Lynn Matteson
Posted: Tue Feb 17, 2009 8:01 pm Post subject: New issue, turtle deck security |
The fact that the rivets have pulled through the wood seems to me to
call for a load-spreading modification.....say something like a
(humor me) MK1000 anchor nut for instance. Sorry, I've been watching
"House" on the tube, and I'm picking up his grating personality. : )
Seriously though, James, that is good news that you found that the
builder followed some directions. If you are going the "hardware
store" option for replacement hardware, you might consider "T-nuts" I
believe they are called...nuts that are stamped metal with a large
washer head with little spikes to prevent rotation in the wood of the
butt rib capstrip. This would allow for easier removal in case things
don't work out with the old windshield/skylight. Not as good in my
opinion as the anchor nuts, because the anchor nuts have the self-
locking feature which the T-nuts do not...could use loctite with the
T-nuts, I suppose. I'd like to use an aircraft fastener or something
a bit more elegant than the T-nuts myself.
Remember too, that the wood in this area has been compromised by the
wood fibers being stretched and torn by the rivets being torn through
the wood, so I'd certainly go beyond just fixing the problem,
whatever that entails.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis done and flying
On Feb 17, 2009, at 8:56 PM, WurlyBird wrote:
Quote: |
<james.t.trizzino(at)us.army.mil>
Well here is an update that is pretty good news, well at least I
now know the builder was not a complete moron. It seems the green
house lexan was in fact installed into the butt ribs, however the
rivets were simple secured into the wood and they seemed to work
their way out. I plan to use washers for backing if I use rivets
to secure the new lexan. I am considering using screws instead. I
noticed that the manual calls for aluminum rivets for this
assembly, I assume this means that AN hardware would not be
necessary and it would be no issue to just use some nice SS hardware.
James
Kitfox 3 / 582 / GSC prop
4 hrs of instruction and climbing (I solo tomorrow)
http://forums.matronics.com/viewtopic.php?p 30781#230781
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
thesupe(at)hotmail.com Guest
Posted: Tue Feb 17, 2009 9:30 pm Post subject: New issue, turtle deck security |
I would not use SS rivits C because they will pull up a lot tighter than aluminum rivits and I would worry that it would mess with the expantion of the lexan leading to cracking. I did use 1/8" washers on the bottom of the aluminum rivits (that I bought from Fastenall) so they wouldn't pull through the butt rib. Just my 2 cents worth. Jim Chuk Avid MK IV Mn
Quote: | Subject: Re: New issue C turtle deck security
Date: Tue C 17 Feb 2009 17:56:57 -0800
--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil>
Well here is an update that is pretty good news C well at least I now know the builder was not a complete moron. It seems the green house lexan was in fact installed into the butt ribs C however the rivets were simple secured into the wood and they seemed to work their way out. I plan to use washers for backing if I use rivets to secure the new lexan. I am considering using screws instead. I noticed that the manual calls for aluminum rivets for this assembly C I assume this means that AN hardware would not be necessary and it would be no issue to just use some nice SS hardware.
James
http://forums.matronics.com/viewtopic.php?p=230781#230781
&g=======
Windows Live™: E-mail. Chat. Share. Get more ways to connect. See how it works.
Lynn Matteson
Posted: Wed Feb 18, 2009 3:05 am Post subject: New issue, turtle deck security |
You're absolutely right, Jim, and that's one of the reasons that I
went to machine screws....better control of the tightness of the
fasteners. Even if you used aluminum pop rivets with aluminum
mandrels, you have no control of the tightness after the mandrel breaks.
Lynn Matteson
Sensenich 62x46
On Feb 18, 2009, at 12:25 AM, Jim_and_Lucy Chuk wrote:
Quote: | I would not use SS rivits, because they will pull up a lot tighter
N369LM |
Guy Buchanan
Posted: Wed Feb 18, 2009 4:06 am Post subject: New issue, turtle deck security |
At 05:56 PM 2/17/2009, you wrote:
Quote: | I noticed that the manual calls for aluminum rivets for this
James,
I too would worry about restraining the expansion of the
skylight excessively with SS rivets. However I use SS screws here, as
you suggest, and they're fine since the loads are negligible. (Indeed
I wonder if your rivets loosened under the thermal expansion load
instead of the flight loads.)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Fox5flyer Guest
Posted: Wed Feb 18, 2009 4:14 am Post subject: New issue, turtle deck security |
Exactly. Either washers or the aluminum strip as called for in the manual.
