		dlm46007(at)cox.net Guest
				 Posted: Wed Jun 18, 2008 12:34 pm    Post subject: HID replacement lights |
				Just spent three  hours swapping the halogen landing lights provided by Vans with a set  of  50W direct replacement HID lights. The before and after pictures  should be on http://www.planelights.com/index.php?id=661 in  a few days. Will be able to show the lights at OSH on the  31,1,2.
		Peter.James(at)sprint.com Guest
				 Posted: Fri Jun 20, 2008 7:56 am    Post subject: HID replacement lights |
				David,
 Stop it already!  Every time I think I am done buying ‘goodies’ for my plane, somebody comes up with one of those have to have it items that cost me more money!
 So tell us, what is the heat output of the HID vs. the stock Halogen’s?  I am concerned about the heat warping the fiberglass wingtip….and I am sure others are concerned and would like to know also.
 Pete
 (not sure where I’m at anymore – too many little things left to do!)
		Tim Olson
				 Posted: Fri Jun 20, 2008 8:16 am    Post subject: HID replacement lights |
				HID's are far cooler than Halogens....far cooler, which is one
 of their benefits.
 James, Peter [SD] wrote:
  David,
  cost me more money!
  Pete
		pascal(at)rv10builder.net Guest
				 Posted: Fri Jun 20, 2008 8:26 am    Post subject: HID replacement lights |
				Check out their site for some other questions. I  had the same thought and recall they had a Q& A
 Q o they get hot
 A: Yes, but the heat is directly  equivalent to the power being applied.  If your original application was  designed for a 55w halogen, then going to a 35w or a 50w HID should not generate  a significant amount more heat than the original halogen.
   From: James, Peter [SD] (Peter.James(at)sprint.com)
  Sent: Friday, June 20, 2008 8:52 AM
  Subject: re: HID replacement lights
 David,
 Pete
				forgot the link.. has the wig-wag answer as  well
  http://www.planelights.com/index.php?id=684
 David,
 Pete
				 Posted: Fri Jun 20, 2008 9:34 am    Post subject: HID replacement lights |
				the replacement HID seems to have less radiated heat to the  fiberglass tip. When testing the lights I placed my hand about 1.5" ahead of the  tip of the light (lens off) and it became hot; but , for unknown reasons the HID  did not heat the strobe glass directly in front of it. going flying tonight so  will have more info later.
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James, Peter  [SD]
 Sent: Friday, June 20, 2008 8:53 AM
 To:  rv10-list(at)matronics.com
 David,
 Pete
