		Deems Davis
				 Posted: Fri May 30, 2008 8:37 pm    Post subject: wiring restive fuel sender/s |
				I'm electron challenged, and so the simplest things elude me at times.
 My question is how to wire the resistance fuel senders. I have 2 wires
 coming from my EIU for each tank. In the center of the fuel sender is a
 screw for a terminal. I assume this is for the sending / signal line,
 there are no other provisions on the sender for additional terminals, is
 it assumed that the unit is grounded through the airframe? In which case
 the 'other' / ground wire/s from the EIU can be terminated at a
 ground/block or on the airframe? If not,  where do it connect the other
 wire/s from the  EIU?
  Deems Davis # 406
 'Its all done....Its just not put together'
 http://deemsrv10.com/
		VHMUM(at)bigpond.com Guest
				 Posted: Sat May 31, 2008 1:54 am    Post subject: wiring restive fuel sender/s |
				Deems sounds the same as the temp probe one wire to probe and one wire to
 ground.
 Chris
		speckter(at)comcast.net Guest
				 Posted: Sat May 31, 2008 5:21 am    Post subject: wiring restive fuel sender/s |
				I put a line on one of the screws that hold the sender into the tank.  I was
 not sure that the proseal would conduct as well as it should through the
 joint of sender and tank.  If you have a good ground at the sender, then you
 can connect the other line near by to airframe ground.  That has worked well
 on mine.
 Gary
 40274
