Dick Maddux
Posted: Sun Jan 11, 2009 6:56 am Post subject: Trailering a KitfoxTrailering a Kitfox |
Tom and Paul,
Thanks for your input on checking the rear spar pivot. I will proceed with the checks you suggested. I checked again yesterday with a super bright light and everything appears in order but will see if I have any movement
Dick Maddux
Pensacola,Fl
New year...new news. Be the first to know what is making headlines.
Fox5flyer Guest
Posted: Sun Jan 11, 2009 7:52 am Post subject: Trailering a KitfoxTrailering a Kitfox |
Dick, checking the spar pivot is a good plan, but I'd suggest that if you want to be absolutely sure, remove the wings and (with a magnifying glass) have a very close look at the spars themselves, mainly at the mounting points and doublers. If the doubler rivets are tight, glue is still intact with no sign of cracking, and the holes are still round, then you're probably good to go. Being 4130 steel, I believe that the fuselage pivot points are much stronger than the spars and it seems to me that if anything would give, it would be the spars themselves.
At the very least, replace the rear spar pivot bolts.
Just my .02.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
akflyer
Posted: Sun Jan 11, 2009 8:23 am Post subject: Re: Trailering a KitfoxTrailering a Kitfox |
AS we all know, the kitfox was a copy of the avid. It has been asked if the original designers were thinking about towing etc. when it was designed, and I do believe it was implied that they were to stupid (or lacked the Grey matter) to have done so....
Please read the last sentence of the brochure.
214.59 KB |
478 Time(s) |
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
akflyer
Posted: Sun Jan 11, 2009 8:45 am Post subject: Re: Trailering a KitfoxTrailering a Kitfox |
Just to be fair, I better post the rest of the story...
 Download |
| Filename: |
Avid Letter.pdf |
705.8 KB |
| Downloaded: |
667 Time(s) |
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
matronics(at)bob.brennan. Guest
Posted: Sun Jan 11, 2009 8:55 am Post subject: Trailering a KitfoxTrailering a Kitfox |
Since the same person also implied that there was no such thing as
consideration of metal fatigue in the design does anyone know any more
about, or have documentation to support, the statement "light structure with
high fatigue life" in that last paragraph? Obviously structure fatigue was a
consideration, but is the airframe's actual "high fatigue life" documented
anywhere?
Also does anyone know what the paragraph means by "towing" in the statement
"strong for towing"? I am thinking they meant towing with the factory
supplied towbar and braces at the recommended speed and distance limits, but
it would be nice to have any confirmation.
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
lcfitt(at)sbcglobal.net Guest
Posted: Sun Jan 11, 2009 9:33 am Post subject: Trailering a KitfoxTrailering a Kitfox |
Bob, I think the documentation you are looking for is the simple fact that
since 1982 there has been no report (read documantation) of an inflight
structural failure on any Avid or Kitfox aircraft. This doesn't meant that
one won't crop up at some time in the future. But I always think of my
friend that is considering buying an ultralight type aircraft that has a
long history of the lift strut attachment failing at a fairly predictable
interval. This item has been tagged by pilots of this airplane for
bimiannual raplacement. I asked him if this was a problem to him - his
answer, No.
Lowell
akflyer
Posted: Sun Jan 11, 2009 10:09 am Post subject: Re: Trailering a KitfoxTrailering a Kitfox |
| matronics(at)bob.brennan. wrote: | Since the same person also implied that there was no such thing as
anywhere?
Wrightsville Pa
I wonder if it is possible that someone may have eaten alot of paint chips as a child.... who knows.... I guess that just as above has shown, thinking can get us all into trouble..
The full file is too large to post (12.8 MB) so I cut out the page for transport. Read the last sentence on transport...
 Download |
| Filename: |
AvidFlyerBrochure1990 7.pdf |
419.1 KB |
| Downloaded: |
629 Time(s) |
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Posted: Sun Jan 11, 2009 10:58 am Post subject: Trailering a KitfoxTrailering a Kitfox |
So do you think your friend's "no" answer meant "no I don't mind replacing
the part(s) every 2 years to be safe, glad I know about it" or "no I don't
believe that's a problem and I'm gonna buy it and fly it without ever
bothering to fix it"?
It seems we have both opinions on this list as regards the stresses of
trailering, but no solid "replace this weak point biannually if you trailer"
good advice.
