capt_riney(at)yahoo.com Guest
Posted: Mon May 25, 2009 2:20 pm Post subject: Aluminum Fuel Tank for MIII |
I had a 20 gal aluminum tank made for my MIII project. For those of you who have done something similar, how did you support it? I'm planning on riveting an .063 thick aluminum pan to the steel cage tabs (the same tabs that would have been used for the two 5-gal jug pan) and strapping the tank to it. The pan dimensions are 36" x 14". Should I go thicker on the aluminum? Do I need to weld more supports to the cage? 20 gal is a lot of weight and I want to be sure it's properly supported. Thanks.
Mark Rinehart
Indy Kolb MIII
aslsa.rng(at)gmail.com Guest
Posted: Mon May 25, 2009 3:16 pm Post subject: Aluminum Fuel Tank for MIII |
Ultimately the tank is supported by the frame tubes that the plate is mounted on. Why not eliminate the middleman and have some tabs welded to the tank that align with the tabs on the frame and bolt the new tank in. Just a thought.
Rick
On Mon, May 25, 2009 at 5:20 PM, mark rinehart <capt_riney(at)yahoo.com (capt_riney(at)yahoo.com)> wrote:
[quote]--> Kolb-List message posted by: mark rinehart <capt_riney(at)yahoo.com (capt_riney(at)yahoo.com)>
Mark Rinehart
Indy Kolb MIII
http://forums.matronics.com
le, List Admin.
captainron1(at)cox.net Guest
Posted: Mon May 25, 2009 4:07 pm Post subject: Aluminum Fuel Tank for MIII |
I also had custom tanks made, mine are kidney type and they go on the bottom straddling the tail boom. In fact I just recently finished welding lateral brackets to support the tanks. If you can post a photo of your tanks so I know where they go, maybe I can offer some ideas from what I have done.
Ron (at) KFHU
Mark Rinehart
Indy Kolb MIII
kugelair.com
icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Tue May 26, 2009 5:54 am Post subject: Aluminum Fuel Tank for MIII |
I like your design, its simpler than mine. I certainly think you ought to run another lateral brace with a support base off the tail boom. Your wood support as temporary as it is right now should be used with some alteration to be the base on the tail boom to distribute the load.
If I remember (gotta fly up to PHX today) when I come back I'll scribble something down as an idea for you to consider. But I like your design, way less plumbing than mine, about 5 gallons less total fuel than my M3X, but not often I see a need for more than 15 gallons anyway.
The short answer yes you need to brace the bottom of your tanks for sure, flight loads and the weight will bend the tubes down on the frame to where it will start contacting the control tube.
Ron (at) KFHU
---- icrashrc <icrashrc(at)aol.com> wrote:
Here's how we did it.
http://www.ill-eagleaviation.com/fuel_tank.htm
Scott
www.ill-EagleAviation.com
http://forums.matronics.com/viewtopic.php?p 45368#245368
icrashrc
Posted: Wed May 27, 2009 3:09 am Post subject: Re: Aluminum Fuel Tank for MIII |
We tested to a 5 g positive, 3 g negative load and all the tank supports did was laugh at our attempts. There's really no possibility of the mounting tubes bending. The only way for the tank to get lower would be for the perimeter of the fuselage to collapse. The way the tank braces are made makes even this very unlikely. I may have a couple better pictures of the setup. If so I'll post them in the next few days. Also, remember the factory setup puts 12 gallons of fuel on those tubes WITHOUT stiffening the tubes as we have.
Scott
| captainron1(at)cox.net wrote: | I like your design, its simpler than mine. I certainly think you ought to run another lateral brace with a support base off the tail boom. Your wood support as temporary as it is right now should be used with some alteration to be the base on the tail boom to distribute the load.
Ron (at) KFHU
Scott
http://forums.matronics.com/viewtopic.php?p 45368#245368 |
Posted: Wed May 27, 2009 7:48 am Post subject: Aluminum Fuel Tank for MIII |
Okay that will be good to see a clearer picture of the tank area. I took some more pics yesterday when I came back of my set up, and as soon as I can remember where I put the camera I'll post them. I really should take some pics of the tanks themselves, as in my design they take quite a bit of the structural load. But I also added some lower bracing and some lateral bracing in tension to keep the tanks from wanting to strain on the frame outwards. As someone mentioned years ago not till I am on my third Kolb will I be able to get it all just right. right now my main emphasis is to build it strong and if its a few pounds more then so be it. I will have excess HP so in all I don't expect it will affect performance all that much if any. All I want to do right now is finish it some time before the end of the century.
Scott
| Quote: | I like your design, its simpler than mine. I certainly think you ought to run another lateral brace with a support base off the tail boom. Your wood support as temporary as it is right now should be used with some alteration to be the base on the tail boom to distribute the load.
Ron (at) KFHU
Scott
http://forums.matronics.com/viewtopic.php?p 45526#245526
kugelair.com
smlplanet(at)msn.com Guest
Posted: Sun Jun 07, 2009 11:51 pm Post subject: Aluminum Fuel Tank for MIII |
I am wanting to build a larger gas tank also but one thing I haven't seen or addressed is W&B with more weight being shifted to the rear. I have a Mark IIIC with a 912 UL and the factory two 5 gal tanks and had to install the adjustable forward horz stablizer brkts for duel flight. I am installing an electric horz stablizer trim system now so as not to have to change the pin locations for solo and duel operations. That have you had to do to address this problem with the larger gas tanks?