Deke
[quote] Subject: RE: Re: New issue, turtle deck security
I would not use SS rivits, because they will pull up a lot tighter than aluminum rivits and I would worry that it would mess with the expantion of the lexan leading to cracking. I did use 1/8" washers on the bottom of the aluminum rivits (that I bought from Fastenall) so they wouldn't pull through the butt rib. Just my 2 cents worth. Jim Chuk Avid MK IV Mn
Quote: | Subject: Re: New issue, turtle deck security
Date: Tue, 17 Feb 2009 17:56:57 -0800
Well here is an update that is pretty good news, well at least I now know the builder was not a complete moron. It seems the green house lexan was in fact installed into the butt ribs, however the rivets were simple secured into the wood and they seemed to work their way out. I plan to use washers for backing if I use rivets to secure the new lexan. I am considering using screws instead. I noticed that the manual calls for aluminum rivets for this assembly, I assume this means that AN hardware would not be necessary and it would be no issue to just use some nice SS hardware.
James
&g=======
Windows Live™: E-mail. Chat. Share. Get more ways to connect. See how it works. Quote: |
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
Fox5flyer Guest
Posted: Wed Feb 18, 2009 4:29 am Post subject: New issue, turtle deck security |
Correctly put, Lynn, and more important to those of you who use the LP
acrylic products. The folks at LP say to drill the holes 50 percent larger
than the fastener then after applying a thin foam 1/2" wide insulating seal,
use truss head screws and nuts (or nutplates), tighten down the screw until
it just begins to distort the acrylic, then stop. This can be easily done
by using reflected light. At this point the screw is not tight and can be
very easily turned in it's place. I personally used #6 screws and nylock
nuts and have had no problems since 2000. One of the advantages to using
machine screws rather than rivets is that it can later be adjusted.
I would also caution against using rivets as you can't control the tension,
something that is very important in avoiding cracking later on. If you have
to use rivets, get the softest ones you can. Don't use stainless. They're
way too strong and your windshield probably won't last a year before it
begins to crack.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Wed Feb 18, 2009 11:10 am Post subject: Re: New issue, turtle deck security |
When I referenced SS hardware I was speaking specifically of the machine screws and nuts and was not considering SS rivets. But I would not have thought about those issues, so thanks. I am trying to figure out the best way to use machine screws without taking three steps backward. I would have to remove fabric around the butt ribs in order to secure anything but I would like to know it is a one handed operation to remove and replace screws. I would also like to use the aluminum strip and I am trying to figure out a way to secure the bolts to that strip. Perhaps I could secure some regular lock nuts with epoxy to the strip during the assembly.
Still thinking on it.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Lynn Matteson
Posted: Wed Feb 18, 2009 12:05 pm Post subject: New issue, turtle deck security |
I would just drill out the existing rivets, and place an anchor nut
in the same location, fastened with solid, flat-head rivets. Once
this job is done, it's a one-handed job to use machine screws forever
after. Epoxy might give out later on, and if you had to remove screws
then, they would just rotate on you, unless you got them close to the
rib itself, then they might hold, but fall off when the screw was
removed. I didn't realize that the area was covered in fabric
already. I think you'd be better off biting the bullet and doing it
right, re-covering, and lay this problem to rest. Heck, you wouldn't
have to recover before you flew again, would you? I'm talking about
just removing the fabric around the butt rib...hey, why not just
slice the fabric, lay it back and tape over the area when the job is
done, go fly, and when the mood hits you, re-do the fabric in that area.
Lynn Matteson
Sensenich 62x46
James
http://forums.matronics.com/viewtopic.php?p 30860#230860
N369LM |
Lynn Matteson
Posted: Wed Feb 18, 2009 12:19 pm Post subject: New issue, turtle deck security |
Absolutely right, Deke, and having installed an LP Aeroplastics
windshield/skylight, I can say that that is just what their
instructions call for, and what I did. Heck, this is good info even
if the builder doesn't have the LP A components. If not explained
earlier, the reason for the oversize holes is to allow for thermal
expansion.
Lynn Matteson
Sensenich 62x46
On Feb 18, 2009, at 7:27 AM, fox5flyer wrote:
Quote: |
<fox5flyer(at)idealwifi.net>
the LP acrylic products. The folks at LP say to drill the holes 50
percent larger than the fastener then after applying a thin foam
1/2" wide insulating seal, use truss head screws and nuts (or
nutplates), tighten down the screw until it just begins to distort
the acrylic, then stop. This can be easily done by using reflected
light. At this point the screw is not tight and can be very easily
turned in it's place. I personally used #6 screws and nylock nuts
using machine screws rather than rivets is that it can later be
adjusted.
tension, something that is very important in avoiding cracking
later on. If you have to use rivets, get the softest ones you
can. Don't use stainless. They're way too strong and your
windshield probably won't last a year before it begins to crack.
