jpg12305
Posted: Wed Jul 16, 2008 9:47 am Post subject: Prop advice fixed pitch - Warpdrive or Arplast ? |
My current prop is the standard 3 blade Warpdrive, but unfortunately shortened in its early life due to a ground encounter.
Diameter is reduced to about 58", which (I assume) reduces significantly as well its efficiency.
In order to revert to proper performance I am considering the current alternative (VP not being an option due to cost and weight) :
- purchase new blades from Warpdrive (cheap and straightforward)
- replace with an Arplast Ecoprop. From misc readings it looks better designed than the Warpdrive, question being if the extra performance worths the extra cost.
Engine is a 912ULS.
Has anyone gone through such change ?
Jean-Paul
Europa monowheel 332 - France
ami(at)mcfadyean.freeserv Guest
Posted: Wed Jul 16, 2008 1:05 pm Post subject: Prop advice fixed pitch - Warpdrive or Arplast ? |
Jean-Paul,
Here are some figures that I measured earlier this year for a 912S Europa
using a 1600mm (63") diameter 130mm chord Arplast Ecoprop in place of the
64" wide chord Warp Drive (which had been set to 20.5 degrees at the tip).
The Ecoprop propeller came off a BanBi Club (which is the version with
longer wings than the normal (UK) BanBi) and for which direct performance
figures were available. So, to compare with the Club, the propeller was set
up at the same pitch as used on the Club
The BanBi performance figure is shown first, with the Europa figure
following in brackets (...).
Blade set at 20 degrees at the tip (no spinner on the Europa):
Max static was 4400rpm for both aircraft.
128 knts tas at 75% (130knts tas)
149 knts tas flat out (154knts tas 5500rpm)
1250 FPM (1200)
17 lph at 75% (16)
The results are the same within measurable error, except that the Europa was
faster!
The 20 degree pitch setting is OK for a 500m strip but for my short (<400m!)
strip and
fully loaded I needed to fine the prop to 18.25 degrees. Which then provided
almost identical take-off performance to the Warp Drive that I had on
previously, except that
fuel burn was 5 to 7% less with the Eco and vibration was reduced.
The Ecoprop does not "constant-speed" as well as the Warp Drive, so has a
narrower operational speed range, meaning more compromise for climb against
cruise performance.
The Ecoprop 130mm chord possibly has a little too much blade area for the
912S and could be better suited to the 914. I have not tried the 110mm chord
Ecoprop.
If I had the choice of the Warp or the Eco I would probably go for the
Eco. If I had a longer airfield I would definitely have the Eco.
Hope this is of use to you.
Duncan McF.
nwcmc(at)tiscali.co.uk Guest
Posted: Wed Jul 16, 2008 1:26 pm Post subject: Prop advice fixed pitch - Warpdrive or Arplast ? |
Hi Duncan
Did you mean 4400rpm static or did you mean 5400rpm?
Nigel Charles
Posted: Wed Jul 16, 2008 4:08 pm Post subject: Prop advice fixed pitch - Warpdrive or Arplast ? |
All
in my experience, (not as extensive as some on this list) the Eco prop
is an excellent compromise. (whatever you do, is compromise in aerodynamics)
Warp drive has good performance when stalled, ie at start of take off.
Thereafter it's efficiency starts to decline. In general I think it is
too stiff, (too much carbon, expensive and V Hi modulus) and designed
for slow airplanes with rag wings, the ECO uses carbon to resist
torsion, (best) and S glass to resist centrifugal loads, also best imho,
it's more flexible but hi modulus) .(forgive me if that may confuse
you,, (I've had a g&t) almost as strong as carbon but more extension
for the same load)
Ecoprop will give you a much smoother ride because it helps to damp out
the vibrations which the Warp Drive does not, it rings like a carbon
bell! and gives everything attached to it a harsh ride. (IMHO! get a
second opinion), I don't know as much as some of you guys do.
Jimmy Keppert in Austria has a lovely monwheel built by Trevor Jackson,
(kit no 3 I think) he has an Ecoprop and goes almost as well as Klaus
with a VP NSI, (Warp blades) Klaus' airplane is lovely too I must say. I
wish those guys would talk to us occasionally, they have valuable
experience to share, (which they do when asked)
Alain Petit who runs Arplast, I have known for many years and I respect
him.
Graham
> Engine is a 912ULS.
> Jean-Paul
Posted: Wed Jul 16, 2008 4:18 pm Post subject: Prop advice fixed pitch - Warpdrive or Arplast ? |
Jen-Paul
try an Ecoprop, Alain Petit knows what he is doing
graham
Engine is a 912ULS.
