-3 degrees flaps
Goto page Previous  1, 2, 3  Next
dmaib@me.com
PostPosted: Thu Jul 02, 2009 12:18 pm    Post subject: -3 degrees flaps Reply with quote
I installed my flaps, ailerons, and wingtips with the wings in the
cradle, versus mounted on the airplane. It was pretty simple and my
wife and I did it without any problems. Everything came out lined up
nicely on our airplane. We put the flaps all the way up, clamped the
ailerons to the flaps, and then carefully fit and drilled the
wingtips. I remember some threads from a couple of years ago
discussing the importance of having someone hold the wingtip in
position while carefully drilling the holes. I seem to remember that
it was pretty important to make sure the tip was pushed fully forward
into the leading edge of the wing. The caution about making sure the
elevator is neutral, if installing after the controls are hooked up,
is an important one. While putting the flight controls back on after
paint, we did some real head scratching trying to figure out why the
flap/aileron alignment was messed up. Turned out to be the elevator
in the full down position.
another $.02 worth
David Maib
40559
On Jul 2, 2009, at 11:37 AM, Seano wrote:
Thanks, I will leave the flaps at the stops and center the ailerons
and wingtips to that position.
Rene, I would still like to see your RV. I am out of OGD a lot in
the citation. My tail number is N458MT.
If you see me out there stop by. I always use Kemp Jet on the south
side.
Sean
David Maib
RV-10 #40559
New Smyrna Beach, FL
johngoodman
PostPosted: Thu Jul 02, 2009 12:21 pm    Post subject: Re: -3 degrees flaps Reply with quote
This brings up another question. Has anybody else been installing
their wingtips with hinges instead of the screws? I remember it was
in an RVAtor a couple of years ago. It really works well and makes
the wingtip a TON easier to take off and put back on.
Jesse,
I remember seeing that. You basically use piano hinge just like most folks do on the cowling.
ScooterF15
PostPosted: Thu Jul 02, 2009 12:54 pm    Post subject: -3 degrees flaps Reply with quote
Hi Tim,
I'll jump in here to muddy up the waters... and Linn this is probably why John suggested to take this off list. Smile
To answer your question, I'll say, for cruise climb in general, you'll typically be better off at the -3 degree setting when climbing at and above 10,000'.
It isn't the lift available for the wing that is important, it's really the lift/drag (L/D) that you want to minimize to increase your rate of climb. The lift doesn't change: if your airplane weighs 2500 lbs then you need 2500 lbs of lift for 1 g unaccelerated flight. So that means that you want to minimize the drag. Cruising or cruise/climbing at 160 KTAS (137.5 KIAS) at 10,000' with a 2500 lb RV-10 requires a coefficient of lift (cl) of 0.276. I would guess the -3 flapped wing has a maximum cl of around 1.0 and the 0 degree around 1.1. So you see that 0.276 is a low cl, either the wing with 0 flap or -3 degree flaps will have no problem generating a that cl. However, most likely, the -3 degree flapped wing will produce that 0.276 cl with a lower coefficient of drag (cd) than the 0 degree wing would. That means a higher L/D, and less drag on the aircraft which results in more power available for climb and, thus, a higher rate of climb.
This still is true if you were to slow to, say 122 KTAS (105 KIAS) for the climb. The cl required there is still only 0.45. It isn't until you start to slow down enough to approach the max cl (i.e. stall) of the -3 flapped airfoil that it may be beneficial to lower the flaps to some other setting (this may also occur at extremely high altitudes).
-Jim
N312JE
On Thu, Jul 2, 2009 at 2:28 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote] --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
I'm not sure if you're saying that I'm wrong, or not. Smile
When I said it helps you keep a good climb rate, I was
intending to mean that you get a tiny bit more lift
out of the zero degree setting vs. the -3 degree setting.
So if you're up high over 10,000' and having very
slow climb rates, you can get a small bump in climb
rate by going back to zero.  Now, you could also
get a better climb rate at lower altitudes, but, the -10
generally climbs so well that it may be just as
practical to "set it and forget it" once you are climbing
out.
