To cut or not to cut?
Goto page Previous  1, 2, 3, 4  Next
Kirk Smith
PostPosted: Sat Mar 04, 2006 11:48 am    Post subject: Re: To cut or not to cut? Reply with quote
"I do have inspection holes but it's very hard to see very small hair-line
cracks"
Very well Very Happy .....I wish you good luck in resolving your dilemma to your satisfaction. By the way I looked at the pic of your plane and it certainly is a sharp looking Kolb.
JetPilot
PostPosted: Sat Mar 04, 2006 1:31 pm    Post subject: Re: To cut or not to cut? Reply with quote
I would not part with the airplane... The firestar is a great plane, and I would also keep the 503 on it, just respect VNE and rough air. What some people do not understand is that fatigue adds up over time to the point that a structure will fail one day with NORMAL loads. If there is fatigue in those ribs, keeping the loads down at this point will not keep you safe. If you read about fatigue failures in structures, its usually a result of many many hours of stress, and the structure finally breaks under NORMAL loads....
The angle aluminum and modification John recommends is only a couple pounds... Given the weight and power you have, a couple extra pounds will make no difference, we are talkng about less than a 1% change in gross weight. Not enough to worry about. You have flown the plane, if you like the way it flys at the heavy weight, keep flying it heavy, no need to trade your plane in. Just do the little bit of work that is need to make the ribs strong enough to handle the extra load. The firestar II is designed to be flown at those weights, so obviously the basic structure is very capable of handling it... Except for those 5 ribs, which is a pretty easy and inexpensive fix.
Michael A. Bigelow
Kolb MK-III Xtra, 912-S
Eugene Zimmerman
PostPosted: Sat Mar 04, 2006 2:15 pm    Post subject: To cut or not to cut? Reply with quote
Smile We can tell how much Kolb RE-building experience you have.
tkrolfe(at)usadatanet.net
PostPosted: Sat Mar 04, 2006 3:24 pm    Post subject: To cut or not to cut? Reply with quote
WhiskeyVictor36(at)aol.com wrote:
In a message dated 3/3/2006 11:06:25 A.M. Eastern Standard Time,
ul15rhb(at)juno.com writes:
The Original 5-rib wing Firestar had a gross weight limit of 535 lbs.
Ralph/John Murr/All,
Speaking of the original 1985 design model FireStar with 5 ribs and a Rotax
377 engine. I bought a kit from Homer on June 30, 1989 and have the plans
and builders manual.
I have never seen the gross weight stated in print on any of the
documentation I have, but on page 50 of the builders manual I quote, "The VNE of the
FireStar in calm air is 75 MPH. As the air gets turbulent, reduce your speed
accordingly. This airplane has a light wing loading. Stresses go way up if it
is fully loaded and the air gets rough".
I have replaced the 377 engine (at 425 hrs) with a 447, added the 1-1/8 inch
gear legs, brakes, 3/4 canopy, baggage board behind the seat and have a
second chance chute above my head between the wings. Instrumentation is ASI,
EGT, CHT, RPM, compass and ALT. Otherwise it is stock with a 5 gal. fuel tank.
Empty wt. (as an UL) is somewhat fat at about 280 lbs. With full fuel (5
gal. X 6 lb. p/gal.) of 30 lbs., plus my 140 lbs., my gross is at 450 lbs. On
occasion, when I go on a long X-country, I carry 4 more gals. of fuel in two
cans as baggage, adding another 24 lbs., for a gross of 474 lbs. Probably
more, as I didn't include weight for a small tool kit, tie down ropes, fuel
transfer hose, camera, cell phone, wallet full of $$ and other pocket items.
I am a very conservative flyer and do worry about overstressing the plane in
rough air, so I always slow down for a more comfortable ride for me.
John M, you will have to make your own decision on what to do. Modifying
the wing as John H suggested will add strength, but it also adds weight.
Calculate your gross weight carefully. Because of your personal body weight, you
might be better off with a two place Kolb. By the way, I've been to
Smoketown's breakfast fly-in several times in my Kolb. Weather permitting I will see
you there this year.
Bill Varnes
Original Kolb FireStar
Audubon NJ
Bill,
You should be advised that the Memorial Day Fly-in isn't going to be at
Smoketown this year. Seems that some disgruntled and "wiser" heads have
decided to move it to Lancaster Airport which is a controlled airspace.
I have met you several times at Smoketown and Homers and thought you
should be aware!
