George Myers
Joined: 10 Jan 2006 Posts: 76 Location: San Marcos, Texas
Posted: Tue Jun 03, 2008 7:39 am Post subject: Firestar Project |
Icom makes a 12V adapter that you can wire into a regulator. I used one for
a few years. Works great. They cost 25 to 35 bucks.
ICOM CP-12L Cigarette Car Adapter A5 A23 CP-12L
George
Posted: Tue Jun 03, 2008 9:18 am Post subject: Firestar Project |
Bob B:
I fly with minimum avionics, an ICOM A3 and a Garmin 196. The A3 is the smallest and cheapest handheld ICOM offered some years ago. It has performed flawlessly for me. I removed the battery and operate the radio off the aircraft 12vdc bat.
I have been able to fly wherever I desired in CONUS, Canada, and Alaska.
I also have a PLB (personal locator beacon with internal GPS) that operates on 406mz.
I have not found it necessary to load the little mkIII down with expensive avionics in order to fly and enjoy traveling.
mkIII - 2,800+ hours
PS: Have decided to fly to Homer Kolb's Fathers Day Flyin.
[quote] As long as there is some info on radios going around.... I have an
Icom A-5, BB
_________________ John Hauck
Titus, Alabama |
Dana
Posted: Tue Jun 03, 2008 9:32 am Post subject: Firestar Project |
At 09:07 AM 6/3/2008, George Alexander wrote:
| Quote: | If you don't have another need for 12V DC, Kuntzleman sells a strobe unit
that runs directly off the lighting coil. Saves a few ounces a
regulator/rectifier would cost you. ( http://www.kestrobes.com )
That's a thought, though I'd like to have power for my GPS as well... it's
a handheld and the life of the internal two AAA batteries is limited
(currently I'm using a pair of C-cells as an external supply).
-Dana
I can see clearly now, the brain is gone...
Dana
At 11:13 AM 6/3/2008, robert bean wrote:
| Quote: | ...the manual says you
HAVE to buy an intermediate device to lower the voltage. The built
in battery pack is crap.
-doesn't hold a charge for very long. Wonder why they didn't design
it for 12V ?
Perhaps 'cuz they can sell you the special adapter?
11V IS kinda weird...
-Dana
tkrolfe(at)toast.net Guest
Posted: Tue Jun 03, 2008 10:54 am Post subject: Firestar Project |
John Hauck wrote:
John,
Great news! I'm adding you to the list. Now I need to hear from any of
you that haven't responded yet and are planning on attending the Homer
Kolb Fathers Day Fly-in. I need to let Clara know how many are planning
on being there so she can make plans for the picnic. Please let me know
if your even thinking of coming!!! Just trying to make things work for
the Kolb's.
Terry - FireFly #95
Posted: Tue Jun 03, 2008 11:09 am Post subject: Firestar Project |
I guess that's what I'll do then. Hate to fry the radio by taking a
chance.
Might even use it someday.
BB (boondocks bob)
BTW, cleaned all the alfalfa off the wires and will put a little
bondo on
the nose cone bruise. Have to learn to cruise a little higher for a
better
choice of landing fields.
That would have been an interesting video of my plane scooting along
on the nose with the tail sticking up out of the hay. -and fortunate
some helpful soul didn't call the authorities. I'm sending the good
samaritan
who drove me to my tools a gift certificate for a nice restaurant.
-like the balloonist's bottle of champagne.
On 3, Jun 2008, at 11:29 AM, Robert Laird wrote:
I have that "intermediate device" for my Icom that they sell (battery
eliminator) and have it plugged into the airplane battery, an
-- Robert
On Tue, Jun 3, 2008 at 10:13 AM, robert bean
> an Icom
> A-5, never used,
> that I considered mounting on my MkIII. If you want to use
> aircraft power
> the manual says you
> built in
> design it for
> 12V ? (actually more
> like 14-15V during run time)
> What say you? -and y'all too
> BB
> On 3, Jun 2008, at 9:12 AM, Robert Laird wrote:
>> <rlaird(at)cavediver.com>
>> Bill --
>> As Ellery said, no freebie on the strobe. The strobe is required if
>> you want to fly that 30 minutes after sunset that FAR 103 allows.
