		rngurley
  Joined: 21 Jan 2008 Posts: 18 Location: Indianapolis, IN
				 Posted: Tue Jul 21, 2009 3:12 pm    Post subject: Aux fuel tanks |
				It has been a few years now that some of you have been flying.  Has anyone installed or wish they have installed aux fuel tanks.  I am currently planning the items to be installed my wings and was wondering what the consensus was.
 Thank you in advance.
 Dick Gurley
		Ron.McGann(at)thalesgroup Guest
				 Posted: Tue Jul 21, 2009 4:14 pm    Post subject: Aux fuel tanks |
				Hi Dick,
 I flew from Adelaide South Australia to Sydney last weekend (~800nm).
 Refuelled at 650nm mark to ensure I had required reserves for alternates
 (weather was not favourable in Sydney), but could easily have made the
 distance and maintained fixed reserves.  YMMV, but my bladder would not
 have held for the full 5 hrs flight time and the fuel stop was a relief.
 Just one data point, but effectively leaned this plane can fly for quite
 a while (and cover a serious distance) on standard tanks.
 Cheers,
 Ron
 VH-XRM
 Flying in Oz
		dmaib@me.com
  Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
				 Posted: Tue Jul 21, 2009 4:22 pm    Post subject: Aux fuel tanks |
				I installed the Safeair1 extended range tanks. I now have about 140 hours on the airplane and am very happy with them. They give the airplane at least 7 hours of fuel if you are running LOP. Very nice kit, well built and good instructions.
 David Maib
 40559
  Dick Gurley
  	  | Quote: | 	 		  http://www.matronics.com/Navigator?RV10-List
 blue; text-decoration: underline; ">http://forums.matronics.com
 style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
  _________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
		Albert Gardner
				 Posted: Tue Jul 21, 2009 4:55 pm    Post subject: Aux fuel tanks |
				I plumbed my aircraft to make it easy to add tip tanks later on but have lost interest. Over the last 160 hours my RV-10 has averaged 10.6 gph. That’s over 5 hours of flying and I normally plan 3-3.5 hr legs. This includes some long flights as well as short local legs. Cross country flights are at 11.5 and 12.5 at 2300 rpm. Local flights usually at 19 or 21 sq. to keep up with the group. Engine is I0-540 10:1, 1 mag, 1 Lightspeed with Aero-Composits 3 blade. When I run into cheap gas I always wish I could haul some home but I no longer feel I need more capacity.
 Albert Gardner
 N991RV
 Yuma, AZ
  _________________ RV-9A N872RV
RV-10 N991RV |
		lbgjb10
				 Posted: Tue Jul 21, 2009 6:51 pm    Post subject: Re: Aux fuel tanks |
				have 15 gal aux tanks built into wings (basically splitting a regular tank) and with transfer pumps, have 90 gal.  having ability to have extra fuel, or to tanker cheaper fuel is very nice.  If you run 75% power and run ROP you will wish you had more fuel sometime.  larry b.
  _________________ Larry and Gayle N104LG |
		lbgjb10
		dlm46007(at)cox.net Guest
				 Posted: Tue Jul 21, 2009 7:12 pm    Post subject: Aux fuel tanks |
				While traveling to TX in June I met an RV10 builder at Bulverde
 airpark/airport (1T8) who was building a wet wing with 120 gal total. If
 anyone is interested I am sure that the FBO there knows of the build.
		AirMike
				 Posted: Tue Jul 21, 2009 11:02 pm    Post subject: Aux fuel tanks |
				No disrespect intended, but didn't Vans issue some kind of admonition warning people NOT to install aux tanks in the wings as the engineering had not accounted for the extra loading????????
 I am wondering why nobody has installed a tank in the baggage area. It could easily hold 20 gallons. The floor is rated for the weight. It could feed by gravity to the wings with the simple turn of a petcock fitting tee'd into the supply line at the wing root. A baggage tank would be relatively safe, could vent outside and would avoid the overloaded wing issue.
  _________________ See you OSH '18
Q/B - sold. |
		vhicy(at)bigpond.com Guest
				 Posted: Wed Jul 22, 2009 3:50 am    Post subject: Aux fuel tanks |
				Ron what power settings do you use and what height were you flying. Just
 want to compare to miine.
