Lew Gallagher
Posted: Sat Aug 02, 2008 2:40 pm Post subject: toner in windshield fairing |
OK, Tim and others.
I really like the idea of coloring the lower windshield fairing resin black so that it looks good from inside. BUT, I've taken to heart those who frown on skimming over fiberglass with bondo type materials.
Now then, I've got a good friend who is in charge of toner for Lexmark and I thought I remembered him saying that most of toner is styrene, i.e. polymer, plastic, whatever that stuff is. So today I called him and he verified that only less than 10% of toner is carbon black. So now I'm wondering how that affects the bonding quality of fiberglass resin mixed with toner ...? Apparently, Tim, you've had no ill effects and you said it doesn't take much toner to turn it black, but I was just wondering if anyone has thought about this, and if there's a source of pure carbon black?
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Tim Olson
Posted: Sat Aug 02, 2008 3:27 pm Post subject: toner in windshield fairing |
Nope, no effect found. Also, you don't want to use any bondo
like products over the fiberglass...you want to use something
like West System epoxy to do the fiberglassing, and then use
west system fairing filler and epoxy to do the filling above.
Lew Gallagher wrote:
<lewgall(at)charter.net>
OK, Tim and others.
materials.
Later, - Lew
-------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549
Engine and FF here, now cowl and baffels,waiting on prop.
http://forums.matronics.com/viewtopic.php?p=196210#196210
coop85(at)cableone.net Guest
Posted: Sat Aug 02, 2008 3:57 pm Post subject: toner in windshield fairing |
Lew,
No help for finding pure carbon black, but FWIW I've got almost 3 years
with the toner/resin mix and no ill effects on the canopy.
May sound silly, but how about grinding some charcoal mortar/pestle style?
Marcus
pascal(at)rv10builder.net Guest
Posted: Sat Aug 02, 2008 4:01 pm Post subject: toner in windshield fairing |
Is that something like Microballoons and epoxy?
Sent: Saturday, August 02, 2008 4:24 PM
Subject: Re: toner in windshield fairing
> OK, Tim and others.
> materials.
> Later, - Lew
> http://www.matronics.com/Navigator?RV10-List
Posted: Sat Aug 02, 2008 4:18 pm Post subject: toner in windshield fairing |
Yes
Rick. Sked
Sent via BlackBerry by AT&T
Tim Olson
Posted: Sat Aug 02, 2008 4:27 pm Post subject: toner in windshield fairing |
They have a variety:
http://www.myrv10.com/tips/options.html
http://www.westsystem.com/
Go to the product guide
410 Microlight is just one of the things you'll use tons of.
Great stuff, sands well. The guy who helped paint was impressed
as heck with it.
406 Colloidal silica is another one you'll use, along with one
other that I can't remember right now.
You'll go through cans and cans of 410 by the time you're done
with the project, and gallons of epoxy. People have no idea
how much you can spend on epoxy supplies to finish the kit...it's
hundreds of dollars.
pascal wrote:
> Tim Olson - RV-10 N104CD - Flying
> do not archive
>> OK, Tim and others.
>> materials.
>> Later, - Lew
Posted: Sat Aug 02, 2008 4:57 pm Post subject: toner in windshield fairing |
Gallons??? Comon. Tim... Maybe 4 quarts!! Did you glue yours together? All smiles!
Rick Sked
40185
Bill Schlatterer
Posted: Sat Aug 02, 2008 6:57 pm Post subject: toner in windshield fairing |
Lew, why not just try the stuff that is made for it. I doubt they would be
selling it if it made any significant difference in strength. This is the
link to the product at ACS. I bought some but have not used it yet.
http://www.aircraftspruce.com/catalog/cmpages/epoxyPigments.php
Hope this helps.
Bill S
7a Finishing
Lew Gallagher
Posted: Sat Aug 02, 2008 7:42 pm Post subject: Re: toner in windshield fairing |
Well, there ya go.
Thanks, Bill !!
flywrights(at)yahoo.com Guest
Posted: Sun Aug 03, 2008 11:16 am Post subject: toner in windshield fairing |
West Marine, epoxy colorant. Mine had to order black; they seemed to have every color but. Comes in a small toothpaste-sized tube. Only takes a small dribble to turn a fair amount of epoxy black.
Rob
#392
fairing sanding and propeller work
drfred(at)suddenlinkmail. Guest
Posted: Sun Aug 03, 2008 12:42 pm Post subject: toner in windshield fairing |
Putting the layers on today. With toner. Also using some of the
carbon fiber to replace a couple layers of fiber glass. Making sure the
layer next to the window is carbon fiber. Should give me a nice black
inside without painting the inside of the window.
Fred
OK, Tim and others.
Later, - Lew
non-pilot
rene(at)felker.com Guest
Posted: Sun Aug 03, 2008 3:38 pm Post subject: toner in windshield fairing |
No expert here, but I don't think you want the carbon fiber to be the first
layer, it would be in contact with the al skin and could cause a corrosion
problem.
Rene'
801-721-6080
Lew Gallagher
Posted: Sun Aug 03, 2008 4:17 pm Post subject: Re: toner in windshield fairing |
Thanks Guys,
If our West Systems dealer here has the black, that's definitely the way to go with no worries. We'll find out tomorrow.
Carbon same as graphite as a corrosive to aluminum? I dunno, Rene'.
Later, - Lew
Posted: Sun Aug 03, 2008 4:19 pm Post subject: toner in windshield fairing |
Rene'
By the time I had any significant lay up on the window it's about the 4
or 5th layer that really goes up the inside of the glass. I put it high
up and not in contact with the aluminum.
Thanks for the warning.
Fred
problem.
Rene'
801-721-6080
AV8ORJWC
Posted: Sun Aug 03, 2008 5:13 pm Post subject: toner in windshield fairing |
Carbon Black is a common ingredient in Printing Inks. I will check with
sources from General/Frederick Levy Ink suppliers and others chemical
suppliers and report back.
John C
