icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Fri Dec 12, 2008 7:14 pm Post subject: xtra wingtip mods |
We've finished modifying our wing to accept fiberglass wingtips. The tips themselves are also finished and ready for primer. A DAR stopped by and checked over the wingtip mods as well as the rest of the plane. He had no issues with the entire inspection and OK'd us to start covering.
http://www.ill-eagleaviation.com/wingtip_modifications.htm
We also ran the engine last week. All seems well with the used engine. We'll leave the engine on until we're finished making the gap seal. Then the whole thing will be taken apart for paint and fabric. Our instalation is a little different than stock. I haven't made a engine webpage yet but when i do i'll post a link.
_________________ Scott
www.ill-EagleAviation.com
do not archive |
icrashrc
Posted: Sat Dec 13, 2008 6:28 am Post subject: xtra wingtip mods |
Scott:
How and where are you all going to attach and rig your aileron counter
balance weights?
_________________ John Hauck
Titus, Alabama |
icrashrc
Posted: Sun Dec 14, 2008 3:42 am Post subject: Re: xtra wingtip mods |
| John Hauck wrote: | Scott:
balance weights?
mkIII |
John,
The mass balances are nothing but a mechanical drawing right now. As soon as i finish the stress analysis i'll build a mock up and test it per FAA regs. I'll post pictures when we have the load limit testing complete.
do not archive |
icrashrc
Posted: Tue Feb 24, 2009 8:03 am Post subject: xtra wingtip mods |
Morning Scott:
Looks good.
When I built my mkIII in 1991, I knew I needed aileron counter balance
weights. Both my Ultrastar and Firestar suffered from aileron flutter. I
could not convince Kolb Aircraft I had a flutter problem, so I designed and
built my own. Wish I had a photo of them. They were pretty. Built similar
to your design, I used 1/8" aluminum plate instead of 4130 streamlined
tubing. My weight was tubular with a turned round nose and tapered tail. I
attached them to the inboard end of the aileron. Early on, during testing,
I experienced severe aileron flutter them installed. Happened to be at the
local airport, landed, and promptly removed them. Flew to Lakeland, Homer's
in PA, and OSH, in 1993, always sitting on the edge of my seat trying to
keep the mkIII close to 80 mph. A couple over and she would start to
flutter. Had a hell of a time trying to fly off a Cessna 210, at OSH, doing
the photo shoot. He was trying to slow down to 80 and I had to fly faster
than 80 to stay up with him. Think it was Lakeland 1994, Dick Rahill had
been out flying the Firestar, got caught is a typical Lakeland wind storm,
was trying to beat feet back to the UL strip, and got into very severe
aileron flutter. Now Kolb Aircraft believed their airplanes were
susceptible to aileron flutter. In a matter of days I had a copy of the new
aileron counter balance weights designed and built for the FS. Their
factory mkIII never fluttered and they were not convinced it needed them. I
flew with the FS counter balance weights on mty 17,400 mile trip to Alaska
and around the country in 1994. They were a blessing. My mkIII has never
had a hint of aileron flutter since I installed them. Made my flying 100%
more comfortable. Soon after they designed and built aileron counter
balance weights for the mkIII.
I really like the center section. Wish I had one similar. Being an
amateur, when I built my mkIII, I ended up with the windshield about 6"
behind the leading edge of the center section. This is a very effect air
scoop, dead air. Randy, at TNK, built me a fairing, but during finishing it
ended up not fitting correctly. Another area of dead air is behind the
doors in the area of both rear quarter windows. Brother Jim and I have
talked about the fix for this many times, but never get around to doing it.
We think a slat, similar to those used on the OH-58 (Bell Jet Ranger) would
work on the sides, and a lexan or sheet metal fairing to kill the hole
between the windshield and leading edge of the center section would fix that
area of drag. How much more cruise speed would it give us? Don't know, but
would be bound to improve some. I lost 5 mph top end installing the 8"
Maule Tundra Tail Wheel, but I don't want to give it up because it works so
well on the ground. Has tapered roller bearings in the pivot and lasts much
longer than the bushed pivots.
Oh well, I am happy with an 80 mph cruise. That has not changed. If I am
patient, I eventually get every where I want to go.
