Posted: Sat Mar 18, 2006 3:25 pm Post subject: Land Shorter VG's on Firestar II |
| P.S. He still might not believe so just put them on the left wing
only!
Will it spin better with VGs on top of left wing, and bottom of right
wing?
Did we ever get a comprehensive report of the experimentation Beauford
T was doing with VGs on the bottom of his wings and top of his helmet?
Got my silencers welded up and ready to reinstall on the MKIII. Was
going to get over and get it done this afternoon, but a gut bug
persuaded me to stay close to the house. Tomorrow is rain. Soon, I
hope to get the old gal flying again to see if I can still fly.
Take care,
DO NOT ARCHIVE
_________________ John Hauck
Titus, Alabama |
ultrastarrick(at)yahoo.co Guest
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Sat Mar 18, 2006 5:58 pm Post subject: Re: Land Shorter VG's on Firestar II |
| Thom Riddle wrote: | John,
Question about your lower approach speed:
Normal approach speed on final is (according to most authorities) 1.3 x Vs. If you were stalling at 40 IAS was your final speed about 52 IAS before and now 39 mph (1.3x30)? If so then to land three point I guess you have to speed up 1 mph to land .
Thom in Buffalo |
Thom,
I used to approach at 50. How the plane acts just over the runway at speeds below 40 is something I'll have to learn. I'm sure that the tail will touch first (it did before). Will the mains hit hard if I get too sow. I doubt it but I don't know yet. If my first three landing are an indication, I going to like it.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
Richard Pike
Posted: Sat Mar 18, 2006 6:18 pm Post subject: Land Shorter VG's on Firestar II |
I can now shoot approaches solo in the MKIII at 45 and do pretty good.
Below that and it gets iffy.
Richard Pike
MKIII N420P (420ldPoops)
John Jung wrote:
<snip>
John Jung
Firestar II N6163J
Surprise, AZ
http://forums.matronics.com/viewtopic.php?p=22571#22571
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Dave Bigelow
Joined: 29 Jan 2006 Posts: 103 Location: Kamuela, Hawaii
Posted: Sun Mar 19, 2006 1:44 pm Post subject: Re: Land Shorter VG's on Firestar II |
My Landshorter VG's are at 7 inches from the leading edge measured along the chord line of my Firestar 2 wing. The interval is from the Landshorter templates. My wing has a smooth leading edge with no sag between ribs, so I could put them at any interval.
Stall is at 30 mph, and is abrupt, much like that of a sailplane laminar wing. Handling is rock solid right up to the stall, and then it quits with a pronounced drop of the nose. I find that the aircraft flys better in ground effect during the landing flare, and doesn't quit flying as suddenly as it did before VG's. I do notice that it takes a little more power to hold cruise speed. Overall, I think they are a great positive.
John's flight tests seem to indicate that the stall charactoristics are more mellow with the VG's at 8 inches. If I were starting from scratch, I'd use 8 inches from the LE.
_________________ Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E |
Posted: Sun Mar 19, 2006 2:08 pm Post subject: Land Shorter VG's on Firestar II |
quit flying as suddenly as it did before VG's. | --------
| Dave Bigelow
The para above, to me, is contradictory. You say the stall is at 30
mph and abrupt. However, during landing, "doesn't quit flying as
suddenly as it did before VG's."
I'm probably reading it wrong. If so, you can straighten me out,
please.
Glad it flies better in ground effect. Mine does too.
MKIII
Titus, Alabama |
John Jung
Posted: Sun Mar 19, 2006 3:38 pm Post subject: Re: Land Shorter VG's on Firestar II |
| Dave Bigelow wrote: | | My Landshorter VG's are at 7 inches from the leading edge measured along the chord line of my Firestar 2 wing. The interval is from the Landshorter templates. My wing has a smooth leading edge with no sag between ribs, so I could put them at any interval. |
Dave and Group,
This is interesting because I have a smooth wing too. What interval did you choose? Could the 1 inch change in placement cause that much difference? Or are we describing the same thing differently? The VG's do give my stall a sharper feel but much less nose drop and much less time before the stall stops. At least that is the impression that I got. At 4,500 rpm, I could do a stall every 5 to 10 seconds, always between 29.5 and 30 mph, and I did not notice a change in my vertical air speed on the EIS, or an altitude loss. Maybe, I not pulling into the stall fast enough, but I think that I was simulating a landing stall. Do we have any former test pilots to help with how stall testing should be done or described?
