billderou(at)yahoo.com Guest
Posted: Tue Jan 06, 2009 10:22 am Post subject: Fuel Flow |
Guys-
I have beat my brain over this issue with no success. Can anyone provide a suitable answer?
When I turn on my electrical fuel pump during cruise the fuel flow will increase approx 10%.
I have the standard Vans setup. There are no leaks nor fuel smells. No metric nor sound on the engine changes (although maybe if I looked carefully the airspeed would increase slowly).
Bill DeRouchey
N939SB, flying
rene(at)felker.com Guest
Posted: Tue Jan 06, 2009 10:50 am Post subject: Fuel Flow |
Yes, turbulence in the fuel line caused by the fuel pump. Same thing for me. The only solution would be to move the sensor……
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
Sent: Tuesday, January 06, 2009 11:22 AM
Subject: Fuel Flow
Guys-
Bill DeRouchey
N939SB, flying
01234567890123
Dave(at)AirCraftersLLC.co Guest
Bill,
Here's my untested, unscientific, uneverything opinion:
In the stock location, the cube gets fuel pushed and pulled through it. The boost pump is essentially a steady pressure on one side of the vane, but I suspect that the mechanical diaphragm pump is pulling in pulses on the other side. As the vanes in the cube rotate, they see a steady pressure on the downstream side from the boost pump, but they get accelerated when the mechanical pump makes a stroke and lowers the pressure on the upstream side. So the vane spins a little faster when it sees the larger differential pressure. Of course there has to be some pressure difference or the vane wouldn't move, but I think the pulses from the upstream pump are the cause.
A few months ago we moved a customer's sender from the stock location to the "approved" location between the servo and the spider. The problem disappeared. I plan on moving mine, too.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
Sent: Tuesday, January 06, 2009 10:22 AM
Subject: Fuel Flow
Guys-
Bill DeRouchey
N939SB, flying
href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics.com/Navigator?RV10-List
href='3D"http://forums.matronics.com"'>http://forums.matronics.com
href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
Tim Olson
Posted: Tue Jan 06, 2009 10:59 am Post subject: Fuel Flow |
I've always heard it's cavitation, but I have no proof.
Bill DeRouchey wrote:
| Quote: | Guys-
a suitable answer?
Bill DeRouchey
N939SB, flying
Posted: Tue Jan 06, 2009 11:26 am Post subject: Fuel Flow |
This has been discussed a fair bit on the list in the past. In the stock location there is always an increase in reading even though the actual flow doesn't necessarily change. In talking to the floscan people they said it has something to do with the pulses sent out by the electric pump that somehow makes it read higher. It may be cavitation as Tim mentioned, but you don't have to sweat it (unless you smell fuel when it's on, of course, or find a leak somewhere). That section of line is not under high pressure unless the boost pump is on, so a poor seal could leak when the pump is on and not when it is off, but you would know if it was.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Jan 6, 2009, at 1:22 PM, Bill DeRouchey wrote:
| Quote: | Guys-
Bill DeRouchey
N939SB, flying
href="3D"http://www.matronics.com/Navigator?RV10-List"">http://www.matronics.com/Navigator?RV10-List
href="3D"http://forums.matronics.com"">http://forums.matronics.com
href="3D"http://www.matronics.com/contribution"">http://www.matronics.com/contribution
Kellym
Posted: Tue Jan 06, 2009 12:00 pm Post subject: Fuel Flow |
Hmm, on certified aircraft with Bendix RSA injection systems the sending
unit cube is normally installed between the mechanical pump and the fuel
servo. Given the line to the spyder is shorter and vertical, finding a
location with enough straight run would be a challenge.
Usually recommended in the middle of the line between the pump and
servo, to give it some vibration isolation, as well as straight hose
sections before and after the cube.
The sending unit used on systems like Continentals is different because
of the fuel return line, and I believe most of those are installed
between the servo and spyder.
