		jeff(at)westcottpress.com Guest
				 Posted: Wed Sep 02, 2009 10:36 pm    Post subject: Window Write-Up |
				As you may know, I attempted to install my left side door window last
 week with somewhat disastrous results.  As best I can tell, my shop
 was too hot (about 85 degrees) and the Weld-on 10 set up too quickly.
 The bond to the fiberglass was perfect, but I had voids between the
 window and the dried Weld-on 10 in over half of the bonding area.  I
 had also failed to remove the masking tape from the inside of the
 window soon enough and had a fair amount of masking tape trapped by
 the Weld-on bead.
 My initial thought was to try to save the window by injecting epoxy
 into the gaps (as some have done with apparent success), but after
 discussions with Vans, the window manufacturer and tech support by the
 makers of Weld-on 10, I decided to route out the window and start
 over.  There are some things I learned from these discussions that are
 worth sharing.
 Vans was not willing to say that the injected epoxy approach would
 work and referred me to the window manufacturer, Jeff from Airplane
 Plastics in Ohio.  Jeff spent a good deal of time with me on the
 phone. He initially thought the injected epoxy idea might work and
 suggested I use Scotch Weld 2216 to accomplish the task.  As we
 discussed the situation further, I was able to communicate that what
 we were really trying to do in this case was bond the window to the
 dried Weld-on 10... not the window to the fiberglass.  He thought that
 could still work... as long as I could scuff up the Weld-on 10!
 So, I was back to square one.   We started to discuss alternatives to
 Weld-on 10 for window installation.  He confessed that it had been a
 long time since he had actually installed a window... then recollected
 that the windows would pop out during the structural roll over test on
 the RV-10 until Vans switched to  Weld-on 10 to bond them in.  With
 Weld-on 10, the window would break before the bond would.  As I
 understood the conversation, Weld-on 10 was an important component of
 the plane passing the test.  This made my decision to start over again
 certain.
 With that, Jeff suggested I route it out with an Onsrud carbide double
 flute 1/2" x 1/2" bit (I wound up using a similar bit I had in my
 router and it worked well), I said good bye and ponied up the $150 to
 Vans for another window.
 I also made a call to tech support at IPS, the makers of Weld-on 10,
 hoping to find another product that would stay open longer.  Here's
 what I learned:
 Weld-on 10 stays open the longest of any product they have for this
 application
 At 70 degrees, there should be 15-20 minutes of time to get the job
 done (I had about 5 minutes at 85 degrees)
 Be certain you are using product less than one year from the
 manufacture date as the working time decreases with age
 They do make a dispensing gun that mixes while dispensing for $300-
 $400.  Weld-on 10 is packed in to a cartridge for this purpose and
 called Weld-on 811.
 I've also combed through the archives and had I done that sooner might
 have avoided some of these problems.  Both Lew Gallagher and John
 Gonzalez had very useful posts (hindsight is 20/20) in early January
 of this year.
 I'm going to wait until the fires in our local mountains have stopped
 burning and I'm able to keep the temperature in the shop at or below
 70 degrees before I try again.  I'll get a second set of hands to
 spread the Weld-on 10 more quickly and be sure to pull up the masking
 tape once the window is down securely.  The gun seems a bit pricey and
 I imagine I can find a way to spread the Weld-on 10 quickly and
 accurately without too much effort or expense.
 Jeff Carpenter
 40304
 one step forward... two steps back
				 Posted: Thu Sep 03, 2009 5:15 am    Post subject: Window Write-Up |
				I imagine I can find a way to spread the Weld-on 10 quickly and  accurately
 Jeff- with two people doing this you should be fine. I had my wife spread
 the weld-on on the window while I spread a small bead on the door. We had
 one person hold the window in place and used retainers drilled into the
 canopy to hold the windows flush. than started removing the tape on the
 inside first, finishing with having the exterior tape removed.
 just make sure you remove the excess Weldon with a stick before removing any
 tape. It really can be done all within 20 minutes- at least in the late fall
 it can, when the temps are in the 70's.
 Pascal
 Sent: Wednesday, September 02, 2009 11:34 PM
 Subject: Window Write-Up
  week with somewhat disastrous results.  As best I can tell, my shop  was
  too hot (about 85 degrees) and the Weld-on 10 set up too quickly.   The
  bond to the fiberglass was perfect, but I had voids between the  window
  and the dried Weld-on 10 in over half of the bonding area.  I  had also
  failed to remove the masking tape from the inside of the  window soon
  enough and had a fair amount of masking tape trapped by  the Weld-on bead.