N369LM |
vadert(at)shaw.ca Guest
Posted: Wed Feb 18, 2009 12:23 pm Post subject: New issue, turtle deck security |
James
6nbsp;
6nbsp; 6nbsp; When rebuilding my Kitfox 6nbsp; I decided to fold a 1 1/2 2 2 strip of aluminum in a right angle C 3/4 2 each side E I notched 6nbsp;one half of the aluminum strip continuously along it 7s length so that it would bend to fit the curve of the capstrip and riveted it to the but rib to prevent the capstrip from lifting E 6nbsp; When reinstalling the windshield I drilled out for the attachment holes through the capstrip and aluminum angle and used 10-32 or 10-28 rivnuts along the capstrips and rear strip of the skylight E 6nbsp; This makes it a one handed operation to remove or replace the machine screws E 6nbsp;
6nbsp; I think that the capstrips are susceptible to pulling away from the butt ribs mostly due to the fact that the tightening curve at the front of the butt ribs makes the tension of bending the windshield over the curve want to pull up at that point E 6nbsp; I 7m sure that the lift generated by the airflow adds to the upward force E
6nbsp;
Tim Vader
6nbsp;
Kitfox IV
Great Plains VW
Calgary C Alberta
Guy Buchanan
Posted: Wed Feb 18, 2009 2:11 pm Post subject: New issue, turtle deck security |
At 11:10 AM 2/18/2009, you wrote:
Quote: | I would also like to use the aluminum strip and I am trying to
Ooo. You might be able to save some time by riveting anchor nuts to
an aluminum strip, then epoxying / riveting that to the butt rib.
That way the anchor nut installation would be easy.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
MDKitfox(at)AOL.COM Guest
Posted: Wed Feb 18, 2009 3:07 pm Post subject: New issue, turtle deck security |
I don't know if this will help, but there is a nutplate that doesn't require riveting. You drill the hole for the fastener, peel off a protective piece of plastic on the nutplate to expose a glued surface and pull an attached plastic tang until the glued surface makes solid contact with undersurface of the structure. Wait overnight and pull out the plastic tang and the nutplate is ready for use. I think they have fixed and floating versions. It's really slick. It may be a little pricey at a dollar or two per nutplate, but if it works....
I believe the name of the company was Click Bond. A friend of mine is building a Lancair 4P and is using them thru out his project.
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
On Feb 18, 2009, at 5:01 PM, Guy Buchanan wrote:
Quote: | --> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com (bnn(at)nethere.com)>
Quote: | I would also like to use the aluminum strip and I am trying to figure out a way to secure the bolts to that strip. Perhaps I could secure some regular lock nuts with epoxy to the strip during the assembly.
Ooo. You might be able to save some time by riveting anchor nuts to an aluminum strip, then epoxying / riveting that to the butt rib. That way the anchor nut installation would be easy.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / War="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com========================
-M==========
= [quote][b]
Lynn Matteson
Posted: Wed Feb 18, 2009 3:33 pm Post subject: New issue, turtle deck security |
That sounds like a good idea if it holds. After all, once installed,
the nutplate is under tension until the bolt is unscrewed, then it is
subjected to rotating forces which put the glued surface under sheer
forces. If the glue is stronger than the resistive "self-locking"
feature of the nutplate, the screw will come out and all will be
well. If the glue now fails...years later, maybe...the plate will
have to be held...if it can be accessed, and a new one installed.
I still like the idea of the riveted nutplate/anchor nut, with its
shear-resistive rivets holding it in place.
Lynn Matteson
Sensenich 62x46
On Feb 18, 2009, at 5:59 PM, Weiss Richard wrote:
Quote: | I don't know if this will help, but there is a nutplate that
Rick Weiss
SkyStar S/N 1
Port Orange, FL
N369LM |
WurlyBird
Posted: Wed Feb 18, 2009 3:55 pm Post subject: Re: New issue, turtle deck security |
Couple questions for ya Lynn;
Is it possible to install these with blind rivets?
I can not find blind countersunk rivets in 3/32" diameter like the anchor nuts call for. Also I am not experienced with solid rivets and I am not going to figure out how on my butt ribs, ya know?
Is there a more reasonable place to buy these anchor nuts then AC Spruce?
The anchor nuts for the butt ribs alone cost over $100. It takes an awful lot of my time before I think it is worth over $100 vs $1 for rivets.
Lynn Matteson
Posted: Wed Feb 18, 2009 4:55 pm Post subject: New issue, turtle deck security |
Very possible, if you can find 3/32" rivets. Spruce has a poor
selection of rivets, but somebody has them, I'm sure. That's why I
used solid rivets and a rivet squeezer. Is there an EAA chapter in
your area? They might have one you could borrow. When I got my kit
there were 3/32 rivets with it, but only 1/8" long. I'm sure they are
out there somewhere. Maybe John McBean has a source, or you could
Google for them, perhaps. Also try Wick's.