Firestar II N6163J
Surprise, AZ |
Dave Bigelow
Posted: Sun Mar 19, 2006 8:39 pm Post subject: Re: Land Shorter VG's on Firestar II |
John Jung,
The interval between the two VG's in a pair is 2.75 inches, and between pairs is 3.00 inches. I think the one inch distance from the LE may make a pretty big difference in the stall. Power off or on with a pitch attitude of level flight (bleeding airspeed attempting to hold a constant altitude to the break), the nose drops at least 20 degrees. If you have any rudder or a bank at the stall, the wing will drop in the direction of bank or rudder input. I get the feeling you could spin it, but so far have not been tempted to test that aspect of Firestar flight.
John H,
The Firestar gear limits the angle of attack of the wing in a three point landing. Most landings seem to touch down near 35, although I have made a few tailwheel first landings a bit slower. I think ground effect may temper the stall a bit close to the ground. I find that I'm doing a lot less stick stirring doing landing, as the response is quicker and less mushy. I'm sure you could get in trouble with a flare six feet (or more) in the air. Instead mushing into the ground in a level attitude, I think the nose would drop. My opinion is that an experienced pilot would have no trouble with the VG's, but a pilot new to Kolbs should probably get some time with the standard wing before adding VG's.
Kamuela, Hawaii
FS2, HKS 700E |
John Jung
Posted: Mon Mar 20, 2006 12:13 pm Post subject: Re: Land Shorter VG's on Firestar II |
| Dave Bigelow wrote: | John Jung,
The interval between the two VG's in a pair is 2.75 inches, and between pairs is 3.00 inches. |
Dave,
We have a similar wing and spacing. From what I have read about VG's, the 1 inch difference from the LE should not cause our difference.Where is your CG? Are you near 37% like I am? Maybe that could explain the difference in stall charactoristics.
Firestar II N6163J
Surprise, AZ |
Dave Bigelow
Posted: Mon Mar 20, 2006 5:56 pm Post subject: Re: Land Shorter VG's on Firestar II |
John J,
My CG is pretty close to the aft limit.
Kamuela, Hawaii
FS2, HKS 700E |
John Jung
Posted: Thu Mar 23, 2006 9:57 am Post subject: Re: Land Shorter VG's on Firestar II |
I'm sure you could get in trouble with a flare six feet (or more) in the air. Instead mushing into the ground in a level attitude, I think the nose would drop. My opinion is that an experienced pilot would have no trouble with the VG's, but a pilot new to Kolbs should probably get some time with the standard wing before adding VG's. |
Dave and I are both flying Firestar II's with similar wings, aft CG's, LandShorter VGs and only on inch difference in placement, yet we have very different descriptions of the change in flight/stall charactoristics. About the only thing we agree on is that we like the plane better than without VGs. This problem of inconsistancy of described results is one of the reasons that it took me so many years to try VGs. I will continue to test them and do my best to report the results.
Firestar II N6163J
Surprise, AZ |
Posted: Thu Mar 23, 2006 10:18 am Post subject: Land Shorter VG's on Firestar II |
Firestar II's with similar wings, aft CG's,>>
Hi John,
if that CG is very far aft I think I would be more worried about getting
that right that with adding VG`s, however desirable they they are.
Cheers
Pat
wcm(at)tampabay.rr.com Guest
Posted: Thu Mar 23, 2006 1:55 pm Post subject: Land Shorter VG's on Firestar II |
All,
It's no mystery to me why there are such varied results, I don't think that
any two people have installed the Land Shorter VGs in the same location on
their wings and none at the recommended distances.
Harrison Designs (in person phone conversation) recommends that the VGs be
placed at 10% of the wing chord on a Firestar II, that's 6.2 inches aft of
the leading edge and spaced at 3 inches apart with the pairs centered in
each valley.
In comparing results from installing something as significant as VGs on an
aircraft wing an inch difference may as well be a mile.
You can steer the whole damned airplane just by sticking your arm out of
the cockpit.
It's apples and oranges guys.
CM
| Quote: | Dave and I are both flying Firestar II's with similar wings, aft CG's,
John Jung
Firestar II N6163J
Surprise, AZ
http://forums.matronics.com/viewtopic.php?p=23734#23734
JetPilot
Posted: Fri Mar 24, 2006 8:18 am Post subject: Re: Land Shorter VG's on Firestar II |
| John Jung wrote: |
I have a bag of LandShorter VG's and the same questions about the best place on the wing to put them. I am sure that they will be an improvement even if I dont get them in the perfect spot the first time.
