				 Posted: Mon Mar 23, 2009 4:59 pm    Post subject: doors |
				OK, speaking of doors ..... has anyone suffered damage because the wind
 caught the doors?  Any other concerns with the doors???  Any 'fixes'
 that you'd do when you're assembling the doors???    I'm getting ready
 to do mine ..... educate me!!!
 Linn
 Tim Olson wrote:
  winds are 20+, taxi isn't the worry,
  holding the doors when you open them is a bigger concern.
		gengrumpy(at)aol.com Guest
				 Posted: Mon Mar 23, 2009 5:29 pm    Post subject: doors |
				Best add a strap you can hold onto when you open it.  Also use it to
 pull it closed.
 I don't let my passengers open the door if there's any wind to speak
 of.....
 grumpy
 N184JM
 On Mar 23, 2009, at 9:00 PM, linn wrote:
  wind caught the doors?  Any other concerns with the doors???  Any
  'fixes' that you'd do when you're assembling the doors???    I'm
  getting ready to do mine ..... educate me!!!
  Linn
  Tim Olson wrote:
 > the winds are 20+, taxi isn't the worry,
 > Tim Olson - RV-10 N104CD - Flying
 > do not archive
		pascal(at)rv10builder.net Guest
				 Posted: Mon Mar 23, 2009 5:33 pm    Post subject: doors |
				The adjusting and making the doors line up will require you to "fix" that
 fit after you trim everything
 The trimming to get the doors to close will require a whole lot of "fixing"
 the aligning/leveling of the doors with the canopy will  require lots of
 "fixing" with flox and micro
 The whole door is a "fix", expect lots of hours fixing it to fit.
 My advice concerning the seals is buy a smaller one than what Van's thinks
 will work, it's pretty sad to see perfectly fitting doors not fit at all
 after installing the seals and having to start all over again trying to
 "fix" it to fit..
 Have fun! I just finished mine took months to complete, but can be done in 1
 month non stop, aka- I took breaks between pages to let things set and
 replace electric tools that the composite cutting and  mainly sanding
 destroyed, .
 Pascal
 Sent: Monday, March 23, 2009 6:00 PM
 Subject: doors
  caught the doors?  Any other concerns with the doors???  Any 'fixes' that
  you'd do when you're assembling the doors???    I'm getting ready to do
  Linn
 > do not archive
		Dave(at)AirCraftersLLC.co Guest
				 Posted: Mon Mar 23, 2009 6:24 pm    Post subject: doors |
				We did a repair for a lucky customer whose door came open just after
 take-off.  He was able to land straight ahead.  The door opened all the way,
 broke the gas strut brackets off the door, but otherwise had no other
 damage.  We did a very thorough inspection of the hinges and other attach
 structure and it was all fine.
 I taxi with the doors open all the time.  I think opening the doors in a
 crosswind would be pretty safe, just a hassle because of all the other
 wind-related issues, but I don't think you'd break anything.
 Dave Saylor
 AirCrafters LLC
 140 Aviation Way
 Watsonville, CA
 831-722-9141
 831-750-0284 CL
 www.AirCraftersLLC.com
		daveleikam(at)wi.rr.com Guest
				 Posted: Mon Mar 23, 2009 7:35 pm    Post subject: doors |
				think of it this way..
 expect the worst, like my fixing, and be pleasantly surprised when you
 discover I had no idea what I was doing and you get it done without any
 issues. Sure beats me telling you its easy; just trim, tuck and snip snip
 and your done.
 You'll thank me one day
 Pascal
 Sent: Monday, March 23, 2009 6:27 PM
 Subject: Re: doors
  I just started mine, thanks for the vote of confidence...  Sheeesh!
		partner14
				 Posted: Mon Mar 23, 2009 8:51 pm    Post subject: doors |
				If I was going o do them again,,,, GOD forbid,  I would insert a strengthening plate aft of the door handle.  Then you'd have something to actually fasten a strap to.
  My 2 cents.
  Don McDonald
  Received the FAA's blessing today with an airworthiness cert!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
 --- On Mon, 3/23/09, linn <pitts_pilot(at)bellsouth.net> wrote:
 Subject: doors
 Date: Monday, March 23, 2009, 7:00 PM
  --> RV10-List message posted by: linn <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
 OK, speaking of doors ..... has anyone suffered damage because the wind caught the doors?  Any other concerns with the doors???  Any 'fixes' that you'd do when you're assembling the doors???    I'm getting ready to do mine ..... educate me!!!
 Linn
40636 |
				 Posted: Tue Mar 24, 2009 6:45 am    Post subject: doors |
				As for doors...
  It takes a very long time to get them to fit perfectly C like sailplane quality.
  As mentioned C I put an additional hardpoint(hardwood block) in the leading edge C above the pin location C so I could instal a locking mechanism C like that on the baggage door.
  I put an additional 6"X6" spider foam block in the rear area of the door above the rear pin location.
  Everything was verified to fit prior to lamination of the door halves on the fuse. Windows where later laminated on the door with the doors on the fuse.
  In the rear additional foam C one should put a hardpiont in that location( either hardpoint only to screw a fastener into or put the fastener into the door before laminating the halve for the strap that will be used to pull the door closed.
  That additional foam will keep the rear half of the door from being so flimsy or compressible from the in or outside.
