AndrewC
Posted: Mon Feb 27, 2006 11:01 am Post subject: Aileron stiffness and force - XL |
Hi there
I'm still going through the test flying of my 601 XL, G-DROO, and the probleme du jour is that the ailerons require excessive force to operate in flight. By excessive I mean, two hands are required and my test pilot rightly wants it fixed. Elevator control is fine by comparison.
My XL has the twin sticks and the flap trim booster mod required by the UK authorities. Application of right stick is heavier than left and when right is applied the ailerons tend to want to settle back half-way towards neutral. Left aileron behaves normally by comparison but is still heavier than I would like. I understand that aileron control on 601s is heavier than in other planes as a starting point, but this is really too much!
The problem is that I have no idea why they are behaving this way and don't know what to change to try and sort it out. Experience of anyone who has the twin stick would be much appreciated. The twin stick arrangement appears to have the torque tube rotating through metal "bearings" (though these are really just holes in metal plates) and one delron bearing. This arrangement seems quite high friction but I'm not sure what lubricant I can use here. Also I can't understand why right aileron requires more force and is more prone to return to neutral than left. Any ideas?!
Thanks in advance
Andrew
Gig Giacona
Posted: Mon Feb 27, 2006 11:22 am Post subject: Re: Aileron stiffness and force - XL |
Do you get the same stiffness on the ground?
601XL Under Construction
Posted: Mon Feb 27, 2006 1:58 pm Post subject: Aileron stiffness and force - XL |
AndrewC wrote:
Hi there
The problem is that I have no idea why they are behaving this way and don't know what to change to try and sort it out. Experience of anyone who has the twin stick would be much appreciated. The twin stick arrangement appears to have the torque tube rotating through metal "bearings" (though these are really just holes in metal plates) and one delron bearing. This arrangement seems quite high friction but I'm not sure what lubricant I can use here. Also I can't understand why right aileron requires more force and is more prone to return to neutral than left. Any ideas?! [Rolling Eyes]
Thanks in advance
Andrew
Andrew,
It's entirely possible that someone has cut the hinge/aileron material
from something thicker than the .016 material needed for the ailerons.
Normally, the aileron force is slight to nil in standard turns and at
slow speed major aileron action can be felt as more resistant, but not
something
so noticeable to require a change. Better check your cables, belcranks
stick bearings and such for friction points and lubricate them first.
Larry McFarland - 601hds
Posted: Mon Feb 27, 2006 2:12 pm Post subject: Aileron stiffness and force - XL |
Hi Andrew,
I wonder if the aileron bell crank pivot bolts are tightened too
much. Also, this area needs some lubricant, but I don't think lack
of lubricant would have as much impact as your problem indicates.
I would suggest you start disconnecting parts, starting at the bolt
in the aileron control horn and feel for the tight movement. If you
keep dividing the aileron control system in half and chasing down the
tight spot you should find it rather quickly.
Good luck,
Paul
XL wings
At 11:01 AM 2/27/2006, you wrote:
Hi there
Thanks in advance
Andrew
cgalley(at)qcbc.org Guest
Posted: Mon Feb 27, 2006 2:30 pm Post subject: Aileron stiffness and force - XL |
I would first unfasten the ailerons from the rest of the system at the
ailerons. Then try see if the binding is still there. If it is, then the
problem may be as simple as lubrication or something in the way. If the
binding goes away, then your have a trailing edge that isn't straight. You
can check this first if you wish just by sighting down the trailing edge.
If it isn't straight, then you have a rebuild project.
Cy Galley - Chair,
Air Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
David X
Joined: 10 Jan 2006 Posts: 154 Location: Princeton, NJ, USA
Posted: Mon Feb 27, 2006 5:34 pm Post subject: Re: Aileron stiffness and force - XL |
Purely a novice suggestion:
Try measuring aileron cable tension at various positions of the stick to see if it's something related to the control geometry. Tension is supposed to be 25 inch-pounds +/-5.
If cable tensions are fairly consistant throughout the range of stick motion, I'd start looking for things that bind or rub. At a minimum, cable tension mesurments may help you narrow down which part of the control mechanism is stiffest.