Good work guys,
Titus, Alabama |
icrashrc
Posted: Tue Feb 24, 2009 7:32 pm Post subject: Re: xtra wingtip mods |
John,
Thanks for the words of wisdom. Sometimes we forget how much of a test pilot the was required as the earlier designs evolved.
I'm sure you now know the reason your first mass balances were ineffective was because of the inboard mounting position. That allowed the LE tube to act as a spring and could have well made the problem worse instead of better.
We used your current mass balances for a start on weight needed. I calculated the weight of yours, added a fudge factor, and sized ours to be a little heavier. I'll be able to drill out some of the lead if i need to after the ailerons are covered and painted.
I'll add more info on the center section in the next day or two. I have Paul writing that up for me. It's been a pain in the rear but we both think it will work out well.
You're right about the area behind the doors. Getting the air to turn there would, if nothing else, help feed air to the bottom half of the prop. Clean air to the prop it always good! We may look at trying something it that area ourselves but not until after the plane is finished and flying.
5mph from just the tail-wheel is a lot!
do not archive |
Posted: Tue Feb 24, 2009 7:52 pm Post subject: xtra wingtip mods |
Indicated airspeed. May be like me, getting old and unreliable.
It is a rather large tail wheel compared to the first one I had on this
mkIII. It was the same as what I had on my original Firestar. The
snowmobile bogey wheel. Didn't last long though. Went through a lot of
tailwheels until I hit on the present one. Took Maule that long to design
and produce something that would last me more than a year or two, back when
I was flying a bit.
Titus, Alabama |
Posted: Wed Feb 25, 2009 5:23 am Post subject: xtra wingtip mods |
I also have contemplated a fix for the angle behind the door on a
MkIII. The idea of a little air-turning gizmo sticking out
could work but seems unappealing. The easy one would be a slab of
foam board attached to the fabric and carved to
provide a better turn. A little goop and surface tape around the
edges would do the job. Laminate the outer surface
with some fine cloth and epoxy and then paint to match. Weight would
be small, more than made up for by efficiency.
BB
On 24, Feb 2009, at 10:32 PM, icrashrc wrote:
John,
Scott
http://forums.matronics.com/viewtopic.php?p 31955#231955
aslsa.rng(at)gmail.com Guest
Posted: Wed Feb 25, 2009 5:37 am Post subject: xtra wingtip mods |
Bob, Take a look at what the BD-4 guys do at the windshield posts. Kind of like a venetian blind slat.
Rick
On Wed, Feb 25, 2009 at 7:21 AM, robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)> wrote:
[quote]--> Kolb-List message posted by: robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)>
I also have contemplated a fix for the angle behind the door on a MkIII. The idea of a little air-turning gizmo sticking out
could work but seems unappealing. The easy one would be a slab of foam board attached to the fabric and carved to
provide a better turn. A little goop and surface tape around the edges would do the job. Laminate the outer surface
with some fine cloth and epoxy and then paint to match. Weight would be small, more than made up for by efficiency.
BB
| Quote: | --> Kolb-List message posted by: "icrashrc" <icrashrc(at)aol.com (icrashrc(at)aol.com)>
John,
Scott
http://forums.matronics.com/viewtopic.php?p=231955#231955
le, List Admin.
Posted: Wed Feb 25, 2009 12:43 pm Post subject: xtra wingtip mods |
The idea of a little air-turning gizmo sticking out could work>>
What about fitting a few VG`s?.
Pat
Posted: Wed Feb 25, 2009 2:51 pm Post subject: xtra wingtip mods |
I put a few VGs on the side (rear edge of the doors) of my MKIIIC a few
years ago. I didn't effect the speed but it did reduce the noise from
turbulent air hitting the side of the rear cage. My cage is fully enclosed
like John H's plane.
Rick Neilsen
Redrive VW powered MKIIIC
Posted: Wed Feb 25, 2009 2:53 pm Post subject: xtra wingtip mods |
my kolb is ugly enough now. That would elevate it to creepy.
BB
On 25, Feb 2009, at 3:42 PM, pj.ladd wrote:
Pat
