rngurley
Joined: 21 Jan 2008 Posts: 18 Location: Indianapolis, IN
Posted: Tue Jul 21, 2009 3:12 pm Post subject: Aux fuel tanks |
It has been a few years now that some of you have been flying. Has anyone installed or wish they have installed aux fuel tanks. I am currently planning the items to be installed my wings and was wondering what the consensus was.
Thank you in advance.
Dick Gurley
Ron.McGann(at)thalesgroup Guest
Posted: Tue Jul 21, 2009 4:14 pm Post subject: Aux fuel tanks |
Hi Dick,
I flew from Adelaide South Australia to Sydney last weekend (~800nm).
Refuelled at 650nm mark to ensure I had required reserves for alternates
(weather was not favourable in Sydney), but could easily have made the
distance and maintained fixed reserves. YMMV, but my bladder would not
have held for the full 5 hrs flight time and the fuel stop was a relief.
Just one data point, but effectively leaned this plane can fly for quite
a while (and cover a serious distance) on standard tanks.
Ron
VH-XRM
Flying in Oz
dmaib@me.com
Posted: Tue Jul 21, 2009 4:22 pm Post subject: Aux fuel tanks |
I installed the Safeair1 extended range tanks. I now have about 140 hours on the airplane and am very happy with them. They give the airplane at least 7 hours of fuel if you are running LOP. Very nice kit, well built and good instructions.
David Maib
40559
Dick Gurley
| Quote: | http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Albert Gardner
Posted: Tue Jul 21, 2009 4:55 pm Post subject: Aux fuel tanks |
I plumbed my aircraft to make it easy to add tip tanks later on but have lost interest. Over the last 160 hours my RV-10 has averaged 10.6 gph. That’s over 5 hours of flying and I normally plan 3-3.5 hr legs. This includes some long flights as well as short local legs. Cross country flights are at 11.5 and 12.5 at 2300 rpm. Local flights usually at 19 or 21 sq. to keep up with the group. Engine is I0-540 10:1, 1 mag, 1 Lightspeed with Aero-Composits 3 blade. When I run into cheap gas I always wish I could haul some home but I no longer feel I need more capacity.
Albert Gardner
N991RV
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
lbgjb10
Posted: Tue Jul 21, 2009 6:51 pm Post subject: Re: Aux fuel tanks |
have 15 gal aux tanks built into wings (basically splitting a regular tank) and with transfer pumps, have 90 gal. having ability to have extra fuel, or to tanker cheaper fuel is very nice. If you run 75% power and run ROP you will wish you had more fuel sometime. larry b.
_________________ Larry and Gayle N104LG |
lbgjb10
dlm46007(at)cox.net Guest
Posted: Tue Jul 21, 2009 7:12 pm Post subject: Aux fuel tanks |
While traveling to TX in June I met an RV10 builder at Bulverde
airpark/airport (1T8) who was building a wet wing with 120 gal total. If
anyone is interested I am sure that the FBO there knows of the build.
AirMike
Posted: Tue Jul 21, 2009 11:02 pm Post subject: Aux fuel tanks |
No disrespect intended, but didn't Vans issue some kind of admonition warning people NOT to install aux tanks in the wings as the engineering had not accounted for the extra loading????????
I am wondering why nobody has installed a tank in the baggage area. It could easily hold 20 gallons. The floor is rated for the weight. It could feed by gravity to the wings with the simple turn of a petcock fitting tee'd into the supply line at the wing root. A baggage tank would be relatively safe, could vent outside and would avoid the overloaded wing issue.
_________________ See you OSH '18
Q/B - sold. |
vhicy(at)bigpond.com Guest
Posted: Wed Jul 22, 2009 3:50 am Post subject: Aux fuel tanks |
Ron what power settings do you use and what height were you flying. Just
want to compare to miine.
Chris ICY
Posted: Wed Jul 22, 2009 4:39 am Post subject: Aux fuel tanks |
The baggage area would seem to be the easiest retrofit. I haven't got an
aerospace engineering opinion of the wing aux tanks but it would seem that
the wing tanks extended would not affect bending moment on the spar nor CG.
