		billderou(at)yahoo.com Guest
				 Posted: Tue Jan 06, 2009 10:22 am    Post subject: Fuel Flow |
				Guys-
  I have beat my brain over this issue with no success. Can anyone provide a suitable answer?
  When I turn on my electrical fuel pump during cruise the fuel flow will increase approx 10%.
  I have the standard Vans setup. There are no leaks nor fuel smells. No metric nor sound on the engine changes (although maybe if I looked carefully the airspeed would increase slowly).
  Bill DeRouchey
  N939SB, flying
		rene(at)felker.com Guest
				 Posted: Tue Jan 06, 2009 10:50 am    Post subject: Fuel Flow |
				Yes, turbulence in the fuel line caused by the fuel pump.  Same thing for me.  The only solution would be to move the sensor……
 Rene' Felker
 RV-10 N423CF Flying
 801-721-6080
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
  Sent: Tuesday, January 06, 2009 11:22 AM
  Subject: Fuel Flow
 Guys-
 Bill DeRouchey
 N939SB, flying
         01234567890123
		Dave(at)AirCraftersLLC.co Guest
				Bill,
  Here's my untested, unscientific, uneverything  opinion:
  In the stock location, the cube gets fuel  pushed and pulled through it.  The boost pump is essentially a steady  pressure on one side of the vane, but I suspect that the mechanical diaphragm  pump is pulling in pulses on the other side.  As the vanes in the cube  rotate, they see a steady pressure on the downstream side from the boost pump,  but they get accelerated when the mechanical pump makes a stroke and lowers the  pressure on the upstream side.  So the vane spins a little faster when it  sees the larger differential pressure.  Of course there has to be some  pressure difference or the vane wouldn't move, but I think the pulses from the  upstream pump are the cause.
  A few months ago we moved a customer's  sender from the stock location to the "approved" location between the servo and  the spider.  The problem disappeared.  I plan on moving mine,  too.
   Dave Saylor
  AirCrafters LLC
  140 Aviation Way
  Watsonville, CA
  831-722-9141
  831-750-0284 CL
  www.AirCraftersLLC.com
 Sent: Tuesday, January 06, 2009 10:22 AM
 To:  rv10-list(at)matronics.com
 Subject: Fuel  Flow
                    Guys-
        Bill DeRouchey
        N939SB, flying
 href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics.com/Navigator?RV10-List
 href='3D"http://forums.matronics.com"'>http://forums.matronics.com
 href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
		Tim Olson
				 Posted: Tue Jan 06, 2009 10:59 am    Post subject: Fuel Flow |
				I've always heard it's cavitation, but I have no proof.
 Bill DeRouchey wrote:
  	  | Quote: | 	 		   Guys-
  a suitable answer?
  Bill DeRouchey
  N939SB, flying
				 Posted: Tue Jan 06, 2009 11:26 am    Post subject: Fuel Flow |
				This has been discussed a fair bit on the list in the past.  In the stock location there is always an increase in reading even though the actual flow doesn't necessarily change.  In talking to the floscan people they said it has something to do with the pulses sent out by the electric pump that somehow makes it read higher.  It may be cavitation as Tim mentioned, but you don't have to sweat it (unless you smell fuel when it's on, of course, or find a leak somewhere).  That section of line is not under high pressure unless the boost pump is on, so a poor seal could leak when the pump is on and not when it is off, but you would know if it was.
  Jesse Saint
 Saint Aviation, Inc.
 Cell: 352-427-0285
 Fax: 815-377-3694
 On Jan 6, 2009, at 1:22 PM, Bill DeRouchey wrote:
  	  | Quote: | 	 		  Guys-
  Bill DeRouchey
  N939SB, flying
 href="3D"http://www.matronics.com/Navigator?RV10-List"">http://www.matronics.com/Navigator?RV10-List
 href="3D"http://forums.matronics.com"">http://forums.matronics.com
 href="3D"http://www.matronics.com/contribution"">http://www.matronics.com/contribution
		Kellym
				 Posted: Tue Jan 06, 2009 12:00 pm    Post subject: Fuel Flow |
				Hmm, on certified aircraft with Bendix RSA injection systems the sending
 unit cube is normally installed between the mechanical pump and the fuel
 servo. Given the line to the spyder is shorter and vertical, finding a
 location with enough straight run would be a challenge.
