Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Mar 24, 2009 7:20 pm Post subject: Elevator level |
Anyone have a good reference point to zero the level to measure elevator
travel? I can only think of trying to use a ruler across the middle of the
airfoil across the chord line.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Strasnuts
Posted: Wed Mar 25, 2009 3:38 am Post subject: Re: Elevator level |
Sorry about the stupid question. Hugo enlightened me. It was a long day.
780 Hours
coop85(at)verizon.net Guest
Posted: Thu Mar 26, 2009 6:41 am Post subject: Elevator level |
I used a protractor with a weighted indicator that moves as you rotate the
device. Easy way to measure moving parts. Here's a link to the one I have
at Home Depot Aircraft Supply:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10
051&langId=-1&catalogId=10053&productId=100165800
Well worth the $9
Marcus
40286
rene(at)felker.com Guest
Posted: Thu Mar 26, 2009 7:13 am Post subject: Elevator level |
I purchased an electronic level from the aviation department of home depot.
Cost a little under $40 before tax. I though it was well worth it. Used on
tail...flaps....magnetometer placement... made it all a lot easier.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Tim Olson
It's been a while but I think I layed a straight edge across the top
of the elevator and the horizontal stab, in the most consistent
place I could. Then that was zero. From there, at the time, I used
this $4 Dial-gauge angle finder from Harbor Freight.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34214
Surprisingly it worked pretty good.
But these days, I found something way cooler....something that is
just my style.
http://www.teego.com/multilevel.html
A level app for the iPhone/iPod Touch. This thing is super accurate,
and dirt cheap if you own the device.
Well worth the $9
Marcus
40286
Phil.Perry(at)netapp.com Guest
planesmith(at)hotmail.com Guest
Posted: Thu Mar 26, 2009 8:10 am Post subject: Elevator level |
This is also what I used. Works great for leveling the plane when working on wheel pants and weight and balance.
Here is a link to the tool: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100653598
Vern Smith (#324 finishing)
[quote] From: rene(at)felker.com
Subject: RE: Elevator level
Date: Thu C 26 Mar 2009 09:11:17 -0600
--> RV10-List message posted by: "Rene Felker" <rene(at)felker.com>
Rene' Felker
RV-10 N423CF Fly================
Hotmail® is up to 70% faster. Now good news travels really fast. Find out more.
Strasnuts
Posted: Thu Mar 26, 2009 8:35 am Post subject: Re: Elevator level |
Thanks everyone,
I bought the 40$ Ridgid digital level from Home Depot and it worked great.
I installed the elevators and they came out really close.
780 Hours
bkbrown(at)minetfiber.com Guest
Posted: Thu Mar 26, 2009 9:05 am Post subject: Elevator level |
Also, you might check with your local EAA Chapter for some of those resources. Vern’s chapter (EAA292) has a top of the line Stabila electronic level and protractor that we loan out to our members for free. In these times, free resources like these add up…
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vernon Smith
Sent: Thursday, March 26, 2009 9:10 AM
To: RV 10 list
> To: rv10-list(at)matronics.com
> Date: Thu, 26 Mar 2009 09:11:17 -0600
> Rene' Felker
Hotmail® is up to 70% faster. Now good news travels really fast. Find out more. | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
jim(at)CombsFive.Com Guest
Posted: Thu Mar 26, 2009 10:47 am Post subject: Elevator level |
I thought the elevator travel was limited by the stops in the tail of the fuselage? The elevator horns contacted the stops. I don't recall having to measure the elevator travel at all with a angle finder. I may be wrong about this.Jim CN312F - Flying--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>It's been a while but I think I layed a straight edge across the topof the elevator and the horizontal stab, in the most consistentplace I could. Then that was zero. From there, at the time, I usedthis $4 Dial-gauge angle finder from Harbor Freight.http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34214Surprisingly it worked pretty good.But these days, I found something way cooler....something that isjust my style.http://www.teego.com/multilevel.htmlA level app for the iPhone/iPod Touch. This thing is super accurate,and dirt cheap if you own the device.Tim Olson - RV-10 N104CD - FlyingMarcus Cooper wrote:> --> RV10-List message posted by: "Marcus Cooper" <coop85(at)verizon.net>>> I used a protractor with a weighted indicator that moves as you rotate> the> device. Easy way to measure moving parts. Here's a link to the one I> have> at Home Depot Aircraft Supply:>> http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10> 051&langId=-1&catalogId=10053&productId=100165800>>> Well worth the $9>> Marcus> 40286> --
bcondrey
Posted: Thu Mar 26, 2009 11:04 am Post subject: Elevator level |
Maybe it’s been too long Jim! Before my first flight I created the following list of alignments and rechecked all. Elevator alignment is on page 11-6.
Bob
N442PM (flying)
Elevator alignments
11-2
Up/Down Travel
11-6
limit stops
11-7
aft tube rod end bearing adjustment
39-10
control stick elevator neutral adjustment
Aileron Alignment
23-7
neutral position
23-8
bellcrank neutral position
23-9
aileron to flap alignment
44-4
control stick aileron neutral adjustment
Elevator trim alignment
11-10
deflection spec & adjustment
Rudder alignment
11-7
limit stops
Control Sticks
39-9
Control stick parallel alignment
Flap Alignment
44-5
Flap full up position alignment
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim(at)CombsFive.Com
Sent: Thursday, March 26, 2009 1:46 PM
Subject: Re: Elevator level
Jim C
N312F - Flying
just my style.
