		skidmk
  Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
				 Posted: Tue Apr 29, 2008 4:41 pm    Post subject: Gliding range specs for Nanchang |
				Hi all,,
 doing a bit of an aircraft profile for my anywhere map... was looking for gliding specs on the chang?  anyone?
 thanks
  _________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
		dougsappllc(at)gmail.com Guest
				 Posted: Tue Apr 29, 2008 5:52 pm    Post subject: Gliding range specs for Nanchang |
				Glides like a wet anvil if the prop is not turning.
  On Tue, Apr 29, 2008 at 5:41 PM, skidmk <bourgem(at)cia.com (bourgem(at)cia.com)> wrote:
  [quote]--> Yak-List message posted by: "skidmk" <bourgem(at)cia.com (bourgem(at)cia.com)>
 Hi all,,
 thanks
 Ottawa, Ontario
 http://forums.matronics.com/viewtopic.php?p=180147#180147
 Always Yakin,
 Doug Sapp
 Phone 509-826-4610
 Fax 509-826-3644   [quote][b]
		talew(at)bellsouth.net Guest
				 Posted: Tue Apr 29, 2008 6:20 pm    Post subject: Gliding range specs for Nanchang |
				Doug knows from experience.
  Believe it!
  A careful search of the archives seemed to indicate  that if you throw your car keys out when the engine quits that is your landing  target. Anything else is stretching it .
  Terry
  [quote]   ---
		threein60(at)yahoo.com Guest
				 Posted: Tue Apr 29, 2008 6:38 pm    Post subject: Gliding range specs for Nanchang |
				When I had an engine out in my cj, it seemed like the glide ratio was 1 to 1.  It might be more be more but it sure felt like 1 to 1.
 Larry
		cjpilot710(at)aol.com Guest
				 Posted: Tue Apr 29, 2008 6:42 pm    Post subject: Gliding range specs for Nanchang |
				I don't remember ever seeing tables on the CJ's gliding distance.  You  could most likely theoretically work it with known figures like gross weight,  airfoil data, and wing area.  A bit out of my league.  However in  playing with my CJ, I found that if I pick a spot on the ground 1/3 the  distance in from the wing tip - I can make that spot in a clean glide, with  a wind-milling engine.  That's for just about any altitude too.   NOTE:  I have an M-14p with a paddle prop.  I suspect the Chinese  metal prop would give you a somewhat better glide.
  Jim "Pappy" Goolsby
 Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
		jonboede(at)hotmail.com Guest
				 Posted: Tue Apr 29, 2008 7:23 pm    Post subject: Gliding range specs for Nanchang |
				I have a friend who's pretty much 100% rotor time... the whole "how do the wings stay on?" thing makes her nervous. Doing any kind of aerobatics brings loud protests (although a carrier break seems to have become an "approved" maneuver).
 Power-off gliding seems to be the only "familiar" thing.. because with the power off the Chang has the glide ratio of a helicopter in an auto-rotation.
 Jon
 [quote]Date: Tue, 29 Apr 2008 18:49:33 -0700
 To: yak-list(at)matronics.com
 Subject: Re: Gliding range specs for Nanchang
   	  | Quote: | 	 		  --> Yak-List message posted by: "skidmk" <bourgem(at)cia.com (bourgem(at)cia.com)>
 Hi all,,
 doing a bit of an aircraft profile for my anywhere map.. was looking for gliding specs on the chang?  anyone?
 thanks
 Ottawa, Ontario
 Always Yakin,
 Doug Sapp
 Phone 509-826-4610
 Fax 509-826-3644    	  | Quote: |
 et="_blank">http://www.matronics.com/Navigator?Yak-List
				 Posted: Tue Apr 29, 2008 8:06 pm    Post subject: Gliding range specs for Nanchang |
				And that comes from a man with first hand experience in testing the engine out glide ratio of a rock.
 Doc
 From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
  Sent: Tuesday, April 29, 2008 8:50 PM
  Hi all,,
  thanks
  Ottawa, Ontario
  Always Yakin,
  Doug Sapp
  Phone 509-826-4610
  Fax 509-826-3644    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Yak-List  | 	  0123456789
		skidmk
				 Posted: Wed Apr 30, 2008 4:08 am    Post subject: Re: Gliding range specs for Nanchang |
				Wow,, thanks I figured it was a rock by the circuit practices I've been doing.
