Jason Omelchuck
Joined: 07 May 2009 Posts: 120 Location: Portland Oregon
Posted: Thu Jul 02, 2009 9:22 am Post subject: New alternate engine on my MKIII |
Well it’s a long story but I will try to make it short.
A couple of years ago I finished my MKIII with an BMW R100 (air cooled) engine on it. After flying it about 50 hours over the last year and a half, I decided that it was not going to provide the power and reliability I demanded. I could climb at about 800’/min but fast cruise was 60mph. I also had teething problems that required me to work on it a lot. There have been other successful conversions of this engine but I decided it was not for me.
A couple of weeks ago I finished the installation of a 2005 Yamaha Vector snowmobile engine with a Rotax 3.47 gearbox. I now have about 5 hours on it and am ready to say that this engine just might provide me with the performance I was looking for. My rates of climb are in 1000’/min range at 1000# gross and I can wind the airplane up to 90mph at full throttle in level flight. I have chosen 70mph as my cruise as that is what feels good with my airplane. Only time will tell about the reliability but I do have a good feeling about this engine. Below is a link to a Utube video of the engine on the airplane.
http://www.youtube.com/watch?v=1_Tlg9RMKx8
Jason Omelchuck
Kolb MKIII Yamaha powered
Portland, OR
Last edited by Jason Omelchuck on Sun May 16, 2010 6:43 am; edited 1 time in total |
Posted: Thu Jul 02, 2009 9:51 am Post subject: New alternate engine on my MKIII |
Tell us about the engine. Most of us southern boys don't have much knowledge of snow machines.
[quote] A couple of weeks ago I finished the installation of a 2005 Yamaha Vector snowmobile engine with a Rotax 3.47 gearbox.
Jason Omelchuck
_________________ John Hauck
Titus, Alabama |
Jason Omelchuck
Posted: Thu Jul 02, 2009 10:24 am Post subject: Re: New alternate engine on my MKIII |
The 2005 Yamaha Vector Snowmobile engine is a liquid cooled 4 stroke 973cc 3 cylinder carbureted engine. It is rated at 120 HP at 8500 RPM. It has electric carb heat.
lucien
Posted: Thu Jul 02, 2009 10:25 am Post subject: Re: New alternate engine on my MKIII |
To answer your question about the gearbox noise - that noise is perfectly normal when running the rk-400 clutch. It's normal gear noise, you'll notice it's more pronounced when turning the prop one way vs the other, which has to do with the helical gears. The noise is just the slight amount of lash you normally have....
LS
_________________ LS
Titan II SS |
Posted: Thu Jul 02, 2009 10:43 am Post subject: New alternate engine on my MKIII |
What RPMs have you been using?
snow can be fun too: http://www.youtube.com/watch?
v=4amTFCen0ZA&feature=related
BB
On 2, Jul 2009, at 2:24 PM, Jason Omelchuck wrote:
tech.com>
http://forums.matronics.com/viewtopic.php?p 51175#251175
Posted: Thu Jul 02, 2009 10:49 am Post subject: New alternate engine on my MKIII |
| Quote: | The 2005 Yamaha Vector Snowmobile engine is a liquid cooled 4 stroke 973cc
electric carb heat.
What gear box ratio?
Sounds like a good engine. Yamaha makes good stuff.
Are you able to use all 8500 rpm?
Where does it get its max torque? That will probably be where you want to
cruise this engine.
Convenient with carb heat.
Are you running oil cooler and coolant radiator?
Seems, just from looking at the video, those two coolers are going to be a
big increase in drag. Just guessing. We have good luck mounting the
coolers behind the fuselage. I even have mine piggy backed'
Titus, Alabama |
Jason Omelchuck
Posted: Thu Jul 02, 2009 10:54 am Post subject: Re: New alternate engine on my MKIII |
I am cruising at 7000 rpm and have it propped for max level flight RPM of 8100 rpm.
Jason Omelchuck
Posted: Thu Jul 02, 2009 11:07 am Post subject: Re: New alternate engine on my MKIII |
| John Hauck wrote: | | Quote: | The 2005 Yamaha Vector Snowmobile engine is a liquid cooled 4 stroke 973cc
electric carb heat.
cruise this engine.
mkIII |
The gearbox is 3.47 ratio
There is no oil cooler but there is a water to oil heat exchanger build into the engine.
I know the radiators might be overkill, but I really wanted to design a system that would cool and not have to dive right back in if it was running too hot. There is a thermostat in the system and the water temp is running cool now, so after this summer, I might try just running 1 cooler and see what happens. Cooling was one of the issues I had with my last engine and it is very gratifying to be able to operate at full throttle for as long as I want and have the temperatures remain well in the green.
On a side note. On one of my full throttle level flight tests, the right side door popped in. I heard it but did not see what had happened until I landed. I just opened the door and put some slight pressure on the inside and it popped right back out.
Jason
Kolb MKIII Yamaha
Posted: Thu Jul 02, 2009 12:07 pm Post subject: New alternate engine on my MKIII |
Are you flying with a slip/skid indicator or yaw string ?
