		Jason Omelchuck
  Joined: 07 May 2009 Posts: 120 Location: Portland Oregon
				 Posted: Thu Jul 02, 2009 9:22 am    Post subject: New alternate engine on my MKIII |
				Well it’s a long story but I will try to make it short.
 A couple of years ago I finished my MKIII with an BMW R100 (air cooled) engine on it.  After flying it about 50 hours over the last year and a half, I decided that it was not going to provide the power and reliability I demanded.  I could climb at about 800’/min but fast cruise was 60mph.  I also had teething problems that required me to work on it a lot.  There have been other successful conversions of this engine but I decided it was not for me.
 A couple of weeks ago I finished the installation of a 2005 Yamaha Vector snowmobile engine with a Rotax 3.47 gearbox.  I now have about 5 hours on it and am ready to say that this engine just might provide me with the performance I was looking for.  My rates of climb are in 1000’/min range at 1000# gross and I can wind the airplane up to 90mph at full throttle in level flight.  I have chosen 70mph as my cruise as that is what feels good with my airplane.  Only time will tell about the reliability but I do have a good feeling about this engine.  Below is a link to a Utube video of the engine on the airplane.
 http://www.youtube.com/watch?v=1_Tlg9RMKx8
 Jason Omelchuck
 Kolb MKIII Yamaha powered
 Portland, OR
  Last edited by Jason Omelchuck on Sun May 16, 2010 6:43 am; edited 1 time in total |
				 Posted: Thu Jul 02, 2009 9:51 am    Post subject: New alternate engine on my MKIII |
				Tell us about the engine.  Most of us southern  boys don't have much knowledge of snow machines.
  [quote]    A couple of weeks ago I finished the    installation of a 2005 Yamaha Vector snowmobile engine with a Rotax 3.47    gearbox.
 Jason Omelchuck
  _________________ John Hauck
Titus, Alabama |
		Jason Omelchuck
				 Posted: Thu Jul 02, 2009 10:24 am    Post subject: Re: New alternate engine on my MKIII |
				The 2005 Yamaha Vector Snowmobile engine is a liquid cooled 4 stroke 973cc 3 cylinder carbureted engine.  It is rated at 120 HP at 8500 RPM.  It has electric carb heat.
		lucien
				 Posted: Thu Jul 02, 2009 10:25 am    Post subject: Re: New alternate engine on my MKIII |
				To answer your question about the gearbox noise - that noise is perfectly normal when running the rk-400 clutch. It's normal gear noise, you'll notice it's more pronounced when turning the prop one way vs the other, which has to do with the helical gears. The noise is just the slight amount of lash you normally have....
 LS
  _________________ LS
Titan II SS |
				 Posted: Thu Jul 02, 2009 10:43 am    Post subject: New alternate engine on my MKIII |
				What RPMs have you been using?
 snow can be fun too:  http://www.youtube.com/watch?
 v=4amTFCen0ZA&feature=related
 BB
 On 2, Jul 2009, at 2:24 PM, Jason Omelchuck wrote:
  tech.com>
  http://forums.matronics.com/viewtopic.php?p 51175#251175
				 Posted: Thu Jul 02, 2009 10:49 am    Post subject: New alternate engine on my MKIII |
				 	  | Quote: | 	 		   The 2005 Yamaha Vector Snowmobile engine is a liquid cooled 4 stroke 973cc
  electric carb heat.
 What gear box ratio?
 Sounds like a good engine.  Yamaha makes good stuff.
 Are you able to use all 8500 rpm?
 Where does it get its max torque?  That will probably be where you want to
 cruise this engine.
 Convenient with carb heat.
 Are you running oil cooler and coolant radiator?
 Seems, just from looking at the video, those two coolers are going to be a
 big increase in drag.  Just guessing.  We have good luck mounting the
 coolers behind the fuselage.  I even have mine piggy backed'
Titus, Alabama |
		Jason Omelchuck
				 Posted: Thu Jul 02, 2009 10:54 am    Post subject: Re: New alternate engine on my MKIII |
				I am cruising at 7000 rpm and have it propped for max level flight RPM of 8100 rpm.
		Jason Omelchuck
				 Posted: Thu Jul 02, 2009 11:07 am    Post subject: Re: New alternate engine on my MKIII |
				 	  | John Hauck wrote: | 	 		   	  | Quote: | 	 		   The 2005 Yamaha Vector Snowmobile engine is a liquid cooled 4 stroke 973cc
  electric carb heat.
 cruise this engine.
 mkIII |
 The gearbox is 3.47 ratio
 There is no oil cooler but there is a water to oil heat exchanger build into the engine.
 I know the radiators  might be overkill, but I really wanted to design a system that would cool and not have to dive right back in if it was running too hot. There is a thermostat in the system and the water temp is running cool now, so after this summer, I might try just running 1 cooler and see what happens.  Cooling was one of the issues I had with my last engine and it is very gratifying to be able to operate at full throttle for as long as I want and have the temperatures remain well in the green.
 On a side note.  On one of my full throttle level flight tests, the right side door popped in.  I heard it but did not see what had happened until I landed.  I just opened the door and put some slight pressure on the inside and it popped right back out.
 Jason
 Kolb MKIII Yamaha
				 Posted: Thu Jul 02, 2009 12:07 pm    Post subject: New alternate engine on my MKIII |
 Are you flying with a slip/skid indicator or yaw string ?
