by0ung(at)brigham.net Guest
Posted: Sun Jan 08, 2006 8:49 pm Post subject: kolb gps |
Robert or anyone else'
I know you can get GPS software that allows you to use a palm pilot or
even better a laptop for a moving map. Is there also any way to interface
engine sending units?
I'm not really sure. Does an EIS monitoring system change analog at the
sender or at the panel?
Vic do not archive
Vic Peters
DeLORME makes a gps that plugs into a serial port on a lap top or
palm...the one I have has the name Earthmate Hyperformance gps receiver..
and will work on DeLORME mapping software... there are probably others.
It seems that some of the newer palms have a gps built in.
I have used the garmin pilot lll and it worked very well.. But I have
been spoiled with the larger screen on the 196, it works wonders in the
air,,, and with the street mapping software it works wonders in the car..
Coming through the spaghetti bowl in Portland my wife turned to me and said
that the thing just paid for itself. I have not yet bought the
navitagable waters maps.. however color on the 296 may be nice...
Boyd
Ps I think the A to D converter is in the panel box.
ulflyer(at)verizon.net Guest
Posted: Mon Jan 09, 2006 8:07 am Post subject: kolb gps |
EIS uses raw analog signals right from the sender - the EIS does the
conversion.
I sit here wondering why you would want to go through all the trouble
trying to interface a PC into your panel. Blue screens are not good
and Winders is still not rock solid. There are other instruments
that would be better - see Grand Rapids Technologies other
products. There is also another company producing a glass cockpit at
moderate cost. For GPS function why not buy a good GPS that can be
used for roads and aviation use. Just my thoughts.
jerb
Vic do not archive
Vic Peters
Boyd
lstavenhagen(at)hotmail.c Guest
Posted: Mon Jan 09, 2006 8:53 am Post subject: kolb gps |
conversion.
jerb
I tend to agree.... GPS's are bad enough in terms of reliability, so not
sure what would be gained by increasing the chances of failure, oh, 10
orders of magnitude by using a palm pilot or worse a Windwoes laptop in the
airplane....
sorry, couldn't resist .
And I shouldn't whine about GPS's, the current crop of them are actually
really good reliable devices. I have had a couple of older ones and they've
always quit or gave me some kind of problem at very inconvenient times.s....
The garmins are really good, I think, especially the newer ones.
But no way no how would I use anything running Windwoes or PalmOS or
anything like that as even a supplemental form of navigation ... JMO....
LS
N646F
or
>Vic do not archive
>Vic Peters
receiver..
>Boyd
>Do not archive
vicsvinyl(at)verizon.net Guest
Posted: Mon Jan 09, 2006 9:10 am Post subject: kolb gps |
Thanks for all that replied,
Just thought a laptop would be a good backup and easy for an old fart to
see.
I was going to ask what the heck is a winder is. Winders Home ain't bad, no
more blue screen for me. I'm less rock solid myself!
Vic Peters
MK3X
WillUribe(at)aol.com Guest
Posted: Mon Jan 09, 2006 9:38 am Post subject: kolb gps |
Vic,
I have a Navman GPS for my laptop. The majority of the time it lags behind
where I'm actually driving and sometimes it freezes up the laptop to the
point I have to re-boot. This is very distracting when I'm driving so I no
longer use it.
jhauck(at)elmore.rr.com Guest
Posted: Mon Jan 09, 2006 1:12 pm Post subject: kolb gps |
times.s....
| LS
LS/All:
What seems to be wrong with the reliability of GPS?
What GPS units have you used and what year were they manufactured?
What did you find wrong with the older Garmin units?
MKIII
Posted: Mon Jan 09, 2006 1:26 pm Post subject: kolb gps |
fart to
| see.
| Vic Peters
Vic/Gang:
What are you going to do with a lap top in a Kolb?
DO NOT ARCHIVE
Posted: Mon Jan 09, 2006 2:25 pm Post subject: kolb gps |
Hey John,
Use it as the GPS display. You can buy a non display Gps unit for about 100
bucks
Vic
Posted: Mon Jan 09, 2006 2:36 pm Post subject: kolb gps |
| Quote: | LS/All:
They're fairly reliable, just not as reliable as a chart and the ground
But seriously, I've been through 2, but they were older low-end Garmin
models. The first one was one of the first to get the 12 channel Rockwell
recievers in it, and the second was an etrex.
The first one would just shut off randomly, but would always come back on by
pressing the power button. My eTrex quit working completely and has never
come back on...
I don't remember when the first one was made, but the eTrex is about 3 years
old I think...
LS
N646F
Posted: Mon Jan 09, 2006 4:03 pm Post subject: kolb gps |
| Hey John,
about 100
| bucks
| Vic
Hi Vic/Gang:
Yep.. Kinda figured that. What I was thinking about was the amount
of room required for a lap top in a Kolb aircraft. I find smaller is
usually better.
MKIII
DO NOT ARCHIVE
Posted: Mon Jan 09, 2006 4:38 pm Post subject: kolb gps |
ground
| LS
LS/All:
Sounds like an operator problem to me.
Amazing! You are the only aviator I have heard make a statement that
GPS is unreliable.
Been flying with GPS since 1993. Have had excellent results. Would
not leave home without it.
