dlm46007(at)cox.net Guest
Posted: Tue Dec 16, 2008 9:43 am Post subject: picture needed |
I am considering locating an APARS box under the fairing that covers the trim servo and cables. Anyone have a picture of the mounted horizontal stab and installed trim servo and cables? I am looking for a convenient place to install APARS AIO (all in one) box. I need a location under fiberglass to allow the GPS signals through. Also need a convenient place to wire external antenna and convenient to power supply with Master ON. Tailcone seems most appropriate but don't wish to cut a hole (with glass inspection panel) for the GPS antenna to see the sky.
Tim Olson
Posted: Tue Dec 16, 2008 10:01 am Post subject: picture needed |
1 Correction. It's APRS....just skip the A.
1 Advice. You don't want the antenna to see the sky. You want it to
see the GROUND. All of the repeaters and internet gateway stations
are on the ground.
David McNeill wrote:
| Quote: | I am considering locating an APARS box under the fairing that covers the
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Wed Dec 17, 2008 9:45 am Post subject: picture needed |
David, it seems that many people have simply stuck them out in a wingtip. Easy enough to power from the position lights and I for one plan on having it on whenever I’m in the air which also works nicely with powering off of the position lights.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Tuesday, December 16, 2008 11:43 AM
Subject: picture needed
| Quote: | | http://www.matronics.com/contribution | 01234567890123
