HID replacement lights
dlm46007(at)cox.net
PostPosted: Wed Jun 18, 2008 12:34 pm    Post subject: HID replacement lights Reply with quote
Just spent three hours swapping the halogen landing lights provided by Vans with a set of 50W direct replacement HID lights. The before and after pictures should be on http://www.planelights.com/index.php?id=661 in a few days. Will be able to show the lights at OSH on the 31,1,2.
Peter.James(at)sprint.com
PostPosted: Fri Jun 20, 2008 7:56 am    Post subject: HID replacement lights Reply with quote
David,
Stop it already! Every time I think I am done buying ‘goodies’ for my plane, somebody comes up with one of those have to have it items that cost me more money!
So tell us, what is the heat output of the HID vs. the stock Halogen’s? I am concerned about the heat warping the fiberglass wingtip….and I am sure others are concerned and would like to know also.
Pete
(not sure where I’m at anymore – too many little things left to do!)
Tim Olson
PostPosted: Fri Jun 20, 2008 8:16 am    Post subject: HID replacement lights Reply with quote
HID's are far cooler than Halogens....far cooler, which is one
of their benefits.
James, Peter [SD] wrote:
David,
Stop it already! Every time I think I am done buying �goodies� for my
cost me more money!
So tell us, what is the heat output of the HID vs. the stock Halogen�s?
I am concerned about the heat warping the fiberglass wingtip�.and I am
Pete
(not sure where I�m at anymore � too many little things left to do!)
pascal(at)rv10builder.net
PostPosted: Fri Jun 20, 2008 8:26 am    Post subject: HID replacement lights Reply with quote
Check out their site for some other questions. I had the same thought and recall they had a Q& A
QVery Happyo they get hot
A: Yes, but the heat is directly equivalent to the power being applied. If your original application was designed for a 55w halogen, then going to a 35w or a 50w HID should not generate a significant amount more heat than the original halogen.
From: James, Peter [SD] (Peter.James(at)sprint.com)
Sent: Friday, June 20, 2008 8:52 AM
Subject: re: HID replacement lights
David,
Stop it already! Every time I think I am done buying �goodies� for my plane, somebody comes up with one of those have to have it items that cost me more money!
So tell us, what is the heat output of the HID vs. the stock Halogen�s? I am concerned about the heat warping the fiberglass wingtip�.and I am sure others are concerned and would like to know also.
Pete
forgot the link.. has the wig-wag answer as well
http://www.planelights.com/index.php?id=684
David,
Pete
dlm46007(at)cox.net
PostPosted: Fri Jun 20, 2008 9:34 am    Post subject: HID replacement lights Reply with quote
the replacement HID seems to have less radiated heat to the fiberglass tip. When testing the lights I placed my hand about 1.5" ahead of the tip of the light (lens off) and it became hot; but , for unknown reasons the HID did not heat the strobe glass directly in front of it. going flying tonight so will have more info later.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James, Peter [SD]
Sent: Friday, June 20, 2008 8:53 AM
David,
Pete
