701 long wing
dpfisher(at)scottsbluff.n
PostPosted: Thu Feb 26, 2009 6:38 pm    Post subject: 701 long wing Reply with quote
Hi guys,
I think the drawing John is talking about is probably a sketch that Chris
sent me in response to my request to extend each wing by one foot for
better high altitude operation.( Naturally aspirated engine performance as
well as take off and climb performance degrades by about 4% per thousand
feet due to the thinner air, I believe.) I've not yet done the mod but I
intend to and I'd be very interested in seeing the 1992 701 UL sketch that
you have, Robert, could you E-Mail me a copy? I'm also planning a slat
less wing with VGs on both the wings and the elevator. In addition,
I'm considering a "cuff " that would put the wing nose profile midway
between the wing with slats and the wing without but have not yet asked the
factory about the " cuff ". Has anyone done anything like this? I'd like
to maintain as much wing area as possible without shifting the center of
lift too far forward.
Thanks!
Dave, 701 with A-80-8 Continental
At 12:58 AM 2/26/2009, you wrote:
Subject: Re: Long wing
Excellent point,
I have a drawing from CH that shows basically the same treatment on the
tip but the main structural change was lengthening the doubler at the
strut attach point and increasing it's thickness,
stepinwolf
PostPosted: Thu Feb 26, 2009 7:40 pm    Post subject: 701 long wing Reply with quote
Dave,
Here it is, however don't expect too much, so as not to be disappointed.
Robert Pelland
Extended_wing.pdf
 Filename:  Extended_wing.pdf
 Filesize:  974.89 KB
 Downloaded:  542 Time(s)
Long wing + vga's, = lo & slo
