rear seat crotch strap attachment
Goto page 1, 2  Next
Bob Turner
PostPosted: Tue Jun 09, 2009 10:44 am    Post subject: rear seat crotch strap attachment Reply with quote
My QB came with the rear seat crotch strap attachment installed. Does anyone use this? Any reason not to remove it? (I keep kneeling on it, and it hurts!)
Bob Turner
RV-10 QB
jdriggs49(at)msn.com
PostPosted: Tue Jun 09, 2009 11:10 am    Post subject: rear seat crotch strap attachment Reply with quote
The discussions i've seen make it appear that most folks cut it off. I'm at the same stage in building and I'm really tired of sitting on it! One of these days I'll get agrivated enough to whack it off
Subject: rear seat crotch strap attachment
Date: Tue C 9 Jun 2009 11:44:40 -0700
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu>
My QB came with the rear seat crotch strap attachment installed. Does anyone use this? Any reason not to remove it? (I keep kneeling on it C and it hurts!)
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=247452#247452
&gt=======================
&g=================
Windows Live™: Keep your life in sync. Check it out.
ricksked(at)embarqmail.co
I cut mine out...most have I think
Rick Sked
N246RS
Final assembly
dave.saylor.aircrafters(a
PostPosted: Tue Jun 09, 2009 11:21 am    Post subject: rear seat crotch strap attachment Reply with quote
I kept mine.  They aren't that big a deal once you start flying.
Dave
On Tue, Jun 9, 2009 at 11:44 AM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
le, List Admin.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
chuck(at)chuckdirect.com
PostPosted: Tue Jun 09, 2009 11:22 am    Post subject: rear seat crotch strap attachment Reply with quote
If I remember correctly, I drilled out the rivets and saved the brackets.
[quote] I cut mine out...most have I think
Rick Sked
N246RS
Final assembly
Tim Olson
PostPosted: Tue Jun 09, 2009 11:41 am    Post subject: rear seat crotch strap attachment Reply with quote
I'm sure SOMEONE left theirs on, but to date I don't remember ever
seeing one in person. That lug is a knee-gouge waiting to happen.
For what it's worth, even when my kids were much smaller, the 4
points left without the crotch strap are plenty to hold them in.
Tim Olson - RV-10 N104CD
> From: bobturner(at)alum.rpi.edu
> Date: Tue, 9 Jun 2009 11:44:40 -0700
> To: rv10-list(at)matronics.com
and it hurts!)
> Bob Turner
> RV-10 QB
> http://forums.matronics.com/viewtopic.php?p 47452#247452
&g=================
<http://windowslive.com/explore?ocid=TXT_TAGLM_WL_BR_life_in_synch_062009>
AirMike
PostPosted: Wed Jun 10, 2009 8:30 pm    Post subject: rear seat crotch strap attachment Reply with quote
Now I know what that left over piece in the parts box is...................
See you OSH '18
Q/B - sold.
johngoodman
PostPosted: Thu Jun 11, 2009 6:27 am    Post subject: Re: rear seat crotch strap attachment Reply with quote
I'm leaving mine in; it prevents "submarining." I'm not planning on a crash but it would be nice for the rear seat occupants to actually be sitting in their seats when it comes to a stop.
John
pitts_pilot(at)bellsouth.
PostPosted: Thu Jun 11, 2009 7:26 am    Post subject: rear seat crotch strap attachment Reply with quote
Submarining isn't usually a problem in sudden deceleration. The torso
moves forward keeping the lap belt across the hips until the shoulder
strap gets really tight. A 5-point harness helps if you're doing wild
aerobatics or tumbling down the track in your racecar.
My Pitts has a 5-point harness, but I've never felt pressure in my
crotch from it.
Linn
John
#40572 QB Fuselage, wings finished. Finish Kit started.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p 47680#247680
Checked by AVG - www.avg.com
bcondrey
PostPosted: Thu Jun 11, 2009 7:55 am    Post subject: rear seat crotch strap attachment Reply with quote
I've always found it interesting that there are provisions for a 5 point
for the rear seats but not the front... I removed them.
Bob
N442PM
Tim Olson
PostPosted: Thu Jun 11, 2009 8:13 am    Post subject: rear seat crotch strap attachment Reply with quote
Being a guy and all, I think I'm more afraid of what would
happen if I actually NEEDED the crotch strap in a crash.
If it seriously maimed me there, I think maybe I would
be wishing I hadn't been wearing any belt... Smile
crotch from it.
Linn
johngoodman wrote:
> <johngoodman(at)earthlink.net>
> John
> N711JG reserved
jkreidler
PostPosted: Fri Jun 12, 2009 5:20 am    Post subject: Re: rear seat crotch strap attachment Reply with quote
The most important function the submarine strap serves (in my opinion) is to keep the lap belt position properly low across your pelvis. The standard shoulder belts supplied are pulled tight by the occupant, when this is done it can pull the lap belt up onto your stomach, which is bad. The inertia reel helps solve this....
I have used seat belts on several occasions, I wear them all the time. I can say from my racing past, actually from my race car crashing past, that I have walked away with bruised hips, shoulders, chest, and ribs. I have never felt it where it counts, if you get what I mean (I may have blocked certain memories though). When the car doesn't fit where you thought it might, those nice wide 5 point harnesses make it a bearable experience.
I was in an extremely bad automobile crash when I was 16, I ran a car into a bridge, I am here because of a seat belt. I shattered my pelvis and ankle in addition to a laundry list of other injuries like third degree burns, I spent six months in a wheel chair. The seat was ripped out of the car by the impact, fire consumed the car, and a friendly truck driver pulled me from the burning car to save my life. Lots of things went right, starting with a properly functioning seat belt.