 Usually recommended in the middle of the line between the pump and
 servo, to give it some vibration isolation, as well as straight hose
 sections before and after the cube.
 The sending unit used on systems like Continentals is different because
 of the fuel return line, and I believe most of those are installed
 between the servo and spyder.
 Kelly
 Dave Saylor wrote:
  	  | Quote: | 	 		   Bill,
  Dave Saylor
  AirCrafters LLC
  140 Aviation Way
  Watsonville, CA
  831-722-9141
  831-750-0284 CL
  [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bill
  DeRouchey
  *Sent:* Tuesday, January 06, 2009 10:22 AM
  *To:* rv10-list(at)matronics.com
  *Subject:* Fuel Flow
  Guys-
  Bill DeRouchey
  N939SB, flying
KCHD |
		msausen
				 Posted: Tue Jan 06, 2009 12:33 pm    Post subject: Fuel Flow |
				I believe that is why Matt developed this…..
 http://www.matronics.com/fuelchec/dampener.html
 Michael
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
  Sent: Tuesday, January 06, 2009 1:25 PM
  Subject: Re: Fuel Flow
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
 Guys-
 Bill DeRouchey
 N939SB, flying
   [quote] [b]
		ron.mcgann(at)baesystems. Guest
				 Posted: Tue Jan 06, 2009 1:51 pm    Post subject: Fuel Flow |
				Curiosity aroused here.  Apart from when switching  tanks, and assuming the mechanical (engine driven) pump is working ok, under  what conditions would you be using the electric fuel pump in cruise?  If  the mechanical pump goes u/s, and the electrical pump is now the main fuel pump,  is there still a problem with overreading flow?
  you know - enquiring minds etc . . .
  cheers
  Ron
  -187, fiddly bits and  paperwork
  Do not  archive
  [quote]         From: owner-rv10-list-server(at)matronics.com    [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder    (Michael Sausen)
 Sent: Wednesday, 7 January 2009 7:02    AM
 Subject: RE: RV10-List:    Fuel Flow
 Michael
 Jesse    Saint
 Cell:    352-427-0285
 Fax:    815-377-3694
 Guys-
 Bill DeRouchey
 N939SB, flying
 "Warning:
 The information contained in this email and any attached files is
 confidential to BAE Systems Australia. If you are not the intended
 recipient, any use, disclosure or copying of this email or any
 attachments is expressly prohibited.  If you have received this email
 in error, please notify us immediately. VIRUS: Every care has been
 taken to ensure this email and its attachments are virus free,
 however, any loss or damage incurred in using this email is not the
 sender's responsibility.  It is your responsibility to ensure virus
 checks are completed before installing any data sent in this email to
 your computer."
		AV8ORJWC
				 Posted: Tue Jan 06, 2009 1:59 pm    Post subject: Fuel Flow |
				Accumulators are a valued asset.  Thanks Michael for reminding me (all of us) of Matt's contribution.  Its use does not mitigate correct placement of the sensor in the scheme of things.
  And kudo's to Tim for the use of the word "cavitation".  We see lots of problems with low fluid level, fluid contaminates, pump impeller function and cavitation.  Correct fuel pressure indication is a Valued thing.  It reminded me how inefficient air impellers are in grand design of moving air (to which there is little direction connection to this thread).
   John Cox
  #40600
   From: owner-rv10-list-server(at)matronics.com on behalf of RV Builder (Michael Sausen)
 Sent: Tue 1/6/2009 12:31 PM
 Subject: RE: Fuel Flow
 Michael
		pascal(at)rv10builder.net Guest
				 Posted: Tue Jan 06, 2009 6:04 pm    Post subject: Fuel Flow |
				Not sure how I missed that the floscan is in the wrong  location the last couple of years..
  Dave;
  I don’t see any room to move my floscan from the Van's plans  location to near the spider, how did you make it so it all fits?
  Thanks!