Is that correct from your perspective as a Flight Engineer,
or not?
Tim Olson - RV-10 N104CD
John Cumins wrote:
[quote]--> RV10-List message posted by: "John Cumins" <jcumins(at)jcis.net (jcumins(at)jcis.net)>
Ok here comes my 2 cents worth.  Being a retired Flight engineer, we have to
educate you guys about the -3 degree reflex and zero degrees.  As it has
been said it is based upon the cord line of the wing.
If you drew a cord line it would be straight from leading edge to the
trailing edge of the flaps with the flaps in the 0 degree position.  With
the flaps in the -3 degree reflex position that cord line would bend up 3
degrees starting at the leading edge of the flap.
So the zero degree position gives the wing its original airfoil shape as
designed, and the lift verses drag index is a set reference.  Thus higher
lift and same lift area and the drag index is the set amount as designed.
The 3 degree position actually just reduces the drag index by bringing the
aft trailing edge of the wind up and actuallr decreases the amount of lift
at slower speeds.  Thus the longer take off roll in the -3 degree position.
But faster cruise speed.
The index of lift vers drag and a very different animal in each airfoil.
All large air frames use slotted follower flaps to extend the wing area
making the amount of lift greatly increased vers the drag index of the take
off flaps position.  This can be very confusing to a lot of people and it is
about a week class in aero dytnamics to really understand how the wing area-
lift vers drag and drag index can change greatly with very small amount of
flap movement.
I will be glad to chat with any one off line and help educate any one if
they want a more in detail lesson on this matter.
Have a great and safe flying weekend and 4th of July,
And GOD bless each and every one of you and this great country.
John Cumins
40864 Priming elevators waiting for it to cool off.
jesse(at)saintaviation.co
PostPosted: Thu Jul 02, 2009 12:59 pm    Post subject: -3 degrees flaps Reply with quote
That's right, although we use the 3 forward screws on top and bottom
because the hinge doesn't bend as well with the sharper curve. Then
we leave the pins long and use a bracket on the little metal rib on
the trailing edge of the wingtip to hold the pins in place. The pins
can be bent and a hinge eyelet used to hold them in place, or you can
make a little metal piece about 1/8 - 3/16 thick and drill a hole for
the hinge pin to slide in, then the bracket can be screwed onto the
rib. This way you can easily put a drill on the hinge pin to spin it
while sliding it in, which is more of a big deal initially until any
burs or sharp edges inside the hinge eyelets are removed by the pin.
A little grease doesn't hurt either. We use the wingtip itself (the
part that would receive the nutplates, which will be removed if using
the hinge method) as a shim for the inboard half of the hinge. The
trick is getting all of the rivet holed drilled in the wingtip before
cutting the "shim" off, then making the cut so the material removed
would be just inboard of the end of the wing skin, so there is no gap
left. If done carefully, it can give a very nice tight and clean fit
between the wingtip and the wing skin.
The nicest part of this method, IMHO, is the wingtips can be removed
or reinstalled in about 3 minutes, versus about 30 minutes with all of
the screws. Taking it off the normal way is not that bad if using a
drill, but putting it on is a pain because the wingtip is flexible
enough that it can be hard to get it close enough to the skin to get
the screws to grab all the way around.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Jesse,
#40572 QB Fuselage, wings finished. Finish Kit started.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p 51200#251200
rv10rob(at)gmail.com
PostPosted: Thu Jul 02, 2009 1:40 pm    Post subject: -3 degrees flaps Reply with quote
I still don't understand how the wingtips can be "aligned."  When I pushed mine all the way forward, it wasn't possible to twist them up or down--they fit in snugly.
