noconwud(at)earthlink.net Guest
Posted: Thu Jan 22, 2009 8:11 pm Post subject: Wing Auto Pilot Servos |
I'm going to be ready to close up my wings in another month or so, and I
recognize that I should have everything I ever want in there before I put
the bottom skins on. I've not really given any thought to an autopilot, but
in order to be smart for an option down the road, would it be prudent to
mount a servo in the wing to set me up for a possible future autopilot
install? If so, what kind of servo is recommended?
Another option is to go ahead and close the wing, and hope there's an
autopilot system that doesn't require mounting servos in the wing.
Thoughts.
Andy Johnson
Poquoson, VA
Posted: Thu Jan 22, 2009 8:26 pm Post subject: Wing Auto Pilot Servos |
maybe go to the Tru Trak web site and look at what they have. The servo is mounted easily after closing up the wing C but it is the five or seven strand wire that controls the servo that you should get in the wing before you close it up C even though I was able to do mine after the fact.
JOhn
[quote] From: noconwud(at)earthlink.net
Subject: Wing Auto Pilot Servos
Date: Thu C 22 Jan 2009 23:08:34 -0500
ricksked(at)embarqmail.co Guest
Posted: Thu Jan 22, 2009 8:27 pm Post subject: Wing Auto Pilot Servos |
Just leave enough conduit to run the five wire...Its easy to do especially if you ran the wire. Honestly just order the Trutrak servo ind install it now..you need to replace a bellcrank bracket...its. 800 dollar investment you will do anyhow
Albert Gardner
Posted: Thu Jan 22, 2009 8:30 pm Post subject: Wing Auto Pilot Servos |
The ones that I know off and like (Trio, Dynon, and TruTrak) all mount at
the wing bellcrank with a modified bellcrank mount and, while I mounted mine
as I was constructing the wing, I understand it's not a serious problem to
mount them after the wing is finished. Put the wires in there though.
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Tim Olson
Posted: Thu Jan 22, 2009 8:40 pm Post subject: Wing Auto Pilot Servos |
I can't imagine that 99% of the builders won't put in an autopilot,
so I'd just agree with Rick and say "go for it".
One other thing that makes that statement something to consider....
Today I filled in my info for insurance renewal quote. I'm going to
be getting the AIG discount this year for TAA's. I think that's
10% off. But, to get it, you have to have a few items in your plane,
and things like RNP Nav equip, WX Equipment, TAWS and Terrain Equip,
and "2 axis autopilot" are all things that they look at for getting
the discount. So in the long run, it may actually pay for itself
over many years to have an Autopilot...and they wouldn't put it on
the form if they didn't feel there was safety value there.
800 dollar investment you will do anyhow ---
rv(at)thelefflers.com Guest
Posted: Fri Jan 23, 2009 3:25 am Post subject: Wing Auto Pilot Servos |
And mount the servo bracket before the leading edge is attached to the spar.
It will make your life easier.
While I had the servo in hand, I didn't think of reading the installation
directions since I had the bottom skins left to install. While it's not
impossible to get the two mounting bolts and nuts in place with the leading
edge riveted to the spar, those with short arms will have difficulties.
Posted: Fri Jan 23, 2009 5:47 am Post subject: Wing Auto Pilot Servos |
Am I missing something? All of the bolts that hold the aileron
bellcrank brackets to the spar are held by nutplates which are
installed along with the tiedown bracket on page 13-5. This way you
can pull the lower bellcrank bracket supplied by Van's with the one
that holds the A/P servo after the wing is closed up. I'm sure I am
missing something obvious about what bolts and nuts you are referring
to.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
the spar.
installation
it's not
leading
difficulties.
johngoodman
Posted: Fri Jan 23, 2009 7:42 am Post subject: Re: Wing Auto Pilot Servos |
Andy,
Picking an autopilot is sort of like politics, or primer wars. Everybody has a strong opinion. There are three good brands for us out there, that I know of - Dynon, Trio, and Tru Trak. They all use a bracket mount at the aileron bell crank so you know you are going to have to put something there. Pick a brand and do it now. Here are three web pages to start on:
http://www.trioavionics.com/ProPilot.htm
http://www.trutrakflightsystems.com/instruments.htm
http://www.dynonavionics.com/docs/Autopilot_intro.html
PS: be prepared for a little sticker shock....
| noconwud(at)earthlink.net wrote: | I'm going to be ready to close up my wings in another month or so, and I
Thoughts.
Andy Johnson
Poquoson, VA |
dlm46007(at)cox.net Guest
Posted: Fri Jan 23, 2009 9:13 am Post subject: Wing Auto Pilot Servos |
You can buy the servo and wait on the remainder.
Posted: Fri Jan 23, 2009 10:02 am Post subject: Wing Auto Pilot Servos |
I would suggest that you make sure you can work on it after it is all closed in.......
I made sure that mne would go in and out the access panels before I riveted the skin on....
bwestfall
Posted: Fri Jan 23, 2009 11:21 am Post subject: Wing Auto Pilot Servos |
Just to throw another one into the mix if you are going with AFS EFIS's they
are OEM'ing a TruTrak VSVG variant soon. AFS will sell you the servos today
if you call. Their price is better than TruTrak retail but a bit more than
buying from Van's.
I don't know any specifics on the autopilot but a forum thread on AFS's site
talks about custom programming to communicate with the AFS EFIS displays.
-Ben
