robin1(at)mrmoisture.com Guest
Posted: Tue Jan 27, 2009 3:17 pm Post subject: Ameri-King AK-451 ELT |
Tim,
You have another option in case you go down. Searchers can just
go online to see your latest web postings of your trip with updated
crash photos and PIREPs on equipment performance for off field landings.
I further expect by the time the rescue team located the site you will
have the whole Swill Family Robinson tree house thing going on with
Andria preparing lunch for the kids while they ride the stationary bike
you built to power the Satellite TV on your converted Chelton MFD.
Robin
steveg(at)redmondair.com Guest
Posted: Tue Jan 27, 2009 3:40 pm Post subject: Ameri-King AK-451 ELT |
I understand, I was sort of confused by the change to the 406 units as well.
I had to do some research to see what the features were in order to answer
customer questions. I really wish that the GPS could be interfaced to all
the units. It would increase safety and make the search and rescue job a
lot easier. When you need the unit, it would be best to have as accurate
location as possible. One nice feature of the new installs is the buzzer
that makes it easier to find an ELT going off in a hanger full of aircraft.
Posted: Tue Jan 27, 2009 3:41 pm Post subject: Ameri-King AK-451 ELT |
Tim Olson wrote:
That's very cool that they have an In and an Out. Right now
I have a GPS signal split that goes to my APRS, also, so in the
case of the ELT, I'll probably change the APRS so that the ELT
gets the GPS signal and then outputs it to the APRS. It should
be almost nothing to change my wiring to support that plan.
Thanks for the update David.
Tim, I'd just hook all the items needing GPS input directly to the GPS.
Going through the ELT may (or may not depending on just how it's wired)
cause a problem if the ELT fails, and you'd never know it.
Linn
Tim Olson
Posted: Tue Jan 27, 2009 4:24 pm Post subject: Ameri-King AK-451 ELT |
Now THAT's the biggest laugh I've had for a while!!
Good one Robin!
Robin Marks wrote:
Tim,
Robin
effectus(at)rogers.com Guest
Posted: Tue Jan 27, 2009 5:09 pm Post subject: Ameri-King AK-451 ELT |
John,
Canada will cease monitoring satellite monitoring of 121.5 mhz as of
Feb. 1, 2009 and the Canadian fleet along with any international
visitors will have to convert their aircraft over to 406 mhz ELTs over a
2 year transition period.
Our Canadian Owners and Pilots Association (COPA) fought to enlighten
Transport Canada on the problems with the current ELTs. They compiled
data from the last 2 years showing that approx. 70 percent of accidents
had the ELT malfunction.
This fell on deaf ears and unlike you guys down south we do not have an
option to stay with the old system and take our chances with SPOT or PLB
augmentation. We (and all those 60,000 visitors) will have to have an
expensive GPS attached 406 installed or else.
From what I have gathered from the COPA publications it is the Canadian
Department of Defense that is pushing this as they are in charge of
CANSARSAT and the rescue efforts. They some how have it in their heads
that with the installation of new equipment the failure rate will go
down from 70% to something around 25%. there is a goal to be striving for!!!
Any how, there is the skinny on what is happening to us Canucks and how
it is going to spill over the border to touch a bunch of our American
friends who like to come up to visit.
Dave Hertner
John Jessen wrote:
When is the 406 required in Canada? I thought it might already be, and I
thought that a PLB was not enough for them.
John Jessen
Lenny Iszak
Posted: Tue Jan 27, 2009 5:42 pm Post subject: Re: Ameri-King AK-451 ELT |
Assuming before going down you will shut down your electrical system, how is your GPS going to keep supplying data to the ELT?
Lenny
dlm46007(at)cox.net Guest
Posted: Tue Jan 27, 2009 7:16 pm Post subject: Ameri-King AK-451 ELT |
Just means that you can't kill the master switch until just before
touchdown. Wherever you shut off electrical is where SAR starts.
