jeff(at)westcottpress.com Guest
Posted: Wed Sep 02, 2009 10:36 pm Post subject: Window Write-Up |
As you may know, I attempted to install my left side door window last
week with somewhat disastrous results. As best I can tell, my shop
was too hot (about 85 degrees) and the Weld-on 10 set up too quickly.
The bond to the fiberglass was perfect, but I had voids between the
window and the dried Weld-on 10 in over half of the bonding area. I
had also failed to remove the masking tape from the inside of the
window soon enough and had a fair amount of masking tape trapped by
the Weld-on bead.
My initial thought was to try to save the window by injecting epoxy
into the gaps (as some have done with apparent success), but after
discussions with Vans, the window manufacturer and tech support by the
makers of Weld-on 10, I decided to route out the window and start
over. There are some things I learned from these discussions that are
worth sharing.
Vans was not willing to say that the injected epoxy approach would
work and referred me to the window manufacturer, Jeff from Airplane
Plastics in Ohio. Jeff spent a good deal of time with me on the
phone. He initially thought the injected epoxy idea might work and
suggested I use Scotch Weld 2216 to accomplish the task. As we
discussed the situation further, I was able to communicate that what
we were really trying to do in this case was bond the window to the
dried Weld-on 10... not the window to the fiberglass. He thought that
could still work... as long as I could scuff up the Weld-on 10!
So, I was back to square one. We started to discuss alternatives to
Weld-on 10 for window installation. He confessed that it had been a
long time since he had actually installed a window... then recollected
that the windows would pop out during the structural roll over test on
the RV-10 until Vans switched to Weld-on 10 to bond them in. With
Weld-on 10, the window would break before the bond would. As I
understood the conversation, Weld-on 10 was an important component of
the plane passing the test. This made my decision to start over again
certain.
With that, Jeff suggested I route it out with an Onsrud carbide double
flute 1/2" x 1/2" bit (I wound up using a similar bit I had in my
router and it worked well), I said good bye and ponied up the $150 to
Vans for another window.
I also made a call to tech support at IPS, the makers of Weld-on 10,
hoping to find another product that would stay open longer. Here's
what I learned:
Weld-on 10 stays open the longest of any product they have for this
application
At 70 degrees, there should be 15-20 minutes of time to get the job
done (I had about 5 minutes at 85 degrees)
Be certain you are using product less than one year from the
manufacture date as the working time decreases with age
They do make a dispensing gun that mixes while dispensing for $300-
$400. Weld-on 10 is packed in to a cartridge for this purpose and
called Weld-on 811.
I've also combed through the archives and had I done that sooner might
have avoided some of these problems. Both Lew Gallagher and John
Gonzalez had very useful posts (hindsight is 20/20) in early January
of this year.
I'm going to wait until the fires in our local mountains have stopped
burning and I'm able to keep the temperature in the shop at or below
70 degrees before I try again. I'll get a second set of hands to
spread the Weld-on 10 more quickly and be sure to pull up the masking
tape once the window is down securely. The gun seems a bit pricey and
I imagine I can find a way to spread the Weld-on 10 quickly and
accurately without too much effort or expense.
Jeff Carpenter
40304
one step forward... two steps back
Posted: Thu Sep 03, 2009 5:15 am Post subject: Window Write-Up |
I imagine I can find a way to spread the Weld-on 10 quickly and accurately
Jeff- with two people doing this you should be fine. I had my wife spread
the weld-on on the window while I spread a small bead on the door. We had
one person hold the window in place and used retainers drilled into the
canopy to hold the windows flush. than started removing the tape on the
inside first, finishing with having the exterior tape removed.
just make sure you remove the excess Weldon with a stick before removing any
tape. It really can be done all within 20 minutes- at least in the late fall
it can, when the temps are in the 70's.
Pascal
Sent: Wednesday, September 02, 2009 11:34 PM
Subject: Window Write-Up
week with somewhat disastrous results. As best I can tell, my shop was
too hot (about 85 degrees) and the Weld-on 10 set up too quickly. The
bond to the fiberglass was perfect, but I had voids between the window
and the dried Weld-on 10 in over half of the bonding area. I had also
failed to remove the masking tape from the inside of the window soon
enough and had a fair amount of masking tape trapped by the Weld-on bead.
