rear seat crotch strap attachment
Goto page Previous  1, 2
robin1(at)mrmoisture.com
PostPosted: Fri Jun 12, 2009 7:24 am    Post subject: rear seat crotch strap attachment Reply with quote
Few items:
What I don't get about the inertia straps is I find great comfort in all
forms of turbulence to really tighten down the straps and not move
independent of the seat & airframe. I assume that inertia reels cannot
hold one tightly in the seat when the random jostling occurs. I know
they prevent the BIG lunge forward but I assume not all the small
movement including the minor up & down.
I have used 5 point a fair amount in my flying and don't give them a
second thought one connected. Like previously stated they do help
maintain the proper position of the lap belt as one tightens the
shoulder straps.
My current concern is how the split in the shoulder straps wraps around
the front seat headrest (on my home made Cam Release seat belts). It
almost seams like the Y section of the belt needs a physical spreader
provide width to clear the headrest and move the belt webbing away from
my neck.
Does anyone else have the issue of the belts hitting the headrest and
also wearing on their neck? Does anyone absolutely LOVE their seatbelt
arrangements (other than the inertia reel builders)?
BTW I love the Cam Release style buckle.
Robin
dave.saylor.aircrafters(a
PostPosted: Fri Jun 12, 2009 7:43 am    Post subject: rear seat crotch strap attachment Reply with quote
My understanding is that the crotch straps are only in the back seat because of the difference in seating position.  The back seaters tend to recline quite a bit more than the front, and in a crash would slip out from under the lap belts ("submarining" I guess is the term).  Since the fronts tend to sit up straighter, more like in a chair, the crotch strap isn't as necessary.  Not that adding one wouldn't help in some cases, but the seating position itself reduces the need.
Another thing I like about the crotch straps in back is that they tend to hold my kids in place (6 and 9) better than without.  Their seating position is even more reclined.  They can practically wriggle out from under the belts even in normal conditions.
Last thing, I was kind of concerned about the bolt in the roof too, but at some point it occured to me that the bolt would be mostly in shear, not tension.  So instead of ripping the head through the fiberglass, wouldn't it mostly be getting dragged through the sandwich structure?
Dave
On Fri, Jun 12, 2009 at 7:00 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
That's quite the life changing experience!  Don't get me wrong,
if someone wants 5 point harnesses, that's great, go ahead
and add them, and like you...ad them to the front too while
you're at it.  Can't hurt.  I didn't want 5 points, and
feel the 4 point ones met my needs just perfectly.  (They're
way better than the 3 point ones in most planes...and WAY WAY
better than only 2 point harnesses)  I just wanted to point out
in my previous posting that the 4 points adjust well and
we have no problem properly positioning the belts for
the adults or kids in the plane.   To me, if there's a weak
link anywhere it's the bolt through the cabin top.
Tim Olson - RV-10 N104CD
jkreidler wrote:
--> RV10-List message posted by: "jkreidler"
<jason.kreidler(at)regalbeloit.com (jason.kreidler(at)regalbeloit.com)>
The most important function the submarine strap serves (in my
opinion) is to keep the lap belt position properly low across your
pelvis.  The standard shoulder belts supplied are pulled tight by the
occupant, when this is done it can pull the lap belt up onto your
stomach, which is bad.  The inertia reel helps solve this....
I have used seat belts on several occasions, I wear them all the
time.  I can say from my racing past, actually from my race car
crashing past, that I have walked away with bruised hips, shoulders,
chest, and ribs.  I have never felt it where it counts, if you get
what I mean (I may have blocked certain memories though).  When the
car doesn't fit where you thought it might, those nice wide 5 point
harnesses make it a bearable experience.
I was in an extremely bad automobile crash when I was 16, I ran a car
into a bridge, I am here because of a seat belt.  I shattered my
pelvis and ankle in addition to a laundry list of other injuries like
third degree burns, I spent six months in a wheel chair.  The seat
was ripped out of the car by the impact, fire consumed the car, and a
friendly truck driver pulled me from the burning car to save my life.
Lots of things went right, starting with a properly functioning seat
belt.