>> There are portable strobes which meet the 3 mile requirement that
>> you
>> could create a cradle for... but the cradle might weigh as much as a
>> permanent strobe light.
>> For radio, the Yaesu VXA-150, Icom IC-A14, and similar radios with a
>> Lightspeed QFR XC is a really good and inexpensive combination for
>> ULs. Again, I'd suggest a cradle* over putting it in your pocket...
>> only the cradle itself would count for weight... you strap in the
>> radio to make it more secure during flight.
>> -- Robert
>> * RAM mounts make terrific cradles for radios
>> On Tue, Jun 3, 2008 at 6:04 AM, william sullivan
>> <williamtsullivan(at)att.net> wrote:
>>> I need some ideas on a good, very simple, radio and headset
>>> combination.
>>> I
>>> would like to tuck the radio in a pocket, rather than install on
>>> the
>>> plane,
>>> and with an internal antenna. Just a simple starter set.
>>> Also, on a 103 plane, somebody said there is no weight penalty
>>> for a
>>> strobe light. Is this true? If so, any recommended ones?
>>> Bill Sullivan
>>> Windsor Locks, Ct.
>>> FS/KX/447
>> Why did the chicken cross the Mobius strip? To get to the other, er,
>> um....
er, um....
ez(at)embarqmail.com Guest
Posted: Tue Jun 03, 2008 2:46 pm Post subject: Firestar Project |
Bob.
A bunch of guys around here use their A-5s wired direct on 12 volt. I
became a bit concerned about mine when one guy's A-5 went south,
because I knew my actual voltage was close to 14 volts. I got one of
those variable volt adaptors at Walmart and have been running mine on
the 9 volt setting and it has been working just fine. The A-5 will
work fine wired direct without without batteries but only with the
double "A" battery holder installed. It will not power-up if you try
to use it without a battery without the double "A "battery holder.
Not sure why.
Gene
On Jun 3, 2008, at 11:13 AM, robert bean wrote:
| Quote: | As long as there is some info on radios going around.... I have an
Icom A-5, never used,
that I considered mounting on my MkIII. If you want to use aircraft
power the manual says you
it for 12V ? (actually more
BB
Posted: Tue Jun 03, 2008 7:13 pm Post subject: Firestar project |
Thanks for the info on the radios, etc.
I went up to the field today to check on the tie-downs- stormed recently- and to top off the gas. I decided to get in some slow speed taxi practice. The wind was gusty and variable. This led to some quick down-wind trips, especially when I went down over the slight hump at the north end to turn around. I usually had to kill the engine to slow down enough to make the u-turn- no brakes. It gave me a lot of in-the-cockpit re-start practice. Going back into the wind it wasn't so bad. Except towards 4:30pm, when the wind swung around to the east and gusted. I thought the right LG leg had bent, as everything leaned to the right. One quick look and a gentle left aileron, and I put the left wing back down. I had been running on the right wheel and the tail wheel, all at low speed. I quick tied the plane up, and tarped it with some difficulty.
The engine still loads up on extended low rpm running. I think it may be running rich at these speeds- under 3000rpm. It kind of bogs down for a couple of seconds, then clears up. I have to check the book and maybe move the clip.
Also- more birds' nests! I don't know if we missed some, or the birds are still building. Maybe duct tape for a parking plug.
Bill Sullivan
Windsor Locks, Ct
FS/KX/447
Dana
Posted: Wed Jun 04, 2008 4:19 am Post subject: Firestar project |
At 11:11 PM 6/3/2008, william sullivan wrote:
move the clip.
Not the clip, that's more for higher rpm, cruise power. Under 3000 rpm
you're running on the pilot jet and the low speed mixture screw (if you
have one).
I fought the bird nest battle constantly when I had the T-Craft. Make sure
EVERY opening is sealed!
-Dana
Access denied--nah nah na nah nah!
by0ung(at)brigham.net Guest
Posted: Wed Jun 04, 2008 6:31 am Post subject: Firestar Project |
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
I have been working on a project to do that very thing,,,, I think I am
getting close when I get the last problem or 2 resolved I will post it to
the list.
