VG affect on stall
Goto page Previous  1, 2
PostPosted: Fri Dec 12, 2008 2:10 pm    Post subject: VG affect on stall Reply with quote
The research has already been done over many years. I prefer to use the
design and placement that a lot of aeronautical engineers have developed
over the years than try to guess on VG placement.
Mike
Mike:
Looks like we are getting a lot of VG manufacturers out there all over the
world.
Do you believe each one of these VG manufacturers has done the research and
testing to provide precise guidance on where to place their VGs on your
Kolb's wings?
mkIII-Slick wing!
Dana
PostPosted: Fri Dec 12, 2008 2:31 pm    Post subject: VG affect on stall Reply with quote
world.
and testing to provide precise guidance on where to place their VGs on
your Kolb's wings?
Well, as long as the _first_ manufacturer did the R&D... everybody else is
probably just copying them...
-Dana (still VG-less in CT)
If we wish to "restore" respect for the law, a good start would be to
pass only laws that people will respect.
PostPosted: Fri Dec 12, 2008 2:42 pm    Post subject: VG affect on stall Reply with quote
is
Dana:
Do you think any of those vg manufacturers ever went so far as do testing on
a Kolb wing?
How do we know what precise is, when placing those little buggers on our
wings and under our tails?
I bet if you get right down to the real nitty gritty, you will discover
there is very, very little serious flight or simulated flight testing on any
UL or experiemental homebuilt.
mkIII-Who did his own testing, good and bad.
JetPilot
PostPosted: Fri Dec 12, 2008 3:39 pm    Post subject: Re: VG affect on stall Reply with quote
I doubt that any manufacturer did testing on the Kolb wing, but they have on many other wings. For the type of airplanes we fly, and the speeds we fly at, VG placement on wings is pretty much universal. In the video below, you see these guys carefully placing VG's right where they should be, at about 10 % of the chord of the wing behind the leading edge, and equally spaced at about 1 % the span of the wing. On my Kolb, I placed my VG's at slightly less than 1 % of the span because it is desirable to put each pair of VG's in the rib valleys, all VG's evenly spaced, 2.5 inches spacing between all VG's on my Kolb. Even more important than the spacing is that VG's be EXACTLY 15 degrees "Nose In " to the relative wind, that is where they create the most efficient "tornado" above the wing without adding excessive drag. It is necessary to use a template to get the correct angle on VG's. The video shows how its done Smile
http://www.youtube.com/watch?v=YQO7SoULc3U&feature=related
Mike
Kolb MK-III Xtra, 912-S
PostPosted: Fri Dec 12, 2008 4:03 pm    Post subject: VG affect on stall Reply with quote
Mike
"NO FEAR" - If you have no fear you did not go as fast as you
could have !!!
http://forums.matronics.com/viewtopic.php?p 19134#219134
PostPosted: Fri Dec 12, 2008 4:10 pm    Post subject: VG affect on stall Reply with quote
Sorry, Gang:
Looks like I fired a blank.
Was thinking about replying and changed my mind.
HShack(at)aol.com
PostPosted: Fri Dec 12, 2008 7:34 pm    Post subject: VG affect on stall Reply with quote
Mike,unlike you, I put VG's on every rib of my wings. I didn't just stick them on willy-nilly. I actually picked a spot chord-wise & used a chalk-line. And, yes, I used a template to accurately place them.  I actually did quite a bit of testing on my FS II, moving the VG's chordwise many times. As it turns out, my original location proved to be the most effective on MY plane [my VG's are very different from landshorters].
