Old subject revisited
ron.mcgann(at)baesystems.
PostPosted: Thu Jan 08, 2009 6:22 pm    Post subject: Old subject revisited Reply with quote
Just had an enlightening discussion with a work colleague that prompts some questions:
1. Nitrogen in the tires
How many use Nitrogen (as opposed to compressed air) in the tires. I have not flown yet, but I notice that my tires regularly deflate very slowly. I've now heard that this may be oxygen leakage through the rubber membrane Interesting thread on VAF on this. To what extent does Nitrogen only in the tires reduce deflation? Any list experiences?
2. Static wicks
I always believed I did not need them.  After all, I was not building a plastic plane. After adding paint, I have changed my mind!! I used two pack Acrylic Urethane on my paint job. Came out pretty good. When vacuuming the paint booth of paint dust, the static build up inside the hose and metal fittings is unbelievable. I often see sparks greater than 1/2" between any conductor on the vacuum cleaner and a ground. Greater than 10kV in this apparently! I expect the static buildup on the plastic paint I now have, especially in the hot, dry, dusty conditions here in South Oz is likely to be quite significant. Looks like a bit more work on bonding the control surfaces and adding some wicks.
Will it ever end . . . .
Ron
-187 fiddly bits and paperwork (and I really should just finish and FLY!!) [quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
rene(at)felker.com
PostPosted: Thu Jan 08, 2009 7:20 pm    Post subject: Old subject revisited Reply with quote
  1. I have not used Nitrogen in the tires………have not had a problem keeping them inflated.
2. Did not put static wicks on the airplane…..having second thoughts. I do get a P-static buildup and thus can have a lot of static…..hear it on the radio. It has not gotten real bad, but I do notice it.
Rene'
801-721-6080
robin1(at)mrmoisture.com
PostPosted: Thu Jan 08, 2009 7:35 pm    Post subject: Old subject revisited Reply with quote
Ron,
  I have no answer for question #1 or #2 but I definitely know the answer to question #3.
Will it ever end…
No
Cheers?
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Thursday, January 08, 2009 6:20 PM
Subject: Old subject revisited
2.   Static wicks
Ron
"Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or anyattachments is expressly prohibited. If you have received this emailin error, please notify us immediately. VIRUS: Every care has beentaken to ensure this email and its attachments are virus free,however, any loss or damage incurred in using this email is not thesender's responsibility. It is your responsibility to ensure viruschecks are completed before installing any data sent in this email toThe information contained in this email and any attached files is
5
6
7
8
9
5
6
7
8
9
wayne.e(at)grandecom.net
PostPosted: Fri Jan 09, 2009 5:17 am    Post subject: Old subject revisited Reply with quote
Ron,
1. I haven't yet put nitrogen in my tires however yesterday when I went to the hangar to fly my tires were low again and after some cussing I made the decision that I'm putting nitrogen in the tires yet this week. I have a good friend who is an A&P and runs an FBO and he maintained my previous certified planes and I never had this low tire problem. He always filled my tires then with nitrogen. He told me it will probably stop 75% of the air loss I'm experiencing.
I'm going to take off the wheel pants and fly over to a nearby airport and have a shop over there put in the good stuff. All repair shops should have nitrogen because they need it for the struts on some of the planes.
2. Yes I did installed static wicks. There was a write up, I believe from this forum, on where to install them. I have instructions on this at my hangar if you can't find it.
Wayne Edgerton N602WT
Time: 06:22:44 PM PST US Subject: Old subject revisited From: "McGANN, Ron" <ron.mcgann(at)baesystems.com (ron.mcgann(at)baesystems.com)>
some questions:
2. Static wicks
wicks.
Ron
FLY!!)
speckter(at)comcast.net
PostPosted: Fri Jan 09, 2009 6:27 am    Post subject: Old subject revisited Reply with quote
I have had static problems on previous planes and thus bonded and static wicked the 10. To date no issues, but I don’t expect any either.