A baggage area tank would probably require a battery on the firewall to be
comfortable with CG and CG movement with fuel burn.
dan.masys(at)Vanderbilt.E Guest
Posted: Wed Jul 22, 2009 9:35 am Post subject: Aux fuel tanks |
| Quote: | Time: 04:12:57 PM PST US
Subject: Aux fuel tanks
anyone
| Quote: | installed or wish they have installed aux fuel tanks. I am currently
consensus was.
Dick Gurley
I added the SafeAir1 tanks to my -10 after flying about 18 months and
although it was a mess to go back in and retrofit the plane (and I
dreaded taking the cutoff wheel to make an access door in those
beautiful painted wingtips) it was easily the best modification I have
made to the -10 and I wish I had just built it that way to begin with.
Having that extra 15 gals (read 1 hour of IFR reserve) helps a lot on my
most common route, which is between Washington DC and Nashville TN --
about 550 nm southwest bound against prevailing winds. It was often
dicey to plan a nonstop IFR flight that direction if the destination
weather was not good, and now there is always lots of fuel for loitering
and alternates.
I also use the extra fuel to tanker fuel to locations where it is
expensive to buy even if not needed for range. In those cases, I
usually pump the tips into the mains just before landing, making it a
smaller fuel bill when telling the line guy to top off the mains for the
return.
Bottom line: great addition to the flexibility of configuration, since
the tanks only weigh 15 lbs empty and sit right on the CG line so they
don't change the basic capability and loading configuration of the
plane, while adding range, safety and cost avoidance options.
But do put them in during the original build if you can, rather than
retrofitting. Installation not that much fun later on.
-Dan Masys
RV-7A sold
RV-10 flying
RV-12 in progress...
Posted: Wed Jul 22, 2009 10:42 am Post subject: Aux fuel tanks |
Another no cost/low cost alternative is running LOP. I have had multiple
trips of 550-600 NM over the last two months. These include FFZ-CNW,
CNW-FFZ, FFZ-MEV, RTS-FFZ each trip left 20-25 gallons in the tanks. Flying
at 10-13000 at 50-55 power, I burned 8.5-9.0 gph. This is about 6:40 to dry
tanks. KTAS was approximately 150. With 5 hours enroute and possible 750nm,
this allows 1:40 at the destination. These were all IFR plans in mostly VMC.
Posted: Wed Jul 22, 2009 1:39 pm Post subject: Aux fuel tanks |
Dick we have just come back from a 42 hour trip in outback Australia. Most of the time we were fine with fuel but as another has pointed out fuel in some areas can be extremely expensive. An extra hour range would be great here. The option of filling further on would be great.
I have spoken to an engineer at Vans regarding making the the outer bay of wing also fuel and his response was like other RV's it actually strengthens the wing however other areas have to be considered like Max weight. He would not put anything on paper.
An extra hour would be good but I don't know about an extra 60 gallons unless you few at gross weight or under but you know what people would do!
With two 10's with gear leg collapses We do not want to fly over gross.
So Yes I would add an extra 1 hour of fuel if I were to build again for out back flying.
Chris
Posted: Wed Jul 22, 2009 2:34 pm Post subject: Aux fuel tanks |
If you must have extra fuel and you are SB wings, then the obvious solution is to enlarge the main tanks by moving the outboard bulkhead out a bay or two. The CG won't shift and the wing will place less bending moment on the spar and center carry through. Even certified aircraft can be successfully flown and landed 10% over gross given the FAAs own rules for Alaska operations. My understanding is that Alaska operations will almost always have lower than standard temperatures and therefore more power available to lift the load. The 10 is not power limited. My 10 lifted off KPRC at 5000 MSL (at) 80F in 1500 ft ground roll at weight of 2750. Distance was calculated by the tower staff.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie
Sent: Wednesday, July 22, 2009 2:29 PM
Subject: Re: Aux fuel tanks
Chris
Posted: Wed Jul 22, 2009 2:49 pm Post subject: Aux fuel tanks |
Hi Chris,
YPPF-YLOX-YROB-YBRN-YHAY-YTEM-YWBN at 5500'.