I have heard the argument that some don't plan to survive the crash
anyway, so the seat belt is a formality.  Like everything we do we
assume certain risk, hopefully we have made the right decisions and
these risks are always out of our control.  I will accept the risks
of flying, but I will do everything in my control to provide safety,
so when it goes wrong, I have the deck stacked as best as I can.
We added 5 point harnesses to the front seats and kept the 5 point in
the rear seat.
Please don't take this as soap boxing, just sharing my real life
experiences so others can learn from it instead of having to learn it
on your own the hard way.
Jason Kreidler N44YH - Flying 4 Partner Build #40617 Wayne Elsner Kyle Hokel Tony Kolar Jason Kreidler
http://forums.matronics.com/viewtopic.php?p=247797#247797
le, List Admin.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
rene(at)felker.com
PostPosted: Fri Jun 12, 2009 8:19 am    Post subject: rear seat crotch strap attachment Reply with quote
Robin, I love my seatbelt arrangements......but I do have inertia reels. The
only draw back is when I put somebody tall in the back seat. Their head can
hit the inertia reel for the front seat passenger.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
gengrumpy(at)aol.com
PostPosted: Fri Jun 12, 2009 8:21 am    Post subject: rear seat crotch strap attachment Reply with quote
From one of the inertia reel guys, I wouldn't trade mine for anything.
Front and rear mounted securely through the top using 4 bolts holding
plate (and glassed in as well) and reels mount to the plates.
grumpy
On Jun 12, 2009, at 10:22 AM, Robin Marks wrote:
Few items:
all
shoulder straps.
around
from
my neck.
Robin
pastedGraphic.pdf
 Filename:  pastedGraphic.pdf
 Filesize:  846.07 KB
 Downloaded:  434 Time(s)
pastedGraphic.pdf
 Filesize:  174.36 KB
 Downloaded:  442 Time(s)
AV8ORJWC
PostPosted: Fri Jun 12, 2009 8:24 am    Post subject: rear seat crotch strap attachment Reply with quote
I want to make a plug here for David McNeill who was the first in my
aging memory, to expand the safety in the cockpit with his presentation
on belt anchor points, materials, AMSAFE products and mount angles over
the top of the seats.
I fly in five point, four point, three, two and yes NONE. I love a five
point with the buckle cam operated from the interior side to assist
extraction (without fumbling with an outboard mounted buckle). I do not
like the buckle connected to the Fifth point Crotch. There are lots of
choices here and in the statistically unlikely occurrence that they are
needed, where they mount and how they fit creates a whole new
"Tomorrow".
When transitioning from the Dash 8/400 to the CRJ-700 at work, All
crewmembers must now taxi with shoulder harness attached. Because I
demonstrated how easy you can send the unsuspecting sole into or beyond
the instrument panel on application of sensitive brakes at really slow
taxi speeds. I can't demo the same technique with the RV-10 but the
deceleration forces are just waiting for the chance to bite.
Choose wisely.
Tim Olson
PostPosted: Fri Jun 12, 2009 10:48 am    Post subject: rear seat crotch strap attachment Reply with quote
I hear you there Robin. I don't have any problem with the
inertials, but I do find comfort in the stock setup. Every
since (and John Cox knows this), the "encounter" I had with
a good sized bump in the Van's plane, I've been much more diligent
when flying in turbulence or anytime I descend into the cloud
layer out of smooth air. I crank those belts tight, and I'm
glad that I have belts that don't have any give. My head easily
hits the ceiling in a nasty bump and I don't like that. So
I feel secure in the standard belts. The only time I miss
an inertial system is when I constantly forget to grab my headset
from the hangers before I start the plane. I have to loosen
a shoulder belt so I can lean forward. But, once I'm in the
air, I leave them on and am happy to have them. I do, as you
noticed, get a little rub from the belt edge due to the "Y"
connection behind the seat. It doesn't get me often, but when
it bugs me I pull my shirt collar up between the belt and my
neck and then it's all ok. It hasn't bothered me enough
to do things like add pads to the web straps, but I know that
some people do that. So I guess I really like what came
as stock, and I'd do it again in a heartbeat. But, I also
can see why the people who have inertials would like those
too. It's a true personal preference item. I just like to
keep mine cranked in in the bumps.