Eventually we could find the optimum spot for the Kolb wing if we all do some testing, and post exactly where we put the VG's and post our results.
Michael A. Bigelow
Kolb MK-III Xtra, 912-S |
Posted: Fri Mar 24, 2006 8:59 am Post subject: Land Shorter VG's on Firestar II |
our results.
| Michael A. Bigelow
If I were to decide to use VG's on my MKIII I would start
experimentation with the VG's placed as suggested by the VG
manufacturer. Tests would proceed from this base. When I was
satisfied I could not find a better place to install them permanently,
that I had them placed for optimum performance, then I'd stick'em.
Even then, I may stick'em semi-permanent in case I wanted to further
experimentation.
Will the placement of Joe Blow's VG's on his Kolb work exactly the
same way on my Kolb??? Have no idea. Think I mentioned in a previous
post, "Flight testing a Kolb is not an exacting science, especially
when the test pilots are from the "Kolb Gang".
While I am suggesting, might add: "Learn to fly the Kolb well,
especially prior to making aerodynamic changes." You may find out you
don't need them, or you may find out you do.
For what it is worth.
MKIII 2,448.2 hrs
912ULS 1,102.3 hrs
Titus, Alabama |
Posted: Sat Mar 25, 2006 9:08 am Post subject: Land Shorter VG's on Firestar II |
on the wing to put them.>>
Hi there,
how about being really daring and put them exactly where the manufacturers
says you should. Or does that offend some basic ethic of the Experimental
category?
Cheers
Pat
Posted: Sat Mar 25, 2006 9:30 am Post subject: Land Shorter VG's on Firestar II |
I totally agree, Joa was very specific about where to place the VGs and how
to space them on the Firestar II when I spoke to him on the phone.
But then again what does he know??? (snip)
CM
John Jung
Posted: Sun Mar 26, 2006 5:31 am Post subject: Re: Land Shorter VG's on Firestar II |
Group,
I did a dozen landings today to learn more about how my Firestar II handles different than before the VGs. Conditions were as thermally and gusty as I have experienced in Arizona. Wind was about 15 mph, mostly down the 1000 ft dirt runway, with a small crosswind component. My first landing was at 4350 rpm, nose high, tail dragging at 30 mph. The plane dropped from there, hit harder than I like but no bent gear. After that, I kept the rpms at 3,600 down to full idle. Average touch down speed was 34 mph, almost always 33 to 35 mph, all tail first, soft landings. Even though conditions were bad, it was easy to land the plane without hitting hard. In the past, I had to get the mains close to the runway before I slowed to 40, because at 40 mph it just dropped.
On the way back to the airport, I tried to duplicate the nose drop stall that Dave reported. I pulled the stick back further so the plane would slow quicker. This time it stalled at 28 and the nose did drop below level, like Dave described. I can't really compare that with before the VGs, because I never pulled my Firestar into a stall that quickly before. And I don't see it happening by accident.
In summary, I much prefer my Firestar with the Landshorter VGs. I have flown Firestars for the past 9 years, and I have some time in a Mark II and a Mark III. These Landshorter VGs make my plane easier to land then any non-VG Kolb I have flown. Granted, if I had flaps, I might never had tried them.
Firestar II N6163J
Surprise, AZ |
Posted: Sun Mar 26, 2006 6:55 am Post subject: Land Shorter VG's on Firestar II |
John,
Joa (from Land Shorter) tells me that if you install the VGs on the
underside of the Horizontal Stabilizer, just ahead of the hinge line at 1.5
inch spacing that the tail will not drag low as you have described, rather
it will stay in normal attitude and do a soft "mush" right at touch down. He
said that the reason for this is that because of the VGs, the Wing wants to
keep flying but the tail wants to stall first, adding the VGs aft will
balance the two flying surfaces and eliminate this tendency.
I installed the VGs on my wing as per Joa's instructions and will add them
to the HZ stab. as per his instructions as well.
Joa has the experience of ALL those that have installed Land Shorter Vgs on
their aircraft regardless of type.
The only thing better than a good set of instructions is a conversation with
the guy that wrote them.
CM
Steven Green
Posted: Sun Mar 26, 2006 10:46 am Post subject: Land Shorter VG's on Firestar II |
If the horizonal stabilizer stalls the tail would go up, not down, unless
you are flying a canard wing with the stab. up front.
Steven
_________________ Steven Green |