 Might have been out of yaw trim, side loading the door.
Titus, Alabama |
		Jason Omelchuck
				 Posted: Thu Jul 02, 2009 12:53 pm    Post subject: Re: New alternate engine on my MKIII |
				I fly with a yaw string, and yes it is possible I "wagged my tail" and put a side load on the door.
		HShack(at)aol.com Guest
				 Posted: Thu Jul 02, 2009 12:55 pm    Post subject: New alternate engine on my MKIII |
				Howard  Shackleford
 FS II
 SC
   In a message dated 7/2/2009 1:22:31 P.M. Eastern Daylight Time,  jason(at)trek-tech.com writes:
   	  | Quote: | 	 		  | A couple    of weeks ago I finished the installation of a 2005 Yamaha Vector snowmobile    engine with a Rotax 3.47 gearbox.    |
  Dell Summer Savings: Cool Deals on Popular Laptops - Shop Now!
				Is that the 120 hp or the 80 hp?
  Howard  Shackleford
 FS II
 SC
   	  | Quote: | 	 		  | A couple    of weeks ago I finished the installation of a 2005 Yamaha Vector snowmobile    engine with a Rotax 3.47 gearbox.  I now have about 5 hours on it and am    ready to say that this engine just might   |
		Jason Omelchuck
				 Posted: Thu Jul 02, 2009 3:45 pm    Post subject: Re: New alternate engine on my MKIII |
				The Yamaha Vector is a 120 HP engine
		herbgh(at)nctc.com Guest
				 Posted: Thu Jul 02, 2009 3:52 pm    Post subject: New alternate engine on my MKIII |
				Didn't find a 2005 Yamaha for sale.. I notice that the snowmobile is
 abt 10k     .What do you have in the installation?   Herb
		capedavis(at)yahoo.com Guest
				 Posted: Thu Jul 02, 2009 8:07 pm    Post subject: New alternate engine on my MKIII |
				My experience with 4 stroke motorcycles tells me that a 4stroke engine running at  7000 rpms is on the edge of explosion  but
  i am old and  my racing  mcs was in the 70's   I can live with a 5000 rpm 4 stroke but 7 is just too many movements for me in a minute when I think about a 4 or 5 hour cross country stretch!  Chris
 Sent: Thursday, July 2, 2009 2:54:12 PM
 Subject: Re: New alternate engine on my MKIII
 --> Kolb-List message posted by: "Jason Omelchuck" <jason(at)trek-tech.com (jason(at)trek-tech.com)>
 http://forums.matronics.com/viewtopic.php?p=251181========================
		Jason Omelchuck
				 Posted: Thu Jul 02, 2009 9:23 pm    Post subject: Re: New alternate engine on my MKIII |
				You can usually get a 2005 to 2007 snowmobile that has very low miles on it for around 4K to 5K.  After you take out the engine and strip the wire harness, you can sell the parts for 1K to 1.5K so you have 3K to 4K in the engine.  My entire conversion including the Rotax gearbox was about 7K.  I purchased the gearbox adapter from a guy and I will pass along his contact in a separate post.
 Jason
 uote] 	  | herbgh(at)nctc.com wrote: | 	 		  Didn't find a 2005 Yamaha for sale.. I notice that the snowmobile is
 abt 10k     .What do you have in the installation?   Herb |
		Jason Omelchuck
				 Posted: Thu Jul 02, 2009 9:30 pm    Post subject: Re: New alternate engine on my MKIII |
				I believe you will find that the technology used in these engines is far superior to what was in the 70's.   Only time will tell, but I do remember the people who were used to flying lycomings said the same thing about the "ticking bomb" rotax 912's when they came out.
 I would be relucent to condem these engines because of expierences of almost 40 years ago.  Bus as I said, only time will tell.
 [quote="capedavis(at)yahoo.com"]My experience with 4 stroke motorcycles tells me that a 4stroke engine running at  7000 rpms is on the edge of explosion  but
  i am old and  my racing  mcs was in the 70's � I can live with a 5000 rpm 4 stroke but 7 is just too many movements for me in a minute when I think about a 4 or 5 hour cross country stretch!� Chris
 --> Kolb-List message posted by: "Jason Omelchuck" <jason>
		rowedenny
				 Posted: Fri Jul 03, 2009 3:12 am    Post subject: New alternate engine on my MKIII |
		FiltranZer
				 Posted: Fri Jul 03, 2009 3:51 am    Post subject: Re: New alternate engine on my MKIII |
				To acknowledgment your catechism about the gearbox babble - that babble is altogether accustomed if active the rk-400 clutch. It's accustomed accessory noise, you'll apprehension it's added arresting if axis the prop one way vs the other, which has to do with the circling gears. The babble is just the slight bulk of baste you commonly have....
 Aprilaire humidifier
				 Posted: Fri Jul 03, 2009 4:41 am    Post subject: New alternate engine on my MKIII |
				Fantastic Jason...
     Hopefully the little engine will have reliability and wearability
 attributes of the 912s... no reason why it should not...
    I notice that Rotax is selling a three cyl, 4 cycle engine with
 throttle body injection in the Ski Doo... for similar money...similar
 hp..  Herb
 At 12:23 AM 7/3/2009, you wrote:
 Jason
 uote]
 http://forums.matronics.com/viewtopic.php?p 51274#251274
 Checked by AVG - www.avg.com
 07/02/09 05:54:00