Robin Marks wrote:
Few items:
shoulder straps.
my neck.
Robin
bwestfall
I’ve implemented a somewhat different method of keeping the lap belt from riding up… It’s called a “gut” J. Works for me… now what to do about the passengers???
-Ben Westfall
Dave
pitts_pilot(at)bellsouth.
PostPosted: Fri Jun 12, 2009 2:02 pm    Post subject: rear seat crotch strap attachment Reply with quote
Tim Olson wrote:
snip
I do, as you
Tim, I added the seat belt pads (from Wal-Mart, I think) to my Pitts
shoulder belts because of the neck rub thingy. I wouldn't be without
them now.
Linn
johngoodman
PostPosted: Fri Jun 12, 2009 3:15 pm    Post subject: Re: rear seat crotch strap attachment Reply with quote
Tim,
Air bags may be coming for aircraft, but I don't think they are here just yet. Looking at all the risks, I think fire is the one we really don't want happening. Van put the 5-point harness as an option in the back, and I'm going with it (costs more). I think he didn't put one in the front because it's complicated: moving seat and not much space to attach it to because the stick has to have priority. Personally I like 5-point harnesses because they keep the seat belt down below my growing beer belly.
For the home-grown entrepreneurs out there, a package set for the '10 would be a viable option. I always loved the Pacific Scientific 5-point rotary belt with the top thumb-latch disconnect for just the shoulder harnesses (Airline stuff). Of course, they would have to come in at least 15 color options Smile
dlm46007(at)cox.net
PostPosted: Fri Jun 12, 2009 4:22 pm    Post subject: rear seat crotch strap attachment Reply with quote
Check just below the throttle quad. Note the red handle.
 Filesize:  1.19 MB
 Viewed:  6838 Time(s)
PostPosted: Fri Jun 12, 2009 8:54 pm    Post subject: rear seat crotch strap attachment Reply with quote
Since I made my own seat belts (for nearly nothing) I have been
contemplating a carbon fiber (or wood) dowel encased in nylon webbing
and sewn in forward of the Y to force the belts open wider than my
headrest (and neck). I don't really see an issue with this except the
thought of what looks like two Water Ski tow ropes hanging from my cabin
top.
Still under consideration...
Robin
johngoodman
PostPosted: Sat Jun 13, 2009 5:04 am    Post subject: Re: rear seat crotch strap attachment Reply with quote
top.
Robin
Robin,
How did you do the sewing? Do you have an industrial sewing machine?
PostPosted: Sat Jun 13, 2009 12:10 pm    Post subject: rear seat crotch strap attachment Reply with quote
John,
I have access to an industrial sewing machine but I initially hand sewed them to tack in place. The webbing is rather course and could be sewn easily. Once tacked in place I dry fit them in the plane and then used a regular sewing machine. it was a snap. If you want a pro to sew it try tacking like I did and take it to an upholstery shop to have them do it while you wait for $20.00.
For the DIYer’s out there one can get a 2” or 3” wide Rotary Cam Release 4 or 5 point seatbelt for under $40.00 delivered from ebay. I think I paid under $30.00 delivered for each of mine. Look up “Cam Seat belt” on ebay. Please note you can make a perfectly good and safe seatbelt set but these are obviously not the quality of a $400-600 Hooker Harness belt.
Other observations. I suggest you but one or two sets to start rather than all 4 sets before one is sure you want to go that way. Additionally there are other belt companies out there that offer “Y” sewn belts already:
http://ep.yimg.com/ip/I/wescoperformance_2053_292106
http://wescoperformance.stores.yahoo.net/racingbelts.html#cam-lock-harness
Good luck,
Robin
 Filesize:  68.86 KB
 Viewed:  6822 Time(s)
 Filesize:  52.08 KB
Tim Olson
PostPosted: Sat Jun 13, 2009 5:43 pm    Post subject: rear seat crotch strap attachment Reply with quote
Now that's a true D-I-Y guy! I'm impressed, Robin...good job!
Robin Marks wrote:
John,
sewn belts already:
Good luck,
Robin
http://209.200.64.237/images/auto/7505-2.jpghttp://209.200.64.237/images/auto/7477.jpg
Page 2 of 2
