daveleikam(at)wi.rr.com Guest
Posted: Tue Aug 11, 2009 9:45 pm Post subject: Lord mounts, tubes for tires |
Van's does not have any Lord engine mounts. They are back ordered with no delivery date in site. They gave me a Lord part number of J3804 but looking at Spruce's site the number includes a -20 or -15 etc. Can anyone tell me which part number to order? Or another source as Spruce's price is $50 more per mount than Van's?
Also, I am about to put the plane on the gear. I have heard I should install better tubes in the tires than what Van's supplies because they leak. Which should I switch to and where to get them? Or are Van's supplied good enough?
Dave Leikam
RV-10 #40496
Fiddling with the doors.
dlm46007(at)cox.net Guest
Posted: Tue Aug 11, 2009 11:00 pm Post subject: Lord mounts, tubes for tires |
My kit was from 2005 and the tubes were Michelin leak proof tubes. check them...
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Tuesday, August 11, 2009 10:39 PM
To: RV-10 matronics
Subject: Lord mounts, tubes for tires
Dave Leikam
RV-10 #40496
gengrumpy(at)aol.com Guest
Posted: Wed Aug 12, 2009 6:09 am Post subject: Lord mounts, tubes for tires |
I've replaced the old leakers with the stop leak tubes. Made by either Michelin or Goodyear.
Remember to use talcum powder when putting the tubes inside the tires and (from experience) slightly inflate the tube then mate the 2 wheel halves to minimize potential to pinch (and tear) the tube when torquing the wheel together.
grumpy
N184JM
On Aug 12, 2009, at 12:39 AM, Dave Leikam wrote:
| Quote: | Van's does not have any Lord engine mounts. They are back ordered with no delivery date in site. They gave me a Lord part number of J3804 but looking at Spruce's site the number includes a -20 or -15 etc. Can anyone tell me which part number to order? Or another source as Spruce's price is $50 more per mount than Van's?
Dave Leikam
RV-10 #40496
tp://www.matronics.com/Navigator?RV10-List
nics.com
w.matronics.com/contribution
= [quote][b]
Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Wed Aug 12, 2009 7:53 am Post subject: Re: Lord mounts, tubes for tires |
Dave, I dropped the tires and tubes from my finish kit and purchased them from Desser tire, which was mentioned by several other builders. I didn't pay too much more than the Vans price, but got Goodyear flight custom tires, and the leak proof tubes (the name was a little different than that though). They arrived in a couple of days and they added in a big bag of tire talc too. I too am waiting on Lord mounts. It looks like I am just going to have to get the credit and buy them on my own if Vans is going to procure any to provide in the kits.
Eric Kallio
40518 Trimming doors, but on its wheels
Tim Olson
Posted: Wed Aug 12, 2009 8:20 am Post subject: Lord mounts, tubes for tires |
One positive about keeping Van's initial tires is that they're
not expensive tires.....and I think many people will be doing
a lot of re-learning or skills improving as they get used to
the new plane. My original tires I think lasted 300 hours
or so, and although I would have done better maybe with better
tires, it's kind of nice to have them be "expendable" tires
that you go with initially. Not that everyone will need this
or see it that way. I know I also went through the first set
of brakes faster. I'd highly recommend that once someone is
flying, you order a replacement set of brake linings right away
and keep them on hand. It'll be a while before you need them,
but some of these things you want to have ready because they
day you find that they're shot, you may want them done
immediately. So get the rivet tools, rivets, linings, and
things on hand early. Anyway, just wanted to point out that
having the cheap tires for the first part of your flying
might not be all that awful....you'll use many sets through
the plane's lifetime, so lots of opportunity to upgrade.
Tim Olson - RV-10 N104CD
Eric_Kallio wrote:
kits.
Eric Kallio 40518 Trimming doors, but on its wheels
http://forums.matronics.com/viewtopic.php?p 57291#257291
bcondrey
Posted: Wed Aug 12, 2009 9:42 am Post subject: Lord mounts, tubes for tires |
Same here (sort of), I had Michelin leak stop tubes for the mains but something else for the nose. I’ve since replaced with a Michelin tube.
Mains: 15x6.00-6 Michelin Airstop 6EL20, P/N 097-500-0
Nose: 5.00x5 Michelin Airstop 5CG67, P/N 092-308-0
N442PM
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Wednesday, August 12, 2009 1:55 AM
Subject: RE: Lord mounts, tubes for tires
To: RV-10 matronics
Dave Leikam
RV-10 #40496
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 4
ivankris
Joined: 29 May 2009 Posts: 21 Location: Guelph, Ontario. Canada
Posted: Wed Aug 12, 2009 3:48 pm Post subject: Re: Lord mounts, tubes for tires |
The correct Lord Mount part # is J-3804-28
I bought mine from Herber Aircraft Services, Inc. They had them in stock and shipped the same day (at) $88.00 ea.
www.herberaircraft.com
Ph.310-322-9575
I found them great to deal with. Good luck.
Ivan Kristensen