Tim Olson
Posted: Tue Jan 27, 2009 8:14 pm Post subject: Ameri-King AK-451 ELT |
Actually, if you kept your head, it might be worth activating the
ELT using the panel mount switch if you knew it was going to end
up bad. Like, if I were going down over the ocean, I'd hope to
hit the button while still flying my way to the water.
I don't know the technical details, but they must have some way
of capturing the GPS signal as long as it's coming in, even with
the ELT not active. I'm not sure if the ELT then reports
"last known position", or what...but it would seem that the
companies that built the things must have taken into account
that when you crash, the wiring to the unit might get trashed.
At least I'd hope so.
I may just have to call and ask about that one.
Posted: Tue Jan 27, 2009 8:33 pm Post subject: Ameri-King AK-451 ELT |
AWESOME Imagination!!! Where does he find the time?
[quote] Subject: RE: RV10-List: Ameri-King AK-451 ELT
Date: Tue C 27 Jan 2009 18:05:28 -0500
Posted: Tue Jan 27, 2009 9:07 pm Post subject: Ameri-King AK-451 ELT |
Based on the way its wired the 406 E04 continuously gets updates and stores
the latest GPS data. That's the reason for the power to the ELT from ship's
power. Once the crash occurs, activation by G switch or activation from
panel switch, the batteries of the ELT begin transmitting GPS id and
location. Sometimes it is on multiple frequencies.
Tim Olson
Posted: Wed Jan 28, 2009 1:25 pm Post subject: Ameri-King AK-451 ELT |
I did just get off the phone with ACK to get the answer to the
question. Yes, the E-04 is continually getting updates and
stores the data as David says, so if you did shut off the
electrical pre-crash (probably something you do very close
to impact), then THAT position would be the one transmitted.
It just stores the position as fast as the GPS sends it and
sends whatever was there last when it is activated.
And, as we saw from their website, the delivery won't be for
a couple months.
For previous Ameri-King installs, you can either cut the
old cable to the panel switch, or if you have the RJ tool
like I do, you can put a new end flipped on it, and plug it
into the ACK. So you shouldn't have to re-run wires to make
it all work.
lbgjb10
Posted: Wed Jan 28, 2009 3:16 pm Post subject: Re: Ameri-King AK-451 ELT |
does anyone now whether the 'footprint' on the small unit in the panel would be changed for the new gps-elt. i assume you would have to run a wire to the new elt from your gps. (long way to the tail!!) larry
_________________ Larry and Gayle N104LG |
Posted: Wed Jan 28, 2009 4:52 pm Post subject: Ameri-King AK-451 ELT |
I got off the phone with EDMO where I have an account. The 451-5 -6, -7 have
GPS capability but their cost is $1800+. Edmo sent me a flyer regarding the
Artex ME406 but it has no provision for GPS input and my cost would be $829.
Accuracy without GPS is about 3 km. All of this is a non starter. I will
wait for the ACK E-04 with GPS interface and a list of $600 (with discounts
available). I have a Mcmurdo PLB with built in GPS available for about $600.
I brief my passengers concerning location and activation of the PLB
Tim Olson
Posted: Wed Jan 28, 2009 6:53 pm Post subject: Ameri-King AK-451 ELT |
The panel switch is compatible so you don't even change that.
Also, I have a GPS signal to my APRS right next to the battery so in
my case it's one short wire run and I'm done. Should maybe be a 1-2
hr project.
On Jan 28, 2009, at 5:16 PM, "lbgjb10" <lbgjb(at)gnt.net> wrote:
tail!!) larry
http://forums.matronics.com/viewtopic.php?p 27409#227409
hsdexo
Posted: Sun Feb 01, 2009 6:38 am Post subject: Re: Ameri-King AK-451 ELT |
Best thing to do is stay away from the 451. I sent a new 450 back to them that would not work. It was 3 months old and I sent the BOS with it.
They have failed to respond and still have my unit 1 year now.