Another reason I am searching for a definition of that "high fatigue life"
statement is that I am considering restoring a 1943 vintage L2 Grasshopper,
which to those who know is the military version of the original Taylorcraft
Cub. Not to get off topic on a Kitfox forum but the L2 has a very similar
fabric covered metal tube fuselage and I can't help but think that in 1943
they didn't build it using molybdenum tubing and TIG welding. So I am
thinking (there I go again!) that the Avid "higher fatigue life" is as
compared to something like an old Cub, and what exactly, or even
approximately, is the life in hours-flown of either, or any tube-framed
aircraft?
Old type-certified aircraft don't fall out of the sky either, but I've seen
lots in museums labelled "past their serviceable life" or completely
rebuilt. But we will just keep merrily flying our Kitfoxes because we don't
know 'bout stuff like that... :-S
Wrightsville Pa
Posted: Sun Jan 11, 2009 11:05 am Post subject: Trailering a KitfoxTrailering a Kitfox |
"We recommend that you trailer your AVID FLYER if you want to transport it
long distances [ie >10 miles]. Always install wing towing supports when the
wings are folded"
<well-intentioned sarcasm>
Oh, ok then. Everybody on this list attaches the factory-supplied towing
supports and puts their plane on a trailer in the same attitude as the
factory-supplied towbar.
So no problems then!
</sarcasm>
Wrightsville Pa
akflyer
Posted: Sun Jan 11, 2009 11:40 am Post subject: Re: Trailering a KitfoxTrailering a Kitfox |
| matronics(at)bob.brennan. wrote: | "We recommend that you trailer your AVID FLYER if you want to transport it
wings are folded"
<well>
</sarcasm>
Wrightsville Pa
what data did you use to determine that >10 miles is considered "long distance", or is that a brown and smelly number? I have the full file from the manufacture and did not see a hard number they considered a "long distance". It seems the most info to be had in that statement was to "make sure you have the wing braces installed when the wings are folded". This is the brace that slips into the forward spar and pins in at the strut attachment on the fuse.
In respect to you other post, it is safe to assume that the welds were made using oxy acetylene and mild steel tubing. Atleast, the early pipers were made this way. I would venture to say that a quick web search would back this up as well as asking anyone of the number of people who have restored one, or asking an A&P with Grey, thinning hair.
The service life you mentioned is more determined by how the AC was used not really how many years old it is. If it was flown off grass strips or paved runways and taken to shows every year and kept in a hangar and has 5000 hrs on it, I would bet it is better shape and has less fatigue than a cub that was built in '78 that has been flown in the Alaskan bush by a sheep or bear guide yet it only has 2800 hrs on it.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Posted: Sun Jan 11, 2009 12:02 pm Post subject: Trailering a KitfoxTrailering a Kitfox |
That depends on if you call the Kitfox Owner's Manual "brown and
smelly"(huh?) Leonard. From the manual, posted at
http://cfisher.com/kitfox/kitfox2poh.pdf, page 5 - "The airplane should not
be towed on its own gear for long distances (more than 10 miles)."
Thanks for your ideas regarding the question of service life of a
fabric-and-tube aircraft, such as the Kitfox and the Taylorcraft. As I said
when the designer of the Avid stated "higher fatigue life" I am guessing he
meant higher than old Cubs and that sort of design, which I am also guessing
was a starting point for the design of the Avid and eventually the Kitfox.
I'll do some research on the service lifetime of that type of aircraft later
tonight, and/or leave the question open to anyone else on the list who may
have some real numbers or know where to get them.
Wrightsville Pa
gary-n-dorothy(at)tctwest Guest
helili(at)chahtatushka.ne Guest
Posted: Sun Jan 11, 2009 2:02 pm Post subject: Trailering a KitfoxTrailering a Kitfox |
FWIW, TCSD for the Taylorcraft L-2 can be found at:
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library%5CrgMakeModel.nsf/
0/A9F4EAFB56CCBA638525673E00624DE4/$FILE/a-699.pdf
John Hart
KF IV, NSI Subaru
Wilburton, OK
Posted: Sun Jan 11, 2009 2:42 pm Post subject: Trailering a KitfoxTrailering a Kitfox |
Thanks for the link John, I'll print that out for the next time I give that
L2 a good looking over. It last flew in 1995 and has quite a bit of fabric
damage, so I don't think it's going anywhere too soon.