Mostly at 2400 22.9" - gave ~152KTAS if I recall. 50F LOP => 45lph
Did not concentrate too much on speeds during the flight, more
interested in finding a range/speed sweet spot for the altitude - still
hunting, but happy with what I got.
Ron
VH-XRM, flying in Oz
Posted: Wed Jul 22, 2009 3:03 pm Post subject: Aux fuel tanks |
Thanks Ron I emailed you direct and email just bounces
Chris
Kelly McMullen
Posted: Wed Jul 22, 2009 3:12 pm Post subject: Aux fuel tanks |
The Alaskan gross wt rule is NOT available to anyone, anytime. It
requires FSDO approval, generally for commercial freight, fuel and
fire fighting operations. It also has consequences. A Beech 1900, IIRC
crashed in Homer, a little over gross, with a load of ice picked up on
approach.
It is one thing to use for tankering fuel, like trans-oceanic flight
where there is no intent to land overgross, and quite another to both
takeoff and land overgross. One also does not know how much an
acceptable flight envelope exists above the published forward and aft
limits, how much narrower the range might be. Yes, you can experiment
with your experimental, declare a higher gross than Van's recommends
and play test pilot. Unfortunately, one -10 has already been lost,
along with the builder, by making hasty changes to what was already a
non-standard variant. We really need to minimize risks, lest our
favorite aircraft become uninsurable.
On Wed, Jul 22, 2009 at 3:29 PM, David McNeill<dlm46007(at)cox.net> wrote:
[quote] If you must have extra fuel and you are SB wings, then the obvious solution
by the tower staff.
back flying.
Chris
A&P/IA, EAA Tech Counselor
KCHD |
rebrunk42(at)gmail.com Guest
Posted: Wed Jul 22, 2009 3:52 pm Post subject: Aux fuel tanks |
Kcvb kelp kffz 10500' 21" 2350 20 lop. 10 gph 750 nm
Kffz kfst kcvb. 9500'. 21" 2350. 20 lop. 10 gph. 1350 egt 370 cht.
200.deg. Oil temp. Io540 1lite speed 1 mag. Hope that helps. Robert
Brunkenhoefer rv10 145 hrs
Robert E. Brunkenhoefer
Brunkenhoefer Law Firm, P.C.
520 Lawrence St.
Corpus Christi, Texas 78401
Phone: 361-888-8808
Facsimile: 361-888-6753
robert(at)brunklaw.com
On Jul 22, 2009, at 5:58 PM, "Chris and Susie" <vhicy(at)bigpond.com>
Chris
148 kts true 126 kts indicated as
520 Lawrence St.
Phone: 361-888-8808
Chris
doctornigel
Joined: 18 Feb 2009 Posts: 11 Location: Indian Harbour Beach, FL
Posted: Wed Jul 22, 2009 4:10 pm Post subject: Re: Aux fuel tanks |
I'm not sure how the aux tanks can be on the CG line as that changes with airplane loading, they could be on the CG line for only one configuration. If they are within the forward and aft limits of CG, then they will have less of an effect on CG as far as knocking it out of range. Gross weight of an airplane is calculated to keep the stall speed below a certain speed, to not stress the landing gear during landing, for the g force loading limits, and take-off landing speeds. Most planes can fly WAY over gross as long as CG is within range and as long as you realize stall speeds will be increased, acceptable g loading decreased, take-off and landing distances will be increased, speeds will decrease, and you may damage the landing gear, etc. For me I won't need more than 60 gallons for 95% of my flights. For the other 5% I am going to fabricate a removable 20 gallon tank that I can easily secure in the space of one of my rear seats. I plan on a 60/40 rear seat with the 60 side removable and the tank will secure on the seat attachment points. The 120 lbs of fuel will be where one small passenger would be so no CG concerns. Should be easily, temporarily plumbed into the fuel system, it may not even need a aux fuel pump.