-Rob
On Thu, Jul 2, 2009 at 1:16 PM, David Maib <dmaib(at)mac.com (dmaib(at)mac.com)> wrote:
[quote] --> RV10-List message posted by: David Maib <dmaib(at)mac.com (dmaib(at)mac.com)>
I installed my flaps, ailerons, and wingtips with the wings in the cradle, versus mounted on the airplane. It was pretty simple and my wife and I did it without any problems. Everything came out lined up nicely on our airplane. We put the flaps all the way up, clamped the ailerons to the flaps, and then carefully fit and drilled the wingtips. I remember some threads from a couple of years ago discussing the importance of having someone hold the wingtip in position while carefully drilling the holes. I seem to remember that it was pretty important to make sure the tip was pushed fully forward into the leading edge of the wing. The caution about making sure the elevator is neutral, if installing after the controls are hooked up, is an important one. While putting the flight controls back on after paint, we did some real head scratching trying to figure out why the flap/aileron alignment was messed up. Turned out to be the elevator in the full down position.
another $.02 worth
David Maib
40559
--> RV10-List message posted by: "Seano" <sean(at)braunandco.com (sean(at)braunandco.com)>
Thanks, I will leave the flaps at the stops and center the ailerons and wingtips to that position.
Rene, I would still like to see your RV.  I am out of OGD a lot in the citation.  My tail number is N458MT.
If you see me out there stop by.  I always use Kemp Jet on the south side.
Sean
jcumins(at)jcis.net
PostPosted: Thu Jul 02, 2009 3:43 pm    Post subject: -3 degrees flaps Reply with quote
Jim
Wow I was not going to get into that much detail but I do agree with you.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James McGrew
Sent: Thursday, July 02, 2009 1:53 PM
Subject: Re: -3 degrees flaps
Hi Tim,
-Jim
N312JE
out.
or not?
flap movement.
John Cumins
jcumins(at)jcis.net
PostPosted: Thu Jul 02, 2009 3:48 pm    Post subject: -3 degrees flaps Reply with quote
You are totally right. The 0 Degree position has more lift then the -3
degree setting.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
jcumins(at)jcis.net
PostPosted: Thu Jul 02, 2009 3:49 pm    Post subject: -3 degrees flaps Reply with quote
I will be glad to keep them on the list.
John Cumins
dmaib@me.com
PostPosted: Thu Jul 02, 2009 4:19 pm    Post subject: -3 degrees flaps Reply with quote
I think maybe some people, early on, match drilled the holes in the wingtip without insuring that the wingtip was solidly in position, as you describe. It would be a bit difficult to hold the wingtip perfectly in position to drill without an extra set of hands. I looked back at some construction photo's and realized that we drilled the wingtips on a table instead of in the cradle. We used a piece of 3/4 aluminum angle to clamp the aileron to the flap. Here are a couple of photo's.
[img]cid:B455C6D0-CFC7-4CE0-B73F-6DAB7009BEB5(at)local[/img][img]cid:9AB06093-2083-4FA9-AF4E-177F247E4C90(at)local[/img]
David Maib
40559
-Rob
 Filesize:  110.63 KB
 Viewed:  9601 Time(s)
 Filesize:  110.99 KB
David Maib
RV-10 #40559
ricksked(at)embarqmail.co
PostPosted: Thu Jul 02, 2009 5:44 pm    Post subject: -3 degrees flaps Reply with quote
Don't mount the tips till the flap and ailerons are installed.....what's the best flap position to keep the airplane from floating 1000 foot past the numbers??
Rick Sked
N246RS
Sent via BlackBerry by AT&T
PostPosted: Thu Jul 02, 2009 6:05 pm    Post subject: -3 degrees flaps Reply with quote
I still haven't figured this one out. What speed do you fly on short
final?
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Rick Sked
N246RS
dlm46007(at)cox.net
PostPosted: Thu Jul 02, 2009 6:12 pm    Post subject: -3 degrees flaps Reply with quote
Speed control.