Boyd Young
MKIIIC 500 + hours and counting
Brigham City Ut.
Posted: Wed Jun 04, 2008 7:06 am Post subject: Firestar Project |
Dana- I thought the clip on the Bing 54 was for a richer/leaner mixture to accomodate for weather changes. I have to read up on it. I have 2 screws- a very large one, and a small one near the air filter. I have NO experience with the Bings, and both screws are located on the prop side. I am not going to try to get my big fat hands in there with it running. It does start good, and re-starts easily, so I think it will only be a minor adjustment.
Bill Sullivan
Windsor Locks, Ct.
FS/KX/447
Thom Riddle
Posted: Wed Jun 04, 2008 8:50 am Post subject: Re: Firestar Project |
Bill,
I suggest you acquire the Bing Manual at
http://www.bingcarburetor.com/manual.html
It is about $10 including shipping and will tell you all you need to know about the Bing Carbs.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
ElleryWeld(at)aol.com Guest
Posted: Wed Jun 04, 2008 10:12 am Post subject: Firestar Project |
Bill
that Large screw is your idle stop the small one is your low speed jet
Ellery in Maine
In a message dated 6/4/2008 11:06:47 A.M. Eastern Daylight Time, williamtsullivan(at)att.net writes:
| Quote: | Dana- I thought the clip on the Bing 54 was for a richer/leaner mixture to accomodate for weather changes. I have to read up on it. I have 2 screws- a very large one, and a small one near the air filter. I have NO experience with the Bings, and both screws are located on the prop side. I am not going to try to get my big fat hands in there with it running. It does start good, and re-starts easily, so I think it will only be a minor adjustment.
Bill Sullivan
Windsor Locks, Ct.
FS/KX/447
="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
Dana
Posted: Wed Jun 04, 2008 2:06 pm Post subject: Firestar Project |
At 10:28 AM 6/4/2008, boyd wrote:
| Quote: | ...If you want to use aircraft
the list.
Getting the required 11VDC requires only a simple voltage regulator
circuit... but engine power is typically rather dirty, so filters and such
are necessary. Seems I saw such a circuit somewhere online, but I don't
recall where.
-Dana
A computer lets you make more mistakes faster than any invention in
human history... with the possible exception of handguns and tequila.
Dana
Posted: Wed Jun 04, 2008 2:11 pm Post subject: Firestar Project |
adjustment.
Correct, but needle clip affects the upper midrange. At WOT the needle has
no effect; the main jet controls the mixture there. At low rpm it's the
idle screw.
See:
http://www.ultralightnews.com/enginetroublshooting/techtips/techtips2.htm
and
http://www.ultralightnews.com/enginemaintenance/bingcarbtuning.htm
-Dana
crad238(at)verizon.net Guest
Posted: Fri Jun 06, 2008 4:21 am Post subject: Firestar Project |
William
I have been lurking here for years. Please don't use the old gas for fire starter. It is extremely dangerous. The fumes spread and cause a small explosion. The fire can leap back up the stream and cause you to drop or throw the flaming container.
Do not archive.
russ(at)rkiphoto.com Guest
Posted: Fri Jun 06, 2008 5:20 am Post subject: Firestar Project |
Carl, NEVER pour gas from a container onto a flame! I thought everybody knew that. Pour some in a small cup & toss that onto the fire if you must.Shouldn't have to use an accelerant with charcoal, anyway. Remember those fumes will go into your food.
On Jun 6, 2008, at 8:18 AM, Carl Radcliffe wrote:
[quote] William
Do not archive.
[quote]---
Posted: Sun Jun 15, 2008 3:44 pm Post subject: Firestar project |
B illForgot to mention -- the Cessna 150/152 is a fine, tough little bird, hope you appreciate it. And the taildragger conversion is one cute little airplane.
i knew a gal who got her ATP license in one! -- when the regs simply said "applicant shall supply the aircraft for the test".
But it was a single-engine ATP -- only good for Cessna Caravan, Beaver, Otter & such.
But she did it in her own 150! Good bird.
Russ
