JetPilot
Posted: Wed Aug 26, 2009 6:57 am Post subject: Re: Wingtips |
Thom Riddle wrote: | MikeBigblow: Wrong again. My "Well done" was for the art work Richard did, which had zero, nothing, zilch, nada to do with the subject of wing tips and EVERYTHING to do with you. |
Lets see, you support Richard posting some of the worst things ever seen on this list, and then you criticize me. Double standards, hypocrisy, call it what you want, what I said about you is true. You are a the type of loser that does not care about right or wrong, or anything except fitting in with you little gang. Typical street punk behavior, you are a very impressive man Thom, I wonder if you teach your kids the same values ?
Mike
Kolb MK-III Xtra, 912-S |
Thom Riddle
Posted: Wed Aug 26, 2009 7:30 am Post subject: Re: Wingtips |
OK Mike, you win.
Through your extreme powers of persuasion, I finally must admit that each and EVERYONE else on the list is a scum bag. Only YOU are worth anything at all. I now see the error of my ways. I shall go into rehabilitation, if YOU think that there is any chance at all for me. If you do please advise me where to get the help I need, for it is obvious that I don't have the mental capacity to figure it our for myself. If YOU don't think I have any chance at all, please advise me of that too. That way I will no beyond a shadow of a doubt because the great one has said it is so. Until then, bite me.
El Fin
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Wed Aug 26, 2009 8:12 am Post subject: Wingtips |
this list, and then you criticize me. Double >>
C`mon you guys. Cool it.
One of the drawbacks of e-mail is that you can make an instant response.
I have found over the years that when I am in a real rage over something
(which is pretty regularly)it is a great thing to write a letter venting my
spleen on the cause of my anger.
You then keep it until the next morning. Tear it up, write a reasoned reply.
This achieves two things.
One) It gets all your anger out of your system.
two) It enables you to refute, with reasoned argument, whatever has upset
you.
We are all on the same side here. There are no enemies, there are just
things on which we disagree. Thats life, no need to go ballistic.
Cheers
Pat (with peacemaker hat on)
Dana
Posted: Wed Aug 26, 2009 8:37 am Post subject: Wingtips |
At 11:43 AM 8/26/2009, Jack B. Hart wrote:
Quote: |
Way back NACA was interested in different wing tip configurations. In a
1923 study, they compared three different wing profiles using three
different wing tip rake angles....
In all cases, the lift to drag ratio improved with increased rake angles..
Interesting Jack, kind of like the "power tip" mod you made to your
propeller (as did I on one of my paramotors).
Bad link.
-Dana
New Yorkers like to boast that if you can survive in New York, you can
survive anywhere. But if you can survive anywhere, why live in New York?
Posted: Wed Aug 26, 2009 9:22 am Post subject: Wingtips |
May be we should ask Matt to start a "bitchlist" where anyone could go to
vent their spleen.
Just a thought, as it may help to keep the kolblist on target.
Jack B. Hart FF004
Winchester, IN
Richard Pike
Posted: Wed Aug 26, 2009 9:39 am Post subject: Re: Wingtips |
Posted: Wed Aug 26, 2009 6:39 am Post subject: Wingtips Reply with quote
Kolbers,
You can see it at:
http://naca.central.cranfield.ac.uk/reports/1923/naca-report-140.pdf
In all cases, the lift to drag ratio improved with increased rake angles for
low angles of attack with increased tip rake angle.
Some of the most up to date work on this subject has been done by
http://www.winggrid.ch/ where they make a short fat wing act like a high
aspect ratio wing. It would be interesting to see a FireFly with this
wing.
Jack B. Hart FF004
Winchester, IN
Really interesting article on that first link Jack, my old Maxair Hummer had that sort of wingtips, don't know how much difference they made in how it flew, but it did fly quite well.
Could you resubmit that second link? It's not working.