 Chris ICY
				 Posted: Wed Jul 22, 2009 4:39 am    Post subject: Aux fuel tanks |
				The baggage area would seem to be the easiest retrofit. I haven't got an
 aerospace engineering opinion of the wing aux tanks but it would seem that
 the wing tanks extended would not affect bending moment on the spar nor CG.
 A baggage area tank would probably require a battery on the firewall to be
 comfortable with CG and CG movement with fuel burn.
		dan.masys(at)Vanderbilt.E Guest
				 Posted: Wed Jul 22, 2009 9:35 am    Post subject: Aux fuel tanks |
				 	  | Quote: | 	 		   Time: 04:12:57 PM PST US
  Subject: Aux fuel tanks
 anyone
  	  | Quote: | 	 		   installed or wish they have installed aux fuel tanks.  I am currently
  consensus was.
  Dick Gurley
 I added the SafeAir1 tanks to my -10 after flying about 18 months and
 although it was a mess to go back in and retrofit the plane (and I
 dreaded taking the cutoff wheel to make an access door in those
 beautiful painted wingtips) it was easily the best modification I have
 made to the -10 and I wish I had just built it that way to begin with.
 Having that extra 15 gals (read 1 hour of IFR reserve) helps a lot on my
 most common route, which is between Washington DC and Nashville TN --
 about 550 nm southwest bound against prevailing winds.  It was often
 dicey to plan a nonstop IFR flight that direction if the destination
 weather was not good, and now there is always lots of fuel for loitering
 and alternates.
 I also use the extra fuel to tanker fuel to locations where it is
 expensive to buy even if not needed for range.  In those cases, I
 usually pump the tips into the mains just before landing, making it a
 smaller fuel bill when telling the line guy to top off the mains for the
 return.
 Bottom line: great addition to the flexibility of configuration, since
 the tanks only weigh 15 lbs empty and sit right on the CG line so they
 don't change the basic capability and loading configuration of the
 plane, while adding range, safety and cost avoidance options.
 But do put them in during the original build if you can, rather than
 retrofitting.  Installation not that much fun later on.
 -Dan Masys
 RV-7A sold
 RV-10 flying
 RV-12 in progress...
				 Posted: Wed Jul 22, 2009 10:42 am    Post subject: Aux fuel tanks |
				Another no cost/low cost alternative is running LOP. I have had multiple
 trips of 550-600 NM over the last  two months. These include FFZ-CNW,
 CNW-FFZ, FFZ-MEV, RTS-FFZ each trip left 20-25 gallons in the tanks. Flying
 at 10-13000 at 50-55 power, I burned 8.5-9.0 gph. This is about 6:40 to dry
 tanks. KTAS was approximately 150. With 5 hours enroute and possible 750nm,
 this allows 1:40 at the destination. These were all IFR plans in mostly VMC.
				 Posted: Wed Jul 22, 2009 1:39 pm    Post subject: Aux fuel tanks |
				Dick we have just come back from a 42 hour trip in  outback Australia. Most of the time we were fine with fuel but as another has  pointed out fuel in some areas can be extremely expensive. An extra hour range  would be great here. The option of filling further on would be  great.
  I have spoken to an engineer at Vans regarding  making the the outer bay of wing also fuel and his response was like other RV's  it actually strengthens the wing however other areas have to be considered like  Max weight. He would not put anything on paper.
  An extra hour would be good but I don't know about  an extra 60 gallons unless you few at gross weight or under but you know what  people would do!
  With two 10's with gear leg collapses We do not  want to fly over gross.
  So Yes I would add an extra 1 hour of fuel if I  were to build again for out back flying.
  Chris
  [quote]   ---
				 Posted: Wed Jul 22, 2009 2:34 pm    Post subject: Aux fuel tanks |
				If you must have extra fuel and you are SB wings, then the  obvious solution is to enlarge the main tanks by moving the outboard  bulkhead out a bay or two. The  CG won't shift and the wing will place less  bending moment on the spar and center carry through. Even certified aircraft can  be successfully flown and landed 10% over gross given the FAAs own rules for  Alaska operations. My understanding is that Alaska operations will almost always  have lower than standard temperatures and therefore more power available to lift  the load. The 10 is not power limited. My 10 lifted off KPRC at 5000 MSL (at) 80F  in 1500 ft ground roll at weight of 2750. Distance was calculated by the tower  staff.