  DId anyone notice that the canopy's Rt front portion which attaches to the fuse stand proud and therefore might makes the Rt door stand more proad where the door transitions from the canopy to the metal fuse???????????????????Or was my conopy removed from the mold a little too early and got warped??? Left side was dead on.
  	  | Quote: | 	 		   Date: Mon C 23 Mar 2009 21:00:48 -0500
  Subject: doors
  --> RV10-List message posted by: linn <pitts_pilot(at)bellsouth.net>
  OK C speaking of doors ..... has anyone suffered damage because the wind
  Linn
  Tim Olson wrote:
  > --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> When the
  > winds are 20+ C taxi isn't the worry C
  > do not archive
		Albert Gardner
				 Posted: Tue Mar 24, 2009 7:15 am    Post subject: doors |
				Let me pass on the report I got from an RV-10 owner concerning the "Lose of
 Door in Flight" situation. The part I like was the statement 'the plane flew
 fine.'
 Albert Gardner
 Yuma, AZ
 "After the P seals are added to the doors it can be rather hard to close
 them. Since the rear latch is difficult to see and you pull the door closed
 from the forward edge the rear pin is the most likely to not be engaged. My
 passenger failed to close it properly and I did not check it before
 take-off. Immediately after rotation and within 200' of the ground there was
 a loud bang and it became very noisy and windy. The plane flew fine, I kept
 it to about 90kts, did a 180 and landed without further incident. The door
 pulled through the bolts at the hinge and the gas strut broke loose both at
 the door and cabin attach points. The door halves had mostly delaminated,
 the window was broken, and the inner shell had broken through at the curve
 but was easily repairable. There was no damage to the empennage."
  _________________ RV-9A N872RV
RV-10 N991RV |
		jcumins(at)jcis.net Guest
				 Posted: Tue Mar 24, 2009 7:59 am    Post subject: doors |
				Congrats Don.  I am sure your inspection will go off with out a hitch.
 When I get to the doors I will sure come visit you for advise.
 John G. Cumins
 President
 JC'S Interactive Systems
 2499 B1 Martin Rd
 Fairfield Ca 94533
 707-425-7100
 707-425-7576 Fax
 Your Total Technology Solution Provider
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
  Sent: Monday, March 23, 2009 9:48 PM
  Subject: Re: doors
 My 2 cents.
 Don McDonald
    Subject: doors
    Linn
    Tim Olson wrote:
    > --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>   When   the winds are 20+, taxi isn't the worry,
    > do not    --> http://www.matronics.com/Navigator?RV10-List
    sp; --> ht              - List Contribution Web Site;                         &nb; http://========================
     	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  0123456789
		partner14
				 Posted: Tue Mar 24, 2009 8:33 am    Post subject: doors |
				Passed already... yesterday.  then took the FAA inspector, Dilly, out for a bbq dinner.  Great guy, unbelievable that he's a govt employee.  Basically inspected my plane on his own time.  Now for finishing my flight training.  Headed to Dallas this weekend for RV10 training and the hp endorcement with Alex.  The ducks are lining up!
  Sure, come on up anytime.
  Don
 --- On Tue, 3/24/09, John Cumins <jcumins(at)jcis.net> wrote:
 Subject: RE: doors
 Date: Tuesday, March 24, 2009, 8:56 AM
 John G. Cumins
 President
 2499 B1 Martin Rd
 Fairfield Ca 94533
 707-425-7100
 707-425-7576 Fax
 From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com ] On Behalf Of Don McDonald
 Subject: Re: doors
 My 2 cents.
 Don McDonald
 Subject: doors
 Linn
 Tim Olson wrote:
  	  | Quote: | 	 		  |     http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com   | 	  012
40636 |
				 Posted: Tue Mar 24, 2009 8:55 am    Post subject: doors |
				Congrats, wish I was going to Dallas with you.  But in due time hehe.  50000 more rivits to go.
 Chat soon.
 John G. Cumins
 President
 2499 B1 Martin Rd
 Fairfield Ca 94533
 707-425-7100
 707-425-7576 Fax
  Sent: Tuesday, March 24, 2009 9:31 AM
  Subject: RE: doors
 Don
    Subject: RE: doors
 When I get   to the doors I will sure come visit you for advise.    |
 John G.   Cumins
 President
 2499 B1 Martin Rd
 Fairfield Ca 94533
 707-425-7100
 707-425-7576   Fax
    Subject: Re: doors
 My     2 cents.
 Don     McDonald
      Subject: doors
      Date: Monday, March 23, 2009, 7:00 PM      |
      Linn
      Tim Olson wrote:
      > --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>   When     the winds are 20+, taxi isn't the worry,
      	  | Quote: | 	 		  |     http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution    get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List=nofollow>http://forums.matronics.com   | 	  01
    23456789 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?RV10-List | 	  0 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?RV10-List | 	  1 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?RV10-List | 	  2 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?RV10-List | 	  3 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?RV10-List | 	  4 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?RV10-List | 	  5 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?RV10-List | 	  6 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?RV10-List | 	  7 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?RV10-List | 	  8 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?RV10-List | 	  9 	  | Quote: | 	 		  | http://forums.matronics.com | 	  0 	  | Quote: | 	 		  | http://forums.matronics.com | 	  1