_________________ Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE |
bryanmmartin
Posted: Mon Feb 27, 2006 5:55 pm Post subject: Aileron stiffness and force - XL |
It may be that the aileron torque tube is slightly out of round. If the
bearing surface that the torque tube rides in is also slightly out of round,
at certain angles of rotation, the two could bind. This could happen if you
tighten the nut on the bolt holding the stop ring on the front of the torque
tube on the standard "Y" stick too tight. I don't know it the twin stick
option has a similar arrangement. You can't tighten the bolts going through
the steel tubes to the torque recommended in the torque tables because it
can crush the tubes. As I recall these bolts are drilled and use castle
nuts, so you just get them snug and install the cotter pin.
In any case, you will probably have to disconnect the aileron cables to
isolate the problem
on 2/27/06 2:01 PM, AndrewC at andrewgcampbell(at)tiscali.co.uk wrote:
Hi there
Thanks in advance
Andrew
_________________ --
Bryan Martin
do not archive. |
JAPhillipsGA(at)aol.com Guest
Posted: Mon Feb 27, 2006 7:05 pm Post subject: Aileron stiffness and force - XL |
Andrew, I have to go along with Larry. Something is just not right ???? I
have duel sticks in my XL with a Jab 3300 and about 55 hours. A problem I had
with initial flights was the right aileron was a beast. Then I noticed I did not
have my rudder centered. The rudder was so stiff initially that at anything
over 100 mph it would not center on it's own. After I got used to re centering
the ball during climb out as the P factor played out the stiff right aileron
went away. Further, without aileron trim and no passenger the right aileron
should be a little stiff compared to left. Now she is so nimble it's scary. Breath
left or right and I'm dragging a wing tip. I recommend you re check fairleads
to see if they are binding. Also, the thread had a series of posts concerning
adjusting ailerons down some time back, but I can't remember why ?? Check the
archives, Best of Luck, Bill of Georgia N505WP
ggower_99(at)yahoo.com Guest
Posted: Mon Feb 27, 2006 10:24 pm Post subject: Aileron stiffness and force - XL |
Needless to say that please dont fly the plane until you find the problem...
Paul idea is a good one.
Saludos
Gary Gower
Beguining a 601 XL kit.
Do not archive.
Paul Mulwitz <p.mulwitz(at)worldnet.att.net> wrote:
Hi Andrew,
Good luck,
Paul
XL wings
Hi there
Thanks in advance
Andrew
AndrewC
Posted: Tue Feb 28, 2006 3:23 pm Post subject: Re: Aileron stiffness and force - XL |
Guys,
Thanks for all the suggestions, will give them all a thorough check through at the weekend and hopefully will get to the bottom of it. There definitely seems to be some friction at the torque tube end and I had wondered whether the design of the elevator attachment might have given it a left tendency sure enough. When the cables weren't connected everything was fairly smooth so perhaps it is as simple as cable tension (I certainly hope so). So I'm going to apply some lube, and progressively go through the connections until I sort this thing out! Certainly can't keep flying with almost full aileron trim just to maintain straight and level...!
Cheers
Andrew
Posted: Tue Feb 28, 2006 5:29 pm Post subject: Aileron stiffness and force - XL |
Andrew,
Don't over tension those cables. I believe 20-25 lbs should be the max
on those. To have more could
likely cause more friction, wear and early deflection on the belcrank
mounts.
Larry McFarland
AndrewC wrote:
Guys,
Cheers
Andrew
http://forums.matronics.com/viewtopic.php?p=18555#18555
AndrewC
Posted: Sun Mar 19, 2006 1:19 pm Post subject: Re: Aileron stiffness and force - XL |
Thanks again for all the postings on this topic. They were all very helpful and I've now finished the test schedule and the problem is now almost gone (or at least within acceptable limits).
It looks as though the source of the problem is that my right wing is generating slightly more lift than the left one. There are two possible cuplrits: one flap appears to be a couple of millimetres lower than the other (no guesses for which side) and there may be a slight twist in the wing but I'll be checking that shortly with my digital protractor at each rib and comparing the same points on each wing. Wing incidence seems to be okay otherwise. Lubrication merely helped the ailerons find their balance; right aileron naturally falls, presumably the weight of the trim servo etc on that aileron. In flight the forces were still the same though so at least it was aerodynamic and we've solved it by adjusting the turnbuckles so both ailerons are equal to the level of the flaps. The plans show the flaps should protrude above the airflow by around 3mm, so that's where the ailerons are now with stick centred and the forces are much reduced. Also the aileron trim is now back towards the middle in level flight too.
The rudder pedal rods will also be adjusted a couple of turns to give a little bit left rudder when pedals are equal - the ball wasn't quite centred in straight and level flight.
