Kolb Ultrastar: How to take-off
Goto page Previous  1, 2, 3  Next
jbhart(at)onlyinternet.ne
PostPosted: Mon Dec 15, 2008 7:18 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
At 12:45 PM 12/15/08 -0000, you wrote:
Fair enough but is that a technique you would recommend to an inexperienced
learner? Would you be happy to be told that was the way to do it with only a
few take offs under your belt. Messing about in ground effect just above the
stall is not something most instructors would suggest.
Pat
No, I do not recommend an inexperienced learner try this technique. But
anyone can learn this technique by using a long runway under no wind
conditions, and then progressing on to low cross wind winds, etc. The time
to learn it is when you don't need to use it. After you land in tall grass
or water puddles in grass is not the time to make your first attempt.
What I recommend before flying a FireFly and taken from the top of the page
that I recommended to Jean:
http://www.thirdshift.com/jack/firefly/howtofly.html
"If you have had little to no flight instruction, I strongly urge you get
flight instruction before attempting your first flight in the FireFly. You
need to understand the basic rudimentary physical principles of flight, so
that you will be able to analyze what is going on and so that you can react
appropriately to the normal unexpected things that happen during any flight.
During slow flight, you need to understand, experience, and practice how to
recover from stalls and spins. In addition, during landings you must be able
to initiate forward slips and side slips to enable you to lose altitude, and
to handle cross winds. When all of these skills have been developed to the
point that they are almost automatic, you will have little trouble
transition to the FireFly.
The following observations come from several years experience getting the
FireFly and myself ready to fly. Hopefully, these comments will be helpful
but I am sure they are not all encompassing."
Messing about in ground effect just above the stall is not something most
instructors would >suggest."
I agree, but few, if any instructor is used to flying a 500 lb gross weight
aircraft with four inch wheels off of grass. One other point. There is
nothing wrong with flying in ground effect if you keep tabs on your ASI.
The problem comes when one is overcome by the illusion that ground and
air speed are the same.
It is unfortunate the most hazardous part of flight, the transition to and
from flight through ground effect is ignored by most instructors and yet, I
feel, it is one of the most important to learn for very light aircraft. I
taught my self by flying a 4,000 foot runway at progressively lower speeds
on a no wind day with the wheels no more than three feet above the ground.
Then I repeated the same process in a light cross wind etc and finally
progressed to gusty cross winds. I would bump a wheel once in a while, but
I improved. With practice and no wind or flaperons, it is possible to
fly/taxi the FireFly with the tail planted and main gear off the runway
surface.
Fly Safe!
Jack B. Hart FF004
Winchester, IN
PostPosted: Mon Dec 15, 2008 7:46 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
surface.
Jack B. Hart FF004
Jack:
I'm curious. What is the purpose of this exercise?
How do you control pitch attitude with the tailwheel on the ground and the
mains flying.
I'm not sure I understand why all this concern about ground effect. Kolbs
and other aircraft, fixed as well as rotary, require less power to fly in
ground effect. Our Kolbs fly so well, most of the time we don't know when
we are in it or out of it.
pj.ladd(at)btinternet.com
PostPosted: Mon Dec 15, 2008 7:49 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
anyone can learn this technique by using a long runway etc..>>
No disagreement there Jack
Cheers
Pat
lucien
PostPosted: Mon Dec 15, 2008 8:10 am    Post subject: Re: Kolb Ultrastar: How to take-off Reply with quote
John Hauck wrote:
Jack:
mains flying.
Don't mean to butt in again, but I'm with John on this - my FSII and thereofre I should think all Kolbs, fly just fine in ground effect.
I'm still a little mystified about these claims that flying in ground-effect is dangerous and not something students should be exposed to, etc.
This is very basic training in fixed-wing airplanes, you're exposed to it pretty much right away when you start on landings and takeoffs. I got hours and hours of training in this as a student in both GA and light a/c from my various instructors.
I submit problems with flying in GE are training issues rather than problems with the plane. I did this literally all the time in my FS II when practicing landings, low approaches and takeoffs.....
Someone help me out here Wink.....
LS
LS
Titan II SS
PostPosted: Mon Dec 15, 2008 8:27 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
If done correctly, there's nothing unsafe about a soft-field takeoff - you
take the same precautions there as you do with any takeoff.