  Pascal
  Sent: Tuesday, January 06, 2009 10:49 AM
  Bill,
   Dave Saylor
  AirCrafters LLC
  140 Aviation Way
  Watsonville, CA
  831-722-9141
  831-750-0284 CL
 Subject: Fuel  Flow
                    Guys-
        Bill DeRouchey
        N939SB, flying
		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Tue Jan 06, 2009 7:18 pm    Post subject: Re: Fuel Flow |
				 	  | pascal(at)rv10builder.net wrote: | 	 		  Not sure how I missed that the floscan is in the wrong  location the last couple of years..
  Dave;
  I don�t see any room to move my floscan from the Van's plans  location to near the spider, how did you make it so it all fits?
  Thanks!
  Pascal
 Pascal,
 Go to Robs forum at
 http://www.advanced-flight-systems.com/forum/viewtopic.php?t=454
 about the 4th message you will find a picture.  I am currently in the process of doing the same thing but it will be another couple weeks before I will have it finished so I can't get any pictures now.
 Basically you place the transducer between the servo and the spider.  If you are not doing an electronic ignition, you could also place the transducer on top of the engine just before it enters the spider.
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
		timrvator(at)comcast.net Guest
				 Posted: Tue Jan 06, 2009 7:27 pm    Post subject: Fuel Flow |
				I had this problem on my RV-6A.  Problem was caused by the fuel pulses from the electric pump.  Solved the problem by putting a Fram G3 clear plastic fuel filter between the electric fuel pump and the fuel flow sensor.  Then I "burped" air into the Fram G3 so that it (the filter) was 1/2 full of air.  The air dampens the pressure pulses, now flow meter reads essentially the same (in steady state) with or without the electric boost pump engaged.  (Out of an abundance of caution I poked a hole in the fuel filter's internal baffle to provide an alternate fluid path in case "crap" or ice crystals ever accumulate in the filter elements.)
  I found that during aerobatics the Fram G3 would sometimes loose all it's air (it would end up being full of fuel).  In that situation, on the ground with the engine running, I'd "burp" more air into the filter by setting the fuel selector at "off" while removing that little brass plug that blocks the fuel selector's "off" input port.
  Matronics sells a device that will accomplish the same thing.  See http://www.matronics.com/fuelchec/dampener.html.  I'll probably use the Matronics device if I see the problem in my RV-10, because I'm not comfortable operating a Fram G3 at high fuel pressure.
   	  | Quote: | 	 		  --
 Tim Lewis -- HEF (Manassas, VA)
 RV-6A N47TD -- 1000 hrs
 RV-10 #40059 under construction |
  Bill DeRouchey wrote: [quote]                                 Guys-
          Bill DeRouchey
          N939SB, flying
  href="3D%22http://www.matronics.com/Navigator?RV10-List%22">http://www.matronics.com/Navigator?RV10-List
  href="3D%22http://forums.matronics.com%22">http://forums.matronics.com
  href="3D%22http://www.matronics.com/contribution%22">http://www.matronics.com/contribution
  | 	   [b]
		msausen
				 Posted: Wed Jan 07, 2009 6:28 am    Post subject: Fuel Flow |
				Pascal,
   I wouldn’t worry about it much, lots of people have put it in the stock location.  If the error is really apparent, I would try Matt’s dampener before trying to relocate it.
 Michael
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
  Sent: Tuesday, January 06, 2009 8:03 PM
 Dave;
 Thanks!
 Pascal
				 Posted: Wed Jan 07, 2009 7:12 pm    Post subject: Fuel Flow |
				Good comments from everyone. I guess I was asleep last year when this was discussed. I read about Matts air-ball but since the stock tubing is straight before and after the flow sensor I thought it applied to a non-stock configuration.
 The only reason I had the electrical fuel pump on in cruise was to test the condition with the autopilot on so I could focus on the abnormality.
 It would seem that any modification or relocation of the fuel flow sensor could upset the calibration - so it must be recalibrated after the final configuration is in place. It is very important to me that this value is correct since it is the basis of many calculations - reserve fuel at destination, horsepower, miles per gallon, and prop efficiency.