Posted: Mon Jun 08, 2009 6:28 am Post subject: Aluminum Fuel Tank for MIII |
For what it is worth, I have a 25 gal aluminum fuel tank in my mkIII. Don't know how much the tank weighs, but it carries 150 lbs of fuel. In addition to that, I carry aprx'ly 125 lbs of gear under the fuel tank in my cargo compartment. To top it off, I have a 12 lb Maule Tundra Tailwheel, 8" pneumatic, mounted, in addition to a 912ULS with a 4" prop extension and a 3 blade WD Prop with nickle steel leading edges.
My mkIII flies well. Extreme testing in every attitude, normal and unusual, I could think of indicates it does not have an aft cg problem. Just completed a 60.2 hour flight over 18 days in some of the most difficult flying conditions I have encountered in 25 years of doing serious cross country flights in Kolb aircraft. Extreme cross winds, 6500 ft field elevations, 9300 ft density altitude, and dust devils, all encountered at the same time by three intrepid Kolb mkIII adventurers in Grants, NM. I might add, my mkIII was at its max gross weight of 1200 lbs during this time frame.
The leading edge of my horizontal stabilizer is positioned below the standard position in the plans. Experimentation indicates it is now in a "sweet spot" for best cruise flight with or without a passenger. We installed adjustable attachments to accomplish this during the fabrication phase of the fuselage at the Kolb Factory in 1991, along with the 25 gal fuel tank.
The major difference between my mkIII and a plans built mkIII is position of the main landing gear, which places the axles 8" forward of the stock location. This will offset aft cg a tad, but not much at its location near the cg.
I emphasize, this is how I configured my mkIII and it works great for me. I don't recommend others follow suit.
[quote] From: ross richardson (smlplanet(at)msn.com)
_________________ John Hauck
Titus, Alabama |
by0ung(at)brigham.net Guest
Posted: Mon Jun 08, 2009 6:54 am Post subject: Aluminum Fuel Tank for MIII |
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>
I bought the 16 gal alum fuel tank that was a factory option in 1998. when doing W&B on my mkIIIC I determined the cg of the fuel tank is verrrrry close to the rear cg limit. When flying solo I am near the rear cg, from full to empty fuel, the cg does not move more than a quarter inch. When I am flying with a passenger, my cg is closer to the center of the range, and as I burn off fuel the cg will creep forward. Even at empty tanks I am well within the limits, so to answer your question “That have you had to do to address this problem with the larger gas tanks? “ there is no problem with my set up. Now if your fuel tank installs further aft than mine does. You will have to do the math.
Boyd young
rowedenny
Posted: Mon Jun 08, 2009 1:56 pm Post subject: Aluminum Fuel Tank for MIII |
Boyd,
Does your tank install from behind the seats like the new xtra tank?
I saw Kolbs online video of installing a big tank in the Xtra and was wondering if the regular Mk-3 had the same option.
Denny Rowe
Boyd young
| [quote][b]
icrashrc
Posted: Mon Jun 08, 2009 11:50 pm Post subject: Re: Aluminum Fuel Tank for MIII |
John,
This post leads to a question I've been meaning to ask for a while now. Have you done a weight & balance lately on your plane with it loaded up and ready for a trip? I'm hoping to get an idea of acceptable CG range so i have some idea of where to start during flight testing. Thank you,
Scott
And yes, let's make it clear that whatever range you post is suitable for YOUR aircraft only!
[quote="John Hauck"]For what it is worth, I have a 25 gal aluminum fuel tank in my mkIII. Don't know how much the tank weighs, but it carries 150 lbs of fuel. In addition to that, I carry aprx'ly 125 lbs of gear under the fuel tank in my cargo compartment. To top it off, I have a 12 lb Maule Tundra Tailwheel, 8" pneumatic, mounted, in addition to a 912ULS with a 4" prop extension and a 3 blade WD Prop with nickle steel leading edges.
| Quote: | From: ross richardson (smlplanet(at)msn.com)
[b] |
_________________ Scott
do not archive |
Posted: Tue Jun 09, 2009 6:13 am Post subject: Aluminum Fuel Tank for MIII |
I haven't done a weight and balance in a some time.
I am sure the results would be very interesting.
However, there has been extensive flight testing which indicates forward and
aft cg are in an acceptable range.
I'd be glad to let you do a weight and balance on my mkIII. I don't have
scales or a good place to do one now.
Titus, Alabama |
Posted: Tue Jun 09, 2009 6:22 am Post subject: Aluminum Fuel Tank for MIII |
Denny
As I remember there are 3 tubes behind the seats that have to come out to install the tank. When I ordered the cage they made provisions for the tubes to be removed. There are tubes that come from either side of the boom tube that join at the center of a cross over tube at the center behind the two seats, and one tube from the boom tube area to the left corner behind the seats. The first two they welded at the factory a small tab on the tubes so we could drill a hole and install a bolt to get them in and out… the third has a small sleeve that goes over where the tube was cut at top and bottom and the sleeve is riveted to the stubs at both ends and also the tube. The tank slides back into the area just behind the seats and sits on the same diagonal tubes that support the plastic tank tray. On the sides of the diagonal tubes there are some tabs welded down, and there is some aluminum angle welded to the bottom of the tank that bolts to the tabs. I drilled the holes in the alum angles a bit over sized and inserted a rubber bushing in the hole and also have a rubber washer on both sides of the angle, this gives the tank a rubber mount to help eliminate vibrations from cracking things. The tank has a curve cut into the bottom to go around and over the aileron torque tube. So there are 2 outlets on the bottom that have to be connected together to get all the fuel out of the tank. John h tank fits in the area behind his head where mine is behind the seats. He has the area behind the seats for storage,, I use the area above the tank for storage. And he carries 9 more gallons than I do.
If you have any other questions I can try and explain or send photos.
Boyd
| Quote: | >>>>>>>>>>>>>>>>>>>>>>..
Boyd,
Denny Rowe
Boyd young