Kelly
Dave Saylor wrote:
| Quote: | Bill,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bill
DeRouchey
*Sent:* Tuesday, January 06, 2009 10:22 AM
*To:* rv10-list(at)matronics.com
*Subject:* Fuel Flow
Guys-
Bill DeRouchey
N939SB, flying
KCHD |
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Tue Jan 06, 2009 12:33 pm Post subject: Fuel Flow |
I believe that is why Matt developed this…..
http://www.matronics.com/fuelchec/dampener.html
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Tuesday, January 06, 2009 1:25 PM
Subject: Re: Fuel Flow
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Guys-
Bill DeRouchey
N939SB, flying
[quote] [b]
ron.mcgann(at)baesystems. Guest
Posted: Tue Jan 06, 2009 1:51 pm Post subject: Fuel Flow |
Curiosity aroused here. Apart from when switching tanks, and assuming the mechanical (engine driven) pump is working ok, under what conditions would you be using the electric fuel pump in cruise? If the mechanical pump goes u/s, and the electrical pump is now the main fuel pump, is there still a problem with overreading flow?
you know - enquiring minds etc . . .
cheers
Ron
-187, fiddly bits and paperwork
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Wednesday, 7 January 2009 7:02 AM
Subject: RE: RV10-List: Fuel Flow
Michael
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Guys-
Bill DeRouchey
N939SB, flying
"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
AV8ORJWC
Posted: Tue Jan 06, 2009 1:59 pm Post subject: Fuel Flow |
Accumulators are a valued asset. Thanks Michael for reminding me (all of us) of Matt's contribution. Its use does not mitigate correct placement of the sensor in the scheme of things.
And kudo's to Tim for the use of the word "cavitation". We see lots of problems with low fluid level, fluid contaminates, pump impeller function and cavitation. Correct fuel pressure indication is a Valued thing. It reminded me how inefficient air impellers are in grand design of moving air (to which there is little direction connection to this thread).
John Cox
#40600
From: owner-rv10-list-server(at)matronics.com on behalf of RV Builder (Michael Sausen)
Sent: Tue 1/6/2009 12:31 PM
Subject: RE: Fuel Flow
Michael
pascal(at)rv10builder.net Guest
Posted: Tue Jan 06, 2009 6:04 pm Post subject: Fuel Flow |
Not sure how I missed that the floscan is in the wrong location the last couple of years..
Dave;
I don’t see any room to move my floscan from the Van's plans location to near the spider, how did you make it so it all fits?
Thanks!
Pascal
Sent: Tuesday, January 06, 2009 10:49 AM
Bill,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
Subject: Fuel Flow
Guys-
Bill DeRouchey
N939SB, flying
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Tue Jan 06, 2009 7:18 pm Post subject: Re: Fuel Flow |
| pascal(at)rv10builder.net wrote: | Not sure how I missed that the floscan is in the wrong location the last couple of years..
Dave;
I don�t see any room to move my floscan from the Van's plans location to near the spider, how did you make it so it all fits?
Thanks!
Pascal
Pascal,
Go to Robs forum at
http://www.advanced-flight-systems.com/forum/viewtopic.php?t=454
about the 4th message you will find a picture. I am currently in the process of doing the same thing but it will be another couple weeks before I will have it finished so I can't get any pictures now.
Basically you place the transducer between the servo and the spider. If you are not doing an electronic ignition, you could also place the transducer on top of the engine just before it enters the spider.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
timrvator(at)comcast.net Guest
Posted: Tue Jan 06, 2009 7:27 pm Post subject: Fuel Flow |
I had this problem on my RV-6A. Problem was caused by the fuel pulses from the electric pump. Solved the problem by putting a Fram G3 clear plastic fuel filter between the electric fuel pump and the fuel flow sensor. Then I "burped" air into the Fram G3 so that it (the filter) was 1/2 full of air. The air dampens the pressure pulses, now flow meter reads essentially the same (in steady state) with or without the electric boost pump engaged. (Out of an abundance of caution I poked a hole in the fuel filter's internal baffle to provide an alternate fluid path in case "crap" or ice crystals ever accumulate in the filter elements.)
I found that during aerobatics the Fram G3 would sometimes loose all it's air (it would end up being full of fuel). In that situation, on the ground with the engine running, I'd "burp" more air into the filter by setting the fuel selector at "off" while removing that little brass plug that blocks the fuel selector's "off" input port.
Matronics sells a device that will accomplish the same thing. See http://www.matronics.com/fuelchec/dampener.html. I'll probably use the Matronics device if I see the problem in my RV-10, because I'm not comfortable operating a Fram G3 at high fuel pressure.
| Quote: | --
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1000 hrs
RV-10 #40059 under construction |
Bill DeRouchey wrote: [quote] Guys-
Bill DeRouchey
N939SB, flying
href="3D%22http://www.matronics.com/Navigator?RV10-List%22">http://www.matronics.com/Navigator?RV10-List
href="3D%22http://forums.matronics.com%22">http://forums.matronics.com
href="3D%22http://www.matronics.com/contribution%22">http://www.matronics.com/contribution
| [b]
msausen
Posted: Wed Jan 07, 2009 6:28 am Post subject: Fuel Flow |
Pascal,
I wouldn’t worry about it much, lots of people have put it in the stock location. If the error is really apparent, I would try Matt’s dampener before trying to relocate it.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
Sent: Tuesday, January 06, 2009 8:03 PM
Dave;
Thanks!