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and  Susie
 Sent: Wednesday, July 22, 2009 2:29 PM
 Subject: Re: Aux fuel  tanks
  Chris
  [quote]   ---
				 Posted: Wed Jul 22, 2009 2:49 pm    Post subject: Aux fuel tanks |
				Hi Chris,
 YPPF-YLOX-YROB-YBRN-YHAY-YTEM-YWBN at 5500'.
 Mostly at 2400 22.9" - gave ~152KTAS if I recall.  50F LOP => 45lph
 Did not concentrate too much on speeds during the flight, more
 interested in finding a range/speed sweet spot for the altitude - still
 hunting, but happy with what I got.
 Cheers,
 Ron
 VH-XRM, flying in Oz
				 Posted: Wed Jul 22, 2009 3:03 pm    Post subject: Aux fuel tanks |
				Thanks Ron I emailed you direct and email just bounces
 Chris
		Kelly McMullen
				 Posted: Wed Jul 22, 2009 3:12 pm    Post subject: Aux fuel tanks |
				The Alaskan gross wt rule is NOT available to anyone, anytime. It
 requires FSDO approval, generally for commercial freight, fuel and
 fire fighting operations. It also has consequences. A Beech 1900, IIRC
 crashed in Homer, a little over gross, with a load of ice picked up on
 approach.
 It is one thing to use for tankering fuel, like trans-oceanic flight
 where there is no intent to land overgross, and quite another to both
 takeoff and land overgross. One also does not know how much an
 acceptable flight envelope exists above the published forward and aft
 limits, how much narrower the range might be. Yes, you can experiment
 with your experimental, declare a higher gross than Van's recommends
 and play test pilot. Unfortunately, one -10 has already been lost,
 along with the builder, by making hasty changes to what was already a
 non-standard variant. We really need to minimize risks, lest our
 favorite aircraft become uninsurable.
 On Wed, Jul 22, 2009 at 3:29 PM, David McNeill<dlm46007(at)cox.net> wrote:
 [quote] If you must have extra fuel and you are SB wings, then the obvious solution
  by the tower staff.
  back flying.
  Chris
A&P/IA, EAA Tech Counselor
KCHD |
		rebrunk42(at)gmail.com Guest
				 Posted: Wed Jul 22, 2009 3:52 pm    Post subject: Aux fuel tanks |
				Kcvb kelp kffz 10500' 21"  2350  20 lop.  10 gph 750 nm
 Kffz kfst kcvb.  9500'.  21" 2350.  20 lop. 10 gph.  1350 egt 370 cht.
 200.deg. Oil temp. Io540 1lite speed 1 mag. Hope that helps. Robert
 Brunkenhoefer  rv10 145 hrs
 Robert E. Brunkenhoefer
 Brunkenhoefer Law Firm, P.C.
 520 Lawrence St.
 Corpus Christi, Texas 78401
 Phone: 361-888-8808
 Facsimile: 361-888-6753
 robert(at)brunklaw.com
 On Jul 22, 2009, at 5:58 PM, "Chris and Susie" <vhicy(at)bigpond.com>
  Chris
				148 kts true 126 kts indicated as
 520 Lawrence St.
 Phone: 361-888-8808
  Chris
		doctornigel
  Joined: 18 Feb 2009 Posts: 11 Location: Indian Harbour Beach, FL
				 Posted: Wed Jul 22, 2009 4:10 pm    Post subject: Re: Aux fuel tanks |
				I'm not sure how the aux tanks can be on the CG line as that changes with airplane loading, they could be on the CG line for only one configuration.  If they are within the forward and aft limits of CG, then they will have less of an effect on CG as far as knocking it out of range.  Gross weight of an airplane is calculated to keep the stall speed below a certain speed, to not stress the landing gear during landing, for the g force loading limits, and take-off landing speeds.   Most planes can fly WAY over gross as long as CG is within range and as long as you realize stall speeds will be increased, acceptable g loading decreased, take-off and landing distances will be increased, speeds will decrease, and you may damage the landing gear, etc.  For me I won't need more than 60 gallons for 95% of my flights.  For the other 5% I am going to fabricate a removable 20 gallon tank that I can easily secure in the space of one of my rear seats.  I plan on a 60/40 rear seat with the 60 side removable and the tank will secure on the seat attachment points.   The 120 lbs of fuel will be where one small passenger would be so no CG concerns.  Should be easily, temporarily plumbed into the fuel system, it may not even need a aux fuel pump.