I also understand the importance of not relying on a GPS 100%, and I
can still fly with a sectional and mag compass. Would you believe
that is how I found my way around Vietnam, in an AH-1G, with map and
compass. Wish we had had GPS back then. Could have saved a lot more
lives.
I have gone through the Garmin 55AVD, 95XL, and am now flying with the
196, a wonderful instrument. Provides a lot of help when an aviator
needs it. Would still be flying with the 55AVD, but Garmin stops
supporting updates for the older instruments. The 196 is a real
sweetheart though. Got a lot more info and capability than my older
models.
GPS is particularly important in Alaska, where magnetic deviation is
as much as 32 degrees, maybe 34 degrees. I'm guessing because I do
not have a Barrow Sectional handy.
Sorry you had such poor results with your GPS.
MKIII
Posted: Mon Jan 09, 2006 4:40 pm Post subject: kolb gps |
Lucien,
It is difficult to use a sectional chart and a calculator in a FireFly. I
used a gps to ferry the FireFly from Missouri to Indiana. Due to an adverse
wind, I could not make 60 mile hops and I had to divert two times to
alternate airports. Just by pushing one button, I had several choices or
alternate airports. Then by pressing another button, I could select the
desired airport and the GPS told me how long it would take to get there plus
much more info than a chart and calculator would have.
I have used a Garmin 90 for about ten years. I dropped it on the concrete
several years ago and popped the lcd display off. I carefully picked it up
and pressed it back in place. It worked well up to about two months ago. I
started loosing lines in the display. Purchased another Garmin.
I would not fly a cross country without a gps. You never know when you are
going to get disoriented. After flying from Perryville Municipal to my EAA
Chapter meetings for several years, I had it happen to me. I was flying
south and got busy in the cockpit. When I returned to looking out over the
nose of the FireFly, I did not recognize anything. I thought I was flying
south, but when I checked the compass, I found I was flying east. Turned 90
degrees and I recognized very thing again.
Since I have moved to Indiana, it happened again. I am not used to flying
over snow covered terrain. The last flight of 2005, I put on my LLBean cold
weather gear and went for a spin late in the afternoon. I flew from
Winchester to Union City and everything looked quit normal. Then I wandered
around a little looking at the edges of Union City. Next I turned back
toward the west. The sun was low in the west and the glare off the snow was
unbelievable. Normally, I could see the airport from where I was, but I
could not pick it out. So I followed the railroad tracks and 32 back toward
Winchester and located the airport.
Jack B. Hart FF004
Winchester, IN
orcabonita(at)hotmail.com Guest
Posted: Mon Jan 09, 2006 5:57 pm Post subject: kolb gps |
In a modern airliner, GPS is the primary cross country navigation. In the
airplane I fly it is backed up by VOR, and Inertial navigation, but the GPS
is primary. When the aircraft senses an error between the systems, it tells
us, and in thousands of hours over almost 10 years, there have been only a
couple times that the GPS would not work. It is one of the most reliable
systems on the plane.
When someone posts that using GPS has been unrealiable, that tells me that
it is either operator error, or a very bad installation... Either of which
can be fixed
Michael A. Bigelow
"NO FEAR" - If you have no fear, you did not go as fast as you could have...
ElleryWeld(at)aol.com Guest
Posted: Mon Jan 09, 2006 6:10 pm Post subject: kolb gps |
I hope you dont crash when your laptop does just a work of thought about how
unreliabale computers really are
Ellery
Posted: Mon Jan 09, 2006 6:15 pm Post subject: kolb gps |
| Quote: | LS/All:
Ah flattery will get you nowhere......
| Quote: | Sorry you had such poor results with your GPS.
It's bizarre in my case, since I know garmin is one of the best products
around, and none of the locals I know of ever had a failure rate like
mine... and of course I used various IFR gps's in a couple of different
planes when I was taking my instrument training and they always worked
fine....
Must be personal radiation or something like that.....
I have lusted after a 195 for years now, although once I saw a friend of
mine's 295 I wanted one of those...
I really would like a 196, though....
LS
N646F
lcottrel(at)kfalls.net Guest
Posted: Mon Jan 09, 2006 7:02 pm Post subject: kolb gps |
| Quote: | I have lusted after a 195 for years now, although once I saw a friend of
LS
N646F
I just bought a 196 on ebay and paid 660.00 for a used 196. ( bought in June
05) There seemed to be a couple of people that decided that they had to have
one, apparently I got in the middle of that. Under the right circumstances
you can pick one up for somewhere around 550.00. There are a lot of guys
updating to the 296 and 396 so the 196's are becoming a glut on the market.
That makes three GPS's that I have owned and have a lot of miles both in the
air and on the ground. Never had a problem that wasn't caused by stupidity.
Larry,Oregon
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Tue Jan 10, 2006 5:08 am Post subject: kolb gps |
John H and Group,
| Quote: | Could you provide dealers that handle the Digital Raster Charts,
please.
Here is one:
http://www.mypilotstore.com/MyPilotStore/sep/2214?qryrmv=1&ctn=afd1
They also reference sources of software to use the charts.
To find this, I used the same search that I used to find the FAA sectionals; I Googled "digital sectionals".
Anyone not familiar with Google should think of it as an archive search for the rest of the world.
John Jung
Firestar II N6163J
Surprise, AZ
http://forums.matronics.com/viewtopic.php?p=2415#2415
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
