autopilot
raimo.toivio(at)rwm.fi
PostPosted: Thu Nov 20, 2008 9:23 am    Post subject: autopilot Reply with quote
All
I got so much encouraging info about Trio Avionicīs autopilot
and so I decided to go on it. I have it here and will install asap I
get plane home. Trioīs customer service has been so far outstanding,
all the data and instructions great and easy to follow and
even the packning was superb.
The Gold Servo really looks golden...but happily not so heavy.
Thanks for many positive inputs like Frans Vīs, Peter Rīs and Steven Pīs.
Raimo from Finland
OH-XRT
g-iani(at)ntlworld.com
PostPosted: Thu Nov 20, 2008 10:02 am    Post subject: autopilot Reply with quote
Raimo
I have attached a copy of the Mod covering the Trio which is with the LAA.
I have been chasing Andy Draper to get it approved for some weeks.
I hope it may help.
I have a supply of the actuator arms being made if you have any problems
sourcing locally.
Ian Rickard G-IANI XS Trigear, 200 hours
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
10507Autopilot.pdf
Download
 Filename:  10507Autopilot.pdf
 Filesize:  486.98 KB
 Downloaded:  254 Time(s)
topglock(at)cox.net
PostPosted: Thu Nov 20, 2008 10:13 am    Post subject: autopilot Reply with quote
Congratulations, Raimo. I know you'll enjoy your unit. I installed the
altitude hold, this past summer...
Jeff - Baby Blue
400+ hours
Raimo Toivio wrote:
All
Raimo from Finland
OH-XRT
Checked by AVG - http://www.avg.com
mikenjulie.parkin(at)btin
PostPosted: Thu Nov 20, 2008 1:03 pm    Post subject: autopilot Reply with quote
Ian,
I have the Navaid wing-leveller which I am about to retrofit with the Trio
control head but retaining the Navaid servo, did you apply for general
modification approval or is it just your own personal application.
If you are interested, I have also bought the trio altitude hold. I have
fitted the new gold servo and introduced an additional control horn. I am
in the process of putting a mod leaflet together for the alt hold system.
I suspect from your comment, that the modification turnround by the LAA is a
lamentable as it was when their title was PFA.
Mike.
PostPosted: Fri Nov 21, 2008 2:11 am    Post subject: autopilot Reply with quote
Mike and others
I will know the cost of the arms in a week or so.
The Mod application covers the Navaid, TruTrack and Trio SINGLE AXIS (Roll)
only. I started by doing the TruTrack but Andy asked me to do it as a
generic mod for all three. This means that the old Navaid mod (10507) will
be replaced with this version. The continued use of the Navaid Servo with a
new head (Trio) is (from memory) covered. The mod also refers to (rather
than repeats) the LAA document "LAA Inspection Checks LA/IC-APWL".
I am aware of two owners waiting on the approval, one TruTrack and one Trio.
If anyone wants a copy of the draft Mod let me know.
As you say turnaround of Mods with the LAA can be very slow. This is
particularly true if they are not holding up someone's permit to test. I
have chased Andy again this week.
karelvranken(at)hotmail.c
PostPosted: Fri Nov 21, 2008 12:57 pm    Post subject: autopilot Reply with quote
Dear Ian,
The one waiting for the TruTrack approval is me, I hope. Otherwise you may
me count in.
Best regards,
Karel Vranken, # 447 F-PKRL 203 hours.
PostPosted: Sat Nov 22, 2008 3:05 am    Post subject: autopilot Reply with quote
Karel
The two I referred to are both in the UK so you are the third. So even more
reason to pressure Andy Draper.
justin(at)systemwise.co.u
PostPosted: Mon Nov 24, 2008 2:11 am    Post subject: autopilot Reply with quote
DO NOT ARCHIVE
Ian,
I too am hoping to install a Trio roll axis autopilot in my Europa G-ZTED this winter,
I really appreciate a copy of the mod when you finally get it.
Anyway could you advise me the mod number when it is released.
Keep pushing.
Justin
Monowheel Classic G-ZTED
PostPosted: Mon Nov 24, 2008 3:00 am    Post subject: autopilot Reply with quote
Justin
Copy of the mod attached. At present it is with Andy, as a draft, but I do not expect much to change much.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Justin Kennedy
Sent: 24 November 2008 10:09
Subject: Europa-List: autopilot
DO NOT ARCHIVE
Ian,
Keep pushing.
Justin
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
10507Autopilot.pdf
Download
 Filesize:  486.98 KB
PostPosted: Mon Nov 24, 2008 7:04 am    Post subject: autopilot Reply with quote
Ian,
this is a great support - I follow these instructions as much as possibe.
Thank you, Raimo
