		daveleikam(at)wi.rr.com Guest
				 Posted: Tue Aug 11, 2009 9:45 pm    Post subject: Lord mounts, tubes for tires |
				Van's does not have any Lord engine mounts.   They are back ordered with no delivery date in site. They gave me a Lord  part number of J3804 but looking at Spruce's site the number includes a -20 or  -15 etc.  Can anyone tell me which part number to order?  Or another  source as Spruce's price is $50 more per mount than Van's?
  Also, I am about to put the plane on the  gear.  I have heard I should install better tubes in the tires than what  Van's supplies because they leak.  Which should I switch to and where to  get them?  Or are Van's supplied good enough?
  Dave Leikam
 RV-10 #40496
 Fiddling with the  doors.
		dlm46007(at)cox.net Guest
				 Posted: Tue Aug 11, 2009 11:00 pm    Post subject: Lord mounts, tubes for tires |
				My kit was from 2005 and the tubes were Michelin leak  proof tubes. check them...
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave  Leikam
 Sent: Tuesday, August 11, 2009 10:39 PM
 To: RV-10  matronics
 Subject: Lord mounts, tubes for  tires
  Dave Leikam
 RV-10 #40496
		gengrumpy(at)aol.com Guest
				 Posted: Wed Aug 12, 2009 6:09 am    Post subject: Lord mounts, tubes for tires |
				I've replaced the old leakers with the stop leak tubes.  Made by either Michelin or Goodyear.
 Remember to use talcum powder when putting the tubes inside the tires and (from experience) slightly inflate the tube then mate the 2 wheel halves to minimize potential to pinch (and tear) the tube when torquing the wheel together.
 grumpy
 N184JM
 On Aug 12, 2009, at 12:39 AM, Dave Leikam wrote:
  	  | Quote: | 	 		  Van's does not have any Lord engine mounts.  They are back ordered with no delivery date in site. They gave me a Lord part number of J3804 but looking at Spruce's site the number includes a -20 or -15 etc.  Can anyone tell me which part number to order?  Or another source as Spruce's price is $50 more per mount than Van's?
 Dave Leikam
 RV-10 #40496
 tp://www.matronics.com/Navigator?RV10-List
 nics.com
 w.matronics.com/contribution
 =  [quote][b]
		Eric_Kallio
  Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
				 Posted: Wed Aug 12, 2009 7:53 am    Post subject: Re: Lord mounts, tubes for tires |
				Dave, I dropped the tires and tubes from my finish kit and purchased them from Desser tire, which was mentioned by several other builders. I didn't pay too much more than the Vans price, but got Goodyear flight custom tires, and the leak proof tubes (the name was a little different than that though). They arrived in a couple of days and they added in a big bag of tire talc too. I too am waiting on Lord mounts. It looks like I am just going to have to get the credit and buy them on my own if Vans is going to procure any to provide in the kits.
 Eric Kallio
 40518 Trimming doors, but on its wheels
		Tim Olson
				 Posted: Wed Aug 12, 2009 8:20 am    Post subject: Lord mounts, tubes for tires |
				One positive about keeping Van's initial tires is that they're
 not expensive tires.....and I think many people will be doing
 a lot of re-learning or skills improving as they get used to
 the new plane.  My original tires I think lasted 300 hours
 or so, and although I would have done better maybe with better
 tires, it's kind of nice to have them be "expendable" tires
 that you go with initially.  Not that everyone will need this
 or see it that way.  I know I also went through the first set
 of brakes faster.  I'd highly recommend that once someone is
 flying, you order a replacement set of brake linings right away
 and keep them on hand.  It'll be a while before you need them,
 but some of these things you want to have ready because they
 day you find that they're shot, you may want them done
 immediately.  So get the rivet tools, rivets, linings, and
 things on hand early.  Anyway, just wanted to point out that
 having the cheap tires for the first part of your flying
 might not be all that awful....you'll use many sets through
 the plane's lifetime, so lots of opportunity to upgrade.
 Tim Olson - RV-10 N104CD
 Eric_Kallio wrote:
  kits.
  Eric Kallio 40518 Trimming doors, but on its wheels
  http://forums.matronics.com/viewtopic.php?p 57291#257291
		bcondrey
				 Posted: Wed Aug 12, 2009 9:42 am    Post subject: Lord mounts, tubes for tires |
				Same here (sort of), I had Michelin leak stop tubes for the mains but something else for the nose.  I’ve since replaced with a Michelin tube.
 Mains: 15x6.00-6 Michelin Airstop 6EL20, P/N 097-500-0
 Nose: 5.00x5 Michelin Airstop 5CG67, P/N 092-308-0
 Bob
 N442PM
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
  Sent: Wednesday, August 12, 2009 1:55 AM
  Subject: RE: Lord mounts, tubes for tires
  To: RV-10 matronics
 Dave Leikam
  RV-10 #40496
    	  | Quote: | 	 		  |   href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c    | 	  0123456789 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  0 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  1 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  2 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  3 	  | Quote: | 	 		  | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 	  4
		ivankris
  Joined: 29 May 2009 Posts: 21 Location: Guelph, Ontario. Canada
				 Posted: Wed Aug 12, 2009 3:48 pm    Post subject: Re: Lord mounts, tubes for tires |
				The correct Lord Mount part # is J-3804-28
 I bought mine from Herber Aircraft Services, Inc. They had them in stock and shipped the same day (at) $88.00 ea.
 www.herberaircraft.com
 Ph.310-322-9575
 I found them great to deal with.  Good luck.
 Ivan Kristensen