So I'm confused.....>>
Sorry that you are confused Lucien.
I just don`t see that dragging a plane off the ground before it is really
ready to go is good technique.
If there are special circumstances , short field , soft field, standing
water, tall obstructions close by then of course you would use techniques
evolved to deal with that situation. I have flown from a field which is
steeply sloped. The only way to land is to land uphill through a farm gate
entrance and to take off downhill the opposite way.. Wind direction is not
in the equation.
That is a technique to deal with a specific problem and is as safe as it can
be made but presumably you would not advocate teaching it to a low hours
pilot or contend that landing and take off down wind is a desirable thing in
normal conditions..
All I am saying is that taking off while holding the tail down CAN be done
and in specific conditions MUST be done but it is not normal take off
technique.
I read once that Gann, the pilot and author, was once by mistake overloaded
with fuel. He just made it into the air but could only just stay airborne.
His speed was OK so he cleaned up the plane, retracted flaps and wheels.
Then to his horror he found he was headed straight for the Taj Mahal getting
close enough that he could see the fearstricken workmen scrambling off the
scaffolding which surrounded it. Being unable to climb over it Gann dropped
his flaps and achieved that extra bit of lift we all experience when
lowering flaps. This just bumped him high enough.
Now that was a technique to suit a particular situation but I presume that
you wouldn`t teach it as normal.
Good. Now we can have a thread about wether it is possible to increase your
height by dropping flaps.
Cheers
Pat
Cheers
Pat
lcottrell
PostPosted: Mon Dec 15, 2008 9:51 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
LS
LS
Titan II SS
Lucien, I think I can bring some clarity into Pat's problem with this technique. You are basing your observations on how a Kolb acts and reacts, while he is basing his on a Challenger. Smile Did you think the name was by chance? (The devil made me do it)
Larry C
PostPosted: Mon Dec 15, 2008 10:26 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
> surface.
> Jack B. Hart FF004
Jack:
There is none, except that it can be done.
mains flying.
Throttle
John,
I do not believe there is much reason to worry about it in heavier and
faster aircraft. Think of risk management and cross wind speed versus stall
speed. Assume you are going to take off in a 20 mph cross wind. Comparing
wind to stall speed, this would give 44% for 45 mphi and 74% for 27 mphi
stall speed. Also comparing 1,000 lb to 500 lb gr wt, which is going to get
blown around more on takeoff and which pilot is going to be the busiest and
who is at greater risk?
Control surface effectiveness is greater in ground effect and cross wind
shear is less close to the ground, so it is better to stabilize and
accelerate the aircraft at this point before moving on up into the full
effects of the cross wind.
Before I changed out the ailerons, modified the control system and added
VGs, I would not have attempted to takeoff in a cross wind of more than 5 mph.
This is the best I can do.
Jack B. Hart FF004
Winchester, IN
PostPosted: Mon Dec 15, 2008 11:10 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
Assume you are going to take off in a 20 mph cross wind. >
Jack B. Hart FF004
Jack:
Kolbs do not have enough yaw attitude authority to overcome a 20 mph cross
wind.
Somewhere below 20 mph the Kolb will begin to weather vane. Rudder becomes
pretty much useless.
VGs or no VGs.
More than once I have had to find some place to land into the wind because
the wind overpowered the rudder, at the risk of wetting my pants because my
bladder was full. Full bladder was reason for landing in the first place.
slyck(at)frontiernet.net
PostPosted: Mon Dec 15, 2008 11:59 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
circumstances when you would want to get into ground effect early:
1. long draggy grass or brush which would otherwise prevent
attaining flying speed.
2. rough plowed ground
3. wet snow.
done 'em all
BB
takeoff - you take the same precautions there as you do with any
takeoff.
really ready to go is good technique.
standing water, tall obstructions close by then of course you would
use techniques evolved to deal with that situation. I have flown
from a field which is steeply sloped. The only way to land is to
land uphill through a farm gate entrance and to take off downhill
the opposite way.. Wind direction is not in the equation.
as it can be made but presumably you would not advocate teaching it
to a low hours pilot or contend that landing and take off down wind
is a desirable thing in normal conditions..
be done and in specific conditions MUST be done but it is not
normal take off technique.
overloaded with fuel. He just made it into the air but could only
just stay airborne. His speed was OK so he cleaned up the plane,
retracted flaps and wheels. Then to his horror he found he was
headed straight for the Taj Mahal getting close enough that he
could see the fearstricken workmen scrambling off the scaffolding
which surrounded it. Being unable to climb over it Gann dropped his
presume that you wouldn`t teach it as normal.
increase your height by dropping flaps.