My initial thought was to try to save the window by injecting epoxy into
the gaps (as some have done with apparent success), but after discussions
with Vans, the window manufacturer and tech support by the makers of
Weld-on 10, I decided to route out the window and start over. There are
some things I learned from these discussions that are worth sharing.
Vans was not willing to say that the injected epoxy approach would work
and referred me to the window manufacturer, Jeff from Airplane Plastics
in Ohio. Jeff spent a good deal of time with me on the phone. He
initially thought the injected epoxy idea might work and suggested I use
Scotch Weld 2216 to accomplish the task. As we discussed the situation
further, I was able to communicate that what we were really trying to do
in this case was bond the window to the dried Weld-on 10... not the
window to the fiberglass. He thought that could still work... as long as
Weld-on 10 for window installation. He confessed that it had been a long
time since he had actually installed a window... then recollected that
the windows would pop out during the structural roll over test on the
RV-10 until Vans switched to Weld-on 10 to bond them in. With Weld-on
10, the window would break before the bond would. As I understood the
conversation, Weld-on 10 was an important component of the plane passing
the test. This made my decision to start over again certain.
flute 1/2" x 1/2" bit (I wound up using a similar bit I had in my router
and it worked well), I said good bye and ponied up the $150 to Vans for
another window.
hoping to find another product that would stay open longer. Here's what
I learned:
application
At 70 degrees, there should be 15-20 minutes of time to get the job done
Be certain you are using product less than one year from the manufacture
They do make a dispensing gun that mixes while dispensing for $300- $400.
Weld-on 10 is packed in to a cartridge for this purpose and called
Weld-on 811.
Gonzalez had very useful posts (hindsight is 20/20) in early January of
this year.
burning and I'm able to keep the temperature in the shop at or below 70
degrees before I try again. I'll get a second set of hands to spread the
Weld-on 10 more quickly and be sure to pull up the masking tape once the
window is down securely. The gun seems a bit pricey and I imagine I can
find a way to spread the Weld-on 10 quickly and accurately without too
Jeff Carpenter
40304
kearney
Posted: Thu Sep 03, 2009 5:23 am Post subject: Window Write-Up |
Hi Jeff
Thanks for the detailed post - I find the posts about how builders solved
problems the most informative of all.
I still have windows to do and have been considering Silpruf as an
alternative to Weldon. Fortunately I don't have to make a decision until
spring when it will be cool.
Do you know if Weldon can be applied effectively at lower temperatures? And
if so how does this impact the cure time? Is too long a cure time a problem?
Do you have any pix of how you routed out the window?
Cheers
Les
#40643 - living in a f/g world
aerosport1
Posted: Thu Sep 03, 2009 6:16 am Post subject: Window Write-Up |
Jeff I used a urethane adhesive to install my windows. It had a 20 min
working time and was easy to clean up and it did not run like weld-on. I
also did a test against weld-on and this held better. I am not flying the
airplane yet but it was a much easier task then the weld-on. The other nice
thing about it was that you can clean the inside edges very good with a PPG
reducer DT870. It is for urethane paints and will not hurt the window in any
way but does clean the urethane very easily. This material is off white and
can be tinted if needed. You would need to use a urethane base tint. It is a
little more flexible than the Weld-on which
Should be an advantage for the different substrates that are being glued
together. Time will tell how it will hold up but so far it has worked out
great. My airplane is painted and a month or so from flying. I used this on
all windows. Give me a call if you would like to discuss further. As far as
I am concerned this is the best solutions for gluing the windows in. I know
one thing is that they will not come out. This urethane has a incredible
bond. We just used it on some samples for a project to butt glue 1/2"
acrylic to each other. We tried to break it and could not.
Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
glastar(at)gmx.net Guest
Posted: Thu Sep 03, 2009 7:21 am Post subject: Window Write-Up |
Geoff any brand/type of urethan you've used?
br Werner
Geoff
Geoff Combs
President
614-834-5227p
614-834-5230f
aerosport1
Posted: Thu Sep 03, 2009 7:52 am Post subject: Window Write-Up |
I used Lord 7542 urethane adhesive
Geoff
Sent from my iPhone Geoff
br Werner
> min
> on. I
> flying the
> other nice
> with a PPG
> window in any
> white and
> tint. It is a
> glued
> worked out
> this on
> As far as
> in. I know
> incredible
> Geoff
> Geoff Combs
> President
> 8090 Howe Industrial Parkway Canal Winchester, Ohio 43110
> 614-834-5227p
> 614-834-5230f
RV-10 QB N829GW
Flying 500 hrs
40033 |
aerosport1
Posted: Thu Sep 03, 2009 8:46 am Post subject: Window Write-Up |
Sorry guys the material I used was 7545 a/c. The 7542 is the same
material but a little thinner and greenish tan in color. The 7545 has
a higher viscosity and does not run. They have different cure times as
well.
They have a 7545 a/e which is slower yet.
Geoff
On Sep 3, 2009, at 11:48 AM, Geoff <g.combs(at)aerosportmodeling.com>
Geoff
> br Werner
>> min
>> on. I
>> flying the
>> other nice
>> with a PPG
>> window in any
>> white and
>> tint. It is a
>> glued
>> worked out
>> used this on
>> As far as
>> in. I know
>> incredible
>> 1/2"
>> Geoff
>> Geoff Combs
>> President
>> 614-834-5227p
>> 614-834-5230f
RV-10 QB N829GW
Flying 500 hrs
40033 |
Posted: Thu Sep 03, 2009 10:23 am Post subject: Window Write-Up |
Well evaluated and thought out. This will surely lead to a much better C engineered result the second time.
I guess this is exactly what the building process is all about C albiet very frustrating. If only everyone's mind would work this way C the cars and other products in this world would be all the much better.
Good science
Keep pluggin away.
| Quote: | From: jeff(at)westcottpress.com
Date: Wed C 2 Sep 2009 23:34:45 -0700
--> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com>
As you may know C I attempted to install my left side door window last
week with somewhat disastrous results. As best I can tell C my shop
The bond to the fiberglass was perfect C but I had voids between the
the Weld-on bead.
into the gaps (as some have done with apparent success) C but after
discussions with Vans C the window manufacturer and tech support by the
makers of Weld-on 10 C I decided to route out the window and start
worth sharing.
work and referred me to the window manufacturer C Jeff from Airplane
discussed the situation further C I was able to communicate that what
So C I was back to square one. We started to discuss alternatives to
Weld-on 10 C the window would break before the bond would. As I
understood the conversation C Weld-on 10 was an important component of
certain.
With that C Jeff suggested I route it out with an Onsrud carbide double
router and it worked well) C I said good bye and ponied up the $150 to
I also made a call to tech support at IPS C the makers of Weld-on 10 C
what I learned:
application
At 70 degrees C there should be 15-20 minutes of time to get the job
called Weld-on 811.
of this year.
Jeff Carpenter
40304
Bob Turner
Posted: Thu Sep 03, 2009 3:16 pm Post subject: Re: Window Write-Up |
A little trick passed on to me from Dave Head, who may have heard it from someone else, is to put the container of mixed weld-on in a tray of ice water. This will extend the working time a bit. (The stuff in the container cures faster than the stuff which has been spread on the windows, due to the build up of heat).
_________________ Bob Turner
RV-10 QB |
Posted: Thu Sep 03, 2009 4:05 pm Post subject: Window Write-Up |
Is there any reason not to just use Scotch Weld 2216 instead of Weld-on 10?
I used this for the control surface tailing edges and like the product.
Carl Froehlich
johngoodman
Posted: Mon Sep 07, 2009 4:56 pm Post subject: Re: Window Write-Up |
Carl,
I'm not versed on the Scotch product, but I can guarantee you that I will never use Weld On again. Nastiest product I have used in a long time.
daveleikam(at)wi.rr.com Guest
Posted: Mon Sep 07, 2009 7:36 pm Post subject: Window Write-Up |
Any crazing? Is one cartridge enough for one window?
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