Pascal
Posted: Wed Jan 07, 2009 7:12 pm Post subject: Fuel Flow |
Good comments from everyone. I guess I was asleep last year when this was discussed. I read about Matts air-ball but since the stock tubing is straight before and after the flow sensor I thought it applied to a non-stock configuration.
The only reason I had the electrical fuel pump on in cruise was to test the condition with the autopilot on so I could focus on the abnormality.
It would seem that any modification or relocation of the fuel flow sensor could upset the calibration - so it must be recalibrated after the final configuration is in place. It is very important to me that this value is correct since it is the basis of many calculations - reserve fuel at destination, horsepower, miles per gallon, and prop efficiency.
Thanks all-
Bill DeRouchey
N939SB
--- On Wed, 1/7/09, RV Builder (Michael Sausen) <rvbuilder(at)sausen.net> wrote:
| Quote: | From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net>
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Wednesday, January 7, 2009, 6:25 AM
Pascal,
I wouldn¢t worry about it much, lots of people have put it in the stock location. If the error is really apparent, I would try Matt¢s dampener before trying to relocate it.
Michael
Dave;
I don¢t see any room to move my floscan from the Van's plans location to near the spider, how did you make it so it all fits?
Thanks!
Pascal
ronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
matronics.com">http://forums.matronics.com
ronics.com/contribution">http://www.matronics.com/contribution
| [quote][b]
Tim Olson
Posted: Wed Jan 07, 2009 8:06 pm Post subject: Fuel Flow |
Bill,
While I do see the increase in fuel flow, just like you do, with
mine installed in the stock location, it doesn't cause me any
headaches. I only use the fuel boost for maybe 60 seconds
during takeoff, and even on landing if I do, it's only for
about 60 seconds again....just that timeframe that I'm under
about 500' AGL. If you only use it a couple minutes during
the flight, it won't change those readings much at all. I've
consistently been accurate to within about .1-.2 gallons
over a 40-45 gallon flight, so it's just not worth worrying
about. In over 400 hours I've never had a fuel fillup that
had any noticeable amount of difference over what the totalizer
told me I should be adding.
If you're going to use it for HP, and things like that, yeah,
you'll get a little mis-reading for those few seconds that
you use it.
| Quote: | Good comments from everyone. I guess I was asleep last year when this
efficiency.
Thanks all-
Bill DeRouchey
N939SB
--- On *Wed, 1/7/09, RV Builder (Michael Sausen)
Pascal,
Michael
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *pascal
*Sent:* Tuesday, January 06, 2009 8:03 PM
*Subject:* Re: Fuel Flow
Dave;
Thanks!
Pascal
gengrumpy(at)aol.com Guest
Posted: Wed Jan 07, 2009 8:12 pm Post subject: Fuel Flow |
My experience is the same as Tim says.
grumpy
N184JM
I wouldn't worry about it unless you want to leave the thing on all
the time, and then you'd have other problems to contend with.
On Jan 7, 2009, at 10:04 PM, Tim Olson wrote:
Bill,
you use it.
> abnormality.
> Thanks all-
> Bill DeRouchey
> N939SB
> --- On *Wed, 1/7/09, RV Builder (Michael Sausen) /<rvbuilder(at)sausen.net
> Pascal,
> it in the
> Matt’s
> dampener before trying to relocate it. Michael
> *From:* owner-rv10-list-server(at)matronics.com
> *pascal
> location the
> Dave;
> Thanks!
> Pascal
Posted: Thu Jan 08, 2009 10:12 am Post subject: Fuel Flow |
That was also my conclusion. I only keep it on for departure and arrivals. Although, on Monday I was at 16,500 over the Rockies with 13,000 ft peaks all around and liked the idea of keeping the electric pump on. But these times are rare.
After thinking about the issue overnight I am not going to make any changes. Not worth it and during moderate to severe turbulence the air ball could be filled with fuel rendering it worthless. Its just comforting that others have seen this abnormalilty and I do not need to dig deeper into my aircraft looking and worrying about a fuel leak.