  My initial thought was to try to save the window by injecting epoxy  into
  the gaps (as some have done with apparent success), but after  discussions
  with Vans, the window manufacturer and tech support by the  makers of
  Weld-on 10, I decided to route out the window and start  over.  There are
  some things I learned from these discussions that are  worth sharing.
  Vans was not willing to say that the injected epoxy approach would  work
  and referred me to the window manufacturer, Jeff from Airplane  Plastics
  in Ohio.  Jeff spent a good deal of time with me on the  phone. He
  initially thought the injected epoxy idea might work and  suggested I use
  Scotch Weld 2216 to accomplish the task.  As we  discussed the situation
  further, I was able to communicate that what  we were really trying to do
  in this case was bond the window to the  dried Weld-on 10... not the
  window to the fiberglass.  He thought that  could still work... as long as
  Weld-on 10 for window installation.  He confessed that it had been a  long
  time since he had actually installed a window... then recollected  that
  the windows would pop out during the structural roll over test on  the
  RV-10 until Vans switched to  Weld-on 10 to bond them in.  With  Weld-on
  10, the window would break before the bond would.  As I  understood the
  conversation, Weld-on 10 was an important component of  the plane passing
  the test.  This made my decision to start over again  certain.
  flute 1/2" x 1/2" bit (I wound up using a similar bit I had in my  router
  and it worked well), I said good bye and ponied up the $150 to  Vans for
  another window.
  hoping to find another product that would stay open longer.  Here's  what
  I learned:
  application
  At 70 degrees, there should be 15-20 minutes of time to get the job  done
  Be certain you are using product less than one year from the  manufacture
  They do make a dispensing gun that mixes while dispensing for $300- $400.
  Weld-on 10 is packed in to a cartridge for this purpose and  called
  Weld-on 811.
  Gonzalez had very useful posts (hindsight is 20/20) in early January  of
  this year.
  burning and I'm able to keep the temperature in the shop at or below  70
  degrees before I try again.  I'll get a second set of hands to  spread the
  Weld-on 10 more quickly and be sure to pull up the masking  tape once the
  window is down securely.  The gun seems a bit pricey and  I imagine I can
  find a way to spread the Weld-on 10 quickly and  accurately without too
  Jeff Carpenter
  40304
		kearney
				 Posted: Thu Sep 03, 2009 5:23 am    Post subject: Window Write-Up |
				Hi Jeff
 Thanks for the detailed post - I find the posts about how builders solved
 problems the most informative of all.
 I still have windows to do and have been considering Silpruf as an
 alternative to Weldon. Fortunately I don't have to make a decision until
 spring when it will be cool.
 Do you know if Weldon can be applied effectively at lower temperatures? And
 if so how does this impact the cure time? Is too long a cure time a problem?
 Do you have any pix of how you routed out the window?
 Cheers
 Les
 #40643 - living in a f/g world
		aerosport1
				 Posted: Thu Sep 03, 2009 6:16 am    Post subject: Window Write-Up |
				Jeff I used a urethane adhesive to install my windows. It had a 20 min
 working time and was easy to clean up and it did not run like weld-on. I
 also did a test against weld-on and this held better. I am not flying the
 airplane yet but it was a much easier task then the weld-on. The other nice
 thing about it was that you can clean the inside edges very good with a PPG
 reducer DT870. It is for urethane paints and will not hurt the window in any
 way but does clean the urethane very easily. This material is off white and
 can be tinted if needed. You would need to use a urethane base tint. It is a
 little more flexible than the Weld-on which
 Should be an advantage for the different substrates that are being glued
 together. Time will tell how it will hold up but so far it has worked out
 great. My airplane is painted and a month or so from flying. I used this on
 all windows. Give me a call if you would like to discuss further. As far as
 I am concerned this is the best solutions for gluing the windows in. I know
 one thing is that they will not come out. This urethane has a incredible
 bond. We just used it on some samples for a project to butt glue 1/2"
 acrylic to each other. We tried to break it and could not.