> the
> have
> Well worth the $9
> Marcus
> 40286
Tim Olson
Posted: Thu Mar 26, 2009 11:23 am Post subject: Elevator level |
Aw shoot....I was talking trim deflection.
You're right. For elevators I just lined up the horns with the HS.
On Mar 26, 2009, at 1:45 PM, jim(at)CombsFive.Com (jim(at)CombsFive.Com) wrote:
[quote]I thought the elevator travel was limited by the stops in the tail of the fuselage? The elevator horns contacted the stops. I don't recall having to measure the elevator travel at all with a angle finder.
Jim C
N312F - Flying
Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
just my style.
[quote] --> RV10-List message posted by: "Marcus Cooper" <coop85(at)verizon.net>
the
have
Well worth the $9
Marcus
40286
If I remember correctly. You need to check and adjust elevator travel once the linkage all the way to the stick is established. I was having my stick, with infinity grip, hit the panel and thus tried to solve that problem by adjusting the linkage……so It may have been different to me.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Sent: Thursday, March 26, 2009 12:46 PM
Jim C
N312F - Flying
just my style.
> the
> have
> Well worth the $9
> Marcus
> 40286
Tim Olson
Posted: Thu Mar 26, 2009 11:32 am Post subject: Elevator level |
That is awesome for you to write this up Bob...I can't remember back that far well anymore but I just followed the plans...
Your write up is a great quick reference!
On Mar 26, 2009, at 1:57 PM, "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com (bob.condrey(at)baesystems.com)> wrote:
[quote] st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Bob
N442PM (flying)
Elevator alignments
11-2
Up/Down Travel
11-6
limit stops
11-7
39-10
Aileron Alignment
23-7
neutral position
23-8
23-9
44-4
11-10
Rudder alignment
11-7
limit stops
Control Sticks
39-9
Flap Alignment
44-5
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of jim(at)CombsFive.Com (jim(at)CombsFive.Com)
Jim C
N312F - Flying
just my style.
> <coop85(at)verizon.net (coop85(at)verizon.net)>
> the
> have
> Well worth the $9
> Marcus
> 40286
Posted: Thu Mar 26, 2009 5:35 pm Post subject: Elevator level |
Whew! - You guys had me worried there! I just followed the directions posted on Tim's web site to set up the elevator trim travel. They worked perfectly!Jim CombsN312F - Flying Do Not Archive-------------------------------------------------------Aw shoot....I was talking trim deflection.You're right. For elevators I just lined up the horns with the HS.TimOn Mar 26, 2009, at 1:45 PM, jim(at)CombsFive.Com wrote:> I thought the elevator travel was limited by the stops in the tail> of the fuselage? The elevator horns contacted the stops. I don't> recall having to measure the elevator travel at all with a angle> finder.>> I may be wrong about this.>> Jim C> N312F - Flying>>> --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>>> It's been a while but I think I layed a straight edge across the top> of the elevator and the horizontal stab, in the most consistent> place I could. Then that was zero.>From there, at the time, I used> this $4 Dial-gauge angle finder from Harbor Freight.> http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34214>> Surprisingly it worked pretty good.>> But these days, I found something way cooler....something that is> just my style.> http://www.teego.com/multilevel.html>> A level app for the iPhone/iPod Touch. This thing is super accurate,> and dirt cheap if you own the device.>> Tim Olson - RV-10 N104CD - Flying>>>> Marcus Cooper wrote:> > --> RV10-List message posted by: "Marcus Cooper"> <coop85(at)verizon.net>> >> > I used a protractor with a weighted indicator that moves as you> rotate> > the> > device. Easy way to measure moving parts. Here's a link to the one I> > have> > at Home Depot Aircraft Supply:> >> > http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10> > 051&langId=-1&catalogId=10053&productId=100165800> >> >> > Well worth the $9> >> > Marcus> > 40286> > -----Original Message-----> >>From: owner-rv10-list-server(at)matronics.com> > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts> > Sent: Tuesday, March 24, 2009 11:21 PM> > To: rv10-list(at)matronics.com> > Subject: Elevator level> >> > --> RV10-List message posted by: "Strasnuts" <sean(at)braunandco.com>> >> > Anyone have a good reference point to zero the level to measure> elevator> > travel? I can only think of trying to use a ruler across the> middle of> > the> > airfoil across the chord line.> >> > --------> > Cust. #40936> > A&P, ATP> > typed CE-525(s), CE-500> > RV-10 tailcone finished> > N801VR reserved> >> >> >> >> > Read this topic online here:> >> > http://forums.matronics.com/viewtopic.php?p 36055#236055> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >>>>>> [quote][b]
Posted: Fri Mar 27, 2009 7:34 pm Post subject: Elevator level |
Bob is right C the "Tool Crib" as it is called is a great resource. If your chapter doesn't have one it's worth asking about starting one. He got ours started and it has been a real asset to the members.
Vern Smith (#324 finishing & airbox fun)
Subject: RE: RV10-List: Elevator level
Date: Thu C 26 Mar 2009 10:04:28 -0700
.ExternalClass .EC_shape {;} .ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.EC_HTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.EC_EmailStyle20 {font-family:'Calibri' C'sans-serif';color:#1F497D;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
Also C you might check with your local EAA Chapter for some of those resources. Vern’s chapter (EAA292) has a top of the line Stabila electronic level and protractor that we loan out to our members for free. In these times C free resources like these add up…
Windows Live™ SkyDrive: Get 25 GB of free online storage. Check it out.