Cheers
Pat
Cheers
Pat
lucien
PostPosted: Mon Dec 15, 2008 4:50 pm    Post subject: Re: Kolb Ultrastar: How to take-off Reply with quote
I've never heard of anything like that being taught. I've never encountered this in any training situation I've ever been in regardless of plane, instructor or situation.
No soft-field technique I've ever been taught involved anything close to that and I don't recall ever doing this personally.
What you described in your particular scenario - bouncing over at least 3 large dirt mounds, then clearing a hedge and then a road after a major, but untested, repair to the prop drive system - is not in any PTS for any rating I'm aware of.
But it's quite right to say that that's definitely not safe takeoff practice!
technique.
with fuel.
Here again is another training item I'm not familiar with. Knowingly taking off over over gross is just plain verboten under all circumstances the way I was taught. Or at least, doing so puts you in test pilot territory and at your own risk.
Actually, I wouldn't teach this technique of dodging buildings and people while over gross as normal or safe under _any_ circumstances at all, so yes, you're quite right.
Again, I'd be instructing some other method than flight as the alternative here, such as a vehicle for the pilot and a trailer for the plane.
You're right - you're definitely not talking about good training or safety here....
LS
LS
Titan II SS
lucien
PostPosted: Mon Dec 15, 2008 5:00 pm    Post subject: Re: Kolb Ultrastar: How to take-off Reply with quote
Larry C
I appreciate the attempt but this doesn't help me too much. Every plane I've flown so far flies just fine in ground effect, even the one or two trikes both single and double-surface. The Kolb is in large company in this regard....
LS
LS
Titan II SS
PostPosted: Tue Dec 16, 2008 4:42 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
<<Knowingly taking off over over gross >>
Sorry Lucien, either we speak different languages or you don`t read very
carefully. I specifically said "loaded by mistake" nothing at all about
`knowingly taking off etc`
From what I remember of the story the refuelling crew were instructed to put
in a specific amount of fuel but instead filled the tanks.
I am not going to get into the question of whether Gann should have checked
the amount. It is just the story as I remember it and its years since I read
it..
As for my `take off with an untested repair`. Replacing a faulty drive belt
with a new one hardly calls for a major investigation. In any case that is
entirely beside the point. The object of the story was to illustrate that in
that instance there WAS a case for dragging the plane off the ground as
quickly as possible as it was a small very rough field and a NORMAL take off
run was impractical.
That encapsulates what I have said all along. You CAN take off with the tail
on the ground but unless you need to what is the point?
I think this has been hammered to death. Let us just leave it. I shall
continue to take off in what I consider a safe manner and no doubt you will
do the same.
Incidentally if you have never come across Ganns books I think his initials
are D.W and there was at least one film derived from one of his stories.
Well worth reading.
Merry Christmas
Pat
lucien
PostPosted: Tue Dec 16, 2008 6:21 am    Post subject: Re: Kolb Ultrastar: How to take-off Reply with quote
Regardless of why, taking off over gross is a training issue and thus has nothing to do correct takeoff technique. Negligence of this type doesn't say anything about the technique used to get in the air, at that point you can't and shouldn't rely on the results you get.
The way I see it, no takeoff at all, regardless of technique used, could have been the correct method to use in that situation. Dirt bars, bushes and roads directly in the path of the takeoff and clearly too close to clear safely is only a case for not attempting flight period and don't support the use of any takeoff method.
Trailering techniques, OTOH, could have been effectively taught in a situation like that.
do the same.
Well, good luck to you,
LS
LS
Titan II SS
russ(at)rkiphoto.com
PostPosted: Tue Dec 16, 2008 6:58 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
read very carefully. I specifically said "loaded by mistake"
nothing at all about `knowingly taking off etc`
> instructed to put
checked the amount. It is just the story as I remember it and its
years since I read it..
drive belt with a new one hardly calls for a major investigation.