Jean-Paul
http://forums.matronics.com/viewtopic.php?p=193137#193137
air.guerner(at)orange.fr Guest
Posted: Thu Jul 17, 2008 11:22 am Post subject: Prop advice fixed pitch - Warpdrive or Arplast ? |
Jean Paul,
I do not know about performances but the Arplast blades are more flexible and therefore should run smoother than the Warp Drive. Arplast blades leading edge is unprotected and will erode when flying in rain. The first thing to do is to check with your GSAC if they would approve the use of Arplast. I believe they would ask you to prove that it is approved by the kit manufacturer. As the only prop approved by the Europa factory is the Warp Drive or the Airmaster with Warp Drive blades, I am afraid you may be in trouble.
Desolé de t'avoir raté à Vichy!
Remi Guerner
F-PGKL
gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Thu Jul 17, 2008 1:34 pm Post subject: Prop advice fixed pitch - Warpdrive or Arplast ? |
Does anybody know if the Arplast blades would fit a Warp Drive HD hub? My beloved Catto
3 blade is down for repairs after a prop strike. I was at the runup area doing a full power
static test in a 20 mph wind holding the tail down with full back stick. A 172 came by and
blasted me with his prop and that was too much for the elevator to deal with. The tail came
up and the prop struck pavement lightly before I got the tail back down. Oh well.
I like the WD hub but hate the blades on my 125 hp Soob. The 130mm wide Arplast blades look attractive!
Glenn
From: air.guerner(at)orange.frTo: europa-list(at)matronics.comSubject: Europa-List: Prop advice fixed pitch - Warpdrive or Arplast ?Date: Thu C 17 Jul 2008 21:19:05 +0200
Jean Paul C
I do not know about performances but the Arplast blades are more flexible and therefore should run smoother than the Warp Drive. Arplast blades leading edge is unprotected and will erode when flying in rain. The first thing to do is to check with your GSAC if they would approve the use of Arplast. I believe they would ask you to prove that it is approved by the kit manufacturer. As the only prop approved by the Europa factory is the Warp Drive or the Airmaster with Warp Drive blades C I am afraid you may be in trouble.
Remi Guerner
F-PGKL
- purchase new blades from Warpdrive (cheap and straightforward)- replace with an Arplast Ecoprop. From misc readings it looks better designedthan the Warpdrive C question being if the extra performance worths the extra cost
Posted: Thu Jul 17, 2008 3:49 pm Post subject: Prop advice fixed pitch - Warpdrive or Arplast ? |
Nigel, 4400, which is about 77hp on the 'S' engine. Rgds.,Duncan.
Posted: Thu Jul 17, 2008 3:58 pm Post subject: Prop advice fixed pitch - Warpdrive or Arplast ? |
Remi
you are probably right about the factory attitude but there are many UK
Europas flying with Arplast props. One of them is in Austria (Ecoprop)
Graham
Remi Guerner
F-PGKL
Posted: Thu Jul 17, 2008 4:06 pm Post subject: Prop advice fixed pitch - Warpdrive or Arplast ? |
Glenn
no, Arplast baldes are too big to fit in a Warp hub. IOW Warp blade hubs
are too small which is why they fail on Lycomings. The won't stand the
vibration. (tortional mostly)
Graham
glenn crowder wrote:
Quote: | Does anybody know if the Arplast blades would fit a Warp Drive HD hub?
Glenn
jpg12305
Posted: Fri Jul 18, 2008 10:52 am Post subject: r |
air.guerner(at)orange.fr wrote: | Jean Paul,
I do not know about performances but the Arplast blades are more flexible and therefore should run smoother than the Warp Drive. Arplast blades leading edge is unprotected and will erode when flying in rain. The first thing to do is to check with your GSAC if they would approve the use of Arplast. I believe they would ask you to prove that it is approved by the kit manufacturer. As the only prop approved by the Europa factory is the Warp Drive or the Airmaster with Warp Drive blades, I am afraid you may be in trouble. |
Thanks Remi.
I actually asked that question to the inspector, and he said that I should file a personal mod with a "Non Technical Objection" from Europa (need to contact Roger about that). He said as well that if the Arplast is already used on Europas, this will surely help. If I decide for the Ecoprop I will go first into that mod application process before spending any money !
Quote: |
Desol� de t'avoir rat� � Vichy!
Same for me. I went to Vichy last Sunday, and it was quite desertic ! Bad and rainy day.
In case you want to come to Amboise, let me know.