Richard Pike
MKIII N420P (420ldPoops)
Posted: Wed Aug 26, 2009 10:09 am Post subject: Wingtips |
At 07:51 AM 8/26/09 -0700, you wrote:
Quote: |
Jack,
Could you check the link you posted http://www.winggrid.ch/ ? When I click
on it, it does not go to what I think you meant it to go to. I'm very
interested in the study.
Thom,
I apologize for shooting a blank. I copied a jump out of my bookmarks
without checking it. After googling I found that most references seem to
have disappeared from the web. It may be due to copyright due to the fact
that NASA partially funded the research. The jump that I found was:
http://www.allstar.fiu.edu/aero/winggrid6.html
The following is a table reproduced from the jump. It indicates that if
this technique is applied to light aircraft there will be a significant
reduction in induced drag possible.
Aircraft Aspect Induced % wing Reduction Total drag
type ratio drag % span with of induced reduction
geom. of total WING-GRID drag
DC-9-80 9.62 30% 5% 10% 3% by retrofit
elliptic wing
Maule 6.2 50% 5% 50% 25% by retrofit
MXT-7-180 rectangular wing
UL-plane 6 60% 20% 70% 42% by retrofit
estimate rectangular wing
By the way, this is just not theory, aircraft are flying using this technology.
Jack B. Hart FF004
Winchester, IN
Thom Riddle
JetPilot
Posted: Thu Aug 27, 2009 9:42 am Post subject: Re: Wingtips |
jbhart(at)onlyinternet.ne wrote: |
Jack B. Hart FF004
Winchester, IN |
Very good post Jack, and exactly what I have been saying about wingtips in this thread all along. This also proves another point, that Richard Pike, Rick Gerard, and a couple others are so desperate to settle an old score and discredit anything that I post, that they will mislead everyone, and try to suppress good information in order to advance their own personal agenda. These people that instigated this whole episode and those that jumped on the bandwagon of joining in on a bash fest at the expense of good and true information are nothing but a disservice to the Kolb community.
Even though these guys are under the illusion that misleading this group, and posting bad information is OK as long as their little gang supports them. Most people do come here for good information and ways to improve their Kolbs. I think most readers will think twice before listening to Richard Pike, and a couple of the others for honest and factual aviation advice.
Mike
Posted: Thu Aug 27, 2009 2:50 pm Post subject: Wingtips |
Mike,
This list is about floating ideas and discussing their merits. We can only
do this by sending these little packets of electrons through the Internet
medium. Most on this list float out ideas and realize nor expect that
everyone is going to agree with them 100% of the time. Better yet, they do
not expect that level of acceptance. What a dull place this list would be
if everyone agreed with each other. It is unrealistic to expect that one
solution will fit all situations and/or condition. Most on the list realize
that it is the reader who decides what is of value to them. I assume they
filter the information as to how it fits their own needs, desires and
experiences.
I do not want to be part of a personal "them or us". This list has to fit
all of us. So back off and re join the list as fellow who recognizes others
on the list that have something to contribute. If you don't agree with what
is written, then respond with "have you considered" etc rather than making
judge mental statements that have nothing to do with Kolb. Please lighten
up. Compose your posts, read them and think "Would my mom or dad be proud
of this one?" If not, don't send it. I am in my early 70's and I still use
this approach. It is a way I can vent, not send it, and not make more of a
fool of my self on the list.
I don't mind you saying it was a good post, but I don't want to have it used
to bushwhack some one else. If you want attack, attack ideas and broaden
the discussion. Nothing said on the list is going to prevent you from doing
what you want with your plane or how you fly it. Give others the same
freedom.
I have thought about it, and I believe my mom and dad would be proud and so
I am going to send this to the list.
Jack B. Hart FF004
Winchester, IN
Posted: Thu Aug 27, 2009 6:53 pm Post subject: Wingtips |
Very good Jack. My pop would be 106 now if he was still walking.
Examples of writing style that offends would be: "only an idiot
would...."
"you would have to be a moron...."
You may get the drift.