Another thought....the solid rivets in the AN426A style are soft, and
as such, could be "bucked" with a hammer and bucking bar...a chunk of
steel. These rivets would probably be more than strong enough to hold
the K1000 anchor nuts in place. If worse came to worse, you could
remove the butt ribs by drilling the rivets holding them on...about
6-8 rivets per but rib as I recall, then take the butt rib to the
workbench and rivet the anchor nuts on where it will be easier to use
solid rivets and peen them by hand ...no special tools required.
Sounds like you are taking about the elastic-insert anchor nuts (at)
over a buck each, and 6-32's (at) damn near $10...WOW! I used the all
metal anchor nuts (at) 51 to 61 cents each...10-32 or 8-32.
Lynn Matteson
Sensenich 62x46
Spruce?
for rivets.
James
http://forums.matronics.com/viewtopic.php?p 30908#230908
N369LM |
patreilly43(at)hotmail.co Guest
Posted: Wed Feb 18, 2009 5:33 pm Post subject: New issue, turtle deck security |
Sonex sells rivets. They have great prices and sone 3/32 nds. They don't have alot of lenght choices though.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Quote: | From: lynnmatt(at)jps.net
Subject: Re: Re: New issue C turtle deck security
Date: Wed C 18 Feb 2009 19:55:03 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Very possible C if you can find 3/32" rivets. Spruce has a poor
selection of rivets C but somebody has them C I'm sure. That's why I
there were 3/32 rivets with it C but only 1/8" long. I'm sure they are
out there somewhere. Maybe John McBean has a source C or you could
Google for them C perhaps. Also try Wick's.
Another thought....the solid rivets in the AN426A style are soft C and
as such C could be "bucked" with a hammer and bucking bar...a chunk of
the K1000 anchor nuts in place. If worse came to worse C you could
6-8 rivets per but rib as I recall C then take the butt rib to the
over a buck each C and 6-32's (at) damn near $10...WOW! I used the all
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 605 hrs
Sensenich 62x46
> and I am not going to figure out how on my butt ribs C ya know?
> Spruce?
> for rivets.
> James
> http://forums.matronics.com/viewtopic.php?p=230908#230908
&g==================
Float Flyr
Posted: Wed Feb 18, 2009 7:00 pm Post subject: New issue, turtle deck security |
When I worked for the AMO (Cdn for FBO) we would give away most common
rivets up to a handful at a time just to help people out.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Guy Buchanan
Posted: Wed Feb 18, 2009 9:42 pm Post subject: New issue, turtle deck security |
For 3/32 counter sunk rivets, see:
http://www.recreationalmobility.com/cgi-bin/recreation/28193.html
http://www.recreationalmobility.com/cgi-bin/recreation/28195.html
and
http://www.skygeek.com/hardware-cherry-rivetblind.html near the
bottom of the page.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Fox5flyer Guest
Posted: Thu Feb 19, 2009 4:23 am Post subject: New issue, turtle deck security |
I second that, Lynn. Some things last longer than others and nothing lasts
forever. As you, or someone else said, people often permanently cover the
locking side of the fastener which makes it inaccessible, for example the
butt rib and fuel tank area. I've never felt comfortable with covering that
area and have found no compelling reason for doing so other than aesthetics.
If one is planning on covering that area it would make good sense to use
permanent fasteners, like nut plates with rivets. It takes some extra time,
but the long term benefit and peace of mind is worth it when one needs to
replace or remove the greenhouse for some reason. If the butt rib isn't
going to be covered, then it doesn't matter much what one uses so long as
the fasteners cannot pull through the wood . Well, I think I would avoid 3"
drywall screws! As someone else said, there is probably some lift in that
area. Well, let me tell you, THERE IS LIFT in that area, and I know from
experience. If you don't have those fasteners well secured, the lift can
and probably will eventually lift the windshield right off the butt ribs.
Personally, on my S5 I just used #6 SS truss head screws with nylock nuts,
all of which are easy to access as I didn't cover the butt ribs. No washers
are necessary. There is no magic bullet here as there are several methods
that will work fine. Just use common sense and look at the long term.
Deke Morisse
Mikado Michigan
- Joseph Joubert
Fox5flyer Guest
Posted: Thu Feb 19, 2009 4:34 am Post subject: New issue, turtle deck security |
I'm not sure what type of anchor nuts you are referring to, but below are
some that will work fine, sans the gold plating. The ones at .36 each will
work fine as will the K1000 at .51 each.
They also have the countersunk blind rivets, see below.
http://www.aircraftspruce.com/catalog/hapages/avexblindriv.php
http://www.aircraftspruce.com/catalog/hapages/anchornuts.php
Deke Morisse
Mikado Michigan
- Joseph Joubert