Thanks for the comments,
--- On Wed, 1/7/09, Miller John <gengrumpy(at)aol.com> wrote:
| Quote: | From: Miller John <gengrumpy(at)aol.com>
Date: Wednesday, January 7, 2009, 8:10 PM
| Quote: | --> RV10-List message posted by: Miller John <gengrumpy(at)aol.com>My experience is the same as Tim says.grumpyN184JMI wouldn't worry about it unless you want to leave the thing on all thetime, and then you'd have other problems to contend with.do not archiveOn Jan 7, 2009, at 10:04 PM, Tim Olson wrote:> --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>> > Bill,> > While I do see the increase in fuel flow, just like you do, with> mine installed in the stock location, it doesn't cause me any> headaches. I only use the fuel boost for maybe 60 seconds> during takeoff, and even on landing if I do, it's only for> about 60 seconds again....just that timeframe that I'm
under> about 500' AGL. If you only use it a couple minutes during> the flight, it won't change those readings much at all. I've> consistently been accurate to within about .1-.2 gallons> over a 40-45 gallon flight, so it's just not worth worrying> about. In over 400 hours I've never had a fuel fillup that> had any noticeable amount of difference over what the totalizer> told me I should be adding.> > If you're going to use it for HP, and things like that, yeah,> you'll get a little mis-reading for those few seconds that> you use it.> > Tim Olson - RV-10 N104CD - Flying> do not archive> > > Bill DeRouchey wrote:>> Good comments from everyone. I guess I was asleep last year when thiswas discussed. I read about Matts air-ball but since the stock tubing isstraight before and after the flow sensor I thought it applied to
a non-stockconfiguration.>> The only reason I had the electrical fuel pump on in cruise was totest the condition with the autopilot on so I could focus on the abnormality.>> It would seem that any modification or relocation of the fuel flowsensor could upset the calibration - so it must be recalibrated after the finalconfiguration is in place. It is very important to me that this value is correctsince it is the basis of many calculations - reserve fuel at destination,horsepower, miles per gallon, and prop efficiency.>> Thanks all->> Bill DeRouchey>> N939SB>> --- On *Wed, 1/7/09, RV Builder (Michael Sausen)/<rvbuilder(at)sausen.net>/* wrote:>> From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net>>> Subject: RE: Fuel Flow>> To: "rv10-list(at)matronics.com"<rv10-list(at)matronics.com>>> Date:
Wednesday, January 7, 2009, 6:25 AM>> Pascal,>> I wouldn¢t worry about it much, lots of people have put itin the>> stock location. If the error is really apparent, I would tryMatt¢s>> dampener before trying to relocate it. Michael>> *From:* owner-rv10-list-server(at)matronics.com>> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *pascal>> *Sent:* Tuesday, January 06, 2009 8:03 PM>> *To:* rv10-list(at)matronics.com>> *Subject:* Re: RV10-List: Fuel Flow>> Not sure how I missed that the floscan is in the wronglocation the>> last couple of years..>> Dave;>> I don¢t see any room to move my floscan from the Van's plans>> location to near the spider, how did you make it so it all fits?>> Thanks!>>
Pascal>> *>> ronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List>> matronics.com">http://forums.matronics.com>> ronics.com/contribution">http://www.matronics.com/contribution>> *>> * |
| [quote][b]
Posted: Thu Jan 08, 2009 10:58 am Post subject: Fuel Flow |
Bill;
Thanks for bringing this up, I was quite concerned with this as well, especially when I saw what it would take to rectify it, seeing the responses from reliable sources certainly put this concern to rest, but glad to have had it discussed.
Pascal
Sent: Thursday, January 08, 2009 10:10 AM
Wednesday, January 7, 2009, 6:25 AM>> Pascal,>> I wouldn¢t worry about it much, lots of people have put itin the>> stock location. If the error is really apparent, I would tryMatt¢s>> dampener before trying to relocate it. Michael>> *From:* owner-rv10-list-server(at)matronics.com>> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *pascal>> *Sent:* Tuesday, January 06, 2009 8:03 PM>> *To:* rv10-list(at)matronics.com>> *Subject:* Re: Fuel Flow>> Not sure how I missed that the floscan is in the wronglocation the>> last couple of years..>> Dave;>> I don¢t see any room to move my floscan from the Van's plans>> location to near the spider, how did you make it so it all fits?>> Thanks!>>
| [quote]