jim(at)CombsFive.Com
PostPosted: Thu Jul 02, 2009 6:47 pm    Post subject: -3 degrees flaps Reply with quote
We had a Navy pilot provide CAP folk with a method for landing on short runways.during cruise flight, slow down, lower the flaps and determine what the indicated stall speed was (Just nibble at it). Round the number up to the nearest 5 knots and then add 10%.So if you saw 58 knots stall, round up to 60, add 10% to get 66. Fly the approach at that speed.When we rounded out over the numbers the bird was done flying and did not float. It was easy to land on 2000 foot runways.Try this with the -10. You will get some numbers that will amaze you.I don't normally fly like this, but to see it work was really cool.What I found for my -10 was I could fly 65 knot finals and make the first turnoff without much braking. What I normally fly is 82 on the approach, 78 over the end of the runway and I get stall warning about 5 feet up and touchdown soon after. Your airplane may be different.All speeds in knots.Jim CN312F [quote][b]
PostPosted: Thu Jul 02, 2009 6:51 pm    Post subject: -3 degrees flaps Reply with quote
I get that David.. Speeds are right on just seems to carry further than. I thought.....
gengrumpy(at)aol.com
PostPosted: Thu Jul 02, 2009 7:05 pm    Post subject: -3 degrees flaps Reply with quote
I routinely cross the fence around 70 kts. If its gusty, add 5.
Cross check with my AOA, which is always better than airspeed.....
grumpy
N184JM
short final?
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
> Rick Sked
> N246RS
rene(at)felker.com
PostPosted: Thu Jul 02, 2009 7:11 pm    Post subject: -3 degrees flaps Reply with quote
Rick, what speeds are you flying. I get the best results when I fly mid
70's on final and 70 or below over the threshold. I am at 4500 feet so
ground speed is a little higher. If I come in any faster than that, it will
float. But, I normally do fly faster than that......I like the extra speed
margin......
Rene' Felker
RV-10 N423CF Flying
801-721-6080
PostPosted: Thu Jul 02, 2009 7:13 pm    Post subject: -3 degrees flaps Reply with quote
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"> Great info...the AOA makes this pretty easy....pitch up, keep the RPMs up, throttle to control decent with positive pitch held just need to call the ball....short field "style" seems the best approach...65 knots on final is our working best number....but then again the DA has been between 4500 to 5300.... go figure
Date: Thu, 2 Jul 2009 22:45:27 -0400 (EDT)
Subject: Re: RV10-List: -3 degrees flaps
_-============================================================ _-= - The RV10-List Email Forum - _-= Use the Matronics List Features Navigator to browse _-= the many List utilities such as List Un/Subscription, _-= Archive Search & Download, 7-Day Browse, Chat, FAQ, _-= Photoshare, and much much more: _-= _-= --> http://www.matronics.com/Navigator?RV10-List _-= _-============================================================ _-= - MATRONICS WEB FORUMS - _-= Same great content also available via the Web Forums! _-= _-= --> http://forums.matronics.com _-= _-============================================================ _-= - List Contribution Web Site - _-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-= --> http://www.matronics.com/contribution _-============================================================
Tim Olson
PostPosted: Thu Jul 02, 2009 7:21 pm    Post subject: -3 degrees flaps Reply with quote
Same here but no AOA. 65 into the short grass strips.
grumpy
N184JM
> <jesse(at)saintaviation.com>
> short final?
> do not archive
> Jesse Saint
> Cell: 352-427-0285
> Fax: 815-377-3694
>> Rick Sked
>> N246RS
PostPosted: Thu Jul 02, 2009 7:33 pm    Post subject: -3 degrees flaps Reply with quote
The good part about the navy based process is that it took into account the current weight of the aircraft. It also uses the "Indicated" stall speed which took into account the pitot system and indicators. A single pilot might get a low stall speed while a gross weight airplane would yield a higher number. It was still fun to do the math and then fly the approach.The -10 is a fun airplane to fly and I know I can slow it down for a short runway.Jim CN312F - 80 hours (Still need to get it painted!)Do Not Archive---------------------------------------------------------------------Great info...the AOA makes this pretty easy....pitch up, keep the RPMs up,throttle to control decent with positive pitch held just need to call theball....short field "style" seems the best approach...65 knots on final isour working best number....but then again the DA has been between 4500 to5300.... go figureSent via BlackBerry by AT&T--
PostPosted: Thu Jul 02, 2009 7:34 pm    Post subject: -3 degrees flaps Reply with quote
90 DW 80 base 70 final... Varies with conditions which have been good cept high ambient temps...Las Vegas June July. No surprises there
Page 2 of 3
