Which Quickbuild Would You Recommend?
fritzsch(at)eskimo.com
PostPosted: Fri Apr 03, 2009 10:31 am    Post subject: Which Quickbuild Would You Recommend? Reply with quote
I am working on my elevators and thinking about how I want to proceed.
While I may go all self built, I want to consider all of my options.
This question is mainly for those who are flying or have finished their
fuselage. If you had to make a choice of one or the other, would you go
for the quickbuild wings or the quickbuild fuselage?
Dave
Dave Fritzsche
40813
Puyallup, WA
bkbrown(at)minetfiber.com
PostPosted: Fri Apr 03, 2009 10:58 am    Post subject: Which Quickbuild Would You Recommend? Reply with quote
QB Wings
Tim Olson
PostPosted: Fri Apr 03, 2009 11:14 am    Post subject: Which Quickbuild Would You Recommend? Reply with quote
I'll counter that with QB Fuse. Depends on if you like
building or like flying.
Bob and Karen Brown wrote:
QB Wings
rv(at)thelefflers.com
PostPosted: Fri Apr 03, 2009 11:18 am    Post subject: Which Quickbuild Would You Recommend? Reply with quote
I don't think you'll get much debate. QB Wings over QB fuselage.
The fuselage goes together quicker and is more interesting (i.e. less
repetitive work). The fuselage requires less proseal too! (i.e fuel tanks
are built in the QB wings)
I think a better question to ask is what will be the quality level of the
QBs with the new factory? Unfortunately, nobody will know that answer until
this summer when they start to ship.
I'm doing a standard build of both.
bob
pascal(at)rv10builder.net
PostPosted: Fri Apr 03, 2009 11:33 am    Post subject: Which Quickbuild Would You Recommend? Reply with quote
Depends on how much you want to build, I would go SB the whole way, as I
did, you lose so much of the building experience getting the QB. If you are
sold on one or the other the fuselage requires more work than the wings did,
the only section in the wings that are a challenge is the fuel tanks and
that just requires an attention to detail, if you are meticulous in applying
the proseal that section can be fun as well and really no big deal.
So if in a rush, get the fusellage QB if not do the SB and enjoy the
building process.
Pascal
From: "Dave Fritzsche (Building)" <fritzsch(at)eskimo.com>
Sent: Friday, April 03, 2009 10:25 AM
To: "RV-10 Matronics" <rv10-list(at)matronics.com>
Subject: Which Quickbuild Would You Recommend?
While I may go all self built, I want to consider all of my options. This
Dave
Dave Fritzsche
40813
Puyallup, WA
Tim Olson
PostPosted: Fri Apr 03, 2009 11:40 am    Post subject: Which Quickbuild Would You Recommend? Reply with quote
Gee, I don't know. I've met more than a handful of people
so far with leaky rivets on fuel tanks from QB Wings. I'd
never want to have my tanks built there based on what I've
seen so far in that respect. But, you're right, based
on the new Philippines issues, it may be safest just to
skip all the QB stuff and do it all yourself. You'd save
enough to buy or almost buy a GNS-430W while you're doing it.
As far as I'm concerned though, the proseal job of
building tanks may suck, but it certainly is bearable
and it's over pretty quick...I'd do it again no
problem.
bob
PostPosted: Fri Apr 03, 2009 11:55 am    Post subject: Which Quickbuild Would You Recommend? Reply with quote
The reason I said wings is...that's the part that's flying, it's the
majority of rivets. I've bought two sets of QB wings...both were almost
flawless. I can't do that good of riveting myself...I went QB all the way
on my -7A. On the 10, went QB wing...happy with that, but would have been
fine either way really. I'd say look at a QB wing if you can...then look at
a first timers wing...make your choice.
sstella(at)incisaledge.co
PostPosted: Fri Apr 03, 2009 12:23 pm    Post subject: Which Quickbuild Would You Recommend? Reply with quote
I just ordered slow build wings and I'm fine with slow build all the way but
it depends on how fast you want to finish. I heard of issues with leaking
quickbuild tanks in the past. I don't know if it has been resolved but that
might be something to consider.
