Deems Davis
Posted: Fri May 30, 2008 8:37 pm Post subject: wiring restive fuel sender/s |
I'm electron challenged, and so the simplest things elude me at times.
My question is how to wire the resistance fuel senders. I have 2 wires
coming from my EIU for each tank. In the center of the fuel sender is a
screw for a terminal. I assume this is for the sending / signal line,
there are no other provisions on the sender for additional terminals, is
it assumed that the unit is grounded through the airframe? In which case
the 'other' / ground wire/s from the EIU can be terminated at a
ground/block or on the airframe? If not, where do it connect the other
wire/s from the EIU?
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
VHMUM(at)bigpond.com Guest
Posted: Sat May 31, 2008 1:54 am Post subject: wiring restive fuel sender/s |
Deems sounds the same as the temp probe one wire to probe and one wire to
ground.
Chris
speckter(at)comcast.net Guest
Posted: Sat May 31, 2008 5:21 am Post subject: wiring restive fuel sender/s |
I put a line on one of the screws that hold the sender into the tank. I was
not sure that the proseal would conduct as well as it should through the
joint of sender and tank. If you have a good ground at the sender, then you
can connect the other line near by to airframe ground. That has worked well
on mine.
Gary
40274