 I've extrapolated some numbers from the chinese "pilot manual", it appears she drops 590feet (converted from meters) for every 1.33 miles forward ,,, thats at 80kts of airspeed.  of course, it doesn't say wind, weight or any of the other variables.
 your mileage may vary
Ottawa, Ontario |
		tjyak50
				 Posted: Wed Apr 30, 2008 6:29 am    Post subject: Re: Gliding range specs for Nanchang |
				Experiment with the prop control on your next engine out landing practice.
 If the engine is windmilling, you most likely have oil pressure and will be up against the low-pitch stops (highest drag).
 Pull the prop control all the way back and feel the airplane surge forward as the blades go to the high pitch stops (towards feather).  You can also push it back to the higher drag setting if needed.
 If your engine is dead stopped it has probably already sprung itself to this coarse setting against the high pitch stops (low drag).
 One client who dead sticked a Nanchang used this trick right at the end of his glide to "jump" a little berm.
 Tj
		brian-1927(at)lloyd.com Guest
				 Posted: Wed Apr 30, 2008 10:27 am    Post subject: Gliding range specs for Nanchang |
				It is quite interesting the lack of useful information to the
 gentleman's original question. (Yes, there were a few useful answers,
 Dennis' sticking in my mind but that was for the Yak-52.)
 I don't know how other instructors provide transition training in the
 Yak or CJ but I believe you should have covered this when you got your
 transition training in the aircraft. I specifically address the issue
 by having a segment of training on engine-out performance. It includes
 putting the aircraft into several different configurations (all with
 throttle at idle), specifically:
 1. gear up, flaps up, max RPM;
 2. gear up, flaps up, low RPM;
 3. gear down, flaps up, max RPM;
 4. gear up, flaps down, max RPM;
 5. gear down, flaps down, max RPM;
 6. gear down, flaps up, low RPM.
 We get the aircraft into a steady-state glide and measure rate-of-
 descent. This allows the student to get a feel for the drag producers
 in the aircraft. After that we make power off landings from the
 downwind. Later on we calculate glide ratio (when back on the ground).
 Power off landings are pretty docile in the CJ with the stock engine
 (they are done flaps-up BTW) but can get pretty exciting in the Yak-52
 with 400hp engine and MT 3-bladed prop. Expect to fly a *very* close
 in pattern with something approaching a 45 degree bank-angle in the
 continuous-turn from downwind to final.
 So getting back to the original question, you need to specify
 airframe, engine, prop, and configuration before anyone can give you a
 hard-and-fast answer to your question. My recommendation is that you
 go out and practice power-off landings yourself in order to become
 comfortable with the event. No amount of talk here on this list will
 prepare you.
 If you are on the west coast I will be happy to provide instruction
 and act as safety pilot while you learn the techniques. If you are
 somewhere else I strongly urge you to find someone experienced with
 this flight regime to help you practice.
 Brian Lloyd                         3191 Western Drive
 brianl AT lloyd DOT com             Cameron Park, CA 95682
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 PGP key ID:          12095C52A32A1B6C
 PGP key fingerprint: 3B1D BA11 4913 3254 B6E0  CC09 1209 5C52 A32A 1B6C
		Dabear(at)damned.org Guest
				 Posted: Wed Apr 30, 2008 1:03 pm    Post subject: Gliding range specs for Nanchang |
 [much good info deleted]
  with 400hp engine and MT 3-bladed prop. Expect to fly a *very* close  in
 The CJ with the M14P and MT prop gets pretty exciting with power off.  It
 should be practiced at altitude first and particular attention should be
 paid to how it flys at lower airspeed.  The combination is wonderful when
 there is power.  Once power is off, don't get slow.  The sink rate is
 impressive.
 Dabear
		ChangDriver
				 Posted: Wed Apr 30, 2008 6:19 pm    Post subject: Re: Gliding range specs for Nanchang |
				Hit "Present Position" on the Anywhere Map and that is where you will land.
 Craig