 Thanks all-
 Bill DeRouchey
 N939SB
 --- On Wed, 1/7/09, RV Builder (Michael Sausen)  <rvbuilder(at)sausen.net> wrote:
  	  | Quote: | 	 		  From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net>
 To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
 Date: Wednesday, January 7, 2009, 6:25 AM
 Pascal,
   I wouldn¢t worry about it much, lots of people have put it in the stock location.  If the error is really apparent, I would try Matt¢s dampener before trying to relocate it.
 Michael
 Dave;
 I don¢t see any room to move my floscan from the Van's plans location to near the spider, how did you make it so it all fits?
 Thanks!
 Pascal
 ronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
 matronics.com">http://forums.matronics.com
 ronics.com/contribution">http://www.matronics.com/contribution
  | 	   [quote][b]
		Tim Olson
				 Posted: Wed Jan 07, 2009 8:06 pm    Post subject: Fuel Flow |
				Bill,
 While I do see the increase in fuel flow, just like you do, with
 mine installed in the stock location, it doesn't cause me any
 headaches.  I only use the fuel boost for maybe 60 seconds
 during takeoff, and even on landing if I do, it's only for
 about 60 seconds again....just that timeframe that I'm under
 about 500' AGL.  If you only use it a couple minutes during
 the flight, it won't change those readings much at all. I've
 consistently been accurate to within about .1-.2 gallons
 over a 40-45 gallon flight, so it's just not worth worrying
 about.  In over 400 hours I've never had a fuel fillup that
 had any noticeable amount of difference over what the totalizer
 told me I should be adding.
 If you're going to use it for HP, and things like that, yeah,
 you'll get a little mis-reading for those few seconds that
 you use it.
  	  | Quote: | 	 		   Good comments from everyone. I guess I was asleep last year when this
  efficiency.
  Thanks all-
  Bill DeRouchey
  N939SB
  --- On *Wed, 1/7/09, RV Builder (Michael Sausen)
      Pascal,
      Michael
      [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *pascal
      *Sent:* Tuesday, January 06, 2009 8:03 PM
      *Subject:* Re: Fuel Flow
      Dave;
      Thanks!
      Pascal
		gengrumpy(at)aol.com Guest
				 Posted: Wed Jan 07, 2009 8:12 pm    Post subject: Fuel Flow |
				My experience is the same as Tim says.
 grumpy
 N184JM
 I wouldn't worry about it unless you want to leave the thing on all
 the time, and then you'd have other problems to contend with.
 On Jan 7, 2009, at 10:04 PM, Tim Olson wrote:
  Bill,
  you use it.
 > abnormality.
 > Thanks all-
 > Bill DeRouchey
 > N939SB
 > --- On *Wed, 1/7/09, RV Builder (Michael Sausen) /<rvbuilder(at)sausen.net
 >    Pascal,
 > it in the
 > Matt’s
 >    dampener before trying to relocate it.          Michael
 >         *From:* owner-rv10-list-server(at)matronics.com
 > *pascal
 > location the
 >    Dave;
 >    Thanks!
 >    Pascal
				 Posted: Thu Jan 08, 2009 10:12 am    Post subject: Fuel Flow |
				That was also my conclusion. I only keep it on for departure and arrivals. Although, on Monday I was at 16,500 over the Rockies with 13,000 ft peaks all around and liked the idea of keeping the electric pump on. But these times are rare.
 After thinking about the issue overnight I am not going to make any changes. Not worth it and during moderate to severe turbulence the air ball could be filled with fuel rendering it worthless. Its just comforting that others have seen this abnormalilty and I do not need to dig deeper into my aircraft looking and worrying about a fuel leak.