Gary Specketer
40274 flying
Sent: Thursday, January 08, 2009 9:20 PM
2.   Static wicks
Ron
5
6
7
8
9
5
6
7
8
9
msausen
PostPosted: Fri Jan 09, 2009 8:34 am    Post subject: Old subject revisited Reply with quote
Ron,
No direct personal experience but I hear that the air stop tubes from Michelin or any other Butyl rubber tubes work pretty well to minimize leaking. I’ll probably run Nitrogen in mine but I haven’t decided on the delivery method yet. As I will also transfill my oxy tank I may just get a Nitrogen tank while I’m at it. You could also take one of those little portable air tanks and go to many tire shops and dealerships and see if they will fill that up for a couple bucks. Here in the US the big new fad is Nitrogen in auto tires so almost every dealership or tire place has on site Nitrogen separators to fill customer tires for a nice little fee.
Michael
Sent: Thursday, January 08, 2009 8:20 PM
2.  Static wicks
Ron
5
6
7
8
9
5
6
7
8
9
Tim Olson
PostPosted: Fri Jan 09, 2009 9:07 am    Post subject: Old subject revisited Reply with quote
I have been having great luck since replacing my tubes with
new ones from Desser Tire.
As for what I fill my tires with, I fill mine with a special
mixture....it's a nitrogen rich mixture. 80% N2, and 20%
O2, roughly...along with a trace amount of C02 and some
other minor gasses. I trans-fill it from a compressor
in my hangar, through a special hose with what's called a
"chuck", into my tires. Wink
RV Builder (Michael Sausen) wrote:
Ron,
Michael
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *McGANN, Ron
*Sent:* Thursday, January 08, 2009 8:20 PM
*To:* rv10-list(at)matronics.com
*Subject:* Old subject revisited
some questions:
2. Static wicks
Ron
"Warning:
your computer."
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
PostPosted: Fri Jan 09, 2009 9:19 am    Post subject: Old subject revisited Reply with quote
Locally it’s $5.00/tire. It sure would be nice to have better access to our tire valves.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Friday, January 09, 2009 8:32 AM
Subject: RE: Old subject revisited
Ron,
Michael
2.   Static wicks
Ron
5
6
7
8
9
5
6
7
8
9
5
6
7
8
9
msausen
PostPosted: Fri Jan 09, 2009 10:13 am    Post subject: Old subject revisited Reply with quote
That's cool, you mix that yourself? The stuff I normally use is 78.08% nitrogen, 20.95% oxygen, 0.93% argon, 0.038% carbon dioxide, and trace amounts of other gases. Razz LMAO
Michael
chuck(at)chuckdirect.com
PostPosted: Fri Jan 09, 2009 10:20 am    Post subject: Old subject revisited Reply with quote
I use nitrogen in all my tires, RV9A, RV10, motorcycles, cars, bicycles, etc. They still deflate but noticebly (by 50% probably) slower. Got some old hospital O2 regulators (distributed the extras to some flying buds too) and bought a tank, hose and fill from the local gas distributor. I think the cost was about $150 total!
Chuck
Sent: Friday, January 09, 2009 9:18 AM
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Ron,
Michael
2. Static wicks
Ron
5
6
7
8
9
5
6
7
8
9
5
6
7
8
9
2 [quote][b]
pitts_pilot(at)bellsouth.
PostPosted: Fri Jan 09, 2009 10:43 am    Post subject: Old subject revisited Reply with quote
All you need to do is replace van's straight valve tubes with 90 degree
valve tubes available from Desser. A small hole large enough for a truck
tire extension takes care of that little task. I haven't done it yet,
but I will before I assemble the wheels/tires.
Linn
to our tire valves.
