picture needed
dlm46007(at)cox.net
PostPosted: Tue Dec 16, 2008 9:43 am    Post subject: picture needed Reply with quote
I am considering locating an APARS box under the fairing that covers the trim servo and cables. Anyone have a picture of the mounted horizontal stab and installed trim servo and cables? I am looking for a convenient place to install APARS AIO (all in one) box. I need a location under fiberglass to allow the GPS signals through. Also need a convenient place to wire external antenna and convenient to power supply with Master ON. Tailcone seems most appropriate but don't wish to cut a hole (with glass inspection panel) for the GPS antenna to see the sky.
Tim Olson
PostPosted: Tue Dec 16, 2008 10:01 am    Post subject: picture needed Reply with quote
1 Correction. It's APRS....just skip the A.
1 Advice. You don't want the antenna to see the sky. You want it to
see the GROUND. All of the repeaters and internet gateway stations
are on the ground.
msausen
PostPosted: Wed Dec 17, 2008 9:45 am    Post subject: picture needed Reply with quote
David, it seems that many people have simply stuck them out in a wingtip. Easy enough to power from the position lights and I for one plan on having it on whenever I’m in the air which also works nicely with powering off of the position lights.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Tuesday, December 16, 2008 11:43 AM
Subject: picture needed
