R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Mon May 19, 2008 1:43 pm Post subject: Re: Tansfer pump Ideas? |
George:
Here are some quick shots of my setup. I'll be using it to fly 356 air miles to the Rock House this Wednesday to meet up with John H, John W, and Larry and Karen Cottrell.
178.34 KB |
566 Time(s) |
215.61 KB |
560 Time(s) |
| Tank pickup-tube and strainer. |
198.96 KB |
539 Time(s) |
| View from the starboard side |
178.13 KB |
561 Time(s) |
139.79 KB |
515 Time(s) |
209.02 KB |
512 Time(s) |
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
knowvne(at)aol.com Guest
Steven Green
Posted: Mon May 19, 2008 4:57 pm Post subject: Tansfer pump Ideas? |
| Quote: | Before I built the 20 gal. aluminum tank for my Mark 3, this is what I used. It is a boat tank with the clunk/filter hose extended to reach the bottom of the tank when standing on end. The fuel pump is a faucet. I used it to transfer fuel in flight. It strapped into the passenger seat. I made a fitting that screwed into the 3/4" pipe thread in the cap of the plastic 5 gallon tanks. This fitting also provided a vent for the tank that I was pumping into.
Steven Green
Mark 3 912
[img]cid:96DFC0E90A634694B124A050526DD7D6(at)GreensPC[/img]
115.03 KB |
532 Time(s) |
_________________ Steven Green |
Posted: Mon May 19, 2008 5:11 pm Post subject: Tansfer pump Ideas? |
Hi Steve...
VERY NICE ! Thats exactly what I want to make..
BTW I like the way Rodger Velcros his pump to his can...
Did you install a in line switch to power the pump or
is it just plug and play?
How long did it take the faucet pump to transfer the 5 Gallons ??
Mark
115.03 KB |
529 Time(s) |
Steven Green
Posted: Mon May 19, 2008 5:24 pm Post subject: Tansfer pump Ideas? |
Mark,
I never timed the transfer but the pump is rated at 30 GPH so 5 gallons should take about 10 minutes. If you're close to East Tennessee, $35 will get this one. I no longer need it. If I remember correctly I used Adel clamps to mount the pump to the handle of the tank.
Steven
115.03 KB |
519 Time(s) |
Posted: Mon May 19, 2008 5:57 pm Post subject: Tansfer pump Ideas? |
Hi Steve Sorry I'm a bit too far North to take ya up on your offer...... Boston.
George Myers
Joined: 10 Jan 2006 Posts: 76 Location: San Marcos, Texas
Posted: Mon May 19, 2008 6:31 pm Post subject: Tansfer pump Ideas? |
Thanks, great pics of good ideas.
George Myers
San Marcos Tx
1984 Twinstar 582 - N2606T
Steven Green
Posted: Tue May 20, 2008 1:13 am Post subject: Tansfer pump Ideas? |
The tank is from Walmart, the fuel pump I bought from Aircraft Spruce.
http://www.aircraftspruce.com/catalog/eppages/facetpumps.php
115.03 KB |
507 Time(s) |
Posted: Tue May 20, 2008 6:07 am Post subject: Tansfer pump Ideas? |
Steve THANKS!
BTW does the pump orientation matter for it to work??
Mounting holes Vertical or Horizontal ???
I was thinking of bolting it to a piece of Delrin
then I could Velcro it to the side of a fuel can....
An easy in and out set up...
Mark
115.03 KB |
512 Time(s) |
JetPilot
Posted: Tue May 20, 2008 10:14 am Post subject: Re: Tansfer pump Ideas? |
Mark,
I'm glad to see that you are going with a well tested, safe pump. The Facet pump will work in any orientation. The fact that you can buy the facet pump from Lockwood, Aircraft Spruce, and CPS should have clued most of the guys in that were giving you bad advice.
Some of these guys are pretty quick to hand out bad advice... Talk is cheap, but I wonder how many of them would actually be foolish enough to drop in a cheap Ebay pump into a plastic tank not designed for it in flight ? Maybe a couple here want to be there for their own barbecue, but from what I read, most people will jump out of a burning airplane, parachute or not, before they will be burned alive.
Kolb MK-III Xtra, 912-S |
Posted: Tue May 20, 2008 12:45 pm Post subject: Tansfer pump Ideas? |
HI Mike
I can't say with any certainty that their advice was bad as I haven't used or tested
what they said... My experiences has taught me their is always more than one way
to pluck a goose... I prefer WAX, Some Boil... All get er done....
I can say that In my 25 years of flying I've learned its what I DONT know I don't know
that can bite..... None of us know it all so brainstorming ideas in my mind is always a
good thing and That's the beauty of these types of on line Campfires.... Sharing ideas..
Even with a proven method I'll test it to MY satisfaction before I rely on it..
Not to say I don't trust others ideas but the OTHERS didn't build mine and it's my butt
thats on the fence....
Regarding the in flight fire an Jumping...... Not me I'd spit alot and find a lake. hahahahaha
One good thing about what I''ll be flying is the Flames should they occur, Will be behind me
so the spitting will be more effective... HAHAHA
Thanks again for all the good ideas... Time to create a parts List....
Experiment, the Wrights didn't have a pilots licence either..
