		noconwud(at)earthlink.net Guest
				 Posted: Thu Jan 22, 2009 8:11 pm    Post subject: Wing Auto Pilot Servos |
				I'm going to be ready to close up my wings in another month or so, and I
 recognize that I should have everything I ever want in there before I put
 the bottom skins on.  I've not really given any thought to an autopilot, but
 in order to be smart for an option down the road, would it be prudent to
 mount a servo in the wing to set me up for a possible future autopilot
 install?  If so, what kind of servo is recommended?
 Another option is to go ahead and close the wing, and hope there's an
 autopilot system that doesn't require mounting servos in the wing.
 Thoughts.
 Andy Johnson
 Poquoson, VA
				 Posted: Thu Jan 22, 2009 8:26 pm    Post subject: Wing Auto Pilot Servos |
				maybe go to the Tru Trak web site and look at what they have. The servo is mounted easily after closing up the wing C but it is the five or seven strand wire that controls the servo that you should get in the wing before you close it up C even though I was able to do mine after the fact.
 JOhn
 [quote] From: noconwud(at)earthlink.net
  Subject: Wing Auto Pilot Servos
  Date: Thu C 22 Jan 2009 23:08:34 -0500
				 Posted: Thu Jan 22, 2009 8:27 pm    Post subject: Wing Auto Pilot Servos |
				Just leave enough conduit to run the five wire...Its easy to do especially if you ran the wire. Honestly just order the Trutrak servo ind install it now..you need to replace a bellcrank bracket...its. 800 dollar investment you will do anyhow
		Albert Gardner
				 Posted: Thu Jan 22, 2009 8:30 pm    Post subject: Wing Auto Pilot Servos |
				The ones that I know off and like (Trio, Dynon, and TruTrak) all mount at
 the wing bellcrank with a modified bellcrank mount and, while I mounted mine
 as I was constructing the wing, I understand it's not a serious problem to
 mount them after the wing is finished. Put the wires in there though.
 Albert Gardner
 Yuma, AZ
  _________________ RV-9A N872RV
RV-10 N991RV |
		Tim Olson
				 Posted: Thu Jan 22, 2009 8:40 pm    Post subject: Wing Auto Pilot Servos |
				I can't imagine that 99% of the builders won't put in an autopilot,
 so I'd just agree with Rick and say "go for it".
 One other thing that makes that statement something to consider....
 Today I filled in my info for insurance renewal quote.  I'm going to
 be getting the AIG discount this year for TAA's.  I think that's
 10% off.  But, to get it, you have to have a few items in your plane,
 and things like RNP Nav equip, WX Equipment, TAWS and Terrain Equip,
 and "2 axis autopilot" are all things that they look at for getting
 the discount.  So in the long run, it may actually pay for itself
 over many years to have an Autopilot...and they wouldn't put it on
 the form if they didn't feel there was safety value there.
  800 dollar investment you will do anyhow ---
		rv(at)thelefflers.com Guest
				 Posted: Fri Jan 23, 2009 3:25 am    Post subject: Wing Auto Pilot Servos |
				And mount the servo bracket before the leading edge is attached to the spar.
 It will make your life easier.
 While I had the servo in hand, I didn't think of reading the installation
 directions since I had the bottom skins left to install.   While it's not
 impossible to get the two mounting bolts and nuts in place with the leading
 edge riveted to the spar, those with short arms will have difficulties.
				 Posted: Fri Jan 23, 2009 5:47 am    Post subject: Wing Auto Pilot Servos |
				Am I missing something?  All of the bolts that hold the aileron
 bellcrank brackets to the spar are held by nutplates which are
 installed along with the tiedown bracket on page 13-5.  This way you
 can pull the lower bellcrank bracket supplied by Van's with the one
 that holds the A/P servo after the wing is closed up.  I'm sure I am
 missing something obvious about what bolts and nuts you are referring
 to.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
  the spar.
  installation
  it's not
  leading
  difficulties.
		johngoodman
				 Posted: Fri Jan 23, 2009 7:42 am    Post subject: Re: Wing Auto Pilot Servos |
				Andy,
 Picking an autopilot is sort of like politics, or primer wars. Everybody has a strong opinion. There are three good brands for us out there, that I know of - Dynon, Trio, and Tru Trak. They all use a bracket mount at the aileron bell crank so you know you are going to have to put something there. Pick a brand and do it now. Here are three web pages to start on:
 http://www.trioavionics.com/ProPilot.htm
 http://www.trutrakflightsystems.com/instruments.htm
 http://www.dynonavionics.com/docs/Autopilot_intro.html
 PS: be prepared for a little sticker shock....
  	  | noconwud(at)earthlink.net wrote: | 	 		  I'm going to be ready to close up my wings in another month or so, and I
 Thoughts.
 Andy Johnson
 Poquoson, VA |
  _________________ #40572 Phase One complete in 2011 |
		dlm46007(at)cox.net Guest
				 Posted: Fri Jan 23, 2009 9:13 am    Post subject: Wing Auto Pilot Servos |
				You can buy the servo and wait on the remainder.
				 Posted: Fri Jan 23, 2009 10:02 am    Post subject: Wing Auto Pilot Servos |
				I would suggest that you make sure you can work on it after it is all closed in.......
 I made sure that mne would go in and out the access panels before I riveted the skin on....
		bwestfall
  Joined: 22 Oct 2008 Posts: 131 Location: Portland, OR
				 Posted: Fri Jan 23, 2009 11:21 am    Post subject: Wing Auto Pilot Servos |
				Just to throw another one into the mix if you are going with AFS EFIS's they
 are OEM'ing a TruTrak VSVG variant soon.  AFS will sell you the servos today
 if you call.  Their price is better than TruTrak retail but a bit more than
 buying from Van's.
 I don't know any specifics on the autopilot but a forum thread on AFS's site
 talks about custom programming to communicate with the AFS EFIS displays.
 -Ben