I have heard the argument that some don't plan to survive the crash anyway, so the seat belt is a formality. Like everything we do we assume certain risk, hopefully we have made the right decisions and these risks are always out of our control. I will accept the risks of flying, but I will do everything in my control to provide safety, so when it goes wrong, I have the deck stacked as best as I can.
We added 5 point harnesses to the front seats and kept the 5 point in the rear seat.
Please don't take this as soap boxing, just sharing my real life experiences so others can learn from it instead of having to learn it on your own the hard way.
Jason Kreidler
N44YH - Flying
4 Partner Build #40617
Wayne Elsner
Kyle Hokel
Tony Kolar
Jason Kreidler
PostPosted: Fri Jun 12, 2009 5:40 am    Post subject: rear seat crotch strap attachment Reply with quote
Considering your luck with cars, are you sure you want to press your luck in aircraft? Smile
Rick Sked
N246RS
DAR in 3
Sent via BlackBerry by AT&T
jkreidler
PostPosted: Fri Jun 12, 2009 5:48 am    Post subject: Re: rear seat crotch strap attachment Reply with quote
Thought had crossed my mind..... Smile
Jason
DO NOT ARCHIVE
dlm46007(at)cox.net
PostPosted: Fri Jun 12, 2009 5:58 am    Post subject: rear seat crotch strap attachment Reply with quote
Agreed. Although I removed the crotch strap lugs in the rear, I installed
inertial reels at all four seats. Seat belts " don't get no respect" until
you need them.
Tim Olson
PostPosted: Fri Jun 12, 2009 6:14 am    Post subject: rear seat crotch strap attachment Reply with quote
That's quite the life changing experience! Don't get me wrong,
if someone wants 5 point harnesses, that's great, go ahead
and add them, and like you...ad them to the front too while
you're at it. Can't hurt. I didn't want 5 points, and
feel the 4 point ones met my needs just perfectly. (They're
way better than the 3 point ones in most planes...and WAY WAY
better than only 2 point harnesses) I just wanted to point out
in my previous posting that the 4 points adjust well and
we have no problem properly positioning the belts for
the adults or kids in the plane. To me, if there's a weak
link anywhere it's the bolt through the cabin top.
jkreidler wrote:
<jason.kreidler(at)regalbeloit.com>
belt.
the rear seat.
Jason Kreidler N44YH - Flying 4 Partner Build #40617 Wayne Elsner
Kyle Hokel Tony Kolar Jason Kreidler
http://forums.matronics.com/viewtopic.php?p 47797#247797
PostPosted: Fri Jun 12, 2009 6:22 am    Post subject: rear seat crotch strap attachment Reply with quote
pelvis.
I didn't think so until I thought about it.
This is true, but if the lap belt is snug and the shoulder belt is
tightened, it won't pull up. At least not enough to matter.
Not really. The inertia reel will allow you much more upper body
movement freedom ..... until you really need it to hold you in place.
Ah, a kindred spirit! BTDT (and had the bruises too). Which brings me
to my favorite pet peeve of aviation belts. Your race car shoulder
belts were attached way up above the level of your shoulders. Most
aircraft shoulder belts terminate below the shoulder level ..... and
some like my little Grumman ..... down below your butt! This causes
severe spinal compression during sudden deceleration. Not a good thing.
The RV-10 does good for the front seat people (attached to the cabin
top), but the back seat people still have the same old problem.
belt.
Using belts has always been a good thing. Glad things went right.
It usually happens that way. But not always.
I was at a fly-in in Crystal River, FL, when a big to-do was made over
two gentlemen. They were walking around in almost full body casts.
They could walk, but just barely. They were in a Bonanza that didn't
clear the trees at the end of the runway. The ensuing deceleration put
their upper torsos into the instrument panel. Way into the instrument
panel. The buckling of the instrument panel absorbed enough of the
energy to allow them to survive, but the shoulder harnesses caused
multiple spinal injuries. Don't know what happened to them in their
recovery. It was a sobering example to me ..... pay particular
attention to DA, runway length, and the performance of your airplane.
the rear seat.
Jason, thank you for your post. It's the varied points of view on this
list that makes us think. I think I'll leave my crotch point intact
.... I was going to remove it ...... I can tape some foam over it when
I'm working there. I'll have to think about the front seater point. Do
you have pictures of where you attached the front crotch strap???
Linn .... working on the doors.
06/12/09 05:55:00
dlm46007(at)cox.net
PostPosted: Fri Jun 12, 2009 6:24 am    Post subject: rear seat crotch strap attachment Reply with quote
Airplanes are safer. Not as may things to hit.
AV8ORJWC
Jason, thanks for a little perspective on why they are of value. The issue should be the poor design of the attachment of the web. Many of us can find a way to improve the mounting without eliminating the belt.
It was too bad so many answered early that they just cut the safety feature out. But then that is the value of an experiment.
John Cox
Sent: Fri 6/12/2009 6:20 AM
Subject: RV10-List: Re: rear seat crotch strap attachment
[quote]--> RV10-List message posted by: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Jason Kreidler
N44YH - Flying
Wayne Elsner
Kyle Hokel
Tony Kolar
Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=247797#247797
Tim Olson
PostPosted: Fri Jun 12, 2009 6:52 am    Post subject: rear seat crotch strap attachment Reply with quote
One additional thought.... There are now aftermarket airbag
systems that can be added to some planes. That may be something
worth looking into for the real risk averse. I would bet that
having those in the front seatbacks would help survivability
very well for the rear seat passengers.
> belt.
> the rear seat.
> Jason Kreidler N44YH - Flying 4 Partner Build #40617 Wayne Elsner Kyle
Goto page 1, 2  Next
Page 1 of 2