BB
On 27, Aug 2009, at 7:57 PM, Jack B. Hart wrote:
Quote: |
<jbhart(at)onlyinternet.net>
> wingtips in
Mike,
can only
Internet
they do
would be
that one
realize
assume they
experiences.
to fit
recognizes others
with what
making
lighten
be proud
still use
more of a
have it used
broaden
from doing
freedom.
proud and so
Jack B. Hart FF004
Winchester, IN
Posted: Fri Aug 28, 2009 1:22 am Post subject: Wingtips |
To all you guys who are much better informed in maths and aerodynamics than
I this may be of interest.
I have come across a fairly new search engine called Wolframalpha which
answers question directly rather than ,like Google, offering you a list of
other places to follow.
This engine seems to deal with advanced maths among other things and in the
`tour video` it brushed through Reynolds Numbers and illustrates airflow.
It seems to me that if some of you smart guys can formulate the question
properly we can get a `proper` answer to the effectiveness of reshaped wing
tips, winglets etc.,
Its a fun site too. I discovered that I share a birthday with Caligula. Hows
that for a conversation stopper?
Cheers
Pat
Thom Riddle
Posted: Fri Aug 28, 2009 6:06 am Post subject: Re: Wingtips |
Below is a link to a website that is primarily about drag reduction using wheel pants but there is also a section some ways down the page that is a study of different wing tip designs that some may find interesting.
http://corvairq.info/Wheel%20Pants.htm
Buffalo, NY (9G0)
- Anonymous |
Posted: Sat Aug 29, 2009 3:22 am Post subject: Wingtips |
Isn`t it surprising in view of all the furore aboout the superiority of one
wing tip over another that three top designers designed three different
planes, with different wing tips to do the same job.
Spitfire Elliptical
Hurricane. Round
Me 109 Square
Maybe is isn`t that important after all.
Pat
Posted: Sat Aug 29, 2009 3:42 am Post subject: Wingtips |
Spitfire Elliptical
Hurricane. Round
Me 109 Square
Pat
It isn't if you have an excess of power and don't have to pay for the fuel.
Jack B. Hart FF004
Winchester, IN
aslsa.rng(at)gmail.com Guest
Posted: Sat Aug 29, 2009 4:51 am Post subject: Wingtips |
Pat, On top of all that, the last models of the Spit had squared off tips.
Rick Girard
On Sat, Aug 29, 2009 at 7:45 AM, Jack B. Hart <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)> wrote:
[quote]--> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)>
>--> Kolb-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
>Spitfire Elliptical
>Hurricane. Round
>Me 109 Square
>Pat
Jack B. Hart FF004
Winchester, IN
http://forums.matronics.com
le, List Admin.
russ(at)rkiphoto.com Guest
Posted: Sat Aug 29, 2009 5:12 am Post subject: Wingtips |
Wasn't the Spit wingtip changed from elliptical to squared-off? For
more efficiency?
On Aug 29, 2009, at 7:10 AM, pj.ladd wrote:
superiority of one wing tip over another that three top designers
designed three different planes, with different wing tips to do the
same job.
Spitfire Elliptical
Hurricane. Round
Me 109 Square
Pat
zeprep251(at)aol.com Guest
Posted: Sat Aug 29, 2009 11:09 am Post subject: Wingtips |
Russ,
They squared them off so they did not bump into the hanger door frame.
Posted: Sun Aug 30, 2009 1:34 am Post subject: Wingtips |
fuel.>>
Hi Jack,
thats part of it of course but surely each of the designers was striving for
the highest efficiency he could get for other reasons.
Cheers
Pat
Wasn't the Spit wingtip changed from elliptical to squared-off? For more
efficiency?>>
Hi Russ,
In the B of B all the Spits had eliptical wings. Later Spits did have a
clipped wing. I think that was because dogfighting had moved to much higher
altitudes.
I love the theory that the Me109 had squared wing tips because German hangar
doors were narrower.
Cheers
Pat