Robin
PostPosted: Fri Jan 09, 2009 11:15 am    Post subject: Old subject revisited Reply with quote
Linn,
We looked at the 90 degree valve extension but they would not
work (too close to the center shaft and extra spinning weight). You are
saying that there are tubes with built in 90 degree valves?
http://shop.desser.com/IW_Products.m4p.pvx?;MULTI_ITEM_SUBMIT (did not
look for exact size)
Rats... I just found them. Sure wish I knew about them before the plane
went to paint... I would have bored an access hole.
Robin
Phil.Perry(at)netapp.com
How strange. That sounds like the same stuff I put into my Lycoming....
Tim Olson
Smile I was hoping that didn't go over too many heads. Wink
Sorry I was a little rough on the percentages. Smile
For what it's worth, since I started with the different
tubes...in my case they were 15/600-6 "LEAKGUARD"
I usually only fill my tires in the early spring at
condition inspection time, and then perhaps once
in the summer and/or fall. Really, I haven't been
super bothered by the lack of air fill access in the
wheel fairings, either, because as far as I'm concerned,
we should be looking inside the fairings and inspecting
brakes and things like that at about the same interval
that I end up adding air to the tires. If I had
super-quick tire fill access, I'd have to fight the
urge to skip a brake check. Which reminds me, I'm
coming up to that time again, having 170 hours on the
first set and now I'm at 430+.
<rvbuilder(at)sausen.net>
Michael Do not archive
Tim Olson
PS: I think maybe we should use Helium. It may leak faster,
but we should get more useful load that way.
Smile
Albert Gardner
PostPosted: Fri Jan 09, 2009 12:59 pm    Post subject: Old subject revisited Reply with quote
I bought the tubes with the 90 deg stems but I didn't like the way they fit
the wheel. The stem on the tube came out of the center whereas the wheel has
a hole offset to the side. Then stem was forced out of its natural path in
order to fit the wheel. It appears the wheel needs to be altered to make the
90 deg stem fit. Maybe all 90 deg tubes are not the same. I don't think
there is sufficient room for any screw-on extension to work.
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
wcurtis(at)nerv10.com
My mix is about the same (78% nitrogen, 21% Oxygen, 0.9% argon, 0.04% carbon dioxide and 0.06% other) but contains a bit more methane in the trace gases cause of all the beans eaten around here.
William
http://nerv10.com/wcurtis/
Bob Turner
PostPosted: Fri Jan 09, 2009 2:16 pm    Post subject: Re: Old subject revisited Reply with quote
As Tim and others point out, if the oxygen really diffused much faster than nitrogen, all you'd have to do is overfill the tires by 20%, and, after a while, they'd be at the correct pressure and 100% nitrogen. (Or let then deflate 20%, the refill with air. You'd then be at 96% nitrogen).
I believe this owt started because the airlines use nitrogen in their tires. But that's to reduce the fire risk (not leakage problems) following a rejected takeoff when the tires can get really hot (and sometimes blow a "fuse plug").
The new leakstop tubes are a real improvement.
Bob Turner
RV-10 QB
nukeflyboy
PostPosted: Sun Jan 11, 2009 5:01 am    Post subject: Re: Old subject revisited Reply with quote
Air is funny stuff, but it acts predictably. It is a fair assumption that oxygen doesn't react with the tire appreciably over a 30 day period, therefore the rate of deflation is a function of the diffusion rate across the membrane. In these physical exchanges, molecular size matters. Nitrogen gas (N2) has a molecular weight of 28, while oxygen gas (O2)has a molecular weight of 32. This reflects a difference in size of the molecule and based on this you would predict that nitrogen will leak out faster. I really think that all this effort to put N2 in your tires is bad science and wasted effort, or perhaps a way to extract a few more $ from you from the A&P. As the previous post points out, N2 can be used but it is driven by other reasons, not leak rate.
By the way, humid air is less dense than dry air for the same reason. Water molecules with a molecular weight of 18 displace N2/O2 molecules which have a proportional molecular weight of about 31 making the average fluid denity less. The same principle is behind reverse osmosis units.
Dave Moore
RV-6 built and sold
RV-10 built and flying