 Geoff
 Geoff Combs
 President
 Aerosport Modeling & Design
 8090 Howe Industrial Parkway
 Canal Winchester, Ohio 43110
 614-834-5227p
 614-834-5230f
 www.aerosportmodeling.com
  _________________ Geoff Combs
 RV-10 QB N829GW
Flying 500 hrs
40033 |
		glastar(at)gmx.net Guest
				 Posted: Thu Sep 03, 2009 7:21 am    Post subject: Window Write-Up |
				Geoff any brand/type of urethan you've used?
 br Werner
  Geoff
  Geoff Combs
  President
  614-834-5227p
  614-834-5230f
		aerosport1
				 Posted: Thu Sep 03, 2009 7:52 am    Post subject: Window Write-Up |
				I used Lord 7542 urethane adhesive
 Geoff
 Sent from my iPhone Geoff
  br Werner
 > min
 > on. I
 > flying the
 > other nice
 > with a PPG
 > window in any
 > white and
 > tint. It is a
 > glued
 > worked out
 > this on
 > As far as
 > in. I know
 > incredible
 > Geoff
 > Geoff Combs
 > President
 > 8090 Howe Industrial Parkway Canal Winchester, Ohio 43110
 > 614-834-5227p
 > 614-834-5230f
 RV-10 QB N829GW
Flying 500 hrs
40033 |
		aerosport1
				 Posted: Thu Sep 03, 2009 8:46 am    Post subject: Window Write-Up |
				Sorry guys the material I used was 7545 a/c. The 7542 is the same
 material but a little thinner and greenish tan in color. The 7545 has
 a higher viscosity and does not run. They have different cure times as
 well.
 They have a 7545 a/e which is slower yet.
 Geoff
 On Sep 3, 2009, at 11:48 AM, Geoff <g.combs(at)aerosportmodeling.com>
  Geoff
 > br Werner
 >> min
 >> on. I
 >> flying the
 >> other nice
 >> with a PPG
 >> window in any
 >> white and
 >> tint. It is a
 >> glued
 >> worked out
 >> used this on
 >> As far as
 >> in. I know
 >> incredible
 >> 1/2"
 >> Geoff
 >> Geoff Combs
 >> President
 >> 614-834-5227p
 >> 614-834-5230f
 RV-10 QB N829GW
Flying 500 hrs
40033 |
				 Posted: Thu Sep 03, 2009 10:23 am    Post subject: Window Write-Up |
				Well evaluated and thought out. This will surely lead to a much better C engineered result the second time.
  I guess this is exactly what the building process is all about C albiet very frustrating. If only everyone's mind would work this way C the cars and other products in this world would be all the much better.
  Good science
  Keep pluggin away.
  	  | Quote: | 	 		   From: jeff(at)westcottpress.com
  Date: Wed C 2 Sep 2009 23:34:45 -0700
  --> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com>
  As you may know C I attempted to install my left side door window last
  week with somewhat disastrous results. As best I can tell C my shop
  The bond to the fiberglass was perfect C but I had voids between the
  the Weld-on bead.
  into the gaps (as some have done with apparent success) C but after
  discussions with Vans C the window manufacturer and tech support by the
  makers of Weld-on 10 C I decided to route out the window and start
  worth sharing.
  work and referred me to the window manufacturer C Jeff from Airplane
  discussed the situation further C I was able to communicate that what
  So C I was back to square one. We started to discuss alternatives to
  Weld-on 10 C the window would break before the bond would. As I
  understood the conversation C Weld-on 10 was an important component of
  certain.
  With that C Jeff suggested I route it out with an Onsrud carbide double
  router and it worked well) C I said good bye and ponied up the $150 to
  I also made a call to tech support at IPS C the makers of Weld-on 10 C
  what I learned:
  application
  At 70 degrees C there should be 15-20 minutes of time to get the job
  called Weld-on 811.
  of this year.
  Jeff Carpenter
  40304
		Bob Turner
				 Posted: Thu Sep 03, 2009 3:16 pm    Post subject: Re: Window Write-Up |
				A little trick passed on to me from Dave Head, who may have heard it from someone else, is to put the container of mixed weld-on in a tray of ice water. This will extend the working time a bit. (The stuff in the container cures faster than the stuff which has been spread on the windows, due to the build up of heat).
  _________________ Bob Turner
RV-10 QB |
				 Posted: Thu Sep 03, 2009 4:05 pm    Post subject: Window Write-Up |
				Is there any reason not to just use Scotch Weld 2216 instead of Weld-on 10?
 I used this for the control surface tailing edges and like the product.
 Carl Froehlich
		johngoodman
				 Posted: Mon Sep 07, 2009 4:56 pm    Post subject: Re: Window Write-Up |
				Carl,
 I'm not versed on the Scotch product, but I can guarantee you that I will never use Weld On again. Nastiest product I have used in a long time.
 John
  _________________ #40572 Phase One complete in 2011 |
		daveleikam(at)wi.rr.com Guest
				 Posted: Mon Sep 07, 2009 7:36 pm    Post subject: Window Write-Up |
				Any crazing?  Is one cartridge enough for one window?
 Dave Leikam
 RV-10 #40496
 N89DA
 Muskego, WI