I shared my design with several hundred pilots, mostly Kolbers. My design may not be optimal, but for the price, results were very good. Never had anyone ask for their money back
Howard Shackleford
FS II
SC do not archive
In a message dated 12/12/2008 1:05:38 P.M. Eastern Standard Time, orcabonita(at)hotmail.com writes:
If you put VG's on only part of the wing, you only get part of the benefit. Being that you guessed where your VG's should go, and that you guessed on the design of your VG's, its no wonder you ended up with some bad characteristics and scared yourself. If you put anything on the wrong part of a wing, including VG's, they can go from being a benefit to being dangerous very quickly. I would not want to be the test pilot on an airplane with poorly place VG's [Shocked]
Here is a video of some guys that put VG's on their airplane the right way, using precise measurements to get them in the correct place on the wing, and getting the exact angles of the VG's to the airstream using templates.
Make your life easier with all your friends, email, and favorite sites in one plid=emlcntaolcom00000010">Try it now.
etzimm(at)gmail.com
PostPosted: Sat Dec 13, 2008 5:57 am    Post subject: VG affect on stall Reply with quote
discover there is very, very little serious flight or simulated
flight testing on any UL or experiemental homebuilt.
John,
I bet if you get right down to the nitty gritty you will discover
that most experimental planes are never actually involved in any real
experimental testing. "Experimental aircraft " is in that case a
misnomer.
The actual testing in most cases is not a testing of the plane, but
most often the real test is a test that reveals whether a person
is, or is not, a real pilot.
How many Kolb "planes" ever proved to be unsatisfactory as a flying
experiment?
How many Kolb "pilots" ever proved to be unsatisfactory as a flying
experiment?
In most cases it is the pilot that is ,,,,,,,,,,, "EXPERIMENTAL"
It is always true in my case anyways ,,,,,,, because the EXPERIENCE is
always mine.
I am always "experimental" ,,,,,,,,,,,, every once in a while my
plane is also.
PostPosted: Sat Dec 13, 2008 6:42 am    Post subject: VG affect on stall Reply with quote
always mine.
I am always "experimental" ,,,,,,,,,,,, every once in a while my plane
is also.
Gene Z:
Good point.
True in my case.
Was and still is a big learning curve flying these little airplanes.
Up until 1990, I flew the single place Kolbs. Never had any professional
instruction. Never had a check ride. Never had another pilot ride along to
see if what I was doing was right or wrong.
In the Army it was a constant series of check rides and standardization. I
enjoy the freedom of my sport, but it can lead to some serious problems if I
let it. Sometimes I don't know if I am letting it or not.
This morning I am going to the airstrip to see if I caught anything. Put
out two big rat traps with peanut butter. Used safety wire to secure them
in place, in case I get a really big one that wants to walk off with my
traps.
I notices yesterday the four trays of Decon were cleaned out. I put them
out and did not have a chance to check them for 48 hours.
The glue traps had caught some pretty big grass hoppers, but that's all.
Brother Jim has volunteered to sew me up some more seat belts and shoulder
harnesses.
I discovered the DRE 6000 ANR headsets are coming back. Aircraft Spruce has
them for 359.00. Wiring in my old set got chewed up, plus they are getting
on in age and hours. I ordered some new ones last night, but they were back
ordered. I like the DRE6000 because I can plug them into the aircraft 12VDC
system and not have to worry about batteries, just rats. Wink
Was 24F this morning. Must have been the nearness of the full moon last
night.
mkIII - Putting another log on the fire.
ez(at)embarqmail.com
PostPosted: Sat Dec 13, 2008 10:06 am    Post subject: VG affect on stall Reply with quote
John,
misnomer.
experiment?
experiment?
always mine.
plane is also.
_____|_____
*=======================R=======================*
\___/
Eugene Zimmerman
etzimm(at)gmail.com
PostPosted: Sat Dec 13, 2008 10:20 am    Post subject: VG affect on stall Reply with quote
Oooops,
Looks like I just posted a duplicate.
Sorry.
Gene
John,
real experimental testing. "Experimental aircraft " is in that case
a misnomer.
flying experiment?
experiment?
is always mine.
plane is also.
_____|_____
\___/
Eugene Zimmerman
Page 2 of 2