Might have been out of yaw trim, side loading the door.
Titus, Alabama |
Jason Omelchuck
Posted: Thu Jul 02, 2009 12:53 pm Post subject: Re: New alternate engine on my MKIII |
I fly with a yaw string, and yes it is possible I "wagged my tail" and put a side load on the door.
HShack(at)aol.com Guest
Posted: Thu Jul 02, 2009 12:55 pm Post subject: New alternate engine on my MKIII |
Howard Shackleford
FS II
SC
In a message dated 7/2/2009 1:22:31 P.M. Eastern Daylight Time, jason(at)trek-tech.com writes:
| Quote: | | A couple of weeks ago I finished the installation of a 2005 Yamaha Vector snowmobile engine with a Rotax 3.47 gearbox. |
Dell Summer Savings: Cool Deals on Popular Laptops - Shop Now!
Is that the 120 hp or the 80 hp?
Howard Shackleford
FS II
SC
| Quote: | | A couple of weeks ago I finished the installation of a 2005 Yamaha Vector snowmobile engine with a Rotax 3.47 gearbox. I now have about 5 hours on it and am ready to say that this engine just might |
Jason Omelchuck
Posted: Thu Jul 02, 2009 3:45 pm Post subject: Re: New alternate engine on my MKIII |
The Yamaha Vector is a 120 HP engine
herbgh(at)nctc.com Guest
Posted: Thu Jul 02, 2009 3:52 pm Post subject: New alternate engine on my MKIII |
Didn't find a 2005 Yamaha for sale.. I notice that the snowmobile is
abt 10k .What do you have in the installation? Herb
At 06:45 PM 7/2/2009, you wrote:
capedavis(at)yahoo.com Guest
Posted: Thu Jul 02, 2009 8:07 pm Post subject: New alternate engine on my MKIII |
My experience with 4 stroke motorcycles tells me that a 4stroke engine running at 7000 rpms is on the edge of explosion but
i am old and my racing mcs was in the 70's I can live with a 5000 rpm 4 stroke but 7 is just too many movements for me in a minute when I think about a 4 or 5 hour cross country stretch! Chris
Sent: Thursday, July 2, 2009 2:54:12 PM
Subject: Re: New alternate engine on my MKIII
--> Kolb-List message posted by: "Jason Omelchuck" <jason(at)trek-tech.com (jason(at)trek-tech.com)>
http://forums.matronics.com/viewtopic.php?p=251181========================
Jason Omelchuck
Posted: Thu Jul 02, 2009 9:23 pm Post subject: Re: New alternate engine on my MKIII |
You can usually get a 2005 to 2007 snowmobile that has very low miles on it for around 4K to 5K. After you take out the engine and strip the wire harness, you can sell the parts for 1K to 1.5K so you have 3K to 4K in the engine. My entire conversion including the Rotax gearbox was about 7K. I purchased the gearbox adapter from a guy and I will pass along his contact in a separate post.
Jason
uote] | herbgh(at)nctc.com wrote: | Didn't find a 2005 Yamaha for sale.. I notice that the snowmobile is
abt 10k .What do you have in the installation? Herb |
Jason Omelchuck
Posted: Thu Jul 02, 2009 9:30 pm Post subject: Re: New alternate engine on my MKIII |
I believe you will find that the technology used in these engines is far superior to what was in the 70's. Only time will tell, but I do remember the people who were used to flying lycomings said the same thing about the "ticking bomb" rotax 912's when they came out.
I would be relucent to condem these engines because of expierences of almost 40 years ago. Bus as I said, only time will tell.
[quote="capedavis(at)yahoo.com"]My experience with 4 stroke motorcycles tells me that a 4stroke engine running at 7000 rpms is on the edge of explosion but
i am old and my racing mcs was in the 70's � I can live with a 5000 rpm 4 stroke but 7 is just too many movements for me in a minute when I think about a 4 or 5 hour cross country stretch!� Chris
--> Kolb-List message posted by: "Jason Omelchuck" <jason>
rowedenny
Posted: Fri Jul 03, 2009 3:12 am Post subject: New alternate engine on my MKIII |
FiltranZer
Posted: Fri Jul 03, 2009 3:51 am Post subject: Re: New alternate engine on my MKIII |
To acknowledgment your catechism about the gearbox babble - that babble is altogether accustomed if active the rk-400 clutch. It's accustomed accessory noise, you'll apprehension it's added arresting if axis the prop one way vs the other, which has to do with the circling gears. The babble is just the slight bulk of baste you commonly have....
Aprilaire humidifier
Posted: Fri Jul 03, 2009 4:41 am Post subject: New alternate engine on my MKIII |
Fantastic Jason...
Hopefully the little engine will have reliability and wearability
attributes of the 912s... no reason why it should not...
I notice that Rotax is selling a three cyl, 4 cycle engine with
throttle body injection in the Ski Doo... for similar money...similar
hp.. Herb
At 12:23 AM 7/3/2009, you wrote:
Jason
uote]
http://forums.matronics.com/viewtopic.php?p 51274#251274
Checked by AVG - www.avg.com
07/02/09 05:54:00
