GRT AHRS Pitch & Roll Calibration...
Site Admin
PostPosted: Sat Feb 07, 2009 8:42 pm    Post subject: GRT AHRS Pitch & Roll Calibration... Reply with quote
How do I adjust the pitch and roll calibration of the AHRS on the Grand Rapids EFIS HX AHRS? I go into the AHRS Maintenance page and find the Pitch and Roll numbers for AHRS 1 and for AHRS 2, but when I select "Change", but none of the numbers are adjustable. I mounted my dual AHRS as level as I possibly could, but there's no way a mere mortal such as myself could possible get it perfect. Surely you are allowed to dial in the pitch and roll attitudes........?
Thanks for the help!
RV-8 #82880 / N998RV (res)
skylor4(at)yahoo.com
PostPosted: Mon Feb 09, 2009 8:32 pm    Post subject: GRT AHRS Pitch & Roll Calibration... Reply with quote
Matt,
On the Settings Menu/Primary Flight Display there is a "Pitch Ladder Offset" that can be adjusted to +- 15 degrees.
There is no adjustment for roll. GRT states that the AHRS and magnetometer must be installed level in roll, and I believe this is critical for stability. If your mounting shelf isn't perfect, use shims between the mounting flange and your mounting bracket to get it level. You'll also want to make sure that your mounting brackets won't flex under "G" and vibrate from engine vibrations.
Skylor
RV-8 Under Construction
Finishing...
--- On Sat, 2/7/09, Matt Dralle <dralle(at)matronics.com> wrote:
[quote]From: Matt Dralle <dralle(at)matronics.com>
Subject: GRT AHRS Pitch [quote][b]
Site Admin
PostPosted: Wed Feb 11, 2009 10:42 am    Post subject: Re: GRT AHRS Pitch & Roll Calibration... Reply with quote
Thanks for the feedback. I also heard back from GRT tech support and they said that anything under .5 degrees is fine. I'm right around .2 degrees in both pitch and roll, so I guess that's close enough.
Matt
Pitch and Roll at .2 Degrees
 Filesize:  86.87 KB
 Viewed:  788 Time(s)
Site Admin
PostPosted: Wed Feb 11, 2009 10:46 am    Post subject: Re: GRT AHRS Pitch & Roll Calibration... Reply with quote
Here's one more shot to prove it looks alright at .2degrees... Smile
Matt
Level to .2 Degrees
 Filesize:  111.27 KB
 Viewed:  5438 Time(s)