Terry - FireFly #95
DO NOT ARCHIVE
Earl Zimmerman
PostPosted: Sat Mar 04, 2006 4:14 pm    Post subject: To cut or not to cut? Reply with quote
John Murr wrote:
Anybody out there interested in a Firestar?
I think that you should sell it to me real cheap cause I'll soon be down
to only one plane in my hanger Smile ~ Earl
jbhart(at)onlyinternet.ne
PostPosted: Sat Mar 04, 2006 4:19 pm    Post subject: To cut or not to cut? Reply with quote
David, and others,
I have to take exception to this statement. It is simply not true. If the
structure is designed so that it will sustain "normal" loads and remain with
in the elastic limit of the structural material, no fatigue will take place.
Fatigue can only take place when the material is over stressed beyond its
elastic limit. When the elastic limit is surpassed, the material will take
a permanent set, but in most cases it will not fail. To get it to fail, the
same previously over stressed area must be repeatedly stressed in opposite
directions until a crack appears. Once the crack is initiated, structural
strength is greatly reduced. The only way this scenario can be played out
is if the structure was inadequately designed, or the structure was
subjected to repeated abuse.
Stay within the design operating limits (normal loads), and you will most
likely will never over stress the structure. I believe my FireFly receives
it greatest structural loading upon landing. If you do not beat up your
plane, it will take care of you.
Jack B. Hart FF004
Winchester, IN
jdm(at)wideworld.net
PostPosted: Sat Mar 04, 2006 4:46 pm    Post subject: To cut or not to cut? Reply with quote
LOL!
PostPosted: Sat Mar 04, 2006 4:49 pm    Post subject: To cut or not to cut? Reply with quote
What about 900 hours of engine vibration?
PostPosted: Sat Mar 04, 2006 5:27 pm    Post subject: To cut or not to cut? Reply with quote
John,
From my experience with the 447 on the FireFly, it shook the heck out of
things at 2,000 rpm or less, but ran smooth at cruise speeds. The only area
of concern I have on the FireFly is the left aileron/flaperon. The most
inboard piano hinge pin seems to wear out. Since I have removed much of the
slack from the aileron control system, it seems to be ok.
Jack B. Hart FF004
Winchester, IN
Eugene Zimmerman
PostPosted: Sat Mar 04, 2006 5:57 pm    Post subject: To cut or not to cut? Reply with quote
John,
your biggest concern on a high time air frame should be rust and
corrosion not "metal fatigue".
djwatson(at)olg.com
PostPosted: Sun Mar 05, 2006 5:49 am    Post subject: To cut or not to cut? Reply with quote
As a former owner of that very same Firestar, I agree with Eugene, it's
a great plane and I believe just as safe as it ever was. P.S. took it to
Sun-N-Fun a few times and received Reserve Grand Champion or something on
more than one occasion. I have seen pictures of it on web sites all over the
place and took some pride in the fact that it used to be mine. When I owned
it, it was powered by the 503 and it also had a BRS in it, sounds like the
BRS is no longer installed. I put very few hours on it, but it had nothing
to do with the plane, it was all a life timing thing.
When I first purchased the Firestar, I had some concern about it having
a 503 on it but was told by a few folks that I respected that you can never
have too much power as it might come in handy some day. I personally had
never operated it at full power as it just wasn't needed. That Firestar was
my first plane. When I was finished with my UL flight instruction in a Rans
S-12, I jumped into the Firestar and had no problems flying it. By the way,
I'm 6 foot and 210 pounds.
I have been sitting here reading all of the E-Mail about cutting, adding
more ribs, etc. and it has just made me sick thinking about it. I have seen
a man who went from being very happy with his Firestar to a person who it
now seems is afraid of the plane and might have no interest in flying it
again. I hope I'm wrong.
Have you ever seen the video of the Kolb being tested to destruction?
Dennis did up in PA. The Kolb is the only UL that I know of that has been
tested to destruction and it took a lot to do it!! One of the reasons I
wanted a Kolb.
This has been more than I ever have responded to any E-mail. Wish I
knew how to type fast. I'm with Eugene on the offer, but I'll up it by
500.00 Again, just joking!!!
John, you have a great Firestar on your hands that has proven itself
many many times over.
V/R
Dennis
PostPosted: Sun Mar 05, 2006 7:35 am    Post subject: To cut or not to cut? Reply with quote
The BRS was a BRS 1 I believe. It was mounted inside the fuselage. I
removed it because it was 12 years out of date. I have a new BRS 5, but I
haven't mounted it yet. It won't fit inside, so I have to mount it on top.
