LOOONG wait and very picky. My inspector told me that if I flew with my ever-so-slightly-slanted N-numbers that he would write me up. Never mind that I bought them from Aircraft Spruce specially made. His interpretation of "block letters" is plumb vertical with no slant. While he was there he did a ramp inspection on a crop duster and busted him.
I sent my paperwork off in May and I got my pink slip in December, 2007.
sdthatcher
Joined: 13 Mar 2008 Posts: 91 Location: Port Saint Lucie
Posted: Sun Apr 27, 2008 6:23 am Post subject: The accident versus ready to fly aircraft |
Just a quick note for those who are concerned about flying their 601XL amid
the recent accident paranoia (I include me as well).
Use a Borescope: The 601XL that sustained vibration damage during a
descending turn and who has successfully repaired that damage has mentioned
that prior to his first flight, he used a borescope to inspect the inside of
the wing, spar and caps, and found them in excellent condition. He was
planning to fly shortly.
Nylon Flap Stop: Also, another reminder to be sure you have installed the
nylon flap stops as indicated in the plans. I have seen two aircraft without
them and one stated that he felt vibration in the wing during cruise flight!
The flaps should not exhibit any movement whatsoever when in the up position
and the nylon stop guarantees that condition will apply. Naturally, when you
lower the flaps, there is a certain amount of movement however the speed at
which you lower the flaps is (should be) significantly lower.
Getting ready for first flight this month!
Scott Thatcher, Palm Beach Gardens, FL
601XL with Corvair, Registered as E-LSA
N601EL, http://placestofly.com, EAA203
_________________ Scott Thatcher, Port Saint Lucie, FL
N601EL, EAA203 140 hours and not flying currently. |
notsew_evets(at)frontiern Guest
Posted: Sun Apr 27, 2008 7:01 am Post subject: The accident versus ready to fly aircraft |
ok, I give... What Flap stop ?????
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Sun Apr 27, 2008 7:39 am Post subject: Re: The accident versus ready to fly aircraft |
| sdthatcher wrote: | The 601XL that sustained vibration damage during a
descending turn and who has successfully repaired that damage has mentioned that |
What vibration damage...?
This sounds like another data point.
And something we should add to the list of things to check.
Patrick
XL/Corvair
N63PZ (reserved)
Jaybannist(at)cs.com Guest
Posted: Sun Apr 27, 2008 7:51 am Post subject: The accident versus ready to fly aircraft |
Steve,
See Drawing 6-S-3.
Jay in Dallas
Posted: Sun Apr 27, 2008 8:06 am Post subject: The accident versus ready to fly aircraft |
OMG !
I love this website !!!
SW
sdthatcher
Posted: Sun Apr 27, 2008 6:14 pm Post subject: Re: The accident versus ready to fly aircraft |
<<What vibration damage...?
<<This sounds like another data point.
<<And something we should add to the list of things to check.
<<Thanks,
<<Patrick
<<XL/Corvair
<<N63PZ (reserved)
Hi Patrick. A 601XL sustained rapid vibrations of the wings during a descending turn. I published the data on this site some time ago but the summary basically stated that a fix was attempted to a damaged rudder which shifted the CG of the rudder rearward and may have contributed to the vibrations which went through the fuselage and wings and may have been exacerbated by pilot induced response to the vibrations.
If you were referring to the flaps, this was mentioned to me by another pilot while visiting a hangar that housed a 601XL and was missing the nylon flap stops.
lgingell
Joined: 10 Jan 2006 Posts: 50 Location: Lake California Airpark 68CA
Posted: Mon Apr 28, 2008 9:06 am Post subject: Re: The accident versus ready to fly aircraft |
My 6-S-3 from 12/03 has no nylon flap stops on it. Someone care to post a scan?
..lance
_________________ Zodiac XL/Jab 3300
http://lancegingell.com |
Posted: Mon Apr 28, 2008 10:25 am Post subject: The accident versus ready to fly aircraft |
I didnt think mine did either til I looked again. It shows a 90 by 25 mm
1/8 nylon piece (2) that goes under the flange of the drag spar . I removed
the three rivets from point of rib 7 outwards....
Whalla! I have a stop....
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Mon Apr 28, 2008 11:17 am Post subject: Re: The accident versus ready to fly aircraft |
Flap Stop comment - The nylon stop does a good job of preventing movement of the retracted flap at the outboard end, while the inboard end is restrained by the actuating pin which rests in a slot. I am considering installing a second stop at the inboard end to make it even more solid.
Comments?
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Mon Apr 28, 2008 12:24 pm Post subject: The accident versus ready to fly aircraft |
Sounds like an excellent idea Tim...
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Mon Apr 28, 2008 12:48 pm Post subject: The accident versus ready to fly aircraft |
Steve
Along the same lines of general enlightenment, a while back you mentioned
"drag spar" in one of your posts. I assume from the context that the drag
spar is the rear spar. Is that correct? Thanks.
Terry
At 09:02 AM 4/27/2008 -0700, you wrote:
| Quote: | OMG !
SW
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Posted: Mon Apr 28, 2008 1:11 pm Post subject: The accident versus ready to fly aircraft |
Yes em.
Wings have "usually" two spars per side. The main spar and the drag
spar....
"Some" designs these days have a humongous main spars and dont have a drag
spar.
These terms are from the 1940s til ???...
Whatever they call them now is "what it is", my man...
SW
ashontz
Posted: Mon Apr 28, 2008 1:12 pm Post subject: Re: The accident versus ready to fly aircraft |
This is probably one of the more informative threads I've read on here in awhile. Thanks. Possible problems make more sense now. More than likely, the only problem is bad maintenance or construction.
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Mon Apr 28, 2008 3:55 pm Post subject: Re: The accident versus ready to fly aircraft |
Tim,
It might work, but I think it could have the opposite effect. By having the stop along way from the flap actuating lever, the flap is allowed to twist a little in the up position so that it's solidly held. By putting a stop inboard, there won't be any twist and you may have it held firm on the inboard side but the flexibility of the flap will allow it to just rattle against the other stop. If they could be adjusted so that the outboard one engaged first, allowed the flap to twist or spring a little, then the inboard one touches it might work. All this just to say, I don't think your idea is a simple slam dunk.
Dan
| Quote: | ="Tim Juhl"]Flap Stop comment - The nylon stop does a good job of preventing movement of the retracted flap at the outboard end, while the inboard end is restrained by the actuating pin which rests in a slot. I am considering installing a second stop at the inboard end to make it even more solid.
Comments?
Do not archive |
_________________ Scratch building XL with Corvair Engine |