PostPosted: Fri Apr 03, 2009 12:55 pm    Post subject: Which Quickbuild Would You Recommend? Reply with quote
I don't know what percentage of QB tanks leak vs SB or "owner built"...but I
can't believe it can be much different. With over 50 RV's based at this
airpark and in my own experiences of being around people who have finished
up their planes and fueled and flown...I just don't see a huge difference in
how many leak...QB vs SB. I've seen just a few leakers from each type, but
I don't really see a chronic problem either way. Chalk up my QB tanks
(knocking on wood now) and everyone I know around me as non leakers. The
only leakers I know of around here (total of maybe six) except one or two
have all been owner built tanks.
dlm46007(at)cox.net
PostPosted: Fri Apr 03, 2009 1:11 pm    Post subject: Which Quickbuild Would You Recommend? Reply with quote
Both QB, of course I got the early QB wings and fuselage. Also I put every
rivet in the Glastar project so don't need the additional experience.
Phil.Perry(at)netapp.com
PostPosted: Fri Apr 03, 2009 1:14 pm    Post subject: Which Quickbuild Would You Recommend? Reply with quote
I wish I hadn't ordered a QB fuse (Or wings for that matter) last
December.
I'm feeling like July or August is optimistic at this time. I really
wish I had ordered parts only.
I'd cancel my order now, but I'm stuck between a rock and a hard place.
If I cancel, I'm starting over from scratch 5 months late and I might be
getting a QB fuse in a few months. A fuse completed to QB status is
more than 3-6 months of work for me to do. So it's a catch 22.
If I was ordering again, I'd just order the parts. Regardless of wings
or fuse.
Phil
robin1(at)mrmoisture.com
PostPosted: Fri Apr 03, 2009 1:48 pm    Post subject: Which Quickbuild Would You Recommend? Reply with quote
Simple math:
Wings = 2
Wing Fuel Tanks = 2
Fuse = 1
Fuse Fuel Tanks = 0
QB wings, SB Fuse IMHO.
Robin
Kelly McMullen
PostPosted: Fri Apr 03, 2009 3:12 pm    Post subject: Which Quickbuild Would You Recommend? Reply with quote
Have you had any updates on the QB delivery time? My order is a couple months behind yours.
On Fri, Apr 3, 2009 at 5:13 PM, Perry, Phil <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)> wrote:
[quote]--> RV10-List message posted by: "Perry, Phil" <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)>
December.
or fuse.
Phil
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
bcondrey
PostPosted: Fri Apr 03, 2009 3:17 pm    Post subject: Which Quickbuild Would You Recommend? Reply with quote
Dave,
The SB wings are largely repetition - 2 essentially identical parts.
Each of them have a lot of ribs. There is nothing at all complex about
building the wings - imagine a much larger scale version of the H-stab.
Fuel tanks aren't that difficult either, just messy. They're also
almost identical to the outboard leading edge assemblies, except for the
proseal Smile
The SB fuselage is a lot more involved - longerons to be bent/twisted,
lower forward/aft cabin skins to be rolled around a hardwood form, etc.
The fuselage requires a lot more head scratching than the wings.
Just depends on why you're considering QB - if it's to avoid complex
construction go with the QB fuselage, if it's to avoid a lot of
repetitious, mundane type of building then go with QB wings.
N442PM (flying)
taildragon(at)msn.com
PostPosted: Fri Apr 03, 2009 4:12 pm    Post subject: Which Quickbuild Would You Recommend? Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Maybe it just comes down to why you are building. Build everything yourself if you can. If you are short on time, because of age or because of "life happening", then consider quick build. I say "consider quick build" because in a perfect world the quick builds would be, well, perfect but we know they have their short comings. Many building starts end with incompletions. If quick builds will make the difference between not finishing and flying a mostly self constructed plane, then the answer is obvious.
Roger
Flying a most awesome beast!
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave
Sent: Friday, April 03, 2009 12:25 PM
To: RV-10 Matronics
--> RV10-List message posted by: "Dave Fritzsche (Building)"
<fritzsch(at)eskimo.com (fritzsch(at)eskimo.com)>
Dave
Dave Fritzsche
40813
Puyallup, p; Navigator Photoshare, and title=http://www.matronics.com/Navigator?RV10-List href="http://www.matronics.com/Navigator?RV10-List">http://www.matronicp; via the Web title=http://forums.matronics.com/ href="http://forums.matronics.com">http://forums.matronics.com
_p; generous bsp;   title=http://www.matronics.com/contribution href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