Performance figures are a little on the disappointing side for me though. I had hoped to be within 10 knots of the oft quoted cruise speed of 120 knots. No such luck. 75% cruise at 5000rpm on the Rotax 912ULS gives around 95 knots around 1000feet. TAS at 5000 feet with more power came out at around 110 knots. I've no intention of flying at max continuous, as I like my engine, so looks like I'll have to settle for 100 knot 80% cruise. At least she flies...
David X
Posted: Sun Mar 19, 2006 7:27 pm Post subject: Re: Aileron stiffness and force - XL |
I have a woodcomp 3-blade on my 912USL, I set the pitch to 17 degrees to top out at about 130 MPH. 15 degrees yields 115 MPG. 13 degrees yields best climb, less p-factor tendancy, but maxes out at about 100 MPH.
I also noticed a tendency for the aircraft to turn left excessively. I thought it was my ailerons or a heavy wing, but turns out that it's my fat ass. Try flying with left tank near empty, right tank near full. Maybe it won't help, but it's easy enough to try.
DO NOT ARCHIVE |
naumuk(at)alltel.net Guest
Posted: Mon Mar 20, 2006 3:22 pm Post subject: Aileron stiffness and force - XL |
professor71(at)hotmail.co Guest
Posted: Mon Mar 20, 2006 3:45 pm Post subject: Aileron stiffness and force - XL |
After 140hrs on my 601HD I just installed aileron trim. Before, when flying
solo, the plane wanted to roll to the left. When carrying a passenger it
flies pretty even. If you are in the building process I would definately go
with the aileron trim. Much easier to do now than later.
John
[quote]From: "Bill+Rose" <naumuk(at)alltel.net>
Reply-To: zenith-list(at)matronics.com
To: <zenith-list(at)matronics.com>
Subject: Re: Re: Aileron stiffness and force - XL
Date: Mon, 20 Mar 2006 18:20:56 -0500
grs-pms(at)comcast.net Guest
Posted: Mon Mar 20, 2006 5:24 pm Post subject: Aileron stiffness and force - XL |
I notice a left turn tendency when flying solo in any of several flying club
Cessna 150s. These are well maintained airplanes, usually used for dual
instruction. I never noticed the left turn tendency with an instructor or
passenger. I wish the 150 had aileron trim.
George Swinford
David X
Posted: Mon Mar 20, 2006 9:05 pm Post subject: Re: Aileron stiffness and force - XL |
P.S. I have the aileron trim :) It's trimmed nearly full right when I solo. It takes less trim adjustment eventually when I burn off left tank first.
DO NOT ARCHIVE |
pmaxpmax(at)hotmail.com Guest
Posted: Tue Mar 21, 2006 6:17 pm Post subject: Aileron stiffness and force - XL |
My landing light is in the right wing for exactly that same reason.
Phil
N601MX
XL/Corvair
| Quote: | The person who owned the first Zenith I'd ever seen up close- a
gorgeous
HDS, commented on the same left turn tendency. He said that if he had to do
it all over again, he'd put as much accessory weight as he could in the
right side. Consequently, I put my landing light and aileron trim in the
right wing.
Before cutting metal, I contacted EAA to find out if there was any reg
against putting a landing light in the right wing. According to the EAA
Technical Counselor, you can put the landing light anywhere, but he said
the
problem was probably aerodynamic and not weight related.
As light as the Zenith is, there's a possibility that weight really is
a
factor, but three people noticing the same tendency is not conclusive.
Anyone else want to "Weigh in"?
Bill
Posted: Wed Mar 22, 2006 6:30 am Post subject: Aileron stiffness and force - XL |
Bill, my XL flies with a little heavy left wing when I fly alone, but when I
carry someone the tendency disappears and depending on weight of passenger I
may not even need to input any aileron trim. I suppose that the ZAC folks
designed these factors into the plane. Before I would weigh the right side to
balance for one I would consider what that will do when the two people weight is
factored in. Might then have a heavy right wing. FWIW, Bill of Georgia
don not archive
Jaybannist(at)cs.com Guest
Posted: Wed Mar 22, 2006 8:10 am Post subject: Aileron stiffness and force - XL |
My EAA tech advisor has suggested a "bungee trim" for ailerons in lieu of a
wing-mounted trim tab. It would be connected to the aileron cables inside the
fuselage with a mechanical control (ala Piper elevator trim).