In any case that is entirely beside the point. The object of the
story was to illustrate that in that instance there WAS a case for
dragging the plane off the ground as quickly as possible as it was
a small very rough field and a NORMAL take off run was impractical.
the tail on the ground but unless you need to what is the point?
shall continue to take off in what I consider a safe manner and no
doubt you will do the same.
initials are D.W and there was at least one film derived from one
of his stories. Well worth reading.
Merry Christmas
Pat
beauford
PostPosted: Tue Dec 16, 2008 10:31 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
Pat:
It is Earnest Kellogg Gann...
Fate is the Hunter, Island in the Sky, Band of Brothers, In The Company of
Eagles, The High and the Mighty,
etc.
Fate is the Hunter is widely regarded as probably the finest aviation book
ever written...
beauford
FF-076
Brandon, FL
Merry Christmas
Pat
PostPosted: Tue Dec 16, 2008 10:49 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
Agreed. If you haven't read it, do it. So real you will feel you are
there.
BB
On 16, Dec 2008, at 1:25 PM, beauford T wrote:
<beauford173(at)verizon.net>
Pat:
Company of
etc.
aviation book
ever written...
beauford
FF-076
Brandon, FL
> Merry Christmas
> Pat
PostPosted: Tue Dec 16, 2008 11:31 am    Post subject: Kolb Ultrastar: How to take-off Reply with quote
> Jack B. Hart FF004
Jack:
wind.
John,
On take off you do not need all that much yaw authority. If you move the
stick into the wind and back to keep the up wind main wheel and the tail
wheel planted until it leaves the ground, there is no need for a rudder.
After it leaves the ground, you can let it weather vane into the wind, level
the wings and crab into the wind on climb out.
Landing is different. You can hold in as much side slip as the rudder will
permit. If the wind blows you off, then you have to decide whether to use a
combination of side alip and a crab to get to the runway, and at the last
second lower the up wind wing and plant the up wind wheel. In this case, I
land into the wind. The landing roll is very short.
Jack B. Hart FF004
Winchester, IN
PostPosted: Tue Dec 16, 2008 12:15 pm    Post subject: Kolb Ultrastar: How to take-off Reply with quote
Jack B. Hart FF004
Jack:
You have written of flying in 25 mph cross winds in the past.
I'd like to watch you demonstrate those maneuvers for me, as soon as I
finish making double tie downs on my mkIII.
PostPosted: Tue Dec 16, 2008 2:25 pm    Post subject: Kolb Ultrastar: How to take-off Reply with quote
Pat, List
I'm sure you're talking about Ernest K. Gann, one of the early
airline pilots and an accomplished sailor. And writer! -- a whole
bunch of great books;
ISLAND IN THE SKY
THE HIGH AND THE MIGHTY
FATE IS THE HUNTER
BAND OF BROTHERS
A HOSTAGE TO FORTUNE (this is my favorite, and I think the Taj
incident is in here)
BLACK WATCH ( SR-71 & others)
SOLDIER OF FORTUNE
MASADA
Many of these were made into films, & all are good reading. I've
talked to him but to my regret, never met him .
Russ Kinne
capedavis(at)yahoo.com
PostPosted: Tue Dec 16, 2008 4:11 pm    Post subject: Kolb Ultrastar: How to take-off Reply with quote
Beauford, I agree wholeheartedly on "FATE IS THE HUNTER" A great story,well written and a real heart thumper if you fly or just dream of flying. Thanks for reminding me ! Chris
Sent: Tuesday, December 16, 2008 1:49:26 PM
Subject: Re: Re: Kolb Ultrastar: How to take-off
--> Kolb-List message posted by: robert bean <slyck(at)frontiernet.net (slyck(at)frontiernet.net)>
there.
BB
[quote] --> Kolb-List message posted by: "beauford T"
<beauford173(at)verizon.net (beauford173(at)verizon.net)>
Pat:
Company of
etc.
aviation book
ever written...
beauford
FF-076
Brandon, FL
> --> Kolb-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
> Merry Christmas
> [quote][b]
Page 2 of 3