Mark
firestar503(at)yahoo.com Guest
Posted: Tue May 20, 2008 12:48 pm Post subject: Tansfer pump Ideas? |
Hi Kolbers,
I know I'm late the party on transfer pumps but
perhaps my experience will help someone.
My system is mounted in a FirestarII where the
second seat belongs. It consists of an aluminum
box that holds two of the Kolb standard five
gallon tanks and a Facet pump. The tanks have
top mounted pickup tubes. One tank in the box
has the pickup tube modified into a "tee" so the
line coming from the the original Kolb five
gallon in the rear cage passes through the Facet
pump, into one side of the "tee'd" pickup in the
first tank and on to the standard pickup tube in
the second tank. Between the Kolb cage tank and
the Facet pump is a quick disconnedt and between
the Tee and the second tank in the box is a
second quick disconnect. There is a third quick
disconnect on the electrical connection to the
Facet pump. The pump switch is mounted under the
pilot seat and is spring loaded. The box is a
nice complete unit that can be quick-disconnected
and lifted out as a unit and the back seat can be
functional in about five minutes. The fuel quick
connects allow fuel operation with 5, 10 or 15
gallons depending on how far you are flying.
With a fuel gage in the original Kolb tank, it is
fun to watch the qage go "up" during flight.
Jon L.
Minnesota
R. Hankins
Posted: Tue May 20, 2008 5:26 pm Post subject: Re: Tansfer pump Ideas? |
| knowvne(at)aol.com wrote: | Rodger NICE idea...
And Its a good thing your Main tank is elevated
Them bullet holes up the side could have messed up Christmas hahahaha
Thanks for the pix..
mark
Mark,
The main tank is sitting on the boom tube. It is an 8 gallon tank out of a Sky Ranger kit. They are under $30 and VERY sturdy. They are 1/2" fatter on the square than the standard tank and quite a bit taller. I had to move the 1/4" crossmember that holds the forward side of the tank to fit it in, but it was worth it for the extra few gallons. As for the bullet holes... You should have seen the other guy .
I'm all packed up, fueled up and headed to the Rock House in the morning. Even with twelve gallons usable, the last leg is a little iffy if the wind kicks up. Maybe I'll hang some bullet shaped tanks off of the struts for next year.
Posted: Tue May 20, 2008 6:07 pm Post subject: Tansfer pump Ideas? |
Thanks Jon...
If you happen to have any Pix of your set up I
would love to compare them to what other have posted...
Mark
pj.ladd(at)btinternet.com Guest
Posted: Wed May 21, 2008 2:05 am Post subject: Tansfer pump Ideas? |
these types of on line Campfires.... Sharing ideas..>>
on my Xtra the engine , Jabiru, pulls fuel equally from 2 tanks connected by a tee piece. Any reason why I can`t put a spare tank on the passengers seat and just add a quick connect into the same fuel line?
Cheers
Pat
Posted: Wed May 21, 2008 3:03 am Post subject: Tansfer pump Ideas? |
Hi Pat Is yours a Gravity feed?
Given the pick up in the portable tank will not be affixed to the tank
at any one point I would fear it might possibly suck air ...
I think I'd prefer the transfer method..
I was considering a flexible tube that was weighted and screened ..
Think RC type of tank here..
Mark
Dana
Posted: Wed May 21, 2008 3:04 am Post subject: Tansfer pump Ideas? |
At 05:59 AM 5/21/2008, pj.ladd wrote:
| Quote: | | on my Xtra the engine , Jabiru, pulls fuel equally from 2 tanks connected by a tee piece. Any reason why I can`t put a spare tank on the passengers seat and just add a quick connect into the same fuel line? |
Same here (two tee'd tanks on my US). I just added a third tank but I didn't run it into the same line as I didn't want it sucking air when the aux tank ran dry; instead I ran it into the top of one of the main tanks with a rubber grommet and push-in fitting (and yes, a quick disconnect in the line so I can remove the aux tank).
-Dana
Never practice proctology on a porcupine. [quote][b]
Dennis.Kirby(at)kirtland. Guest
Posted: Wed May 21, 2008 6:32 am Post subject: Tansfer pump Ideas? |
HYPERLINK "mailto:knowvne(at)aol.com" knowvne(at)aol.com asked: << BTW does
the pump orientation matter for it to work?? Mounting holes Vertical or
Horizontal ??? >>
Mark -
The instructions that come with the Facet fuel pump tell you that the
ideal installation is for the pump to be level with the bottom of your
fuel tank, and oriented with its axis of fuel flow at a 45 degree angle.
Of course, you'll see many variations of fuel pump installation that
still work, like on Steven Green's setup for his auxiliary transfer
tank.
Dennis Kirby
Mark-3, New Mexico
Posted: Wed May 21, 2008 12:12 pm Post subject: Tansfer pump Ideas? |
Thanks for the heads up Dennis.
I haven't started the parts list yet so any and all info is appreciated...
I have ideas floating around in the Grey matter and on paper..
but thats as far as i've gone so far...
I may hard wire a female plug to the battery terminals and install a
In line switch for power... but again that just one idea.. The goal is
a KISS approach.... I want an easy in and out and reliable set up...
Mark
