"Over Square, back loading, detuning, underboost-etc.
cjpilot710(at)aol.com
PostPosted: Sat May 03, 2008 6:17 pm    Post subject: "Over Square, back loading, detuning, underboost-etc. Reply with quote
There has been several things mentioned here about the necessity or not of staying "over square". Some are not quite sure at what is happening.  I have "lived" with this a good many years and I know that big radials will not last long if you treat them poorly. In fact one of the reasons the bombers I fly stay "in business" is because of the way we fly the engines.  Averaging around 300 plus hours a year per airplane - that's equates to about 600 takeoff and landings a year per airplane. If we flew them the way the USAAF did, we'd be changing engines every couple of months.  Usually we change one engine per year per airplane. Here is how the problem was written up in Warbird Notes #3 in March 1994, by R.L. Sohn.  It is probably the best explanation I've ever seen written.
"Now the cause which we want discuss in this bulletin. This happens when the pilot pulls the throttle back to a very low MP. --------- Under normal conditions the master rod thrust bearing is loaded against the crankshaft from multiplicity of direction as all the pistons progress through their assigned firing order. Remember that all the other connecting rods are linked to this one master rod and the pressures on this master rod journal are the constantly changing resultant of all the pressures exerted by these pistons. The crankshaft is drilled on the thrust side allowing oil access to this area when under power. The heat is carried away with the oil flow. No oil hole is drilled on the anti-thrust side, it's not considered necessary since the hole the thrust side provides constant lubrication from pressurized oil flowing around the bearing. If this series of alternating forces is severely disturbed by a large reduction in MP then the propeller in effect is turning the engine. It might be helpful here to visualize the unloaded pistons trying to throw themselves out the top of the cylinders. In this case the load is continuously applied to this one (anti-thrust side) area of the master rod journal where no oil hole is located. In short order this "squeeze play" situation causes oil (lubrication and cooling ) starvation resulting in failure to dissipate the frictional heat. This rapidly progresses from overheating to self destruction. In some cases during tear down the bleed holes have been found wiped full of silver metal from the multi-layered plating of the master rod bearing"
The Wright can stand up a little better the Pratts because the they have more master rod bearing area. The journal diameter of the 1820 is about 3 1/4" as compared to the 1830's 2 5/8". Both have virtually the same displacement.
Comparing the M-14? There no doubt that the forces and situation is the same. However I do not know the oiling of the M-14. Jill could elucidate better than I on that. I think if you compare engine size to horsepower (I don't how to arthritically do that) I believe you'd find the M-14 is "beefier" for its HP. I know that I fly my M14 the same way I do the Pratts and Wrights.
Jim "Pappy" Goolsby
Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food.
viperdoc(at)mindspring.co
PostPosted: Sat May 03, 2008 7:50 pm    Post subject: "Over Square, back loading, detuning, underboost-etc. Reply with quote
Pappy,
Thanks. So my theory according to this excerpt was correct in feeling comfortable in pulling the MAP to idle with the %RPM pushed up.
Now I understand better what is really going on at the Master Rod main bearing.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com
Sent: Saturday, May 03, 2008 9:14 PM
To: yak-list(at)matronics.com
Subject: "Over Square, back loading, detuning, underboost-etc.
Jim "Pappy" Goolsby
jack
PostPosted: Sat May 03, 2008 8:19 pm    Post subject: "Over Square, back loading, detuning, underboost-etc. Reply with quote
--- On Sat, 5/3/08, Roger Kemp M.D. <viperdoc(at)mindspring.com> wrote:
> ... Now I understand better <<
Randy Sohn is surely one of the masters of the radial world, indeed, one of the masters of the legacy aviation world.
There may be some reading this list who don't know his name. He's had a good bit to say about flying and it can be a good idea to search out his comment.
best ...
jack
Subject: RE: "Over Square, back loading, detuning, underboost-etc.
Date: Saturday, May 3, 2008, 11:47 PM
Pappy,
in feeling
up.
Master Rod main
bearing.
Doc
necessity or not of
reasons the
that's equates to
flew them the way
months. Usually we
problem was
It is probably
This happens when
the crankshaft
through their
connecting rods are
master rod journal
exerted by these
allowing oil access
with the oil flow.
not considered
lubrication from
of alternating
then the propeller
to visualize the
the cylinders.
(anti-thrust side)
heat. This
In some cases
of silver metal
bearing"
the they have
1820 is about 3
displacement.
situation is the
could elucidate
to horsepower (I
find the M-14 is
and Wrights.
Jim "Pappy" Goolsby
_____
<http://food.aol.com/dinner-tonight?NCID=aolfod00030000000001>
twists on
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Rob Rowe
PostPosted: Sun May 04, 2008 8:35 am    Post subject: Re: Reply with quote
FYI - extracted the following master connecting rod lubrication description from the M14P manual ...
“The crank-pin has a radial hole to supply oil from the crankshaft rear to its front section and two radial holes to feed oil to the master connecting rod bushing which are at an angle of 60° from the axis of symmetry in the direction of crankshaft rotation”
... and compiled the attached JPG file composite of the associated schematic diagrams from the same source (which won't be distributed with the daily digest email but can be found at ... http://forums.matronics.com/viewtopic.php?t=43148 )
I'll leave it to the engineers amongst you to determine the significance of this description.
Rob R.
 Filesize:  73.25 KB
 Viewed:  527 Time(s)
mark.bitterlich(at)navy.m
PostPosted: Mon May 05, 2008 1:05 pm    Post subject: "Over Square, back loading, detuning, underboost-etc. Reply with quote
Jim, just a comment. I am not disagreeing with anything you have said
or the quotes from others with far more round engine time than my own.
That said, the M-14 has been flying in Unlimited Aerobatic Competition
for years. I happen to have the privilege of working with (and on) the
M-14 engines mounted in a few of the most heavily and most outrageously
flown aircraft in this country. In most every M-14 engine I have had
experience with, the failure items usually consist of front engine seals
(gone bad from extreme loading in gyroscopic maneuvers... Looks like a
prop seal, but isn't!) some cracked piston rings, a lot of #2 cylinder
low compression gripes, many mag gripes, bent rods from oil in the
cylinders, but not one ... Not one single occasion of bad internal
bearings or any kind of silver in the screens. These engines are
usually flown with two power settings. WFO, and yanked to zero. The
only "normal" engine use is flying to and from the locations of the
competitions or air shows. Possibly we are not into the range of total
operating hours to see this kind of wear and failure yet? Most of the
aerobatic guys I know change engines at around 1000 hours even if they
are running OK.
Point is, I understand and concur with every word you have said, and
like yourself, I am wondering if there is anything different or special
about the M-14, because it sure is not failing like the American made
round engines would if treated the same way. Further, I believe that
the M-14 weighs less than any other American made engine for the
horsepower it produces. It is also 'geared' and turns higher RPM than
most made American Radials too.
I believe someone ought to contact Russian Master Mechanic Vladimir
Yastremski and ask him about this issue. I honestly believe he would
know even more than Jill or George about the matter.
Just a thought.
Mark Bitterlich
