skidmk
Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
Posted: Tue Apr 29, 2008 4:41 pm Post subject: Gliding range specs for Nanchang |
Hi all,,
doing a bit of an aircraft profile for my anywhere map... was looking for gliding specs on the chang? anyone?
thanks
_________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
dougsappllc(at)gmail.com Guest
Posted: Tue Apr 29, 2008 5:52 pm Post subject: Gliding range specs for Nanchang |
Glides like a wet anvil if the prop is not turning.
On Tue, Apr 29, 2008 at 5:41 PM, skidmk <bourgem(at)cia.com (bourgem(at)cia.com)> wrote:
[quote]--> Yak-List message posted by: "skidmk" <bourgem(at)cia.com (bourgem(at)cia.com)>
Hi all,,
thanks
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=180147#180147
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644 [quote][b]
talew(at)bellsouth.net Guest
Posted: Tue Apr 29, 2008 6:20 pm Post subject: Gliding range specs for Nanchang |
Doug knows from experience.
Believe it!
A careful search of the archives seemed to indicate that if you throw your car keys out when the engine quits that is your landing target. Anything else is stretching it .
Terry
threein60(at)yahoo.com Guest
Posted: Tue Apr 29, 2008 6:38 pm Post subject: Gliding range specs for Nanchang |
When I had an engine out in my cj, it seemed like the glide ratio was 1 to 1. It might be more be more but it sure felt like 1 to 1.
Larry
cjpilot710(at)aol.com Guest
Posted: Tue Apr 29, 2008 6:42 pm Post subject: Gliding range specs for Nanchang |
I don't remember ever seeing tables on the CJ's gliding distance. You could most likely theoretically work it with known figures like gross weight, airfoil data, and wing area. A bit out of my league. However in playing with my CJ, I found that if I pick a spot on the ground 1/3 the distance in from the wing tip - I can make that spot in a clean glide, with a wind-milling engine. That's for just about any altitude too. NOTE: I have an M-14p with a paddle prop. I suspect the Chinese metal prop would give you a somewhat better glide.
Jim "Pappy" Goolsby
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
jonboede(at)hotmail.com Guest
Posted: Tue Apr 29, 2008 7:23 pm Post subject: Gliding range specs for Nanchang |
I have a friend who's pretty much 100% rotor time... the whole "how do the wings stay on?" thing makes her nervous. Doing any kind of aerobatics brings loud protests (although a carrier break seems to have become an "approved" maneuver).
Power-off gliding seems to be the only "familiar" thing.. because with the power off the Chang has the glide ratio of a helicopter in an auto-rotation.
Jon
[quote]Date: Tue, 29 Apr 2008 18:49:33 -0700
To: yak-list(at)matronics.com
Subject: Re: Gliding range specs for Nanchang
| Quote: | --> Yak-List message posted by: "skidmk" <bourgem(at)cia.com (bourgem(at)cia.com)>
Hi all,,
doing a bit of an aircraft profile for my anywhere map.. was looking for gliding specs on the chang? anyone?
thanks
Ottawa, Ontario
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644 | Quote: |
et="_blank">http://www.matronics.com/Navigator?Yak-List
Posted: Tue Apr 29, 2008 8:06 pm Post subject: Gliding range specs for Nanchang |
And that comes from a man with first hand experience in testing the engine out glide ratio of a rock.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
Sent: Tuesday, April 29, 2008 8:50 PM
Hi all,,
thanks
Ottawa, Ontario
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644 | Quote: | | http://www.matronics.com/Navigator?Yak-List | 0123456789
skidmk
Posted: Wed Apr 30, 2008 4:08 am Post subject: Re: Gliding range specs for Nanchang |
Wow,, thanks I figured it was a rock by the circuit practices I've been doing.
I've extrapolated some numbers from the chinese "pilot manual", it appears she drops 590feet (converted from meters) for every 1.33 miles forward ,,, thats at 80kts of airspeed. of course, it doesn't say wind, weight or any of the other variables.
your mileage may vary
Ottawa, Ontario |
tjyak50
Posted: Wed Apr 30, 2008 6:29 am Post subject: Re: Gliding range specs for Nanchang |
Experiment with the prop control on your next engine out landing practice.
If the engine is windmilling, you most likely have oil pressure and will be up against the low-pitch stops (highest drag).
Pull the prop control all the way back and feel the airplane surge forward as the blades go to the high pitch stops (towards feather). You can also push it back to the higher drag setting if needed.
If your engine is dead stopped it has probably already sprung itself to this coarse setting against the high pitch stops (low drag).
One client who dead sticked a Nanchang used this trick right at the end of his glide to "jump" a little berm.
Tj
brian-1927(at)lloyd.com Guest
Posted: Wed Apr 30, 2008 10:27 am Post subject: Gliding range specs for Nanchang |
It is quite interesting the lack of useful information to the
gentleman's original question. (Yes, there were a few useful answers,
Dennis' sticking in my mind but that was for the Yak-52.)
I don't know how other instructors provide transition training in the
Yak or CJ but I believe you should have covered this when you got your
transition training in the aircraft. I specifically address the issue
by having a segment of training on engine-out performance. It includes
putting the aircraft into several different configurations (all with
throttle at idle), specifically:
1. gear up, flaps up, max RPM;
2. gear up, flaps up, low RPM;
3. gear down, flaps up, max RPM;
4. gear up, flaps down, max RPM;
5. gear down, flaps down, max RPM;
6. gear down, flaps up, low RPM.
We get the aircraft into a steady-state glide and measure rate-of-
descent. This allows the student to get a feel for the drag producers
in the aircraft. After that we make power off landings from the
downwind. Later on we calculate glide ratio (when back on the ground).
Power off landings are pretty docile in the CJ with the stock engine
(they are done flaps-up BTW) but can get pretty exciting in the Yak-52
with 400hp engine and MT 3-bladed prop. Expect to fly a *very* close
in pattern with something approaching a 45 degree bank-angle in the
continuous-turn from downwind to final.
So getting back to the original question, you need to specify
airframe, engine, prop, and configuration before anyone can give you a
hard-and-fast answer to your question. My recommendation is that you
go out and practice power-off landings yourself in order to become
comfortable with the event. No amount of talk here on this list will
prepare you.
If you are on the west coast I will be happy to provide instruction
and act as safety pilot while you learn the techniques. If you are
somewhere else I strongly urge you to find someone experienced with
this flight regime to help you practice.
Brian Lloyd 3191 Western Drive
brianl AT lloyd DOT com Cameron Park, CA 95682
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
Dabear(at)damned.org Guest
Posted: Wed Apr 30, 2008 1:03 pm Post subject: Gliding range specs for Nanchang |
[much good info deleted]
with 400hp engine and MT 3-bladed prop. Expect to fly a *very* close in
The CJ with the M14P and MT prop gets pretty exciting with power off. It
should be practiced at altitude first and particular attention should be
paid to how it flys at lower airspeed. The combination is wonderful when
there is power. Once power is off, don't get slow. The sink rate is
impressive.
Dabear
ChangDriver
Posted: Wed Apr 30, 2008 6:19 pm Post subject: Re: Gliding range specs for Nanchang |
Hit "Present Position" on the Anywhere Map and that is where you will land.
Craig