Posted: Sun Jan 11, 2009 2:53 pm Post subject: Trailering a KitfoxTrailering a Kitfox |
You're right Leonard, the service life of a commercial aircraft is limited
to a number of take-off and landing "cycles" rather than hours flown,
specifically because of the predicted occurrence of fatigue failure after a
certain number of "cycles", which is where all the stress occurs.
However, I also know from working at a flight data recorder analysis company
for a while that *any* non-flight related stress on a commercial airliner
requires mandatory inspection for stress fractures. Tail scrapes, bumping
into or being bumped by something, hard landings, departure from a taxiway
or runway, all these things and more require an inspection before the
aircraft can be put back in commercial service.
My DAR was surprised to see my airframe logbook contained the number of
take-offs and landings per entry as well as the hours flown, and the engine
logbook has a running count of starts and stops. Apparently you yanks don't
record those details?
bob
akflyer
Posted: Sun Jan 11, 2009 3:25 pm Post subject: Re: Trailering a KitfoxTrailering a Kitfox |
| matronics(at)bob.brennan. wrote: | You're right Leonard, the service life of a commercial aircraft is limited
bob
I was getting more at how the aircraft is used, not necessarily commercial or not.
To keep it relevant, if you were looking at buying a used Kitfox (as an example), you would probably be better off buying one from a guy that has only flown it on sunny days, it has had a set of wheel pants on it since day one (and they are not cracked) and there is not one spec of dirt on it, as opposed to buying one that I have flown lol... Mine has big tires and sees most of its action on unimproved strips, getting abused (or should I say used to the full potential) as they were originally designed to be used. I also trailer mine every flight so I can keep it in a nice warm garage instead of out in the -34 crap we have had sitting on top of us for the last 3 weeks.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
dwight purdy
Posted: Sun Jan 11, 2009 4:02 pm Post subject: Trailering a KitfoxTrailering a Kitfox |
Was just thing about the post a year ago of how you could take the wing spar
bolts out in flight and they would not go anywhere. Compression forces. In
transit the forces are just the opposite especially if the tail is left
down.
Dwight Purdy
model II
_________________ dwight
model II |
Posted: Sun Jan 11, 2009 4:32 pm Post subject: Trailering a KitfoxTrailering a Kitfox |
So never buy a Kitfox from Leonard Perry... got it
Mine had been through 5 owners already when I got it, and I was not a
wizened aircraft buyer at the time (an owner-virgin one might say). Other
than a leaky wing tank, leaky tyre (Brit for "tire"), and at least one owner
who thought electrical tape was the only way to repair anything on an
airplane... I think I got lucky and got myself a really perfect aeroplane
(Brit for "airplane"), for my purposes at least.
Wrightsville Pa
Lynn Matteson
Posted: Sun Jan 11, 2009 5:19 pm Post subject: Trailering a KitfoxTrailering a Kitfox |
I record all the landings....assuming I made a take-off to get to
that point...and hours and tenths, plus where I went, amount of fuel
installed in plane and miles flown.
If something eventful happens, I note that too...like taking off up
through fog (known thickness) during one brain fart incident: Note
to self: "Don't ever do this again."
I since then bought an artificial horizon, so I may not have learned
my lesson. : )
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
flying again after engine rebuild, and new Electroair direct-fire
ignition system;
also building a new pair of snow skis
On Jan 11, 2009, at 5:52 PM, Bob Brennan wrote:
<matronics(at)bob.brennan.name>
| Quote: | My DAR was surprised to see my airframe logbook contained the
number of
the engine
yanks don't
bob
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Sun Jan 11, 2009 6:50 pm Post subject: Trailering a KitfoxTrailering a Kitfox |
For what it's worth and from someone who went through it last year, I would
suggest that all Log Book entries be made with the thought of just who you
would want to read them. These are legal documents and if there is ever an
incident or accident, these will be surrendered to the FAA for their
inpection - no warrant required.
In my personal case, all engine and airframe info was logged in the book.
Personal flight data was logged in a trip form I made up (four to a page,
both sides - eight days from the first take off of the day wherever that
was) and kept in a binder. Periodically, all pertinent hours, and landings
were transferred to my pilot's log in bulk form. When the FAA came calling,
I gave him the two log books and everyone was satisfied. I still have all
the personal data, T/Os and landings, fuel, landing sites, persons on
board, observation notes and stuff in a very personal file. I don't mean to
imply that I flew without regard to the regs, but I just think some of the
observarions and comments were logged for my benefit alone.
Lowell