 Thanks for the comments,
 Bill
 --- On Wed, 1/7/09, Miller John <gengrumpy(at)aol.com> wrote:
  	  | Quote: | 	 		  From: Miller John  <gengrumpy(at)aol.com>
 Date: Wednesday, January 7, 2009, 8:10 PM
  	  | Quote: | 	 		  --> RV10-List message posted by: Miller John <gengrumpy(at)aol.com>My experience is the same as Tim says.grumpyN184JMI wouldn't worry about it unless you want to leave the thing on all thetime, and then you'd have other problems to contend with.do not archiveOn Jan 7, 2009, at 10:04 PM, Tim Olson wrote:> --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>> > Bill,> > While I do see the increase in fuel flow, just like you do, with> mine installed in the stock location, it doesn't cause me any> headaches.  I only use the fuel boost for maybe 60 seconds> during takeoff, and even on landing if I do, it's only for> about 60 seconds again....just that timeframe that I'm
  under> about 500' AGL.  If you only use it a couple minutes during> the flight, it won't change those readings much at all. I've> consistently been accurate to within about .1-.2 gallons> over a 40-45 gallon flight, so it's just not worth worrying> about.  In over 400 hours I've never had a fuel fillup that> had any noticeable amount of difference over what the totalizer> told me I should be adding.> > If you're going to use it for HP, and things like that, yeah,> you'll get a little mis-reading for those few seconds that> you use it.> > Tim Olson - RV-10 N104CD - Flying> do not archive> > > Bill DeRouchey wrote:>> Good comments from everyone. I guess I was asleep last year when thiswas discussed. I read about Matts air-ball but since the stock tubing isstraight before and after the flow sensor I thought it applied to
  a non-stockconfiguration.>> The only reason I had the electrical fuel pump on in cruise was totest the condition with the autopilot on so I could focus on the abnormality.>> It would seem that any modification or relocation of the fuel flowsensor could upset the calibration - so it must be recalibrated after the finalconfiguration is in place. It is very important to me that this value is correctsince it is the basis of many calculations - reserve fuel at destination,horsepower, miles per gallon, and prop efficiency.>> Thanks all->> Bill DeRouchey>> N939SB>> --- On *Wed, 1/7/09, RV Builder (Michael Sausen)/<rvbuilder(at)sausen.net>/* wrote:>>    From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net>>>    Subject: RE: Fuel Flow>>    To: "rv10-list(at)matronics.com"<rv10-list(at)matronics.com>>>    Date:
  Wednesday, January 7, 2009, 6:25 AM>>    Pascal,>>           I wouldn¢t worry about it much, lots of people have put itin the>>    stock location.  If the error is really apparent, I would tryMatt¢s>>    dampener before trying to relocate it.          Michael>>         *From:* owner-rv10-list-server(at)matronics.com>>    [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *pascal>>    *Sent:* Tuesday, January 06, 2009 8:03 PM>>    *To:* rv10-list(at)matronics.com>>    *Subject:* Re: RV10-List: Fuel Flow>>         Not sure how I missed that the floscan is in the wronglocation the>>    last couple of years..>>    Dave;>>    I don¢t see any room to move my floscan from the Van's plans>>    location to near the spider, how did you make it so it all fits?>>    Thanks!>>
  Pascal>>    *>>   ronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List>>    matronics.com">http://forums.matronics.com>>   ronics.com/contribution">http://www.matronics.com/contribution>>    *>> * |
  | 	   [quote][b]
				 Posted: Thu Jan 08, 2009 10:58 am    Post subject: Fuel Flow |
				Bill;
  Thanks for bringing this up, I was quite concerned with this  as well, especially when I saw what it would take to rectify it, seeing the  responses from reliable sources certainly put this concern to rest, but glad to  have had it discussed.
  Pascal
  Sent: Thursday, January 08, 2009 10:10 AM
 Bill
  Wednesday, January 7, 2009, 6:25 AM>>    Pascal,>>           I wouldn¢t worry about it much, lots of people have put itin the>>    stock location.  If the error is really apparent, I would tryMatt¢s>>    dampener before trying to relocate it.          Michael>>         *From:* owner-rv10-list-server(at)matronics.com>>    [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *pascal>>    *Sent:* Tuesday, January 06, 2009 8:03 PM>>    *To:* rv10-list(at)matronics.com>>    *Subject:* Re: Fuel Flow>>         Not sure how I missed that the floscan is in the wronglocation the>>    last couple of years..>>    Dave;>>    I don¢t see any room to move my floscan from the Van's plans>>    location to near the spider, how did you make it so it all fits?>>    Thanks!>>
  | 	  [quote]
