greghale
Joined: 10 Jan 2007 Posts: 91 Location: Tulsa, Oklahoma
Posted: Mon Nov 17, 2008 3:53 pm Post subject: plexiglass cleaning |
OK I know I have probably done the bad deed, but I used a combination of masking tape and duct tape to retain the plastic sheet on my windows while I was doing some body work. You probably already know that the duct tape left globs of adhesive behind when I tried removing it. Is there a product I can use to remove the adhesive safely without destroying my windows and windshield. The duct tape has been on the windows for almost a year.
Thanks...Greg
_________________ Greg Hale rv10 -- N210KH
www.nwacaptain.com |
Kelly McMullen
Posted: Mon Nov 17, 2008 4:15 pm Post subject: plexiglass cleaning |
Isopropyl alcohol, high purity, 90% or better.
On Mon, Nov 17, 2008 at 4:53 PM, greghale <ghale5224(at)aol.com> wrote:
Thanks...Greg
www.nwacaptain.com
http://forums.matronics.com/viewtopic.php?p 14784#214784
A&P/IA, EAA Tech Counselor
KCHD |
indigoonlatigo(at)MSN.COM Guest
Posted: Mon Nov 17, 2008 4:24 pm Post subject: plexiglass cleaning |
If denatured alcohol doesn't work get a plexiglass cleaner C it has some form of petroleum distilates that microscopically clean craze lines from the plexi glass and it might also remove the duct tape adhessive.
I have had no problems using the denatured alcohol C but maybe others can chime in.
John G.
| Quote: | Subject: plexiglass cleaning
Date: Mon C 17 Nov 2008 15:53:07 -0800
--> RV10-List message posted by: "greghale" <ghale5224(at)aol.com>
OK I know I have probably done the bad deed C but I used a combination of masking tape and duct tape to retain the plastic sheet on my windows while I was doing some body work. You probably already know that the duct tape left globs of adhesive behind when I tried removing it. Is there a product I can use to remove the adhesive safely without destroying my windows and windshield. The duct tape has been on the windows for almost a year.
Thanks...Greg
www.nwacaptain.com
http://forums.matronics.com/viewtopic.php?p=214784#214784
Archive Search & Download C 7-Day Browse C Chat C FAQ C
Tim Olson
Posted: Mon Nov 17, 2008 4:52 pm Post subject: plexiglass cleaning |
Kerosene.
greghale wrote:
Thanks...Greg
-------- Greg Hale rv10 -- N210KH www.nwacaptain.com
dlm46007(at)cox.net Guest
Posted: Mon Nov 17, 2008 4:58 pm Post subject: plexiglass cleaning |
Plexus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
Sent: Monday, November 17, 2008 5:21 PM
To: RV 10 group
Subject: RE: plexiglass cleaning
If denatured alcohol doesn't work get a plexiglass cleaner, it has some form of petroleum distilates that microscopically clean craze lines from the plexi glass and it might also remove the duct tape adhessive.
I have had no problems using the denatured alcohol, but maybe others can chime in.
John G.
Date: Mon, 17 Nov 2008 15:53:07 -0800
Thanks...Greg
www.nwacaptain.com
Archive Search & Download, 7-Day Browse, Chat, FAQ,
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Kelly McMullen
Posted: Mon Nov 17, 2008 6:13 pm Post subject: plexiglass cleaning |
I would avoid denatured alcohol, as it contains methanol. Either
Isopropyl or as Tim suggested, kerosene are safe for plexi.
On Mon, Nov 17, 2008 at 5:21 PM, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
| Quote: | If denatured alcohol doesn't work get a plexiglass cleaner, it has some form
chime in.
John G.
> From: ghale5224(at)aol.com
> To: rv10-list(at)matronics.com
> Thanks...Greg
> www.nwacaptain.com
KCHD |
planesmith(at)hotmail.com Guest
Posted: Mon Nov 17, 2008 9:31 pm Post subject: plexiglass cleaning |
A product I have used is 5 star Brand Wax & Grease Remover #5900. I bought it from an Auto Quest's paint shop. It was recommended to me by an A&P when I had some old paint over spray to remove from a Cessna 150 window. Not sure what it is other than being petroleum based. Probably just a good grade of kerosene C like Tim recommended.
Vern Smith (#324 fairings)
Thanks...Greg
www.nwacaptain.com
Color coding for safety: Windows Live Hotmail alerts you to suspicious email. Sign up today. |