It's on my "to do: list.
JetPilot
PostPosted: Sun Mar 05, 2006 8:49 am    Post subject: Re: To cut or not to cut? Reply with quote
jbhart(at)onlyinternet.ne wrote:
David, and others,
Jack B. Hart FF004
Winchester, IN
You could not be more wrong about metal fatigue. In a perfect world where airplanes are designed perfectly parts would not fatigue, but we live in the real world and almost EVERY airplane ever designed has had failrues due to fatigue under normal operating conditions. From the first commercial jet, the Comet, metal fatigue started in the window frames and the airplanes started comming apart only with many thousands of pressure cycles, under NORMAL loads. I remember some of the L-1011's that I flew going into heavy maintenance due to wing spar cracks that developed over time and NORMAL use. DC-3's have lost wings after developing cracks in the wings... The governer of one of the western states was killed years back when his DC-3 came apart in flight in normal conditions. Many general aviation airplanes develop cracks in the tails, and AD's require thier inspection for cracks every so many hours (fatigue). Bottom line is fatigue cracks have been a constant problem in every type of plane from the smallest to the biggest. Anyone that says a plane will not fail due to metal fatigue under normal conditions obviously does not know what he is talking about.
As far as the ultralight in question, the owner was obviously wondering about this posibility prior to this discussion, why do you think he asked the question in the first place? This particular firestar is flown very heavy, and has been subjected to aerobatics (overloads), is very high time, pretty much the same scenario that caused another Firestars wing to fail... I just wonder how you can totally discount the possiblity that it could happen again.
Michael A. Bigelow
Mike Schnabel
PostPosted: Sun Mar 05, 2006 10:12 am    Post subject: To cut or not to cut? Reply with quote
Dennis, I would love to see the video of the Kolb flown to the point of destruction. Do you have a copy? Is it on the internet anywhere? If not, and if i could get a copy, i would be glad to post it on the net for all the Kolb'ers to view. So anyone that has a copy, please contact me.
Mike S
Manchester TN
Firestar 2 503
destruction?
been
wanted a Kolb.
V/R
Dennis
PostPosted: Sun Mar 05, 2006 4:43 pm    Post subject: To cut or not to cut? Reply with quote
In a message dated 3/4/2006 6:25:04 P.M. Eastern Standard Time,
tkrolfe(at)usadatanet.net writes:
Hi Terry,
Oh no! That's terrible! What are they thinking?
Well, that lets me out. I'm not equipped to fly in controlled airspace.
But, if Smoketown is still UL friendly, I guess there's nothing to stop us from
going there on our own. We can still fly in and have breakfast or lunch.
Just have to walk up the street to that great little restaurant around the
corner.
Thanks for the info.
Bill Varnes
Audubon NJ
PostPosted: Sun Mar 05, 2006 4:56 pm    Post subject: To cut or not to cut? Reply with quote
All you need is a radio to fly into class D airspace. There are ultralights
based there. Don't let this discourage you from attending.
PostPosted: Sun Mar 05, 2006 6:40 pm    Post subject: To cut or not to cut? Reply with quote
Hi Terry,
corner.
Bill Varnes
Audubon NJ
Bill, If you and your buddy decide to fly into Smoketown on Memorial
Day any way let me know and I will join you. I didn't lose anything at
Lancaster Airport and don't intend to go there to find it. Smoketown is
more than UL friendly all of the time!!!!!!
Terry
DO NOT ARCHIVE
a58r(at)verizon.net
PostPosted: Sun Mar 05, 2006 7:41 pm    Post subject: To cut or not to cut? Reply with quote
For strength, look at this: http://www,angelfire,com/rpg/ronoy/B-17.png
regards,
Bob N.
a58r(at)verizon.net
do not rechive
a58r(at)verizon.net
PostPosted: Sun Mar 05, 2006 8:01 pm    Post subject: To cut or not to cut? Reply with quote
Geez, I've got to take some meds for my peripheral neuropathy! Or
maybe taking my boxing gloves off!
Try this http://www.angelfire.com/rpg/ronoy/B-17.png
regards,
Bob N.
a58r(at)verizon.net
edchmiel(at)mindspring.co
PostPosted: Sun Mar 05, 2006 8:13 pm    Post subject: To cut or not to cut? Reply with quote
Hi Bob,
That worked gooder! Lots of daylight under that vertical stab.
Great pic!
Ed in JXN
Do not archive.
Page 3 of 4
