plexiglass cleaning
greghale
PostPosted: Mon Nov 17, 2008 3:53 pm    Post subject: plexiglass cleaning Reply with quote
OK I know I have probably done the bad deed, but I used a combination of masking tape and duct tape to retain the plastic sheet on my windows while I was doing some body work. You probably already know that the duct tape left globs of adhesive behind when I tried removing it. Is there a product I can use to remove the adhesive safely without destroying my windows and windshield. The duct tape has been on the windows for almost a year.
Thanks...Greg
Greg Hale rv10 -- N210KH
www.nwacaptain.com
Kelly McMullen
PostPosted: Mon Nov 17, 2008 4:15 pm    Post subject: plexiglass cleaning Reply with quote
Isopropyl alcohol, high purity, 90% or better.
Thanks...Greg
www.nwacaptain.com
http://forums.matronics.com/viewtopic.php?p 14784#214784
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
indigoonlatigo(at)MSN.COM
PostPosted: Mon Nov 17, 2008 4:24 pm    Post subject: plexiglass cleaning Reply with quote
If denatured alcohol doesn't work get a plexiglass cleaner C it has some form of petroleum distilates that microscopically clean craze lines from the plexi glass and it might also remove the duct tape adhessive.
I have had no problems using the denatured alcohol C but maybe others can chime in.
John G.
Subject: plexiglass cleaning
Date: Mon C 17 Nov 2008 15:53:07 -0800
--> RV10-List message posted by: "greghale" <ghale5224(at)aol.com>
OK I know I have probably done the bad deed C but I used a combination of masking tape and duct tape to retain the plastic sheet on my windows while I was doing some body work. You probably already know that the duct tape left globs of adhesive behind when I tried removing it. Is there a product I can use to remove the adhesive safely without destroying my windows and windshield. The duct tape has been on the windows for almost a year.
Thanks...Greg
www.nwacaptain.com
http://forums.matronics.com/viewtopic.php?p=214784#214784
Archive Search & Download C 7-Day Browse C Chat C FAQ C
&gt==================
Tim Olson
PostPosted: Mon Nov 17, 2008 4:52 pm    Post subject: plexiglass cleaning Reply with quote
Kerosene.
Thanks...Greg
-------- Greg Hale rv10 -- N210KH www.nwacaptain.com
dlm46007(at)cox.net
PostPosted: Mon Nov 17, 2008 4:58 pm    Post subject: plexiglass cleaning Reply with quote
Plexus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
Sent: Monday, November 17, 2008 5:21 PM
To: RV 10 group
Subject: RE: plexiglass cleaning
If denatured alcohol doesn't work get a plexiglass cleaner, it has some form of petroleum distilates that microscopically clean craze lines from the plexi glass and it might also remove the duct tape adhessive.
I have had no problems using the denatured alcohol, but maybe others can chime in.
John G.
Date: Mon, 17 Nov 2008 15:53:07 -0800
Thanks...Greg
www.nwacaptain.com
Archive Search & Download, 7-Day Browse, Chat, FAQ,
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Kelly McMullen
PostPosted: Mon Nov 17, 2008 6:13 pm    Post subject: plexiglass cleaning Reply with quote
I would avoid denatured alcohol, as it contains methanol. Either
Isopropyl or as Tim suggested, kerosene are safe for plexi.
On Mon, Nov 17, 2008 at 5:21 PM, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
chime in.
John G.
> From: ghale5224(at)aol.com
> To: rv10-list(at)matronics.com
> Thanks...Greg
> www.nwacaptain.com
Kelly McMullen
KCHD
PostPosted: Mon Nov 17, 2008 7:14 pm    Post subject: plexiglass cleaning Reply with quote
Okay C it has been quite a number of years since my organic chemistry days C but indeed denatured alcohol may have methanol added to the ethanol so that it cannot be easily converted to drinkable ethanol C but basically methanol is just a primary alcohol containing only one carbon atom C four hydrogen and one oxygen. Isopropyl alcohol has three carbon atoms C eight hydrogens and one oxygen. Isopropyl comes in different purities C some with higher water concentrations than others. One more distilled then other.
I would think that ethanol C denatured alcohol C or high or low grade isopropyl would all be safe for plexi...at least that has been my experience with my RV 10 C all my RC airplanes and the plastic canopies on my Ravell and Monogram plastic models as a kid. Has someone had a bad experience with methanol C not to be confused with methane...your spouse's gas after that rich dinner.
Thanks for bringing me back to my organic chemistry atom model building days in undergrad.
Now I just build teeth and planes C what ever happened to all that knowledge I once had...so sad!
John G
Date: Mon C 17 Nov 2008 19:12:19 -0700
Subject: Re: plexiglass cleaning
planesmith(at)hotmail.com
PostPosted: Mon Nov 17, 2008 9:31 pm    Post subject: plexiglass cleaning Reply with quote
A product I have used is 5 star Brand Wax & Grease Remover #5900. I bought it from an Auto Quest's paint shop. It was recommended to me by an A&P when I had some old paint over spray to remove from a Cessna 150 window. Not sure what it is other than being petroleum based. Probably just a good grade of kerosene C like Tim recommended.
 Vern Smith (#324 fairings)
Thanks...Greg
www.nwacaptain.com
Color coding for safety: Windows Live Hotmail alerts you to suspicious email. Sign up today.
